    3. Einsteigerfragen
    4. Zigbee Adapter nach Stromausfall keine Verbindung (gelöst)
      mrjeschke @stefu87_CH last edited by
      @stefu87_ch
      Das log vom Anfang des Adapterstarts wäre hilfreicher,
      aber vermutlich müssen da die zigbee-Profis ran.
        stefu87_CH @mrjeschke last edited by stefu87_CH
        @mrjeschke sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
        @stefu87_ch
        2024-06-20 20:08:37.797 - info: host.Iobroker instance system.adapter.zigbee.0 started with pid 12801
        2024-06-20 20:08:38.775 - debug: zigbee.0 (12801) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-06-20 20:08:38.817 - debug: zigbee.0 (12801) Objects client ready ... initialize now
        2024-06-20 20:08:38.817 - debug: zigbee.0 (12801) Objects create System PubSub Client
        2024-06-20 20:08:38.818 - debug: zigbee.0 (12801) Objects create User PubSub Client
        2024-06-20 20:08:38.869 - debug: zigbee.0 (12801) Objects client initialize lua scripts
        2024-06-20 20:08:38.872 - debug: zigbee.0 (12801) Objects connected to redis: 127.0.0.1:9001
        2024-06-20 20:08:38.873 - silly: zigbee.0 (12801) redis psubscribe cfg.o.system.user.*
        2024-06-20 20:08:38.900 - silly: zigbee.0 (12801) redis psubscribe cfg.o.enum.*
        2024-06-20 20:08:38.901 - silly: zigbee.0 (12801) objectDB connected
        2024-06-20 20:08:38.902 - debug: zigbee.0 (12801) Redis States: Use Redis connection: 127.0.0.1:9000
        2024-06-20 20:08:38.921 - debug: zigbee.0 (12801) States create System PubSub Client
        2024-06-20 20:08:38.921 - debug: zigbee.0 (12801) States create User PubSub Client
        2024-06-20 20:08:39.006 - debug: zigbee.0 (12801) States connected to redis: 127.0.0.1:9000
        2024-06-20 20:08:39.006 - silly: zigbee.0 (12801) statesDB connected
        2024-06-20 20:08:39.032 - debug: zigbee.0 (12801) Plugin sentry Initialize Plugin (enabled=true)
        2024-06-20 20:08:39.157 - info: zigbee.0 (12801) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.14.0, js-controller: 5.0.19
        2024-06-20 20:08:39.166 - debug: zigbee.0 (12801) Using zigbee-herdsman with settings: {"network":{"panID":1207,"extendedPanID":[221,141,221,125,229,221,221,211],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00","adapter":"ezsp"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
        2024-06-20 20:08:39.181 - info: zigbee.0 (12801) delete old Backup files. keep only last 10
        2024-06-20 20:08:39.181 - info: zigbee.0 (12801) Starting Zigbee npm ...
        2024-06-20 20:08:39.189 - silly: zigbee.0 (12801) States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1718906919182,"q":0,"from":"system.adapter.zigbee.0","lc":1718297685652}
        2024-06-20 20:08:39.192 - debug: zigbee.0 (12801) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_06_20-20_08_39.tar.gz success
        2024-06-20 20:08:39.259 - debug: zigbee.0 (12801) Starting zigbee-herdsman...
        2024-06-20 20:08:39.339 - info: zigbee.0 (12801) Installed Version: iobroker.zigbee@latest
        2024-06-20 20:08:39.383 - silly: zigbee.0 (12801) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1718906919382,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
        2024-06-20 20:09:09.478 - error: zigbee.0 (12801) Starting zigbee-herdsman problem : "Failure to connect"
        2024-06-20 20:09:09.478 - error: zigbee.0 (12801) Failed to start Zigbee
        2024-06-20 20:09:09.478 - error: zigbee.0 (12801) Error herdsman start
        2024-06-20 20:09:09.561 - silly: zigbee.0 (12801) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Failure to connect\". undefined","ack":true,"ts":1718906949483,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718727323838}
        2024-06-20 20:09:09.562 - silly: zigbee.0 (12801) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1718906949483,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
        2024-06-20 20:09:19.479 - info: zigbee.0 (12801) Try to reconnect. 1 attempts left
        2024-06-20 20:09:19.480 - info: zigbee.0 (12801) Starting Zigbee npm ...
        2024-06-20 20:09:19.481 - debug: zigbee.0 (12801) Starting zigbee-herdsman...
        2024-06-20 20:09:19.483 - info: zigbee.0 (12801) Installed Version: iobroker.zigbee@latest
        2024-06-20 20:09:49.578 - error: zigbee.0 (12801) Starting zigbee-herdsman problem : "Failure to connect"
        2024-06-20 20:09:49.578 - error: zigbee.0 (12801) Failed to start Zigbee
        2024-06-20 20:09:49.578 - error: zigbee.0 (12801) Error herdsman start
        2024-06-20 20:09:49.585 - silly: zigbee.0 (12801) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Failure to connect\". undefined","ack":true,"ts":1718906989584,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718727323838}
        2024-06-20 20:09:49.667 - silly: zigbee.0 (12801) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1718906989666,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
          arteck Developer Most Active @stefu87_CH last edited by
          @stefu87_ch kannst du mal den sonoff neu flashen...
          das wundert mich
            stefu87_CH @arteck last edited by
            @arteck ok, werde das mal versuchen und dann Rückmeldung geben.
              @arteck Habe den Sonoff mit neuer Firmware geflasht, aber ohne Erfolg. Bleibt weitherin gelb.
                Habe es jetzt mal auf meinem Testsystem versucht, ohne da irgendwelche Config Dateien zu ändern sonder direkt einzubinden, aber auch das klappt es nicht.
                  crunchip Forum Testing Most Active @stefu87_CH last edited by
                  @stefu87_ch sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                  mit der Aussage kann dir allerdings auch niemand helfen.
                  Welche Fehlermeldung?
                    stefu87_CH @crunchip last edited by
                    @crunchip
                    2024-06-22 16:16:28.763 - info: host.Iobroker instance system.adapter.zigbee.0 started with pid 23502
                    2024-06-22 16:16:29.687 - debug: zigbee.0 (23502) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2024-06-22 16:16:29.725 - debug: zigbee.0 (23502) Objects client ready ... initialize now
                    2024-06-22 16:16:29.726 - debug: zigbee.0 (23502) Objects create System PubSub Client
                    2024-06-22 16:16:29.726 - debug: zigbee.0 (23502) Objects create User PubSub Client
                    2024-06-22 16:16:29.778 - debug: zigbee.0 (23502) Objects client initialize lua scripts
                    2024-06-22 16:16:29.780 - debug: zigbee.0 (23502) Objects connected to redis: 127.0.0.1:9001
                    2024-06-22 16:16:29.781 - silly: zigbee.0 (23502) redis psubscribe cfg.o.system.user.*
                    2024-06-22 16:16:29.808 - silly: zigbee.0 (23502) redis psubscribe cfg.o.enum.*
                    2024-06-22 16:16:29.809 - silly: zigbee.0 (23502) objectDB connected
                    2024-06-22 16:16:29.810 - debug: zigbee.0 (23502) Redis States: Use Redis connection: 127.0.0.1:9000
                    2024-06-22 16:16:29.828 - debug: zigbee.0 (23502) States create System PubSub Client
                    2024-06-22 16:16:29.828 - debug: zigbee.0 (23502) States create User PubSub Client
                    2024-06-22 16:16:29.903 - debug: zigbee.0 (23502) States connected to redis: 127.0.0.1:9000
                    2024-06-22 16:16:29.903 - silly: zigbee.0 (23502) statesDB connected
                    2024-06-22 16:16:29.928 - debug: zigbee.0 (23502) Plugin sentry Initialize Plugin (enabled=true)
                    2024-06-22 16:16:30.040 - info: zigbee.0 (23502) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.14.0, js-controller: 5.0.19
                    2024-06-22 16:16:30.050 - debug: zigbee.0 (23502) Using zigbee-herdsman with settings: {"network":{"panID":1207,"extendedPanID":[221,141,221,125,229,221,221,211],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"ls /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00","adapter":"ezsp"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                    2024-06-22 16:16:30.064 - info: zigbee.0 (23502) delete old Backup files. keep only last 10
                    2024-06-22 16:16:30.065 - info: zigbee.0 (23502) Starting Zigbee npm ...
                    2024-06-22 16:16:30.073 - silly: zigbee.0 (23502) States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1719065790065,"q":0,"from":"system.adapter.zigbee.0","lc":1718297685652}
                    2024-06-22 16:16:30.077 - debug: zigbee.0 (23502) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_06_22-16_16_30.tar.gz success
                    2024-06-22 16:16:30.147 - debug: zigbee.0 (23502) Starting zigbee-herdsman...
                    2024-06-22 16:16:30.221 - info: zigbee.0 (23502) Installed Version: iobroker.zigbee@latest
                    2024-06-22 16:16:30.264 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1719065790263,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
                    2024-06-22 16:17:00.258 - error: zigbee.0 (23502) Starting zigbee-herdsman problem : "Failure to connect"
                    2024-06-22 16:17:00.259 - error: zigbee.0 (23502) Failed to start Zigbee
                    2024-06-22 16:17:00.259 - error: zigbee.0 (23502) Error herdsman start
                    2024-06-22 16:17:00.343 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Failure to connect\". undefined","ack":true,"ts":1719065820263,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1719059632123}
                    2024-06-22 16:17:00.344 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1719065820343,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
                    2024-06-22 16:17:10.260 - info: zigbee.0 (23502) Try to reconnect. 1 attempts left
                    2024-06-22 16:17:10.260 - info: zigbee.0 (23502) Starting Zigbee npm ...
                    2024-06-22 16:17:10.261 - debug: zigbee.0 (23502) Starting zigbee-herdsman...
                    2024-06-22 16:17:10.262 - info: zigbee.0 (23502) Installed Version: iobroker.zigbee@latest
                    2024-06-22 16:17:40.266 - error: zigbee.0 (23502) Starting zigbee-herdsman problem : "Failure to connect"
                    2024-06-22 16:17:40.267 - error: zigbee.0 (23502) Failed to start Zigbee
                    2024-06-22 16:17:40.267 - error: zigbee.0 (23502) Error herdsman start
                    2024-06-22 16:17:40.273 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Failure to connect\". undefined","ack":true,"ts":1719065860272,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1719059632123}
                    2024-06-22 16:17:40.313 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1719065860312,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
                    • Asgothian
                      Asgothian Developer @stefu87_CH last edited by
                      @stefu87_ch
                      Steckt der Stick in einem usb3 Anschluss ?
                      Nutzt du eine usb Verlängerung ?
                        stefu87_CH @Asgothian last edited by stefu87_CH
                        @asgothian sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                        Nein ist ein USB 2.0 Anschluss
                        Ist direkt eingesteckt
                        • Asgothian
                          @stefu87_ch hast du im Direkten Umfeld etwas via USB3 angeschlossen ? USB3 hat die sehr unangenehme Eigenschaft im Zigbee-Band stören zu können
                          A.
                            @asgothian nein da ist nichts.
                            Bevor ich die umstellung per Direkt USB verbindung gemacht habe, also über die Anpassung der Daten, hat ja alles funktioniert.
                            Das Problem liegt ja daran, das er den Stick nicht erkennt im Zigbee Adapter.
                            • Meister Mopper
                              Meister Mopper @stefu87_CH last edited by Meister Mopper
                              Trotzdem kann es ja jetzt die Hardware sein, probier es aus.
                              Ich hatte schon oft Fehler, die vorher nicht auftraten, obwohl ich nichts geändert hatte. Vielleicht ist es der Nachbar, oder es lag am Fettgehalt der Sonne 🤷‍♂️ .
                                stefu87_CH @Meister Mopper last edited by
                                @meister-mopper Habe auch mit einem anderen Sonoff Stick versucht ohne Erfolg. Auch auf meiner Testumgebung, die im Keller ist, hat sich keiner der beiden Sticks verbunden.
                                Und im Keller ist nichts anderes als der Intel Nuc
                                • Meister Mopper
                                  Ich rede von der Hardware, die mit einer veränderten Umgebung konfrontiert ist.
                                    @meister-mopper Ich wüsste nicht was anderst sein sollte. Es ist nichts dazu gekommen. Es sind ja 2 verschiedene Geräte und auf beiden klappt es nicht.
                                      Habe jetzt mal in der Iobroker Shell das ausgeführt und frage mich, sind da alle Berechtigungen freigegeben?
                                      admin@Iobroker:~$ ls -la /dev/serial/by-id/
                                      total 0
                                      drwxr-xr-x 2 root  root      60 Jun 22 16:56 .
                                      drwxr-xr-x 3 root  root      60 Jun 22 16:56 ..
                                      crw-rw---- 1 admin admin 166, 0 Jun 22 16:56 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
                                        Thomas Braun Most Active @stefu87_CH last edited by Thomas Braun
                                        Da darf nur der user admin und dessen Gruppe was melden. Der iobroker ist aber mit Sicherheit nicht in dieser Gruppe enthalten. Üblich ist sowas:
                                        echad@chet:~ $ ls -la /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
                                        lrwxrwxrwx 1 root root 13 Jun 21 14:43 /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                                        echad@chet:~ $ ls -la /dev/ttyUSB0
                                        crw-rw---- 1 root dialout 188, 0 Jun 22 14:45 /dev/ttyUSB0
                                        echad@chet:~ $
                                        Wie kommt da admin:admin her? Das ist absolut unüblich.
                                        Davon ab liegen in /dev/serial/by-id/ nur Links zu den eigentlichen Geräten drin. Die finden sich dann in /dev/ wieder.
                                          stefu87_CH @Thomas Braun last edited by
                                          @thomas-braun sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                                          Wieso da 2 mal admin drin sind, weiss ich auch nicht, keine Ahnung wie die da rein kommen. Habe ja nichts verändert ausser die Sache mit dem Zigbee Stick.
                                            @stefu87_ch
                                            Das ist ein LXC? Dann ist das falsch durchgereicht worden.
                                            10833
