      liv-in-sky @Michael Roling last edited by
      @michael-roling
      ok - die 1.7.1. läuft wieder - ich probier's nochmal
        @michael-roling
        es wird installiert - der adapter ist jetzt grün - aber in telgram wird nicht reagiert und das setting geht auch nicht auf
        telegram-menu.0
        2024-06-23 17:30:27.847	debug	Sent Value to {"xxxxx":6178} users!
        telegram-menu.0
        2024-06-23 17:30:27.788	debug	ParseModeType: "Markdown"
        telegram-menu.0
        2024-06-23 17:30:27.788	debug	ChatId : "xxxxxxx"
        telegram-menu.0
        2024-06-23 17:30:27.788	debug	Parse_mode : "false"
        telegram-menu.0
        2024-06-23 17:30:27.788	debug	UserListWithChatID : [{"name":"liv-in-sky","chatID":"xxxxxxx"}]
        telegram-menu.0
        2024-06-23 17:30:27.787	debug	Instance: "telegram.3"
        telegram-menu.0
        2024-06-23 17:30:27.787	debug	Send to: liv-in-sky => Startseite aktualisiert ....
        telegram-menu.0
        2024-06-23 17:30:27.787	debug	User List: [{"name":"liv-in-sky","chatID":"989074665"}]
        telegram-menu.0
        2024-06-23 17:30:27.783	debug	GoBackMenu {"liv-in-sky":{"list":[],"last":"an"}}
        telegram-menu.0
        2024-06-23 17:30:27.783	debug	Startseite: "an"
        telegram-menu.0
        2024-06-23 17:30:27.783	debug	MenuList: ["liv-in-sky"]
        telegram-menu.0
        2024-06-23 17:30:27.783	debug	Checkboxes: {"checkboxNoValueFound":false,"resKey":true,"oneTiKey":false,"sendMenuAfterRestart":true}
        telegram-menu.0
        2024-06-23 17:30:27.783	debug	Gen. Actions: {"an":{"nav":[["➡ Heizung","outSide","getStandort"],["Clear","CompAus","➡ Grüner"],["➡ Tests"]],"text":"Startseite aktualisiert ....","parse_mode":"false"},"➡ Heizung":{"nav":[["Room","Bad"],["Flur","Küche"],["ÜbersichtHeizung"],["BACK ↩"]],"text":"nur wenn Standort 4 {set:'id':'0_userdata.0.CONTROL-OWN.HeizungTelegram',true,ack}","parse_mode":"false"},"➡ Grüner":{"nav":[["MelPic","MelSet","➡ SonderTour",""],["SonderStart","SonderEnde","SonderPic"],["MelBild","PostGPS(RouteRecord)"],["BACK ↩","SetLoc","SetZeit"],["RepariereKM","SetKilometer",""]],"text":"SetLoc (in Tab eintragen) zuerst Text - Sonderfahrt zuerst Button Sondertour zuerst Name","parse_mode":"false"},"➡ Tests":{"nav":[["IN","OUT"],["GetTable","GetDevices","SetWord"],["DynMenu","AlexaShopping","PostIts","LÖSCHEN","BACK ↩"]],"text":"Choose an action","parse_mode":"false"},"BACK ↩":{"nav":[["menu:back"],[""]],"text":"Wähle eine Aktion","parse_mode":"false"},"outSide":{"nav":[["menu:number0-6-1- :aussen:"],[""]],"text":"Wähle eine Aktion aus","parse_mode":"false"},"➡ SonderTour":{"nav":[["Anfahrt","Abholung"],["EndeAbholung","BeendeFahrt"],["SonderPic2","BACK ↩"]],"text":"Anfahrt zuerst Name - und Anfahrt drücken","parse_mode":"false"},"LÖSCHEN":{"nav":[["menu:deleteAll:➡ Grüner"],[""]],"text":"Choose an action","parse_mode":"false"},"Lüfter5":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.Luefter5","value":"!","toggle":true,"confirm":"true","returnText":"Lüfter ist jetzt: &amp;&amp; ","ack":"true","parse_mode":"false"}]},"IN":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.AAATEST.telegramInnen","value":"!","toggle":true,"confirm":"true","returnText":"","ack":"true","parse_mode":"false"}]},"OUT":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.AAATEST.telegramAUSSEN","value":"!","toggle":true,"confirm":"true","returnText":"","ack":"true","parse_mode":"false"}]},"MelBild":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.sendTelegramMelikeGesamtBild","value":"-","toggle":true,"confirm":"true","returnText":"-","ack":"false","parse_mode":"false"}]},"Clear":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TelegramDelete3Chat","value":true,"toggle":false,"confirm":"true","returnText":"ALLES LÖSCHEN ... Wait ... {novalue}","ack":"true","parse_mode":"false"}]},"CompAus":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.fx6300","value":false,"toggle":true,"confirm":"true","returnText":"Computer wird abgeschalten! Value: &amp;&amp;","ack":"false","parse_mode":"false"}]},"SonderStart":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtBeginn","value":true,"toggle":false,"confirm":"true","returnText":"Name und Kilometer (mit Komma) {'id':'0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.BeginnKM','text':'Kilometer Start ist &amp;&amp;'}","ack":"false","parse_mode":"false"}]},"SonderEnde":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtEnde","value":true,"toggle":false,"confirm":"true","returnText":"Name und Kilometer (mit Komma) {'id':'0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.EndeKM','text':'Kilometer Ende ist &amp;&amp;'}","ack":"false","parse_mode":"false"}]},"MelSet":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.MelikeSchreiben","value":"-","toggle":true,"confirm":"true","returnText":"Wert ist &amp;&amp;","ack":"false","parse_mode":"false"}]},"PostGPS(RouteRecord)":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.postGPSData","value":true,"toggle":false,"confirm":"true","returnText":"{'id':'0_userdata.0.CONTROL-OWN.TRACCAR.postGPSResult','text':'GPS Post ist:\\n&amp;&amp;'}","ack":"false","parse_mode":"false"}]},"aussen":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.MOTION.Standort","value":"!","toggle":false,"confirm":"true","returnText":"Standort: &amp;&amp; ","ack":"true","parse_mode":"false"}]},"Room":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.HeizungZimmer30","value":true,"toggle":false,"confirm":"true","returnText":"Heizung Raum ist: &amp;&amp;","ack":"false","parse_mode":"false"}]},"Bad":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.BAD.BADHeizung30","value":true,"toggle":false,"confirm":"true","returnText":"Heizung Bad ist: &amp;&amp;","ack":"false","parse_mode":"false"}]},"Flur":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.Heizung30","value":true,"toggle":false,"confirm":"true","returnText":"Heizung Flur ist: &amp;&amp;","ack":"false","parse_mode":"false"}]},"Küche":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.HeizungKueche30","value":true,"toggle":false,"confirm":"true","returnText":"Heizung Küche ist: &amp;&amp;","ack":"false","parse_mode":"false"}]},"ÜbersichtHeizung":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.HeizungTelegram","value":true,"toggle":false,"confirm":"true","returnText":"-","ack":"false","parse_mode":"false"}]},"SetLoc":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.SetLoc","value":true,"toggle":false,"confirm":"true","returnText":"{'id':'0_userdata.0.CONTROL-OWN.TRACCAR.OldValue','text':'SetLoc ist:\\n&amp;&amp;'}","ack":"false","parse_mode":"false"}]},"SetZeit":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.DailyHoursSwitch","value":true,"toggle":false,"confirm":"false","returnText":"done &&","ack":"false","parse_mode":"false"}]},"SetWord":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.AAATEST.TestString4","value":"&&","toggle":false,"confirm":"true","returnText":"{setDynamicValue:WaitForManualInput:Type:Input was : &&:}","ack":"true","parse_mode":"false"}]},"RepariereKM":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.Kilometer.KorrektiereKilometer","value":"&&","toggle":false,"confirm":"true","returnText":"{setDynamicValue:nur Abweichung eingeben:Number: &&:}","ack":"true","parse_mode":"false"}]},"SetKilometer":{"switch":[{"id":"0_userdata.0.CONTROL-OWN.TRACCAR.Kilometer.SetKMoverTelegram","value":"&&","toggle":false,"confirm":"true","returnText":"setz kM {setDynamicValue:GebeGesamtKmEin:number:'Kilometer ist &&':}","ack":"true","parse_mode":"false"}]},"MelPic":{"sendPic":[{"id":"-","fileName":"/opt/iobroker/iobrokerMelike.png","delay":"5000"}]},"SonderPic":{"sendPic":[{"id":"-","fileName":"/opt/iobroker/iobrokerSonder.png","delay":"5000"}]},"SonderPic2":{"sendPic":[{"id":"-","fileName":"/opt/iobroker/iobrokerSonderEinmalig.png","delay":"5000"}]},"getStandort":{"getData":[{"id":"0_userdata.0.CONTROL-OWN.MOTION.Standort","text":"Standort ist momentan: <b>&&</b>","newline":"true","parse_mode":"true"}]},"GetTable":{"getData":[{"id":"0_userdata.0.CONTROL-OWN.AAATEST.TestJSON","text":"{json;[label:\"ErsterWert\",value:\"ZweiterWert\"];MonatsÜbersicht;}","newline":"true","parse_mode":"false"}]},"GetDevices":{"getData":[{"id":"0_userdata.0.CONTROL-OWN.STROMZÄHLER.JSONStromDaten","text":"{json;[Datum:Datum,VerbrauchMonat:VerbrauchMonat];Monatlich;TextTable;}","newline":"true","parse_mode":"false"}]},"AlexaShopping":{"getData":[{"id":"alexa-shoppinglist.0.list_activ","text":"{json;[name:Einträge];ALEXALIST-Shopping;shoppinglist;}","newline":"true","parse_mode":"false"}]},"PostIts":{"getData":[{"id":"0_userdata.0.Alarm-MaterialDesign.PostItMessages","text":"{json;[text:Einträge];Postit's;}","newline":"true","parse_mode":"false"}]}}
        telegram-menu.0
        2024-06-23 17:30:27.782	debug	Array Buttons: [{"call":"an","text":"Startseite aktualisiert ....","parse_mode":"false","nav":[["➡ Heizung","outSide","getStandort"],["Clear","CompAus","➡ Grüner"],["➡ Tests"]]},{"call":"➡ Heizung","text":"nur wenn Standort 4 {set:'id':'0_userdata.0.CONTROL-OWN.HeizungTelegram',true,ack}","parse_mode":"false","nav":[["Room","Bad"],["Flur","Küche"],["ÜbersichtHeizung"],["BACK ↩"]]},{"call":"➡ Grüner","text":"SetLoc (in Tab eintragen) zuerst Text - Sonderfahrt zuerst Button Sondertour zuerst Name","parse_mode":"false","nav":[["MelPic","MelSet","➡ SonderTour",""],["SonderStart","SonderEnde","SonderPic"],["MelBild","PostGPS(RouteRecord)"],["BACK ↩","SetLoc","SetZeit"],["RepariereKM","SetKilometer",""]]},{"call":"➡ Tests","text":"Choose an action","parse_mode":"false","nav":[["IN","OUT"],["GetTable","GetDevices","SetWord"],["DynMenu","AlexaShopping","PostIts","LÖSCHEN","BACK ↩"]]},{"call":"BACK ↩","text":"Wähle eine Aktion","parse_mode":"false","nav":[["menu:back"],[""]]},{"call":"outSide","text":"Wähle eine Aktion aus","parse_mode":"false","nav":[["menu:number0-6-1- :aussen:"],[""]]},{"call":"➡ SonderTour","text":"Anfahrt zuerst Name - und Anfahrt drücken","parse_mode":"false","nav":[["Anfahrt","Abholung"],["EndeAbholung","BeendeFahrt"],["SonderPic2","BACK ↩"]]},{"call":"LÖSCHEN","text":"Choose an action","parse_mode":"false","nav":[["menu:deleteAll:➡ Grüner"],[""]]}]
        telegram-menu.0
        2024-06-23 17:30:27.782	debug	MenuName: "liv-in-sky"
        telegram-menu.0
        2024-06-23 17:30:27.782	debug	Subscribe all States of: [["0_userdata.0.CONTROL-OWN.TelegramDelete3Chat"]]
        telegram-menu.0
        2024-06-23 17:30:27.782	debug	Subscribe all States of: ["0_userdata.0.CONTROL-OWN.Luefter5","0_userdata.0.CONTROL-OWN.AAATEST.telegramInnen","0_userdata.0.CONTROL-OWN.AAATEST.telegramAUSSEN","0_userdata.0.CONTROL-OWN.TRACCAR.sendTelegramMelikeGesamtBild","0_userdata.0.CONTROL-OWN.TelegramDelete3Chat","0_userdata.0.CONTROL-OWN.fx6300","0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtBeginn","0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtEnde","0_userdata.0.CONTROL-OWN.TRACCAR.MelikeSchreiben","0_userdata.0.CONTROL-OWN.TRACCAR.postGPSData","0_userdata.0.CONTROL-OWN.MOTION.Standort","0_userdata.0.CONTROL-OWN.HeizungZimmer30","0_userdata.0.CONTROL-OWN.BAD.BADHeizung30","0_userdata.0.CONTROL-OWN.Heizung30","0_userdata.0.CONTROL-OWN.HeizungKueche30","0_userdata.0.CONTROL-OWN.HeizungTelegram","0_userdata.0.CONTROL-OWN.TRACCAR.SetLoc","0_userdata.0.CONTROL-OWN.TRACCAR.DailyHoursSwitch","0_userdata.0.CONTROL-OWN.AAATEST.TestString4","0_userdata.0.CONTROL-OWN.TRACCAR.Kilometer.KorrektiereKilometer","0_userdata.0.CONTROL-OWN.TRACCAR.Kilometer.SetKMoverTelegram"]
        telegram-menu.0
        2024-06-23 17:30:27.782	debug	SubscribeForeignStates: ["0_userdata.0.CONTROL-OWN.Luefter5","0_userdata.0.CONTROL-OWN.AAATEST.telegramInnen","0_userdata.0.CONTROL-OWN.AAATEST.telegramAUSSEN","0_userdata.0.CONTROL-OWN.TRACCAR.sendTelegramMelikeGesamtBild","0_userdata.0.CONTROL-OWN.TelegramDelete3Chat","0_userdata.0.CONTROL-OWN.fx6300","0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtBeginn","0_userdata.0.CONTROL-OWN.TRACCAR.SONDERFAHRT.SonderfahrtEnde","0_userdata.0.CONTROL-OWN.TRACCAR.MelikeSchreiben","0_userdata.0.CONTROL-OWN.TRACCAR.postGPSData","0_userdata.0.CONTROL-OWN.MOTION.Standort","0_userdata.0.CONTROL-OWN.HeizungZimmer30","0_userdata.0.CONTROL-OWN.BAD.BADHeizung30","0_userdata.0.CONTROL-OWN.Heizung30","0_userdata.0.CONTROL-OWN.HeizungKueche30","0_userdata.0.CONTROL-OWN.HeizungTelegram","0_userdata.0.CONTROL-OWN.TRACCAR.SetLoc","0_userdata.0.CONTROL-OWN.TRACCAR.DailyHoursSwitch","0_userdata.0.CONTROL-OWN.AAATEST.TestString4","0_userdata.0.CONTROL-OWN.TRACCAR.Kilometer.KorrektiereKilometer","0_userdata.0.CONTROL-OWN.TRACCAR.Kilometer.SetKMoverTelegram"]
        telegram-menu.0
        2024-06-23 17:30:27.780	debug	Telegram Info Connection: true
        telegram-menu.0
        2024-06-23 17:30:27.771	info	Telegram was found
        telegram-menu.0
        2024-06-23 17:30:27.763	info	StartSides {"liv-in-sky":"an"}
        telegram-menu.0
        2024-06-23 17:30:27.752	info	starting. Version 1.7.3 (non-npm: MiRo1310/ioBroker.telegram-menu#9a12d94de9f0dfd9cb6800d909f66b54191999c6) in /opt/iobroker/node_modules/iobroker.telegram-menu, node: v20.13.1, js-controller: 5.0.19
        • Michael Roling
          Michael Roling Developer @liv-in-sky last edited by
          @liv-in-sky Stimmt, was ist das denn jetzt. Moment ich mache mal was rückgängig
            @michael-roling
            node 20 ?
            • Michael Roling
              @liv-in-sky Nein nein, warte kurz
              • Michael Roling
                @liv-in-sky geh wieder auf 1.7.3 . Ich muss mir das in Ruhe anschauen, ich weiss nicht was da jetzt auf einmal los ist
                  @michael-roling geht leider nicht mehr - muss auf 1.7.1 gehen, damit ich das setting öffnen kann
                  1.7.2. kann auch kein setting öffnen
                  • Michael Roling
                    @liv-in-sky okay
                    • Michael Roling
                      @liv-in-sky So ich habe es hin bekommen, was ein Sch....
                      Ich habe es bei mir installiert und ich komme auch auf die UI, also bitte einmal testen.
                        @michael-roling hoffe, du hast nicht die ganze nacht durchgemacht 🙂 - setting wieder erreichbar - den test, um was es eigendlich ging - liefere ich bald nach
                        danke
                          liv-in-sky @Michael Roling last edited by liv-in-sky
                          @michael-roling
                          test erfolgreich 🙂 🙂
                          {setDynamicValue:GebeGesamtKmEin:number:Kilometer ist &&:0_userdata.0.CONTROL-OWN.TRACCAR.Kilometer.Stand:}
                          wenn du zeit hast, evtl noch in die hilfe im setting mit eingeben - funktioniert dann das ganze auch noch, wenn ich eine fremd-id am ende weglasse - also der orginal befehl
                          Michael Roling 1 Reply Last reply Reply Quote 1
                          • Michael Roling
                            Michael Roling Developer @liv-in-sky last edited by Michael Roling
                            @liv-in-sky ja das funktioniert wie gewohnt ohne die id. Eigentlich habe ich die Hilfe angepasst. Ich schaue aber noch mal.
                            Habe ich auch angepasst
                            mickemup 1 Reply Last reply Reply Quote 1
                            • mickemup
                              mickemup @Michael Roling last edited by
                              @michael-roling
                              Einen super Adapter hast du da. Danke für die Arbeit
                              Ich bin gerade daran mir mein Menu zu bauen.
                              Bei den Zeitstempeln stehe aber an:
                              Ich habe den Text aus dem Helper kopiert:
                              meine Zeit: {time.ts,(DD MM YYYY hh:mm:ss:sss),id:'alias.0.Garten.HotPot.TempW'}
                              Und einfach meine ID hinzugefügt.
                              Installiert habe ich 1.7.4 und kriege folgende Errormeldung: (Im Telegram Chat wird nichts angezeigt)
                              Ist das ein Bug oder was mache ich falsch?
                              Grüsse
                              • Michael Roling
                                Michael Roling Developer @mickemup last edited by
                                @michael-inglin Das werde ich mir nächste Woche mal anschauen. Ich würde dich bitten ein Issue auf Github an zu legen, mit den Infos die du hier auch geschrieben hast.
                                mickemup B 2 Replies Last reply Reply Quote 0
                                • mickemup
                                  @michael-roling Danke, erledigt 🙂
                                    BobBruni @Michael Roling last edited by BobBruni
                                    @michael-roling
                                    Glaub ich habe plötzlich das gleiche Problem mit dem Zeitstempel:
                                    Bringt keine Ausgabe mehr... Dieses Setup hat aber schon mal zu 100% funktioniert.
                                    Was muss ich genau ändern?
                                    • Michael Roling
                                      Michael Roling Developer @mickemup last edited by Michael Roling
                                      @michael-inglin @BobBruni Oh ich glaube ich habe das falsche überprüft. Ich werde es mir noch einmal anschauen.
                                      • Michael Roling
                                        @michael-inglin @BobBruni Ich habe gerade noch mal einen Fix hoch geladen, bitte einmal testen und dann ein Feedback posten
                                        B mickemup 3 Replies Last reply Reply Quote 1
                                          @michael-roling Läuft wieder einwandfrei 👍 Vielen Dank!
                                          • mickemup
                                            @michael-roling
                                            Sry war paar Tage Offline
                                            Habe es gerade getestet (mit V2) und funktioniert.
                                            Vielen Dank für einen Einsatz
                                            1795
                                            786896
