    3. Einsteigerfragen
    4. Installation
    5. Adapter aktualisieren
      Thomas Braun Most Active @lamo1966 last edited by
      @lamo1966
      Ja, immer zeilenweise einzeln.
        lamo1966 @Thomas Braun last edited by lamo1966
        @thomas-braun said in Adapter aktualisieren:
        @lamo1966
        iob update
        al@Raspberry:~ $ al@Raspberry:~ $ iob update
        Used repository: stable
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 8.3.1    , installed 6.1.4  [Updatable]
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
        Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
        Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        iob upgrade
        al@Raspberry:~ $ iob upgrade
        This upgrade of "trashschedule" will introduce the following changes:
        -> 3.3.0:
        NodeJS >= 18.x and js-controller >= 5 is required
        * Improved error reporting / log messages
        * Fixed translations
        * Added Abfall+ as Webservice
        Would you like to upgrade trashschedule from @3.2.0 to @3.3.0 now? [(y)es, (n)o]:
        Y oder?
        und die nächsten auch
          @lamo1966
          Ja, alles aktualisieren.
            @lamo1966
            da gehts nicht weiter, nachdem ich y eingegeben hab
            Would you like to upgrade trashschedule from @3.2.0 to @3.3.0 now? [(y)es, (n)o]: ^Cy
            Update trashschedule from @3.2.0 to @3.3.0
            NPM version: 10.7.0
            Installing iobroker.trashschedule@3.3.0... (System call)
            al@Raspberry:~ $
            • DJMarc75
              DJMarc75 @lamo1966 last edited by
              @lamo1966 sagte in Adapter aktualisieren:
              hast Du ja auch nicht
              ^Cy
                lamo1966 @DJMarc75 last edited by
                @djmarc75 said in Adapter aktualisieren:
                ^Cy
                danke für den Hinweis, das kommt immer, wenn ich eine Copy vom Text machen will
                Thomas Braun L Homoran 3 Replies Last reply Reply Quote 0
                  @lamo1966
                  iob stop
                  sudo reboot
                  Und wenn die Kiste wieder oben ist mal ein
                  iob diag
                  zum Besten geben.
                    lamo1966 @lamo1966 last edited by
                    @Thomas-Braun
                    jetzt heisst es
                    This upgrade of "shelly" will introduce the following changes:
                    -> 7.0.0:
                    * Added Shelly 1 Mini (Gen3)
                    * Added Shelly 1 PM Mini (Gen3)
                    * Added Shelly PM Mini (Gen3)
                    * Added Shelly Pro Dimmer 1 PM and Pro Dimmer 2 PM
                    * Fixed Shelly Wall Display integration
                    * Added device list of ble events (receivedBy) - removed rssi state
                    * Added Switch Addon for Shelly Pro 3 EM
                    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                    Would you like to upgrade shelly from @6.9.0 to @7.0.0 now? [(y)es, (n)o]:
                    Machen ?
                      @lamo1966
                      Ja, natürlich.
                                                v.2024-05-22
                           Static hostname: Raspberry
                                 Icon name: computer
                          Operating System: Debian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.1.21-v8+
                              Architecture: arm64
                        Installation:           native
                        Kernel:                 aarch64
                        Userland:               64 bit
                        Timezone:               Europe/Berlin (CEST, +0200)
                        User-ID:                1000
                        Display-Server:         false
                        Boot Target:            multi-user.target
                        Pending OS-Updates:     0
                        Pending iob updates:    0
                        Nodejs-Installation:
                        /usr/bin/nodejs         v20.15.0
                        /usr/bin/node           v20.15.0
                        /usr/bin/npm            10.7.0
                        /usr/bin/npx            10.7.0
                        /usr/bin/corepack       0.28.1
                        Recommended versions are nodejs 18.20.3 and npm 10.7.0
                        MEMORY:
                        Mem:            3.8G        976M        2.1G        1.0M        765M        2.8G
                        Swap:            99M          0B         99M
                        Total:          3.9G        976M        2.2G
                        Active iob-Instances:   16
                        Active repo(s): stable
                        ioBroker Core:          js-controller           5.0.19
                                                admin                   6.13.16
                        Objects type: jsonl
                        States  type: jsonl
                        + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects:                1506
                        States:                 1248
                        Size of iob-Database:
                        25M     /opt/iobroker/iobroker-data/objects.jsonl
                        5.3M    /opt/iobroker/iobroker-data/states.jsonl
                        === Mark text until here for copying ===
                          @lamo1966
                          Die Zusammenfassung schaut gut aus.
                            das war der Anfang
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Model           : Raspberry Pi 4 Model B Rev 1.5
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             16:47:48 up 7 min,  2 users,  load average: 0.68, 1.04, 0.61
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            *** Time and Time Zones ***
                                           Local time: Sat 2024-06-22 16:47:49 CEST
                                       Universal time: Sat 2024-06-22 14:47:49 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            al
                            HOME=/home/al
                            GROUPS=al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                            *** Display-Server-Setup ***
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        977M        2.0G        1.0M        766M        2.8G
                            Swap:            99M          0B         99M
                            Total:          3.9G        977M        2.2G
                                     3794 M total memory
                                      977 M used memory
                                     1171 M active memory
                                      432 M inactive memory
                                     2050 M free memory
                                       62 M buffer memory
                                      703 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 16:47:49 up 7 min,  2 users,  load average: 0.68, 1.04, 0.61
                            Tasks: 183 total,   1 running, 182 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3794.3 total,   2049.8 free,    978.2 used,    766.4 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2756.8 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G   11G   17G  40% /
                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                            tmpfs          tmpfs     759M  1.2M  758M   1% /run
                            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                            [Sat Jun 22 16:40:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [Sat Jun 22 16:40:06 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sat Jun 22 16:40:06 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Sat Jun 22 16:40:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            Show mounted filesystems:
                            TARGET                       SOURCE         FSTYPE     OPTIONS
                            /                            /dev/mmcblk0p2 ext4       rw,noatime
                            |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=1678472k,nr_inodes=419618,mode=755
                            | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
                            | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                            | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
                            |-/proc                      proc           proc       rw,relatime
                            | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                            |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                            | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                            | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
                            | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
                            |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
                            | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                            | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
                            | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
                            `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            3.9G    /var/
                            2.9G    /var/log/journal/20caf098a3be48108459316835c16c60
                            2.9G    /var/log
                            692M    /var/cache
                            Archived and active journals take up 2.8G in the file system.
                            /opt/iobroker/backups:
                            70M     /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            654M    /opt/iobroker/iobroker-data/
                            408M    /opt/iobroker/iobroker-data/files
                            138M    /opt/iobroker/iobroker-data/files/javascript.admin
                            136M    /opt/iobroker/iobroker-data/history
                            118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                            24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                            23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            *** NodeJS-Installation ***
                            /usr/bin/npm            10.7.0
                            /usr/bin/npx            10.7.0
                            nodejs:
                              Installed: 20.15.0-1nodesource1
                              Candidate: 20.15.0-1nodesource1
                              Version table:
                             *** 20.15.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                    100 /var/lib/dpkg/status
                                 20.14.0-1nodesource1 1001
                                 20.13.1-1nodesource1 1001
                                 20.13.0-1nodesource1 1001
                                 20.12.2-1nodesource1 1001
                                 20.12.1-1nodesource1 1001
                                 20.12.0-1nodesource1 1001
                                 20.11.1-1nodesource1 1001
                                 20.11.0-1nodesource1 1001
                                 20.10.0-1nodesource1 1001
                                 20.9.0-1nodesource1 1001
                                 20.8.1-1nodesource1 1001
                                 20.8.0-1nodesource1 1001
                                 20.7.0-1nodesource1 1001
                                 20.6.1-1nodesource1 1001
                                 20.6.0-1nodesource1 1001
                                 20.5.1-1nodesource1 1001
                                 20.5.0-1nodesource1 1001
                                 20.4.0-1nodesource1 1001
                                 20.3.1-1nodesource1 1001
                                 20.3.0-1nodesource1 1001
                                 20.2.0-1nodesource1 1001
                                 20.1.0-1nodesource1 1001
                                 20.0.0-1nodesource1 1001
                                 12.22.12~dfsg-1~deb11u4 500
                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  5.0.19
                            admin:          6.13.16
                            javascript:     8.3.1
                            nodejs modules from github:     0
                            Adapter State
                              system.adapter.alias-manager.0          : alias-manager         : Raspberry                                -  enabled
                            + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
                            + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
                            + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
                            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberry                                -  enabled
                            + system.adapter.energiefluss.0           : energiefluss          : Raspberry                                -  enabled
                            + system.adapter.history.0                : history               : Raspberry                                -  enabled
                              system.adapter.influxdb.0               : influxdb              : Raspberry                                - disabled, port: 8086
                            + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
                            + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
                            + system.adapter.modbus.0                 : modbus                : Raspberry                                -  enabled
                              system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                - disabled
                            + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.sonoff.0                 : sonoff                : Raspberry                                -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.sourceanalytix.0         : sourceanalytix        : Raspberry                                -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            Installed ioBroker-Instances
                            Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                            Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                            Objects and States
                            Objects:        1506
                            States:         1248
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 https://apt.grafana.com stable InRelease
                            Hit:3 https://repos.influxdata.com/debian stable InRelease
                            Hit:4 http://deb.debian.org/debian bullseye InRelease
                            Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15643      570/vncserver-x11-c
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17019      1674/io.shelly.0
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16249      1706/io.sonoff.0
                            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        13811      546/influxd
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16119      932/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14061      932/iobroker.js-con
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11258      529/cupsd
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15620      580/sshd: /usr/sbin
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16171      1525/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15005      1751/io.web.0
                            tcp6       0      0 :::8086                 :::*                    LISTEN      116        15940      546/influxd
                            tcp6       0      0 :::5900                 :::*                    LISTEN      0          15642      570/vncserver-x11-c
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11257      529/cupsd
                            tcp6       0      0 :::3000                 :::*                    LISTEN      117        14810      540/grafana
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          15622      580/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14519      497/dhcpcd
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16400      602/cups-browsed
                            udp        0      0 0.0.0.0:54466           0.0.0.0:*                           108        13722      390/avahi-daemon: r
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13720      390/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          14547      497/dhcpcd
                            udp6       0      0 :::37421                :::*                                108        13723      390/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        13721      390/avahi-daemon: r
                            2024-06-22 16:41:29.325  - error: sourceanalytix.0 (1798) Initialization of alias.0.Photovoltaik.Zaehler.DVES_88D1F8 DWS7420  energy.DWS7420_energy failed, check warn messages !
                            2024-06-22 16:41:29.326  - info: sourceanalytix.0 (1798) Initialising (8 of 8) "alias.0.Photovoltaik.SMAx.Gesamtertrag in kWh.30531_total_eingespeiste_AC-Energie_auf_allen_Außenleitern"
                            2024-06-22 16:41:30.200  - info: energiefluss.0 (1813) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.15.0, js-controller: 5.0.19
                            2024-06-22 16:41:30.236  - info: energiefluss.0 (1813) Starting Energiefluss Adapter
                            2024-06-22 16:41:30.394  - info: energiefluss.0 (1813) Adapter started and listening to 6 States
                            2024-06-22 16:41:30.729  - info: sourceanalytix.0 (1798) Initialization of alias.0.Photovoltaik.SMAx.Gesamtertrag in kWh.30531_total_eingespeiste_AC-Energie_auf_allen_Außenleitern successfully
                            2024-06-22 16:41:30.738  - warn: sourceanalytix.0 (1798) Cannot handle calculations for 5 of 8 enabled states, check error messages
                            2024-06-22 16:41:30.739  - info: sourceanalytix.0 (1798) Successfully activated SourceAnalytix for 3 of 8 states, will do my Job until you stop me!
                            2024-06-22 16:41:32.020  - info: host.Raspberry instance system.adapter.energiefluss-erweitert.0 started with pid 1828
                            2024-06-22 16:41:32.529  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplug-s-4022D889A3CA" connected!
                            2024-06-22 16:41:34.165  - info: energiefluss-erweitert.0 (1828) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.15.0, js-controller: 5.0.19
                            2024-06-22 16:41:34.256  - info: energiefluss-erweitert.0 (1828) Adapter started. Loading config!
                            2024-06-22 16:41:34.363  - info: energiefluss-erweitert.0 (1828) Configuration loaded!
                            2024-06-22 16:41:34.364  - info: energiefluss-erweitert.0 (1828) Requesting the following states: energiefluss-erweitert.0.configuration
                            2024-06-22 16:41:41.305  - info: shelly.0 (1674) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
                            2024-06-22 16:41:41.989  - info: sourceanalytix.0 (1798) Updating SourceAnalytix configuration for : shelly.0.SHEM#244CAB418C05#1.Emeter0.Power
                            2024-06-22 16:41:55.580  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
                            2024-06-22 16:42:36.432  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                            2024-06-22 16:42:41.050  - info: shelly.0 (1674) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                            2024-06-22 16:43:14.183  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                            2024-06-22 16:43:18.204  - info: shelly.0 (1674) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                            2024-06-22 16:47:40.742  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                            2024-06-22 16:47:44.478  - info: shelly.0 (1674) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                            2024-06-22 16:48:18.230  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                            2024-06-22 16:48:21.958  - info: shelly.0 (1674) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                              @lamo1966
                              Ja, passt.
                              Künftig das System regelmäßig updaten.
                              Sowohl Betriebssystem wie auch den ioBroker mit allen Bestandteilen.
                                herzlichen Dank, du bist der Wahnsinn.
                                Die letzte Stunde hat mich Tage meines Lebens gekostet.👍
                                  Homoran Global Moderator Administrators @lamo1966 last edited by
                                  warum?
                                  machst du STRG-c?
                                  nur markieren! Das reicht, dann ist es in der Zwischenablage. STRG-C bricht die Ausführung des laufenden Befehls ab.
                                  Frag mal Thomas! 😁
                                  • DJMarc75
                                    Die letzte Stunde hat Dir Tage Deines Lebens gerettet !
                                      lamo1966 @Homoran last edited by lamo1966
                                      @homoran said in Adapter aktualisieren:
                                      muss man halt wissen
                                      Frag mal Thomas!
                                        da hast du ganz sicher Recht
                                          lamo1966 last edited by lamo1966
                                          ich weiss nicht so recht, wo ich die Frage stellen darf.
                                          Nachdem ich gestern ja mit eurer Hilfe mein System aktualisiert habe, stell ich mir die Frage, was eigentlich passiert, wenn mein Raspi plötzlich defekt ist.
                                          Werden die Adapter, Scripts, echarts, etc....in dem Backitup abgespeichert?
                                          Muss ich den Raspi erst wieder bereit machen (Linux), dann den iobroker wieder installieren, etc. oder gibt es eine Möglichkeit das einfacher - vor allem für Anfänger - zu machen.
                                          War nämlich ein ziemlicher Akt für mich, den Raspi soweit herzurichten, dass der iobroker drauf läuft.
                                            Thomas Braun Most Active @lamo1966 last edited by Thomas Braun
                                            Werden die Adapter, Scripts, echarts, etc....in dem Backup abgespeichert?
                                            Ja, das ist der Zweck von Backups.
                                            Muss ich den Raspi erst wieder bereit machen, dann den iobroker wieder installieren, etc. oder gibt es eine Möglichkeit das einfacher - vor allem für Anfänger - zu machen.
                                            Das ist doch einfach?
                                            Einfacher als so geht es meiner Meinnung nach nicht:
                                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                            5348
