    4. (gelöst) JS-Controller 6.0.5 NodeJS 18
      JoeBaum @wendy2702 last edited by
      @wendy2702 Vielen Dank für den Hinweis, ist mir durchgerutscht, hab es gleich korrigiert.
        Thomas Braun Most Active @JoeBaum last edited by
        @joebaum
        Zeig mal die Ausgabe von
        iob diag
        in der Langfassung.
          JoeBaum @Thomas Braun last edited by
          Hier der Summery:
                                  v.2024-05-22
             Static hostname: iobrokerVM
                   Icon name: computer-vm
                     Chassis: vm
              Virtualization: kvm
            Operating System: Debian GNU/Linux 10 (buster)
                      Kernel: Linux 4.19.0-17-amd64
                Architecture: x86-64
          Installation:           kvm
          Kernel:                 x86_64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1000
          Display-Server:         true
          Boot Target:            graphical.target
          Pending OS-Updates:     338
          Pending iob updates:    45
          Nodejs-Installation:
          /usr/bin/nodejs         v18.20.3
          /usr/bin/node           v18.20.3
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.0
          Recommended versions are nodejs 18.20.3 and npm 10.7.0
          MEMORY:
          Mem:           8.0G        3.5G        3.2G        6.0M        1.3G        4.2G
          Swap:          974M        298M        676M
          Total:         9.0G        3.8G        3.8G
          Active iob-Instances:   33
          Active repo(s): beta
          ioBroker Core:          js-controller           6.0.5
                                  admin                   6.17.14
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : iobrokerVM                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.web.0                    : web                   : iobrokerVM                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                65631
          States:                 49848
          Size of iob-Database:
          71M     /opt/iobroker/iobroker-data/objects.jsonl
          38M     /opt/iobroker/iobroker-data/objects.json.migrated
          38M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          28M     /opt/iobroker/iobroker-data/objects.json.broken
          56M     /opt/iobroker/iobroker-data/states.jsonl
          18M     /opt/iobroker/iobroker-data/states.json.migrated
          18M     /opt/iobroker/iobroker-data/states.json.bak.migrated
          0       /opt/iobroker/iobroker-data/states.json.broken
          Und hier die Langversion
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
          model name      : Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           06:03:17 up 14:13,  1 user,  load average: 1.18, 1.07, 0.69
          CPU threads: 8
          *** Time and Time Zones ***
                         Local time: Thu 2024-06-20 06:03:17 CEST
                     Universal time: Thu 2024-06-20 04:03:17 UTC
                           RTC time: Thu 2024-06-20 04:03:18
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout cdrom floppy audio dip video plugdev netdev bluetooth lpadmin scanner
          iobroker
          HOME=/home/iobroker
          *** Display-Server-Setup ***
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           8.0G        3.4G        3.3G        6.0M        1.4G        4.3G
          Total:         9.0G        3.7G        3.9G
                   7978 M total memory
                   3369 M used memory
                   3685 M active memory
                    641 M inactive memory
                   3253 M free memory
                    155 M buffer memory
                   1199 M swap cache
                    974 M total swap
                    298 M used swap
                    676 M free swap
          top - 06:03:17 up 14:13,  1 user,  load average: 1.18, 1.07, 0.69
          Tasks: 183 total,   1 running, 182 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  3.1 us,  1.6 sy,  0.0 ni, 95.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7978.4 total,   3252.3 free,   3370.9 used,   1355.2 buff/cache
          MiB Swap:    975.0 total,    676.5 free,    298.5 used.   4309.9 avail Mem
          *** FAILED SERVICES ***
            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
          * udisks2.service loaded failed failed Disk Manager
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     798M   79M  719M  10% /run
          /dev/sda1      ext4       19G  9.0G  8.7G  51% /
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
          tmpfs          tmpfs     798M  3.1M  795M   1% /run/user/117
          tmpfs          tmpfs     798M     0  798M   0% /run/user/1000
          [Wed Jun 19 15:50:32 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Wed Jun 19 15:50:53 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          [Wed Jun 19 17:27:15 2024] Modules linked in: bluetooth drbg ansi_cprng ecdh_generic cfg80211 rfkill cdc_acm sg virtio_balloon joydev evdev serio_raw pcspkr qemu_fw_cfg parport_pc ppdev sunrpc lp parport ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic fscrypto ecb crypto_simd cryptd glue_helper aes_x86_64 hid_generic usbhid hid sr_mod cdrom sd_mod ata_generic virtio_net net_failover virtio_scsi failover ata_piix xhci_pci libata xhci_hcd bochs_drm ttm uhci_hcd psmouse drm_kms_helper scsi_mod ehci_hcd drm usbcore virtio_pci virtio_ring virtio i2c_piix4 usb_common floppy button
          [Wed Jun 19 17:27:37 2024] Modules linked in: bluetooth drbg ansi_cprng ecdh_generic cfg80211 rfkill cdc_acm sg virtio_balloon joydev evdev serio_raw pcspkr qemu_fw_cfg parport_pc ppdev sunrpc lp parport ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic fscrypto ecb crypto_simd cryptd glue_helper aes_x86_64 hid_generic usbhid hid sr_mod cdrom sd_mod ata_generic virtio_net net_failover virtio_scsi failover ata_piix xhci_pci libata xhci_hcd bochs_drm ttm uhci_hcd psmouse drm_kms_helper scsi_mod ehci_hcd drm usbcore virtio_pci virtio_ring virtio i2c_piix4 usb_common floppy button
          [Wed Jun 19 21:26:19 2024]  ext4_filemap_fault+0x2c/0x40 [ext4]
          Show mounted filesystems:
          TARGET                                SOURCE      FSTYPE      OPTIONS
          /                                     /dev/sda1   ext4        rw,relatime,errors=remount-ro
          |-/sys                                sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security              securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup                    tmpfs       tmpfs       ro,nosuid,nodev,noexec,mode=755
          | | |-/sys/fs/cgroup/unified          cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate
          | | |-/sys/fs/cgroup/systemd          cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
          | | |-/sys/fs/cgroup/pids             cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,pids
          | | |-/sys/fs/cgroup/memory           cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,memory
          | | |-/sys/fs/cgroup/net_cls,net_prio cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
          | | |-/sys/fs/cgroup/devices          cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,devices
          | | |-/sys/fs/cgroup/rdma             cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,rdma
          | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
          | | |-/sys/fs/cgroup/freezer          cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,freezer
          | | |-/sys/fs/cgroup/cpuset           cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
          | | |-/sys/fs/cgroup/blkio            cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,blkio
          | | `-/sys/fs/cgroup/perf_event       cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
          | |-/sys/fs/pstore                    pstore      pstore      rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf                       bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
          | `-/sys/kernel/debug                 debugfs     debugfs     rw,relatime
          |-/proc                               proc        proc        rw,nosuid,nodev,noexec,relatime
          | `-/proc/sys/fs/binfmt_misc          systemd-1   autofs      rw,relatime,fd=40,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12592
          |   `-/proc/sys/fs/binfmt_misc        binfmt_misc binfmt_misc rw,relatime
          |-/dev                                udev        devtmpfs    rw,nosuid,relatime,size=4065044k,nr_inodes=1016261,mode=755
          | |-/dev/pts                          devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | |-/dev/shm                          tmpfs       tmpfs       rw,nosuid,nodev
          | |-/dev/mqueue                       mqueue      mqueue      rw,relatime
          | `-/dev/hugepages                    hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
          `-/run                                tmpfs       tmpfs       rw,nosuid,noexec,relatime,size=816988k,mode=755
            |-/run/lock                         tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
            |-/run/rpc_pipefs                   sunrpc      rpc_pipefs  rw,relatime
            |-/run/user/117                     tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=816988k,mode=700,uid=117,gid=124
            `-/run/user/1000                    tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=816988k,mode=700,uid=1000,gid=1000
          /var:
          1.2G    /var/
          912M    /var/cache
          893M    /var/cache/apt
          831M    /var/cache/apt/archives
          227M    /var/lib
                Users in the 'systemd-journal' group can see all messages. Pass -q to
                turn off this notice.
          No journal files were opened due to insufficient permissions.
          /opt/iobroker/backups:
          59M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          969M    /opt/iobroker/iobroker-data/
          296M    /opt/iobroker/iobroker-data/backup-objects
          264M    /opt/iobroker/iobroker-data/files
          127M    /opt/iobroker/iobroker-data/sonosCache
          61M     /opt/iobroker/iobroker-data/files/javascript.admin
          57M     /opt/iobroker/iobroker-data/states.jsonl
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.16__Embed_with_CMSIS-DAP_L1100LTM-if03
          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.16__Embed_with_CMSIS-DAP_L1100LTM-if00
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          *** NodeJS-Installation ***
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Installed: 18.20.3-1nodesource1
            Candidate: 18.20.3-1nodesource1
            Version table:
           *** 18.20.3-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.2-1nodesource1 500
               18.20.1-1nodesource1 500
               18.20.0-1nodesource1 500
               18.19.1-1nodesource1 500
               18.19.0-1nodesource1 500
               18.18.2-1nodesource1 500
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
               10.24.0~dfsg-1~deb10u4 500
                  500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
               10.24.0~dfsg-1~deb10u1 500
                  500 http://deb.debian.org/debian buster/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.5
          admin:          6.17.14
          javascript:     5.2.16
          nodejs modules from github:     0
          Adapter State
          + system.adapter.alarm.0                  : alarm                 : iobrokerVM                               -  enabled
          + system.adapter.alexa2.0                 : alexa2                : iobrokerVM                               -  enabled
          + system.adapter.backitup.0               : backitup              : iobrokerVM                               -  enabled
            system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobrokerVM                               - disabled
            system.adapter.daswetter.0              : daswetter             : iobrokerVM                               -  enabled
            system.adapter.deconz.0                 : deconz                : iobrokerVM                               - disabled, port: 80
          + system.adapter.discovery.0              : discovery             : iobrokerVM                               -  enabled
            system.adapter.fakeroku.0               : fakeroku              : iobrokerVM                               -  enabled
            system.adapter.feiertage.0              : feiertage             : iobrokerVM                               -  enabled
            system.adapter.flot.0                   : flot                  : iobrokerVM                               - disabled
          + system.adapter.harmony.0                : harmony               : iobrokerVM                               -  enabled
            system.adapter.history.0                : history               : iobrokerVM                               -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobrokerVM                               -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerVM                               -  enabled, port: 12001
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerVM                               -  enabled, port: 12010
          + system.adapter.hue.0                    : hue                   : iobrokerVM                               -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : iobrokerVM                               -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobrokerVM                               -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobrokerVM                               -  enabled
          + system.adapter.iot.0                    : iot                   : iobrokerVM                               -  enabled
          + system.adapter.javascript.0             : javascript            : iobrokerVM                               -  enabled
          + system.adapter.kecontact.0              : kecontact             : iobrokerVM                               -  enabled
            system.adapter.klf200.0                 : klf200                : iobrokerVM                               - disabled
            system.adapter.kodi.0                   : kodi                  : iobrokerVM                               - disabled, port: 9090
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerVM                               -  enabled, port: 54321
          + system.adapter.modbus.0                 : modbus                : iobrokerVM                               -  enabled
            system.adapter.mqtt.0                   : mqtt                  : iobrokerVM                               - disabled, port: 1886, bind: 0.0.0.0
            system.adapter.netatmo.0                : netatmo               : iobrokerVM                               - disabled
          + system.adapter.nina.0                   : nina                  : iobrokerVM                               -  enabled
          + system.adapter.octoprint.0              : octoprint             : iobrokerVM                               -  enabled
            system.adapter.oilfox.0                 : oilfox                : iobrokerVM                               -  enabled
          + system.adapter.robonect.0               : robonect              : iobrokerVM                               -  enabled
            system.adapter.samsung.0                : samsung               : iobrokerVM                               - disabled
          + system.adapter.shelly.0                 : shelly                : iobrokerVM                               -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobrokerVM                               -  enabled
          + system.adapter.sonnen.0                 : sonnen                : iobrokerVM                               -  enabled
          + system.adapter.sonos.0                  : sonos                 : iobrokerVM                               -  enabled
            system.adapter.spotify-premium.0        : spotify-premium       : iobrokerVM                               - disabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerVM                               -  enabled
          + system.adapter.telegram.0               : telegram              : iobrokerVM                               -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.trashschedule.0          : trashschedule         : iobrokerVM                               -  enabled
            system.adapter.unifi-protect.0          : unifi-protect         : iobrokerVM                               -  enabled
          + system.adapter.unifi.0                  : unifi                 : iobrokerVM                               -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobrokerVM                               - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokerVM                               - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerVM                               - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokerVM                               - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobrokerVM                               -  enabled
            system.adapter.vis-history.0            : vis-history           : iobrokerVM                               - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerVM                               - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerVM                               -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerVM                               -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerVM                               - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobrokerVM                               - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobrokerVM                               - disabled
            system.adapter.vis-map.0                : vis-map               : iobrokerVM                               - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobrokerVM                               - disabled
            system.adapter.vis-players.0            : vis-players           : iobrokerVM                               - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobrokerVM                               - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokerVM                               - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerVM                               - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobrokerVM                               - disabled
            system.adapter.vis.0                    : vis                   : iobrokerVM                               -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : iobrokerVM                               -  enabled
          + system.adapter.wled.0                   : wled                  : iobrokerVM                               -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobrokerVM                               -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.16__Embed_with_CMSIS-DAP_L1100LTM-if00
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.17.14  , installed 6.17.14
          Adapter    "alarm"        : 3.6.1    , installed 3.6.0  [Updatable]
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.5    , installed 2.9.10 [Updatable]
          Adapter    "coronavirus-statistics": 0.9.0, installed 0.8.7 [Updatable]
          Adapter    "daswetter"    : 3.1.15   , installed 3.1.3  [Updatable]
          Adapter    "deconz"       : 1.4.1    , installed 2.0.5
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
          Adapter    "fakeroku"     : 0.3.0    , installed 0.2.1  [Updatable]
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "harmony"      : 1.5.0    , installed 1.5.0
          Adapter    "history"      : 3.0.1    , installed 1.9.14 [Updatable]
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
          Adapter    "homekit-controller": 0.5.10, installed 0.5.8 [Updatable]
          Adapter    "hue"          : 3.11.0   , installed 3.11.0
          Adapter    "ical"         : 1.15.0   , installed 1.13.6 [Updatable]
          Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.6.0    , installed 5.2.16 [Updatable]
          Controller "js-controller": 6.0.5    , installed 6.0.5
          Adapter    "kecontact"    : 2.1.1    , installed 2.1.1
          Adapter    "klf200"       : 1.2.0    , installed 1.1.2  [Updatable]
          Adapter    "kodi"         : 3.1.0    , installed 2.0.8  [Updatable]
          Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.0  [Updatable]
          Adapter    "modbus"       : 6.2.3    , installed 5.0.11 [Updatable]
          Adapter    "mqtt"         : 5.2.0    , installed 2.4.1  [Updatable]
          Adapter    "netatmo"      : 3.1.0    , installed 1.4.4  [Updatable]
          Adapter    "nina"         : 0.0.26   , installed 0.0.25 [Updatable]
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "oilfox"       : 4.3.0    , installed 4.2.0  [Updatable]
          Adapter    "robonect"     : 1.3.5    , installed 1.3.4  [Updatable]
          Adapter    "samsung"      : 0.6.0    , installed 0.2.9  [Updatable]
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "shuttercontrol": 1.7.1   , installed 1.7.0  [Updatable]
          Adapter    "simple-api"   : 2.8.0    , installed 2.6.2  [Updatable]
          Adapter    "socketio"     : 6.7.0    , installed 3.1.5  [Updatable]
          Adapter    "sonnen"       : 1.18.1   , installed 1.17.0 [Updatable]
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "spotify-premium": 1.5.0  , installed 1.2.2  [Updatable]
          Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
          Adapter    "telegram"     : 3.6.0    , installed 3.0.1  [Updatable]
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "unifi"        : 0.7.0    , installed 0.6.0  [Updatable]
          Adapter    "unifi-protect": 1.0.1    , installed 0.0.12 [Updatable]
          Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
          Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
          Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.3  [Updatable]
          Adapter    "vis-hqwidgets": 1.5.1    , installed 1.1.9  [Updatable]
          Adapter    "vis-icontwo"  : 1.5.0    , installed 0.84.0 [Updatable]
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.2.5  [Updatable]
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
          Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.0.4  [Updatable]
          Adapter    "vis-map"      : 1.1.0    , installed 1.0.4  [Updatable]
          Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
          Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.5  [Updatable]
          Adapter    "vw-connect"   : 0.6.0    , installed 0.5.1  [Updatable]
          Adapter    "web"          : 6.2.6    , installed 3.4.13 [Updatable]
          Adapter    "wled"         : 0.7.3-beta.0, installed 0.6.7 [Updatable]
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        65631
          States:         49839
          Hit:1 http://deb.debian.org/debian buster InRelease
          Hit:2 http://security.debian.org/debian-security buster/updates InRelease
          Hit:3 http://deb.debian.org/debian buster-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 338
          *** Listening Ports ***
          tcp        0      0 192.168.1.188:12001     0.0.0.0:*               LISTEN      1000       489009     25111/io.hm-rpc.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       486212     24655/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       487751     24655/iobroker.js-c
          tcp        0      0 192.168.1.188:12010     0.0.0.0:*               LISTEN      1000       488096     25142/io.hm-rpc.1
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2321       1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19581      503/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          599348     27291/cupsd
          tcp6       0      0 :::61991                :::*                    LISTEN      1000       486923     25103/io.harmony.0
          tcp6       0      0 :::3500                 :::*                    LISTEN      1000       488220     25405/io.sonos.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          1692       1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       486265     24673/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          19583      503/sshd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          599347     27291/cupsd
          udp        0      0 0.0.0.0:44291           0.0.0.0:*                           112        17051      448/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18603      522/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2322       1/init
          udp        0    768 0.0.0.0:53421           0.0.0.0:*                           1000       489077     25183/io.mihome-vac
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       486924     25103/io.harmony.0
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          600109     27292/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       491687     26031/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17049      448/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       489810     25239/io.shelly.0
          udp        0      0 0.0.0.0:51075           0.0.0.0:*                           1000       489960     25552/io.kecontact.
          udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1000       490499     25552/io.kecontact.
          udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1000       490500     25552/io.kecontact.
          udp6       0      0 :::111                  :::*                                0          1695       1/init
          udp6       0      0 :::5353                 :::*                                112        17050      448/avahi-daemon: r
          udp6       0      0 :::35274                :::*                                112        17052      448/avahi-daemon: r
          J Thomas Braun 2 Replies Last reply Reply Quote 0
            JoeBaum @JoeBaum last edited by
            2024-06-20 06:02:13.285  - debug: zigbee.0 (28449) DeviceAvailability:Successful read state 'state' of '0x84182600000c6fb3' in stead of pinging
            2024-06-20 06:02:13.296  - debug: zigbee.0 (28449) Publish {"state":"ON"} to "84182600000c6fb3"
            2024-06-20 06:02:54.136  - debug: zigbee.0 (28449) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_applicationVersion":2,"_dateCode":"20191218","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Philips","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20191218","swBuildId":"1.50.2_r30933"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":1}}},"deviceIeeeAddress":"0x0017880102465914","deviceNetworkAddress":58971,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x0017880102465914"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x0017880102465914","deviceNetworkAddress":58971,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x0017880102465914"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0017880102465914","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856174136,"_manufacturerID":4107,"_manufacturerName":"Philips","_modelID":"LCT010","_networkAddress":58971,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.50.2_r30933","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":15,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":15,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":170,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2024-06-20 06:02:54.136  - debug: zigbee.0 (28449) Received Zigbee message from '0x0017880102465914', type 'readResponse', cluster 'genOnOff', data '{"onOff":1}' from endpoint 11 with groupID 0
            2024-06-20 06:02:54.137  - debug: zigbee.0 (28449) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_applicationVersion":2,"_dateCode":"20191218","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Philips","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20191218","swBuildId":"1.50.2_r30933"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":1}}},"deviceIeeeAddress":"0x0017880102465914","deviceNetworkAddress":58971,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x0017880102465914"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x0017880102465914","deviceNetworkAddress":58971,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x0017880102465914"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0017880102465914","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856174136,"_manufacturerID":4107,"_manufacturerName":"Philips","_modelID":"LCT010","_networkAddress":58971,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.50.2_r30933","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":15,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"mapped":{"toZigbee":[{"key":["state","brightness","brightness_percent","on_time"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["transition"]},{"key":["level_config"]},{"key":["rate"]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color","color_temp","color_temp_percent"],"options":[{"name":"color_sync","label":"Color sync","access":2,"type":"binary","property":"color_sync","description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","value_on":true,"value_off":false},{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_mode"]},{"key":["color_options"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_temp_startup"]},{"key":["hue_move","saturation_move"]},{"key":["hue_step","saturation_step"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["power_on_behavior"]},{"key":["hue_power_on_behavior"]},{"key":["hue_power_on_brightness","hue_power_on_color_temperature","hue_power_on_color"]},{"key":["effect"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"],"options":[{"name":"color_sync","label":"Color sync","access":2,"type":"binary","property":"color_sync","description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","value_on":true,"value_off":false}]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"light","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of this light","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"},{"name":"brightness","label":"Brightness","access":7,"type":"numeric","property":"brightness","description":"Brightness of this light","value_max":254,"value_min":0},{"name":"color_temp","label":"Color temp","access":7,"type":"numeric","property":"color_temp","description":"Color temperature of this light","unit":"mired","value_max":500,"value_min":153,"presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"}]},{"name":"color_temp_startup","label":"Color temp startup","access":7,"type":"numeric","property":"color_temp_startup","description":"Color temperature after cold power on of this light","unit":"mired","value_max":500,"value_min":153,"presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]},{"name":"color_xy","label":"Color (X/Y)","access":7,"type":"composite","property":"color","description":"Color of this light in the CIE 1931 color space (x/y)","features":[{"name":"x","label":"X","access":7,"type":"numeric","property":"x"},{"name":"y","label":"Y","access":7,"type":"numeric","property":"y"}]},{"name":"color_hs","label":"Color (HS)","access":7,"type":"composite","property":"color","description":"Color of this light expressed as hue/saturation","features":[{"name":"hue","label":"Hue","access":7,"type":"numeric","property":"hue"},{"name":"saturation","label":"Saturation","access":7,"type":"numeric","property":"saturation"}]}]},{"name":"power_on_behavior","label":"Power-on behavior","access":7,"type":"enum","property":"power_on_behavior","description":"Controls the behavior when the device is powered on after power loss. If you get an `UNSUPPORTED_ATTRIBUTE` error, the device does not support it.","category":"config","values":["off","on","toggle","previous"]},{"name":"effect","label":"Effect","access":2,"type":"enum","property":"effect","values":["blink","breathe","okay","channel_change","candle","fireplace","colorloop","finish_effect","stop_effect","stop_hue_effect"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"meta":{"supportsHueAndSaturation":true,"turnsOffAtBrightness1":true},"ota":{},"zigbeeModel":["LCT001","LCT007","LCT010","LCT012","LCT014","LCT015","LCT016","LCT021"],"model":"9290012573A","vendor":"Philips","description":"Hue white and color ambiance E26/E27/E14","options":["[Circular]","[Circular]","[Circular]"]},"name":"0x0017880102465914"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_applicationVersion":2,"_dateCode":"20191218","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Philips","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20191218","swBuildId":"1.50.2_r30933"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":1}}},"deviceIeeeAddress":"0x0017880102465914","deviceNetworkAddress":58971,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x0017880102465914"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x0017880102465914","deviceNetworkAddress":58971,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x0017880102465914"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0017880102465914","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856174136,"_manufacturerID":4107,"_manufacturerName":"Philips","_modelID":"LCT010","_networkAddress":58971,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.50.2_r30933","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":15,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":15,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":170,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2024-06-20 06:02:54.138  - debug: zigbee.0 (28449) DeviceAvailability:Successful read state 'state' of '0x0017880102465914' in stead of pinging
            2024-06-20 06:02:54.150  - debug: zigbee.0 (28449) Publish {"state":"ON"} to "0017880102465914"
            2024-06-20 06:02:56.566  - debug: zigbee.0 (28449) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":20,"_applicationVersion":2,"_dateCode":"20210331","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,64515,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20210331","swBuildId":"1.88.1"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":1}}},"deviceIeeeAddress":"0x00178801023c7578","deviceNetworkAddress":59784,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x00178801023c7578"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x00178801023c7578","deviceNetworkAddress":59784,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x00178801023c7578"}}],"_hardwareVersion":1,"_ieeeAddr":"0x00178801023c7578","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856176566,"_manufacturerID":4107,"_manufacturerName":"Signify Netherlands B.V.","_modelID":"LCT010","_networkAddress":59784,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.88.1","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":18,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":18,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":171,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2024-06-20 06:02:56.567  - debug: zigbee.0 (28449) Received Zigbee message from '0x00178801023c7578', type 'readResponse', cluster 'genOnOff', data '{"onOff":1}' from endpoint 11 with groupID 0
            2024-06-20 06:02:56.568  - debug: zigbee.0 (28449) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":20,"_applicationVersion":2,"_dateCode":"20210331","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,64515,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20210331","swBuildId":"1.88.1"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":1}}},"deviceIeeeAddress":"0x00178801023c7578","deviceNetworkAddress":59784,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x00178801023c7578"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x00178801023c7578","deviceNetworkAddress":59784,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x00178801023c7578"}}],"_hardwareVersion":1,"_ieeeAddr":"0x00178801023c7578","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856176566,"_manufacturerID":4107,"_manufacturerName":"Signify Netherlands B.V.","_modelID":"LCT010","_networkAddress":59784,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.88.1","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":18,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"mapped":{"toZigbee":[{"key":["state","brightness","brightness_percent","on_time"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["transition"]},{"key":["level_config"]},{"key":["rate"]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color","color_temp","color_temp_percent"],"options":[{"name":"color_sync","label":"Color sync","access":2,"type":"binary","property":"color_sync","description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","value_on":true,"value_off":false},{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_mode"]},{"key":["color_options"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_temp_startup"]},{"key":["hue_move","saturation_move"]},{"key":["hue_step","saturation_step"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["power_on_behavior"]},{"key":["hue_power_on_behavior"]},{"key":["hue_power_on_brightness","hue_power_on_color_temperature","hue_power_on_color"]},{"key":["effect"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"],"options":[{"name":"color_sync","label":"Color sync","access":2,"type":"binary","property":"color_sync","description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","value_on":true,"value_off":false}]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"light","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of this light","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"},{"name":"brightness","label":"Brightness","access":7,"type":"numeric","property":"brightness","description":"Brightness of this light","value_max":254,"value_min":0},{"name":"color_temp","label":"Color temp","access":7,"type":"numeric","property":"color_temp","description":"Color temperature of this light","unit":"mired","value_max":500,"value_min":153,"presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"}]},{"name":"color_temp_startup","label":"Color temp startup","access":7,"type":"numeric","property":"color_temp_startup","description":"Color temperature after cold power on of this light","unit":"mired","value_max":500,"value_min":153,"presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]},{"name":"color_xy","label":"Color (X/Y)","access":7,"type":"composite","property":"color","description":"Color of this light in the CIE 1931 color space (x/y)","features":[{"name":"x","label":"X","access":7,"type":"numeric","property":"x"},{"name":"y","label":"Y","access":7,"type":"numeric","property":"y"}]},{"name":"color_hs","label":"Color (HS)","access":7,"type":"composite","property":"color","description":"Color of this light expressed as hue/saturation","features":[{"name":"hue","label":"Hue","access":7,"type":"numeric","property":"hue"},{"name":"saturation","label":"Saturation","access":7,"type":"numeric","property":"saturation"}]}]},{"name":"power_on_behavior","label":"Power-on behavior","access":7,"type":"enum","property":"power_on_behavior","description":"Controls the behavior when the device is powered on after power loss. If you get an `UNSUPPORTED_ATTRIBUTE` error, the device does not support it.","category":"config","values":["off","on","toggle","previous"]},{"name":"effect","label":"Effect","access":2,"type":"enum","property":"effect","values":["blink","breathe","okay","channel_change","candle","fireplace","colorloop","finish_effect","stop_effect","stop_hue_effect"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"meta":{"supportsHueAndSaturation":true,"turnsOffAtBrightness1":true},"ota":{},"zigbeeModel":["LCT001","LCT007","LCT010","LCT012","LCT014","LCT015","LCT016","LCT021"],"model":"9290012573A","vendor":"Philips","description":"Hue white and color ambiance E26/E27/E14","options":["[Circular]","[Circular]","[Circular]"]},"name":"0x00178801023c7578"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":20,"_applicationVersion":2,"_dateCode":"20210331","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,64515,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20210331","swBuildId":"1.88.1"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":1}}},"deviceIeeeAddress":"0x00178801023c7578","deviceNetworkAddress":59784,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x00178801023c7578"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x00178801023c7578","deviceNetworkAddress":59784,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x00178801023c7578"}}],"_hardwareVersion":1,"_ieeeAddr":"0x00178801023c7578","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856176566,"_manufacturerID":4107,"_manufacturerName":"Signify Netherlands B.V.","_modelID":"LCT010","_networkAddress":59784,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.88.1","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":18,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":18,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":171,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2024-06-20 06:02:56.570  - debug: zigbee.0 (28449) DeviceAvailability:Successful read state 'state' of '0x00178801023c7578' in stead of pinging
            2024-06-20 06:02:56.631  - debug: zigbee.0 (28449) Publish {"state":"ON"} to "00178801023c7578"
            2024-06-20 06:02:57.801  - debug: zigbee.0 (28449) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"_applicationVersion":2,"_dateCode":"20210331","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,64515,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20210331","swBuildId":"1.88.1"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x0017880102464b47","deviceNetworkAddress":51066,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x0017880102464b47"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x0017880102464b47","deviceNetworkAddress":51066,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x0017880102464b47"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0017880102464b47","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856177800,"_manufacturerID":4107,"_manufacturerName":"Signify Netherlands B.V.","_modelID":"LCT010","_networkAddress":51066,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.88.1","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":36,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":36,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":172,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2024-06-20 06:02:57.801  - debug: zigbee.0 (28449) Received Zigbee message from '0x0017880102464b47', type 'readResponse', cluster 'genOnOff', data '{"onOff":0}' from endpoint 11 with groupID 0
            2024-06-20 06:02:57.802  - debug: zigbee.0 (28449) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"_applicationVersion":2,"_dateCode":"20210331","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,64515,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20210331","swBuildId":"1.88.1"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x0017880102464b47","deviceNetworkAddress":51066,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x0017880102464b47"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x0017880102464b47","deviceNetworkAddress":51066,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x0017880102464b47"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0017880102464b47","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856177800,"_manufacturerID":4107,"_manufacturerName":"Signify Netherlands B.V.","_modelID":"LCT010","_networkAddress":51066,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.88.1","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":36,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"mapped":{"toZigbee":[{"key":["state","brightness","brightness_percent","on_time"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["transition"]},{"key":["level_config"]},{"key":["rate"]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color","color_temp","color_temp_percent"],"options":[{"name":"color_sync","label":"Color sync","access":2,"type":"binary","property":"color_sync","description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","value_on":true,"value_off":false},{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_mode"]},{"key":["color_options"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_temp_startup"]},{"key":["hue_move","saturation_move"]},{"key":["hue_step","saturation_step"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["power_on_behavior"]},{"key":["hue_power_on_behavior"]},{"key":["hue_power_on_brightness","hue_power_on_color_temperature","hue_power_on_color"]},{"key":["effect"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"],"options":[{"name":"color_sync","label":"Color sync","access":2,"type":"binary","property":"color_sync","description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","value_on":true,"value_off":false}]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"light","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of this light","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"},{"name":"brightness","label":"Brightness","access":7,"type":"numeric","property":"brightness","description":"Brightness of this light","value_max":254,"value_min":0},{"name":"color_temp","label":"Color temp","access":7,"type":"numeric","property":"color_temp","description":"Color temperature of this light","unit":"mired","value_max":500,"value_min":153,"presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"}]},{"name":"color_temp_startup","label":"Color temp startup","access":7,"type":"numeric","property":"color_temp_startup","description":"Color temperature after cold power on of this light","unit":"mired","value_max":500,"value_min":153,"presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":500,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]},{"name":"color_xy","label":"Color (X/Y)","access":7,"type":"composite","property":"color","description":"Color of this light in the CIE 1931 color space (x/y)","features":[{"name":"x","label":"X","access":7,"type":"numeric","property":"x"},{"name":"y","label":"Y","access":7,"type":"numeric","property":"y"}]},{"name":"color_hs","label":"Color (HS)","access":7,"type":"composite","property":"color","description":"Color of this light expressed as hue/saturation","features":[{"name":"hue","label":"Hue","access":7,"type":"numeric","property":"hue"},{"name":"saturation","label":"Saturation","access":7,"type":"numeric","property":"saturation"}]}]},{"name":"power_on_behavior","label":"Power-on behavior","access":7,"type":"enum","property":"power_on_behavior","description":"Controls the behavior when the device is powered on after power loss. If you get an `UNSUPPORTED_ATTRIBUTE` error, the device does not support it.","category":"config","values":["off","on","toggle","previous"]},{"name":"effect","label":"Effect","access":2,"type":"enum","property":"effect","values":["blink","breathe","okay","channel_change","candle","fireplace","colorloop","finish_effect","stop_effect","stop_hue_effect"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"meta":{"supportsHueAndSaturation":true,"turnsOffAtBrightness1":true},"ota":{},"zigbeeModel":["LCT001","LCT007","LCT010","LCT012","LCT014","LCT015","LCT016","LCT021"],"model":"9290012573A","vendor":"Philips","description":"Hue white and color ambiance E26/E27/E14","options":["[Circular]","[Circular]","[Circular]"]},"name":"0x0017880102464b47"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"_applicationVersion":2,"_dateCode":"20210331","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,64515,768,64513],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20210331","swBuildId":"1.88.1"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x0017880102464b47","deviceNetworkAddress":51066,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x0017880102464b47"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x0017880102464b47","deviceNetworkAddress":51066,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x0017880102464b47"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0017880102464b47","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1718856177800,"_manufacturerID":4107,"_manufacturerName":"Signify Netherlands B.V.","_modelID":"LCT010","_networkAddress":51066,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.88.1","_stackVersion":1,"_type":"Router","_zclVersion":1,"_linkquality":36,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"meta":{"configured":2}},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":36,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":172,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2024-06-20 06:02:57.802  - debug: zigbee.0 (28449) DeviceAvailability:Successful read state 'state' of '0x0017880102464b47' in stead of pinging
            2024-06-20 06:02:57.814  - debug: zigbee.0 (28449) Publish {"state":"OFF"} to "0017880102464b47"
            2024-06-20 06:03:06.295  - debug: zigbee.0 (28449) DeviceAvailability:Non-pingable device 0x00158d00057f8249 lumi.sensor_motion.aq2 was last seen '779.361' seconds ago.
            2024-06-20 06:03:06.295  - debug: zigbee.0 (28449) DeviceAvailability:Non-pingable device 0x00158d00054cb2c5 lumi.weather was last seen '29226707.704' seconds ago.
            2024-06-20 06:03:06.296  - debug: zigbee.0 (28449) DeviceAvailability:Non-pingable device 0x00158d00054bdf58 lumi.weather was last seen '1770815.955' seconds ago.
            2024-06-20 06:03:06.297  - debug: zigbee.0 (28449) DeviceAvailability:Non-pingable device 0x00158d00054ba0ff lumi.weather was last seen '30569952.722' seconds ago.
            2024-06-20 06:03:06.298  - debug: zigbee.0 (28449) DeviceAvailability:Non-pingable device 0x00158d000456d9de lumi.sensor_magnet.aq2 was last seen '12470587.417' seconds ago.
            2024-06-20 06:03:06.298  - debug: zigbee.0 (28449) DeviceAvailability:Non-pingable device 0x00158d00054d64d0 lumi.sensor_magnet.aq2 was last seen '2469836.43' seconds ago.
            2024-06-20 06:03:06.298  - debug: zigbee.0 (28449) DeviceAvailability:Non-pingable device 0x00158d00044e7f73 lumi.sensor_magnet.aq2 was last seen '35290404.709' seconds ago.
            2024-06-20 06:03:06.298  - debug: zigbee.0 (28449) DeviceAvailability:Non-pingable device 0x00158d00044f32d9 lumi.sensor_magnet.aq2 was last seen '2744.013' seconds ago.
              Frank579 @JoeBaum last edited by
              @joebaum ganz ehrlich? Du willst eine (recht frühe) BETA Version vom JS Controller testen. Dein System ist aber aus der Steinzeit 🙈. --> Backup ziehen, Aktuelles OS + IOBroker neu installieren , Backup einspielen, Adapter Updaten. Dann weiter sehen, ich würde aber an deiner Stelle auf Stable bleiben 😉
                Thomas Braun Most Active @JoeBaum last edited by Thomas Braun
                @joebaum
                Debian 10 Buster ist zu alt und längst abgekündigt.
                Installier da NEU Debian 12 'Bookworm'
                Das neue System dann gleich OHNE Desktop aufsetzen:
                Display-Server: true
                Boot Target: graphical.target
                Und regelmäßig bzw. mal überhaupt updaten dann:
                Pending OS-Updates: 338
                Pending iob updates: 45
                Einen anderen username als iobroker. Dein Vorname eignet sich da z. B. hervorragend.
                Diesen user dann in die Gruppe adm packen.
                Setz den ioBroker auf das stable-Repository. Kein Developer braucht Betatestings gegen alte Versionen.
                  JoeBaum @Thomas Braun last edited by
                  @thomas-braun Ich habe nun Debian 12 installiert und entsprechend alles per Backup eingespielt. zunächst äußerte sich das Problem exakt gleich wie bei der alten Konfiguration. Nach dem Update des Web Server Adapters war das Problem weg.
                  In dem Zuge habe ich auch gleich noch den User geändert.
                  Vielen Dank für die Hilfe, nun läuft wieder alles stabil.
                  Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                    @joebaum sagte in JS-Controller 6.0.5 NodeJS 18:
                    Und deswegen hält man das komplette Konstrukt halt immer auf einem aktuellen, stabilen Stand. Also Betriebssystem, Laufzeitumgebung, js-controller, ioBroker-Adapter.
                    Das spielt ja alles zusammen.
                    • mcm1957
                      mcm1957 @JoeBaum last edited by
                      @joebaum said in (gelöst) JS-Controller 6.0.5 NodeJS 18:
                      Deswegen sollte man auch den js-controller 6 Test Topic lesen bevor man js-controller 6 installiert, Da steht im 2ten Beitrag eine Liste von Adapetrn die aktualisiert werden müssen 🙂
                      Aber hauptsache es geht jetzt.
                      Ansonsten bitte mit js-controller 6 Problemen im js-controller 6 Topic melden:
                      https://forum.iobroker.net/topic/75206/beta-test-js-controller-kiera-v6-0
                      @Homoran
                      Ev. bitte hier schließen. js-controlelr 6 Dinge sollten im Haupttopic bleiben.
                        Homoran Global Moderator Administrators @mcm1957 last edited by
                        @mcm1957 sorry, der ist mir durchgerutscht.
                        800
