    3. Einsteigerfragen
    4. Installation
    5. Adapter aktualisieren
    • DJMarc75
      DJMarc75 @lamo1966 last edited by
      @lamo1966 sagte in Adapter aktualisieren:
      da gehts nicht weiter, nachdem ich y eingegeben hab
      hast Du ja auch nicht
      ^Cy
        lamo1966 @DJMarc75 last edited by
        @djmarc75 said in Adapter aktualisieren:
        ^Cy
        danke für den Hinweis, das kommt immer, wenn ich eine Copy vom Text machen will
        Thomas Braun L Homoran 3 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @lamo1966 last edited by
          @lamo1966
          iob stop
          sudo reboot
          Und wenn die Kiste wieder oben ist mal ein
          iob diag
          zum Besten geben.
            lamo1966 @lamo1966 last edited by
            @Thomas-Braun
            jetzt heisst es
            This upgrade of "shelly" will introduce the following changes:
            -> 7.0.0:
            NodeJS >= 18.x and js-controller >= 5 is required
            * Added Shelly 1 Mini (Gen3)
            * Added Shelly 1 PM Mini (Gen3)
            * Added Shelly PM Mini (Gen3)
            * Added Shelly Pro Dimmer 1 PM and Pro Dimmer 2 PM
            * Fixed Shelly Wall Display integration
            * Added device list of ble events (receivedBy) - removed rssi state
            * Added Switch Addon for Shelly Pro 3 EM
            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
            Would you like to upgrade shelly from @6.9.0 to @7.0.0 now? [(y)es, (n)o]:
            Machen ?
              @lamo1966
              Ja, natürlich.
                lamo1966 @Thomas Braun last edited by
                                        v.2024-05-22
                   Static hostname: Raspberry
                         Icon name: computer
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Installation:           native
                Kernel:                 aarch64
                Userland:               64 bit
                Timezone:               Europe/Berlin (CEST, +0200)
                User-ID:                1000
                Display-Server:         false
                Boot Target:            multi-user.target
                Pending OS-Updates:     0
                Pending iob updates:    0
                Nodejs-Installation:
                /usr/bin/nodejs         v20.15.0
                /usr/bin/node           v20.15.0
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                /usr/bin/corepack       0.28.1
                Recommended versions are nodejs 18.20.3 and npm 10.7.0
                MEMORY:
                Mem:            3.8G        976M        2.1G        1.0M        765M        2.8G
                Swap:            99M          0B         99M
                Total:          3.9G        976M        2.2G
                Active iob-Instances:   16
                Active repo(s): stable
                ioBroker Core:          js-controller           5.0.19
                                        admin                   6.13.16
                Objects type: jsonl
                States  type: jsonl
                + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                Objects:                1506
                States:                 1248
                Size of iob-Database:
                25M     /opt/iobroker/iobroker-data/objects.jsonl
                5.3M    /opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===
                  @lamo1966
                  Die Zusammenfassung schaut gut aus.
                    das war der Anfang
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.5
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     16:47:48 up 7 min,  2 users,  load average: 0.68, 1.04, 0.61
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Sat 2024-06-22 16:47:49 CEST
                               Universal time: Sat 2024-06-22 14:47:49 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    al
                    HOME=/home/al
                    GROUPS=al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                    *** Display-Server-Setup ***
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        977M        2.0G        1.0M        766M        2.8G
                    Swap:            99M          0B         99M
                    Total:          3.9G        977M        2.2G
                             3794 M total memory
                              977 M used memory
                             1171 M active memory
                              432 M inactive memory
                             2050 M free memory
                               62 M buffer memory
                              703 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    top - 16:47:49 up 7 min,  2 users,  load average: 0.68, 1.04, 0.61
                    Tasks: 183 total,   1 running, 182 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3794.3 total,   2049.8 free,    978.2 used,    766.4 buff/cache
                    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2756.8 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/root      ext4       29G   11G   17G  40% /
                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                    tmpfs          tmpfs     759M  1.2M  758M   1% /run
                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                    [Sat Jun 22 16:40:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Sat Jun 22 16:40:06 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Sat Jun 22 16:40:06 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Sat Jun 22 16:40:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    Show mounted filesystems:
                    TARGET                       SOURCE         FSTYPE     OPTIONS
                    /                            /dev/mmcblk0p2 ext4       rw,noatime
                    |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=1678472k,nr_inodes=419618,mode=755
                    | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
                    | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                    | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
                    |-/proc                      proc           proc       rw,relatime
                    | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                    |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
                    | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
                    | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                    | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
                    | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                    | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
                    | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
                    | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
                    | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
                    |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
                    | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                    | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
                    | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
                    `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    3.9G    /var/
                    2.9G    /var/log/journal/20caf098a3be48108459316835c16c60
                    2.9G    /var/log
                    692M    /var/cache
                    Archived and active journals take up 2.8G in the file system.
                    /opt/iobroker/backups:
                    70M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    654M    /opt/iobroker/iobroker-data/
                    408M    /opt/iobroker/iobroker-data/files
                    138M    /opt/iobroker/iobroker-data/files/javascript.admin
                    136M    /opt/iobroker/iobroker-data/history
                    118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                    USB-Devices by-id:
                    No Devices found 'by-id'
                    *** NodeJS-Installation ***
                    /usr/bin/npm            10.7.0
                    /usr/bin/npx            10.7.0
                    nodejs:
                      Installed: 20.15.0-1nodesource1
                      Candidate: 20.15.0-1nodesource1
                      Version table:
                     *** 20.15.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                            100 /var/lib/dpkg/status
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         12.22.12~dfsg-1~deb11u4 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.19
                    admin:          6.13.16
                    javascript:     8.3.1
                    nodejs modules from github:     0
                    Adapter State
                      system.adapter.alias-manager.0          : alias-manager         : Raspberry                                -  enabled
                    + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
                    + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
                    + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberry                                -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : Raspberry                                -  enabled
                    + system.adapter.history.0                : history               : Raspberry                                -  enabled
                      system.adapter.influxdb.0               : influxdb              : Raspberry                                - disabled, port: 8086
                    + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
                    + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
                    + system.adapter.modbus.0                 : modbus                : Raspberry                                -  enabled
                      system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                - disabled
                    + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.sonoff.0                 : sonoff                : Raspberry                                -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : Raspberry                                -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                    Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                    Adapter    "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
                    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                    Adapter    "ws"           : 2.6.1    , installed 2.6.1
                    Objects and States
                    Objects:        1506
                    States:         1248
                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:2 https://apt.grafana.com stable InRelease
                    Hit:3 https://repos.influxdata.com/debian stable InRelease
                    Hit:4 http://deb.debian.org/debian bullseye InRelease
                    Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15643      570/vncserver-x11-c
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17019      1674/io.shelly.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16249      1706/io.sonoff.0
                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        13811      546/influxd
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16119      932/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14061      932/iobroker.js-con
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11258      529/cupsd
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15620      580/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16171      1525/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15005      1751/io.web.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      116        15940      546/influxd
                    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15642      570/vncserver-x11-c
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11257      529/cupsd
                    tcp6       0      0 :::3000                 :::*                    LISTEN      117        14810      540/grafana
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15622      580/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14519      497/dhcpcd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16400      602/cups-browsed
                    udp        0      0 0.0.0.0:54466           0.0.0.0:*                           108        13722      390/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13720      390/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          14547      497/dhcpcd
                    udp6       0      0 :::37421                :::*                                108        13723      390/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        13721      390/avahi-daemon: r
                    2024-06-22 16:41:29.325  - error: sourceanalytix.0 (1798) Initialization of alias.0.Photovoltaik.Zaehler.DVES_88D1F8 DWS7420  energy.DWS7420_energy failed, check warn messages !
                    2024-06-22 16:41:29.326  - info: sourceanalytix.0 (1798) Initialising (8 of 8) "alias.0.Photovoltaik.SMAx.Gesamtertrag in kWh.30531_total_eingespeiste_AC-Energie_auf_allen_Außenleitern"
                    2024-06-22 16:41:30.200  - info: energiefluss.0 (1813) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.15.0, js-controller: 5.0.19
                    2024-06-22 16:41:30.236  - info: energiefluss.0 (1813) Starting Energiefluss Adapter
                    2024-06-22 16:41:30.394  - info: energiefluss.0 (1813) Adapter started and listening to 6 States
                    2024-06-22 16:41:30.729  - info: sourceanalytix.0 (1798) Initialization of alias.0.Photovoltaik.SMAx.Gesamtertrag in kWh.30531_total_eingespeiste_AC-Energie_auf_allen_Außenleitern successfully
                    2024-06-22 16:41:30.738  - warn: sourceanalytix.0 (1798) Cannot handle calculations for 5 of 8 enabled states, check error messages
                    2024-06-22 16:41:30.739  - info: sourceanalytix.0 (1798) Successfully activated SourceAnalytix for 3 of 8 states, will do my Job until you stop me!
                    2024-06-22 16:41:32.020  - info: host.Raspberry instance system.adapter.energiefluss-erweitert.0 started with pid 1828
                    2024-06-22 16:41:32.529  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplug-s-4022D889A3CA" connected!
                    2024-06-22 16:41:34.165  - info: energiefluss-erweitert.0 (1828) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.15.0, js-controller: 5.0.19
                    2024-06-22 16:41:34.256  - info: energiefluss-erweitert.0 (1828) Adapter started. Loading config!
                    2024-06-22 16:41:34.363  - info: energiefluss-erweitert.0 (1828) Configuration loaded!
                    2024-06-22 16:41:34.364  - info: energiefluss-erweitert.0 (1828) Requesting the following states: energiefluss-erweitert.0.configuration
                    2024-06-22 16:41:41.305  - info: shelly.0 (1674) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
                    2024-06-22 16:41:41.989  - info: sourceanalytix.0 (1798) Updating SourceAnalytix configuration for : shelly.0.SHEM#244CAB418C05#1.Emeter0.Power
                    2024-06-22 16:41:55.580  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
                    2024-06-22 16:42:36.432  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                    2024-06-22 16:42:41.050  - info: shelly.0 (1674) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                    2024-06-22 16:43:14.183  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                    2024-06-22 16:43:18.204  - info: shelly.0 (1674) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                    2024-06-22 16:47:40.742  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                    2024-06-22 16:47:44.478  - info: shelly.0 (1674) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                    2024-06-22 16:48:18.230  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                    2024-06-22 16:48:21.958  - info: shelly.0 (1674) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                      @lamo1966
                      Ja, passt.
                      Künftig das System regelmäßig updaten.
                      Sowohl Betriebssystem wie auch den ioBroker mit allen Bestandteilen.
                        @thomas-braun said in Adapter aktualisieren:
                        herzlichen Dank, du bist der Wahnsinn.
                        Die letzte Stunde hat mich Tage meines Lebens gekostet.👍
                          Homoran Global Moderator Administrators @lamo1966 last edited by
                          warum?
                          machst du STRG-c?
                          nur markieren! Das reicht, dann ist es in der Zwischenablage. STRG-C bricht die Ausführung des laufenden Befehls ab.
                          Frag mal Thomas! 😁
                          • DJMarc75
                            Die letzte Stunde hat Dir Tage Deines Lebens gerettet !
                              lamo1966 @Homoran last edited by lamo1966
                              @homoran said in Adapter aktualisieren:
                              muss man halt wissen
                              Frag mal Thomas!
                                da hast du ganz sicher Recht
                                  lamo1966 last edited by lamo1966
                                  ich weiss nicht so recht, wo ich die Frage stellen darf.
                                  Nachdem ich gestern ja mit eurer Hilfe mein System aktualisiert habe, stell ich mir die Frage, was eigentlich passiert, wenn mein Raspi plötzlich defekt ist.
                                  Werden die Adapter, Scripts, echarts, etc....in dem Backitup abgespeichert?
                                  Muss ich den Raspi erst wieder bereit machen (Linux), dann den iobroker wieder installieren, etc. oder gibt es eine Möglichkeit das einfacher - vor allem für Anfänger - zu machen.
                                  War nämlich ein ziemlicher Akt für mich, den Raspi soweit herzurichten, dass der iobroker drauf läuft.
                                    Thomas Braun Most Active @lamo1966 last edited by Thomas Braun
                                    Werden die Adapter, Scripts, echarts, etc....in dem Backup abgespeichert?
                                    Ja, das ist der Zweck von Backups.
                                    Muss ich den Raspi erst wieder bereit machen, dann den iobroker wieder installieren, etc. oder gibt es eine Möglichkeit das einfacher - vor allem für Anfänger - zu machen.
                                    Das ist doch einfach?
                                    Einfacher als so geht es meiner Meinnung nach nicht:
                                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                      @lamo1966
                                      Die Übung kannst du gleich schon mal für ein Upgrade des Betriebssystems (spätestens im nächsten Jahr) vormerken.
                                      Läuft im Sommer/Herbst 2025 nämlich aus. Wenn Debian 13 'Trixie' herauskommt.
                                        ja, liest sich einfach, bis es soweit ist 😊 - danke für den Link
                                        Muss jetzt mal sehen, wohin ich das Backup speichere, bis dato wird es nämlich am Raspi abgelegt, was nonsens ist
                                          was nonsens ist
                                          Richtig. Gleich aus mehreren Gründen sind 'Backups' auf dem gleichen Datenträger keine Backups.
                                          Ein 'Spar-NAS' ist oft aber bereits in Form einer FritzBox vorhanden. USB-Stick dran und per CIFS dahin backuppen.
                                          5348
