    4. iobroker startet nicht mehr
      manrum1 @Thomas Braun last edited by
      @thomas-braun Danke für deine schnelle Antwort. Das ist de rOutput:
      iobroker@iob2:~ $ cd /opt/iobroker
      iobroker@iob2:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm error code 1
      npm error path /opt/iobroker/node_modules/iobroker.js-controller
      npm error command failed
      npm error command sh -c node iobroker.js setup first
      npm error node:internal/modules/cjs/loader:1143
      npm error   throw err;
      npm error   ^
      npm error
      npm error Error: Cannot find module '../path-exists'
      npm error Require stack:
      npm error - /opt/iobroker/node_modules/fs-extra/lib/copy/copy.js
      npm error - /opt/iobroker/node_modules/fs-extra/lib/copy/index.js
      npm error - /opt/iobroker/node_modules/fs-extra/lib/index.js
      npm error - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
      npm error - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
      npm error - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      npm error     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      npm error     at Module._load (node:internal/modules/cjs/loader:981:27)
      npm error     at Module.require (node:internal/modules/cjs/loader:1231:19)
      npm error     at require (node:internal/modules/helpers:177:18)
      npm error     at Object.<anonymous> (/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js:6:24)
      npm error     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      npm error     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      npm error     at Module.load (node:internal/modules/cjs/loader:1203:32)
      npm error     at Module._load (node:internal/modules/cjs/loader:1019:12)
      npm error     at Module.require (node:internal/modules/cjs/loader:1231:19) {
      npm error   code: 'MODULE_NOT_FOUND',
      npm error   requireStack: [
      npm error     '/opt/iobroker/node_modules/fs-extra/lib/copy/copy.js',
      npm error     '/opt/iobroker/node_modules/fs-extra/lib/copy/index.js',
      npm error     '/opt/iobroker/node_modules/fs-extra/lib/index.js',
      npm error     '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
      npm error     '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
      npm error     '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      npm error   ]
      npm error }
      npm error
      npm error Node.js v18.20.3
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-06-23T10_25_13_196Z-debug-0.log
        Thomas Braun Most Active @manrum1 last edited by
        @manrum1
        Versuch mal den fixer.
        iob stop
        iob fix
        iob start
          @thomas-braun Habe ich vor her schon mal versucht. Jetzt noch mal ohne Erfolg.
           iob fix
          library: loaded
          Library version=2024-05-24
              Welcome to the ioBroker installation fixer!
              Script version: 2024-01-04
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          OK:1 http://deb.debian.org/debian bullseye InRelease
          OK:2 http://deb.debian.org/debian bullseye-updates InRelease
          OK:3 http://security.debian.org/debian-security bullseye-security InRelease
          OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:5 https://repos.influxdata.com/debian bullseye InRelease
          OK:6 https://apt.grafana.com stable InRelease
          OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
              Checking ioBroker user and directory permissions (2/5)
          [sudo] Passwort f▒r iobroker:
          Fixing directory permissions...
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
            Homoran Global Moderator Administrators @manrum1 last edited by
            @manrum1 sagte in iobroker startet nicht mehr:
            ohne Erfolg.
            woran siehst du das?
              @manrum1
              [sudo] Passwort für iobroker:
              Du bist da noch mit dem falschen user bzw. einem falschen Setup unterwegs.
              An der Stelle dürfte eigentlich das Passwort nicht für den iobroker angefragt werden.
                @thomas-braun sagte in iobroker startet nicht mehr:
                hab immer noch nicht erkennen können, wer da gerade wo jnterwegs ist 1000 oder 1001?
                iobroker oder iobroker 😡
                  manrum1 @Homoran last edited by
                  @homoran Sorry, war unterwegs. Der User heißt iobroker und hat die UID 1001:
                  iobroker❌1001:1001::/home/iobroker:/bin/bash
                    @homoran Woran sehe ich das?
                    1. ich komme nicht per WEB drauf.
                    2. ich habe immer noch die npm errors
                    • DJMarc75
                      DJMarc75 @manrum1 last edited by
                      dann mach halt nen anderen User ... z.B. Dein Vorname damit der User sich von dem Systemuser auch unterscheidet 😉
                        manrum1 @DJMarc75 last edited by
                        @djmarc75 Mir war nicht bewusst, dass der user nicht iobroker heißen darf. Lief bisher und die directory permissions stehen alle ebenfalls auf iobroker. Aber sicher, wenn es Sinn macht ändere ich das. Nur wie?
                          Nur wie?
                          Es muss aber auch bereits einen User mit der uid 1000 geben.
                          grep 1000 /etc/passwd
                          sagt?
                            @thomas-braun Ja, gibt es. Was soll ich tun?
                              @manrum1
                              Dich mit diesem user einloggen und NICHT mit dem 'iobroker' Der ist dafür nicht gedacht.
                                @thomas-braun Ja, habe ich genacht. Deshalb läuft aber mein iobroker immer noch nicht.
                                  Thomas Braun Most Active last edited by
                                  @manrum1
                                  Das vielleicht nicht unmittelbar, aber ordentlicher Umgang mit Usern und deren Rechte ist die Grundlage für ein sauber laufendes System.
                                  iob diag
                                  sagt nun?
                                    manrum1 @Thomas Braun last edited by manrum1
                                    @thomas-braun So, habs jetzt hinbekommen.
                                    1. Verzeichnis /opt/iobroker/node_modules gelöscht
                                    2. Mit " npm clean --force" npm cache gelöscht
                                    3. Mit "sudo -H -u iobroker npm install iobroker.js-controller" installiert
                                    Vielen Dank für Deine/Eure Hilfe!!!
                                    Als Warnung an Nachahmer sei gesagt: Das hat bei mir so funktioniert und soll keine Anleitung für ähnliche Probleme sein.
                                      eher nicht
                                      mit der nachfolgenden "Anleitung" wahrscheinlich mehr Schaden angerichtet.
                                        @homoran Kann ja nur sagen, was ich gemacht habe.
        v.2024-05-22
                                           Static hostname: iob2
                                                 Icon name: computer
                                          Operating System: Debian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 6.1.21-v8+
                                              Architecture: arm64
                                        Installation:           native
                                        Kernel:                 aarch64
                                        Userland:               64 bit
                                        Timezone:               Europe/Berlin (CEST, +0200)
                                        User-ID:                1000
                                        Display-Server:         false
                                        Boot Target:            multi-user.target
                                        Pending OS-Updates:     0
                                        Pending iob updates:    2
                                        Nodejs-Installation:
                                        /usr/bin/nodejs         v18.20.3
                                        /usr/bin/node           v18.20.3
                                        /usr/bin/npm            10.7.0
                                        /usr/bin/npx            10.7.0
                                        /usr/bin/corepack       0.28.0
                                        Recommended versions are nodejs 18.20.3 and npm 10.7.0
                                        MEMORY:
                                        Mem:            1.8G        313M        824M        0.0K        711M        1.5G
                                        Swap:            99M         64M         35M
                                        Total:          1.9G        378M        859M
                                        Active iob-Instances:   1
                                        Active repo(s): stable
                                        ioBroker Core:          js-controller           5.0.19
        admin                   6.13.16
                                        ioBroker Status:        iobroker is not running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                          system.adapter.admin.0                  : admin                 : iob2                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          system.adapter.web.0                    : web                   : iob2                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        Objects:                6693
                                        States:                 5242
                                        Size of iob-Database:
                                        7.9M    /opt/iobroker/iobroker-data/objects.jsonl
                                        1.3M    /opt/iobroker/iobroker-data/states.jsonl
                                          du hast alle Informationen gelöscht.
                                          da läuft nur noch eine Instanz
                                            @homoran Soweit ich sehe läuft alles. Daten sind bis zum Ausfall alle da.
                                            934
