    4. JavaScript Adapter 8.0.0
    • mcm1957
      mcm1957 @Diginix last edited by mcm1957
      @diginix
      Wie installierst du die Betas?
      "Normal" via UI im Admin Interface?
      Oder über die Katze?
      Oder ...
      Frage storniert - hast eh einen log gepostet
      • Diginix
        Diginix @mcm1957 last edited by Diginix
        @mcm1957 Ausschließlich im Adapter Tab vom Admin.
        Edit: Updates aller anderen Adapter laufen alle inkl Upload mit Exit Code 0 durch.
        (zuletzt zB Admin, Telegram, Backitup, email)
        • Diginix
          Auch mit node 20.14.0 und js-controller 6.0.4 muss ich beim javascript Adapter den upload manuell nach jedem Update machen. Alle anderen Adapter aktualisieren sich komplett fehlerfrei.
          Ausgabe vom Update mit unvollständigem upload:
          $ iobroker upgrade javascript@8.6.0 --debug
          Update javascript from @8.5.2 to @8.6.0
          NPM version: 10.7.0
          Installing iobroker.javascript@8.6.0... (System call)
          npm warn ERESOLVE overriding peer dependency
          npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warnnpm warn Conflicting peer dependency: @iobroker/types@5.0.19npm warn node_modules/@iobroker/typesnpm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
          changed 1 package in 19s190 packages are looking for funding run `npm fund` for details
          Update "system.adapter.javascript.0"
          upload [754] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
          upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
          upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_system_esm_GlobalStyles_GlobalStyles_js-node_modules_mui_system_esm_-8241e1.b8c9d73a.chunk.js.map custom/static/js/vendors-node_modules_mui_system_esm_GlobalStyles_GlobalStyles_js-node_modules_mui_system_esm_-8241e1.b8c9d73a.chunk.js.map application/json
          upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_switch.js google-blockly/own/blocks_switch.js application/javascript
          upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/122.405c394f.chunk.js.map static/js/122.405c394f.chunk.js.map application/json
          upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/239.4b3a951a.chunk.js static/js/239.4b3a951a.chunk.js application/javascript
          ERROR: Process exited with code null
          Ausgabe vom manuellen upload:
          $ iobroker upload javascript --debug
          upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/335.9591bd2c.chunk.js.map static/js/335.9591bd2c.chunk.js.map application/json
          upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.a78d4702.chunk.js.map static/js/409.a78d4702.chunk.js.map application/json
          upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/498.660757a3.chunk.js.map static/js/498.660757a3.chunk.js.map application/json
          upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/704.7f142efd.chunk.js.map static/js/704.7f142efd.chunk.js.map application/json
          upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/837.70f35e1e.chunk.js.map static/js/837.70f35e1e.chunk.js.map application/json
          upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/928.f1f4f4bb.chunk.js static/js/928.f1f4f4bb.chunk.js application/javascript
          upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.5424e0d7.js.map static/js/main.5424e0d7.js.map application/json
          upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Ceiling Spotlights.485822441b5df3b3384a.svg static/media/Ceiling Spotlights.485822441b5df3b3384a.svg image/svg+xml
          upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Area.1c29b81e75b75e3310db.svg static/media/Living Area.1c29b81e75b75e3310db.svg image/svg+xml
          upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Outdoors.da42e64a4b6ec2dd1e1c.svg static/media/Outdoors.da42e64a4b6ec2dd1e1c.svg image/svg+xml
          upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Second Floor.a2d5ed32df336591c06b.svg static/media/Second Floor.a2d5ed32df336591c06b.svg image/svg+xml
          upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Stairwell.0914feea948153a8637a.svg static/media/Stairwell.0914feea948153a8637a.svg image/svg+xml
          upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
          upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
          upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
          upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/coffee/coffee.js vs/basic-languages/coffee/coffee.js application/javascript
          upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
          upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
          upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
          upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
          upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
          upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
          upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
          upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
          upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
          upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
          upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
          upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
          upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
          upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
          upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
          upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
          upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
          upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
          upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
          upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
          upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
          Process exited with code 0
          Bin für jeden Tipp dankbar.
            Thomas Braun Most Active @Diginix last edited by
            @diginix
            Hast du den admin mal neuinstalliert?
            Diginix 1 Reply Last reply Reply Quote 1
            • Diginix
              Diginix @Thomas Braun last edited by Diginix
              @thomas-braun Bisher nicht. Updates aller anderen Adapter funktionieren vollautomatisch. An den "/opt/iobroker/node_modules/iobroker.javascript/..." Dateien vom javascript Adapter liegt es nicht?
              Weil da bricht ja der automatische upload immer ab. Aber beim nachträglichen manuellen upload klappt es dann mit allen Dateien.
                @diginix
                Schaut für mich eher nach einem Thema beim admin aus:
                • Diginix
                  @thomas-braun Ok, da hast du definitiv mehr know-how. Soll ich 6.17.14 einfach nochmal im Admin selbst hierüber drüber inst?
                    @diginix
                    Ich würde sowas immer über die Kommandozeile machen.
                    iob update
                    iob upgrade admin@6.17.14 --omit=dev
                    • Diginix
                      @thomas-braun Ok, hab schon vor deiner Antw. den admin nochmal über die GUI neu inst. Und danach das gleiche beim javascript. Nun lief es mit exit code 0 durch. Ob das beim nächsten "echten" Update dann auch so ist, wird sich zeigen.
                      Ausgabe der javascript Inst.:
                      Update javascript from @8.6.0 to @8.6.0
                      Uninstall npm packet "iobroker.javascript" for a clean re-installation
                      192 packages are looking for funding run `npm fund` for details
                      NPM version: 10.7.0
                      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                      added 17 packages in 14s
                      • Diginix
                        Diginix @Diginix last edited by
                        @haus-automatisierung
                        Leider klappt ein echtes Versionsupdate von javascript weiterhin nicht vollautomatisch inkl. sauberem upload. Admin ist mittlerweile 7.0.2 und alle Tipps von @Thomas-Braun hatte ich auch probiert.
                        NPM version: 10.7.0
                        changed 1 package in 11s
                        Danach laufen alle Skripte, aber man kann keine Skripte bearbeiten. Wie hier https://forum.iobroker.net/topic/73946/javascript-adapter-8-0-0/41?_=1719305444921 schon geschrieben.
                        Der upload steigt immer bei diesen javascript/admin/static/js/???.chunk.js.map Dateien aus.
                        Nach manuellem upload des Adapter im Admin, passt dann alles:
                        admin: 7.0.2
                        nodejs: 20.15.0
                        js-controller: 6.0.5
                        javascript update von 8.5.2 auf 8.6.0 (aber war auch schon bei update von 8.5.x auf 8.5.y)
                        51
                        5837
