iobroker startet nicht mehr
@manrum1 sagte in mein 2tes iobroker-system startet nicht mehr, benötige Hilfe:
äh, wie
ääähhh was?
EDIT: Der Herr haben editiert ohne Kennzeichnung!
ersten Post editieren und Titel ändern -
@homoran Danke!
Und hier noch die Langfassung:======== Start marking the full check here ========= Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: iob2 Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 12:14:58 up 17 min, 1 user, load average: 0.34, 0.21, 0.18 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Sun 2024-06-23 12:14:58 CEST Universal time: Sun 2024-06-23 10:14:58 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth gpio i2c User that is running 'js-controller': js-controller is not running *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 1.8G 332M 837M 1.0M 678M 1.4G Swap: 99M 0B 99M Total: 1.9G 332M 937M Active iob-Instances: 0 1849 M total memory 332 M used memory 565 M active memory 315 M inactive memory 837 M free memory 48 M buffer memory 629 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 12:14:59 up 17 min, 1 user, load average: 0.34, 0.21, 0.18 Tasks: 157 total, 1 running, 156 sleeping, 0 stopped, 0 zombie %Cpu(s): 1.4 us, 2.9 sy, 0.0 ni, 94.2 id, 1.4 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 1849.2 total, 837.5 free, 333.2 used, 678.5 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 1439.1 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 7.2G 20G 27% / devtmpfs devtmpfs 667M 0 667M 0% /dev tmpfs tmpfs 925M 0 925M 0% /dev/shm tmpfs tmpfs 370M 1.1M 369M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 31M 225M 13% /boot tmpfs tmpfs 185M 0 185M 0% /run/user/1001 Messages concerning ext4 filesystem in dmesg: [Sun Jun 23 11:57:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:13:59:70 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=20988741-02 rootfstype=ext4 fsck.repair=yes rootwait [Sun Jun 23 11:57:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Sun Jun 23 11:57:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Sun Jun 23 11:57:30 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/dev devtmpfs devtmpfs rw,relatime,size=682572k,nr_inodes=170643,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime | |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime | `-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=378720k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1001 tmpfs tmpfs rw,nosuid,nodev,relatime,size=189356k,nr_inodes=47339,mode=700,uid=1001,gid=1001 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 4.4G /var/ 3.6G /var/log 2.9G /var/log/journal/879f6c73ec204cb2920b3b859423412b 2.9G /var/log/journal 454M /var/cache Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 2.0G in the file system. /opt/iobroker/backups: 18M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 136M /opt/iobroker/iobroker-data/ 87M /opt/iobroker/iobroker-data/files 67M /opt/iobroker/iobroker-data/files/javascript.admin 48M /opt/iobroker/iobroker-data/files/javascript.admin/static 47M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 7.8M /opt/iobroker/iobroker-data/objects.jsonl 7.5M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map 7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 5.7M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/484.5f7d9187.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v18.20.3 /usr/bin/node v18.20.3 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 nodejs: Installed: 18.20.3-1nodesource1 Candidate: 18.20.3-1nodesource1 Version table: *** 18.20.3-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.20.2-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.2-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status node:internal/modules/cjs/loader:1143 throw err; ^ Error: Cannot find module '../path-exists' Require stack: - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js - /opt/iobroker/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) at Module._load (node:internal/modules/cjs/loader:981:27) at Module.require (node:internal/modules/cjs/loader:1231:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24) at Module._compile (node:internal/modules/cjs/loader:1364:14) at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) at Module.load (node:internal/modules/cjs/loader:1203:32) at Module._load (node:internal/modules/cjs/loader:1019:12) at Module.require (node:internal/modules/cjs/loader:1231:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js', '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js', '/opt/iobroker/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ] } Node.js v18.20.3 Core adapters versions node:internal/modules/cjs/loader:1143 throw err; ^ Error: Cannot find module '../path-exists' Require stack: - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js - /opt/iobroker/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) at Module._load (node:internal/modules/cjs/loader:981:27) at Module.require (node:internal/modules/cjs/loader:1231:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24) at Module._compile (node:internal/modules/cjs/loader:1364:14) at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) at Module.load (node:internal/modules/cjs/loader:1203:32) at Module._load (node:internal/modules/cjs/loader:1019:12) at Module.require (node:internal/modules/cjs/loader:1231:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js', '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js', '/opt/iobroker/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ] } Node.js v18.20.3 js-controller: node:internal/modules/cjs/loader:1143 throw err; ^ Error: Cannot find module '../path-exists' Require stack: - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js - /opt/iobroker/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) at Module._load (node:internal/modules/cjs/loader:981:27) at Module.require (node:internal/modules/cjs/loader:1231:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24) at Module._compile (node:internal/modules/cjs/loader:1364:14) at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) at Module.load (node:internal/modules/cjs/loader:1203:32) at Module._load (node:internal/modules/cjs/loader:1019:12) at Module.require (node:internal/modules/cjs/loader:1231:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js', '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js', '/opt/iobroker/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ] } Node.js v18.20.3 admin: node:internal/modules/cjs/loader:1143 throw err; ^ Error: Cannot find module '../path-exists' Require stack: - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js - /opt/iobroker/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) at Module._load (node:internal/modules/cjs/loader:981:27) at Module.require (node:internal/modules/cjs/loader:1231:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24) at Module._compile (node:internal/modules/cjs/loader:1364:14) at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) at Module.load (node:internal/modules/cjs/loader:1203:32) at Module._load (node:internal/modules/cjs/loader:1019:12) at Module.require (node:internal/modules/cjs/loader:1231:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js', '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js', '/opt/iobroker/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ] } Node.js v18.20.3 javascript: nodejs modules from github: 0 Adapter State Enabled adapters with bindings ioBroker-Repositories node:internal/modules/cjs/loader:1143 throw err; ^ Error: Cannot find module '../path-exists' Require stack: - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js - /opt/iobroker/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) at Module._load (node:internal/modules/cjs/loader:981:27) at Module.require (node:internal/modules/cjs/loader:1231:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24) at Module._compile (node:internal/modules/cjs/loader:1364:14) at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) at Module.load (node:internal/modules/cjs/loader:1203:32) at Module._load (node:internal/modules/cjs/loader:1019:12) at Module.require (node:internal/modules/cjs/loader:1231:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js', '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js', '/opt/iobroker/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ] } Node.js v18.20.3 Installed ioBroker-Instances node:internal/modules/cjs/loader:1143 throw err; ^ Error: Cannot find module '../path-exists' Require stack: - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js - /opt/iobroker/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) at Module._load (node:internal/modules/cjs/loader:981:27) at Module.require (node:internal/modules/cjs/loader:1231:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24) at Module._compile (node:internal/modules/cjs/loader:1364:14) at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) at Module.load (node:internal/modules/cjs/loader:1203:32) at Module._load (node:internal/modules/cjs/loader:1019:12) at Module.require (node:internal/modules/cjs/loader:1231:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js', '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js', '/opt/iobroker/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ] } Node.js v18.20.3 Objects and States Please stand by - This may take a while Objects: 0 States: 0 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://repos.influxdata.com/debian bullseye InRelease Hit:6 https://apt.grafana.com stable InRelease Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 1864 506/sshd: /usr/sbin tcp6 0 0 :::22 :::* LISTEN 0 1866 506/sshd: /usr/sbin tcp6 0 0 :::3000 :::* LISTEN 110 13792 695/grafana tcp6 0 0 :::8086 :::* LISTEN 999 13742 635/influxd udp 0 0 0.0.0.0:44677 0.0.0.0:* 108 14890 356/avahi-daemon: r udp 0 0 0.0.0.0:68 0.0.0.0:* 0 1880 631/dhcpcd udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14888 356/avahi-daemon: r udp6 0 0 :::36594 :::* 108 14891 356/avahi-daemon: r udp6 0 0 :::5353 :::* 108 14889 356/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-06-14 22:33:00.038 - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated 2024-06-14 22:33:00.056 - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated 2024-06-14 22:33:00.057 - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus 2024-06-14 22:33:00.073 - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated 2024-06-14 22:34:00.007 - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated 2024-06-14 22:34:00.018 - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated 2024-06-14 22:34:00.018 - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus 2024-06-14 22:34:00.030 - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated 2024-06-14 22:34:00.044 - info: javascript.0 (931) script.js.hichi.hichi-run: Strom HichiMB Werte geschrieben 2024-06-14 22:35:00.020 - info: javascript.0 (931) script.js.hichi.hichi-run: Strom HichiMB Werte geschrieben 2024-06-14 22:35:00.041 - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated 2024-06-14 22:35:00.066 - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated 2024-06-14 22:35:00.067 - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus 2024-06-14 22:35:00.079 - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated 2024-06-14 22:36:00.007 - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated 2024-06-14 22:36:00.018 - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated 2024-06-14 22:36:00.018 - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus 2024-06-14 22:36:00.031 - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated 2024-06-14 22:36:00.045 - info: javascript.0 (931) script.js.hichi.hichi-run: Strom HichiMB Werte geschrieben 2024-06-14 22:37:00.008 - info: javascript.0 (931) script.js.hichi.hichi-run: Strom HichiMB Werte geschrieben 2024-06-14 22:37:00.018 - info: javascript.0 (931) script.js.wolf.wolf_run: Wolf 0data updated 2024-06-14 22:37:00.030 - info: javascript.0 (931) script.js.Shelly.shelly-run: Wolf 0data updated 2024-06-14 22:37:00.031 - info: javascript.0 (931) script.js.Shelly.shelly-run: Stellmotor Solar aus 2024-06-14 22:37:00.043 - info: javascript.0 (931) script.js.pv.0-run.fronius: Fronius 0data updated
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller
Und verwende den user mit der uid=1000, nicht den user iobroker mit der uid=1001.
@thomas-braun Danke für deine schnelle Antwort. Das ist de rOutput:
iobroker@iob2:~ $ cd /opt/iobroker iobroker@iob2:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller npm error code 1 npm error path /opt/iobroker/node_modules/iobroker.js-controller npm error command failed npm error command sh -c node iobroker.js setup first npm error node:internal/modules/cjs/loader:1143 npm error throw err; npm error ^ npm error npm error Error: Cannot find module '../path-exists' npm error Require stack: npm error - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js npm error - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js npm error - /opt/iobroker/node_modules/fs-extra/lib/index.js npm error - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js npm error - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js npm error - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js npm error at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) npm error at Module._load (node:internal/modules/cjs/loader:981:27) npm error at Module.require (node:internal/modules/cjs/loader:1231:19) npm error at require (node:internal/modules/helpers:177:18) npm error at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24) npm error at Module._compile (node:internal/modules/cjs/loader:1364:14) npm error at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) npm error at Module.load (node:internal/modules/cjs/loader:1203:32) npm error at Module._load (node:internal/modules/cjs/loader:1019:12) npm error at Module.require (node:internal/modules/cjs/loader:1231:19) { npm error code: 'MODULE_NOT_FOUND', npm error requireStack: [ npm error '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js', npm error '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js', npm error '/opt/iobroker/node_modules/fs-extra/lib/index.js', npm error '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', npm error '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', npm error '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' npm error ] npm error } npm error npm error Node.js v18.20.3 npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-06-23T10_25_13_196Z-debug-0.log iobroker@iob2:/opt/iobroker $
@thomas-braun Habe ich vor her schon mal versucht. Jetzt noch mal ohne Erfolg.
iob fix library: loaded Library version=2024-05-24 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2024-01-04 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/5) ========================================================================== OK:1 http://deb.debian.org/debian bullseye InRelease OK:2 http://deb.debian.org/debian bullseye-updates InRelease OK:3 http://security.debian.org/debian-security bullseye-security InRelease OK:4 http://archive.raspberrypi.org/debian bullseye InRelease OK:5 https://repos.influxdata.com/debian bullseye InRelease OK:6 https://apt.grafana.com stable InRelease OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease Paketlisten werden gelesen... Fertig ========================================================================== Checking ioBroker user and directory permissions (2/5) ========================================================================== [sudo] Passwort f▒r iobroker: Fixing directory permissions... ========================================================================== Check and cleanup npm temporary directories (3/5) ========================================================================== Done. ========================================================================== Database maintenance (4/5) ========================================================================== Checking for uncompressed JSONL databases... This might take a while! Compressing /opt/iobroker/iobroker-data/states.jsonl Compressing /opt/iobroker/iobroker-data/objects.jsonl Compressed 2 JSONL files. Done ========================================================================== Checking autostart (5/5) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ==========================================================================
[sudo] Passwort für iobroker:
Du bist da noch mit dem falschen user bzw. einem falschen Setup unterwegs.
An der Stelle dürfte eigentlich das Passwort nicht für den iobroker angefragt werden. -
@thomas-braun sagte in iobroker startet nicht mehr:
hab immer noch nicht erkennen können, wer da gerade wo jnterwegs ist 1000 oder 1001?
iobroker oder iobroker -
@homoran Sorry, war unterwegs. Der User heißt iobroker und hat die UID 1001:
iobroker1001:1001::/home/iobroker:/bin/bash
@homoran Woran sehe ich das?
- ich komme nicht per WEB drauf.
- ich habe immer noch die npm errors
@manrum1 sagte in iobroker startet nicht mehr:
dann mach halt nen anderen User ... z.B. Dein Vorname damit der User sich von dem Systemuser auch unterscheidet
@djmarc75 Mir war nicht bewusst, dass der user nicht iobroker heißen darf. Lief bisher und die directory permissions stehen alle ebenfalls auf iobroker. Aber sicher, wenn es Sinn macht ändere ich das. Nur wie?
Nur wie?
Es muss aber auch bereits einen User mit der uid 1000 geben.
grep 1000 /etc/passwd
sagt?
@thomas-braun Ja, gibt es. Was soll ich tun?
Dich mit diesem user einloggen und NICHT mit dem 'iobroker' Der ist dafür nicht gedacht.
@thomas-braun Ja, habe ich genacht. Deshalb läuft aber mein iobroker immer noch nicht.
Das vielleicht nicht unmittelbar, aber ordentlicher Umgang mit Usern und deren Rechte ist die Grundlage für ein sauber laufendes System.
iob diag
sagt nun?
@thomas-braun So, habs jetzt hinbekommen.
- Verzeichnis /opt/iobroker/node_modules gelöscht
- Mit " npm clean --force" npm cache gelöscht
- Mit "sudo -H -u iobroker npm install iobroker.js-controller" installiert
Vielen Dank für Deine/Eure Hilfe!!!
Als Warnung an Nachahmer sei gesagt: Das hat bei mir so funktioniert und soll keine Anleitung für ähnliche Probleme sein.
eher nicht
mit der nachfolgenden "Anleitung" wahrscheinlich mehr Schaden angerichtet.
