    4. Timeout & "Cannot read repository"
      Thomas Braun Most Active @Happyuser20 last edited by
      @happyuser20 sagte in Timeout & "Cannot read repository":
      wo kann ich ansetzen um das zu beheben bzw. den Verursacher zu finden.
      Schau dir das Setup per
      iob diag
      an.
        Was kann ich da rauslesen? 😬
        Skript v.2024-05-22
        *** BASE SYSTEM ***
        /home/iobroker/.diag.sh: line 66: hostnamectl: command not found
        model name      : Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
        Docker          : false
        /home/iobroker/.diag.sh: line 191: timedatectl: command not found
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         10:07:42 up 22:34,  0 users,  load average: 4.43, 4.48, 4.34
        CPU threads: 2
        *** Time and Time Zones ***
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        iobroker
        sudo: unable to resolve host iobroker: Name or service not known
        HOME=/opt/iobroker
        GROUPS=iobroker tty dialout audio video
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:
        /home/iobroker/.diag.sh: line 227: systemctl: command not found
        Boot Target:
        *** MEMORY ***
        Mem:            15G        5.0G        6.4G        136M        4.5G         10G
        Swap:           11G          0B         11G
        Total:          27G        5.0G         17G
        Active iob-Instances:   41
                15854 M total memory
                 5018 M used memory
                 5931 M active memory
                 2690 M inactive memory
                 6383 M free memory
                  582 M buffer memory
                 3869 M swap cache
                11561 M total swap
                    0 M used swap
                11561 M free swap
        top - 10:07:43 up 22:34,  0 users,  load average: 4.43, 4.48, 4.34
        Tasks:  48 total,   4 running,  44 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 58.1 us,  9.7 sy,  0.0 ni, 32.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  15854.1 total,   6388.2 free,   5013.8 used,   4452.1 buff/cache
        MiB Swap:  11561.9 total,  11561.9 free,      0.0 used.  10376.0 avail Mem
        *** FAILED SERVICES ***
        /home/iobroker/.diag.sh: line 254: systemctl: command not found
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        none           aufs   3.6T  3.0T  638G  83% /
        tmpfs          tmpfs   64M     0   64M   0% /dev
        tmpfs          tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
        /dev/md2       ext4   3.6T  3.0T  638G  83% /opt/iobroker
        shm            tmpfs   64M     0   64M   0% /dev/shm
        tmpfs          tmpfs  7.8G     0  7.8G   0% /proc/acpi
        tmpfs          tmpfs  7.8G     0  7.8G   0% /proc/scsi
        tmpfs          tmpfs  7.8G     0  7.8G   0% /sys/firmware
        [Tue Jun 25 11:33:49 2024] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem
        [Tue Jun 25 11:33:49 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
        [Tue Jun 25 11:33:49 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
        [Tue Jun 25 11:33:56 2024] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem
        [Tue Jun 25 11:33:56 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
        [Tue Jun 25 11:33:57 2024] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem
        [Tue Jun 25 11:33:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
        [Tue Jun 25 11:34:23 2024] EXT4-fs (md2): barriers disabled
        [Tue Jun 25 11:34:23 2024] EXT4-fs (md2): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl
        Show mounted filesystems:
        TARGET                           SOURCE        FSTYPE OPTIONS
        /                                none        aufs   rw,relatime,si=7d6ee40d85ed2f3c,dio,dirperm1
        |-/proc                          proc        proc   rw,nosuid,nodev,noexec,relatime
        | |-/proc/bus                    proc[/bus]        proc   ro,nosuid,nodev,noexec,relatime
        | |-/proc/fs                     proc[/fs]        proc   ro,nosuid,nodev,noexec,relatime
        | |-/proc/irq                    proc[/irq]        proc   ro,nosuid,nodev,noexec,relatime
        | |-/proc/sys                    proc[/sys]        proc   ro,nosuid,nodev,noexec,relatime
        | |-/proc/sysrq-trigger          proc[/sysrq-trigger]        proc   ro,nosuid,nodev,noexec,relatime
        | |-/proc/acpi                   tmpfs        tmpfs  ro,relatime
        | |-/proc/kcore                  tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
        | |-/proc/keys                   tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
        | |-/proc/timer_list             tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
        | |-/proc/sched_debug            tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
        | `-/proc/scsi                   tmpfs        tmpfs  ro,relatime
        |-/dev                           tmpfs        tmpfs  rw,nosuid,size=65536k,mode=755
        | |-/dev/console                 devpts[/0]        devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
        | |-/dev/pts                     devpts        devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
        | |-/dev/mqueue                  mqueue        mqueue rw,nosuid,nodev,noexec,relatime
        | `-/dev/shm                     shm        tmpfs  rw,nosuid,nodev,noexec,relatime,size=65536k
        |-/sys                           sysfs        sysfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/firmware                tmpfs        tmpfs  ro,relatime
        | `-/sys/fs/cgroup               tmpfs        tmpfs  rw,nosuid,nodev,noexec,relatime,mode=755
        |   |-/sys/fs/cgroup/systemd     cgroup[/docker/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9]                           cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd
        |   |-/sys/fs/cgroup/synomonitor cgroup[/system.slice/pkg-ContainerManager-dockerd.service]                                                 cgroup rw,nosuid,nodev,noexec,relatime,name=synomonitor
        |   |-/sys/fs/cgroup/memory      cgroup[/docker/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9]                           cgroup rw,nosuid,nodev,noexec,relatime,memory
        |   |-/sys/fs/cgroup/cpu         cgroup[/docker/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9]                           cgroup rw,nosuid,nodev,noexec,relatime,cpu
        |   |-/sys/fs/cgroup/cpuacct     cgroup[/docker/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9]                           cgroup rw,nosuid,nodev,noexec,relatime,cpuacct
        |   |-/sys/fs/cgroup/cpuset      cgroup[/docker/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9]                           cgroup rw,nosuid,nodev,noexec,relatime,cpuset
        |   |-/sys/fs/cgroup/freezer     cgroup[/docker/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9]                           cgroup rw,nosuid,nodev,noexec,relatime,freezer
        |   |-/sys/fs/cgroup/devices     cgroup[/docker/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9]                           cgroup rw,nosuid,nodev,noexec,relatime,devices
        |   `-/sys/fs/cgroup/blkio       cgroup[/docker/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9]                           cgroup rw,nosuid,nodev,noexec,relatime,blkio
        |-/opt/iobroker                  /dev/md2[/docker/iobroker_data]        ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
        |-/etc/resolv.conf               /dev/md2[/@docker/containers/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9/resolv.conf] ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
        |-/etc/hostname                  /dev/md2[/@docker/containers/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9/hostname]    ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
        `-/etc/hosts                     /dev/md2[/@docker/containers/b8d452b3801d968a8c641430b33b66a4f32c2d23d1d8a4dac880f761fe76d8e9/hosts]       ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
        /var:
        34M     /var/
        31M     /var/lib
        18M     /var/lib/apt/lists
        18M     /var/lib/apt
        14M     /var/lib/dpkg
        /home/iobroker/.diag.sh: line 278: journalctl: command not found
        /opt/iobroker/backups:
        402M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        8.0G    /opt/iobroker/iobroker-data/
        7.0G    /opt/iobroker/iobroker-data/History
        635M    /opt/iobroker/iobroker-data/files
        196M    /opt/iobroker/iobroker-data/backup-objects
        139M    /opt/iobroker/iobroker-data/files/javascript.admin
        40M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        26M     /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x buster/main amd64 Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u4 500
                500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
             10.24.0~dfsg-1~deb10u1 500
                500 http://deb.debian.org/debian buster/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.17.14
        javascript:     8.3.1
        nodejs modules from github:     12
        +-- iobroker.apple-find-me@0.0.15 (git+ssh://git@github.com/PfisterDaniel/ioBroker.apple-find-me.git#b7d022dd3412d6945d1a380b53e7c75f10fbecde)
        +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#fd28f98d7ec46f36f4a2dae2d9ac740966453704)
        +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
        +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#e43b4427386d3425f3347c0dfea37331650e72af)
        +-- iobroker.fronius-solarweb@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#ca2f1a4972992cbd0d14bb25f5f7546219dd5b9e)
        +-- iobroker.klipper-moonraker@0.0.4 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#3d592b417b27cde2561a470eb7958ee43b6d8a0a)
        +-- iobroker.linkeddevices@1.5.5 (git+ssh://git@github.com/Scrounger/ioBroker.linkeddevices.git#2fee2ef78373864dc939f4c858dfc6ed49c780f3)
        +-- iobroker.smartgarden@2.0.0 (git+ssh://git@github.com/jpgorganizer/ioBroker.smartgarden.git#2d972262d6f1dffb2cda512705f7a546359a5e99)
        +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
        +-- iobroker.spritmonitor@0.0.2-beta.10 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#4059f9e2e3019b0a025fd7af850c259a84a797de)
        | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bambulab.0               : bambulab              : iobroker                                 -  enabled, port: 8883
          system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        + system.adapter.ds18b20.0                : ds18b20               : Slave-Heizraum                           -  enabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
        + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
        + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
          system.adapter.mqtt-client.0            : mqtt-client           : raspberry_Heizraum_slave                 - disabled, port: 1883
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          system.adapter.reolink.0                : reolink               : iobroker                                 - disabled
          system.adapter.rpi2.2                   : rpi2                  : iobroker                                 - disabled
          system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
        + system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
          system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.spritmonitor.0           : spritmonitor          : iobroker                                 -  enabled
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          system.adapter.trashschedule.1          : trashschedule         : iobroker                                 - disabled
        + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        + system.adapter.viessmann.0              : viessmann             : Slave-Heizraum                           -  enabled, port: 3002
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 6.17.14  , installed 6.17.14
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "birthdays"    : 3.0.0    , installed 3.0.0
        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
        Adapter    "fronius"      : 2.1.0    , installed 2.1.0
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "hass"         : 1.4.0    , installed 1.4.0
        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
        Adapter    "hmip"         : 1.23.3   , installed 1.23.3
        Adapter    "i2c"          : 1.2.1    , installed 1.2.1
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.3.1    , installed 8.3.1
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "owfs"         : 0.7.0    , installed 0.7.0
        Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "reolink"      : 1.1.0    , installed 1.1.0
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Objects and States
        Objects:        28175
        States:         0
        Hit:1 http://security.debian.org/debian-security buster/updates InRelease
        Hit:2 http://deb.debian.org/debian buster InRelease
        Hit:3 http://deb.debian.org/debian buster-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x buster InRelease
        Reading package lists...
        Pending Updates: 149
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          31525      -
        tcp        0      0 0.0.0.0:7000            0.0.0.0:*               LISTEN      0          82469      -
        tcp        0      0 0.0.0.0:7000            0.0.0.0:*               LISTEN      0          82459      -
        tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         66172      -
        tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          64251      -
        tcp        0      0 0.0.0.0:88              0.0.0.0:*               LISTEN      0          25384      -
        tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          104530     -
        tcp        0      0 127.0.0.1:18617         0.0.0.0:*               LISTEN      0          91063      -
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       146290     579/io.shelly.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       140535     470/io.mqtt.0
        tcp        0      0 0.0.0.0:8123            0.0.0.0:*               LISTEN      0          103935     -
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          38475      -
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          38467      -
        tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          31274      -
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          46160      -
        tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          106885     -
        tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          82465      -
        tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          82455      -
        tcp        0      0 0.0.0.0:8001            0.0.0.0:*               LISTEN      0          82467      -
        tcp        0      0 0.0.0.0:8001            0.0.0.0:*               LISTEN      0          82457      -
        tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          44674      -
        tcp        0      0 0.0.0.0:161             0.0.0.0:*               LISTEN      0          37250      -
        tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          86366      -
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       132313     224/iobroker.js-con
        tcp        0      0 192.168.1.111:49160     0.0.0.0:*               LISTEN      0          90816      -
        tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          38469      -
        tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          38461      -
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       132304     224/iobroker.js-con
        tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          38471      -
        tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          38463      -
        tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN      0          88603      -
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          46161      -
        tcp        0      0 0.0.0.0:9900            0.0.0.0:*               LISTEN      0          82471      -
        tcp        0      0 0.0.0.0:9900            0.0.0.0:*               LISTEN      0          82461      -
        tcp        0      0 0.0.0.0:9901            0.0.0.0:*               LISTEN      0          82473      -
        tcp        0      0 0.0.0.0:9901            0.0.0.0:*               LISTEN      0          82463      -
        tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          44695      -
        tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          40098      -
        tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          40096      -
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23020      -
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          38473      -
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          38465      -
        tcp        0      0 192.168.1.111:50001     0.0.0.0:*               LISTEN      0          80070      -
        tcp        0      0 0.0.0.0:50002           0.0.0.0:*               LISTEN      0          80400      -
        tcp        0      0 192.168.1.111:49170     0.0.0.0:*               LISTEN      254178     80348      -
        tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          44303      -
        tcp6       0      0 :::8086                 :::*                    LISTEN      1000       110869     -
        tcp6       0      0 :::662                  :::*                    LISTEN      0          31531      -
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       157816     825/io.simple-api.0
        tcp6       0      0 :::7000                 :::*                    LISTEN      0          82470      -
        tcp6       0      0 :::7000                 :::*                    LISTEN      0          82460      -
        tcp6       0      0 :::88                   :::*                    LISTEN      0          25386      -
        tcp6       0      0 :::8889                 :::*                    LISTEN      0          104533     -
        tcp6       0      0 :::43675                :::*                    LISTEN      0          107635     -
        tcp6       0      0 :::8123                 :::*                    LISTEN      0          103938     -
        tcp6       0      0 :::443                  :::*                    LISTEN      0          38476      -
        tcp6       0      0 :::443                  :::*                    LISTEN      0          38468      -
        tcp6       0      0 :::892                  :::*                    LISTEN      0          31280      -
        tcp6       0      0 :::445                  :::*                    LISTEN      0          46158      -
        tcp6       0      0 :::3261                 :::*                    LISTEN      0          45264      -
        tcp6       0      0 :::5566                 :::*                    LISTEN      0          69645      -
        tcp6       0      0 :::3263                 :::*                    LISTEN      0          45262      -
        tcp6       0      0 :::8000                 :::*                    LISTEN      0          82466      -
        tcp6       0      0 :::8000                 :::*                    LISTEN      0          82456      -
        tcp6       0      0 :::3264                 :::*                    LISTEN      0          45266      -
        tcp6       0      0 127.0.0.1:9665          :::*                    LISTEN      0          83695      -
        tcp6       0      0 :::8001                 :::*                    LISTEN      0          82468      -
        tcp6       0      0 :::8001                 :::*                    LISTEN      0          82458      -
        tcp6       0      0 :::3265                 :::*                    LISTEN      0          45900      -
        tcp6       0      0 :::2049                 :::*                    LISTEN      0          44685      -
        tcp6       0      0 :::161                  :::*                    LISTEN      0          37251      -
        tcp6       0      0 ::1:9666                :::*                    LISTEN      0          108791     -
        tcp6       0      0 127.0.0.1:9666          :::*                    LISTEN      0          108790     -
        tcp6       0      0 :::5000                 :::*                    LISTEN      0          38470      -
        tcp6       0      0 :::5000                 :::*                    LISTEN      0          38462      -
        tcp6       0      0 :::5001                 :::*                    LISTEN      0          38472      -
        tcp6       0      0 :::5001                 :::*                    LISTEN      0          38464      -
        tcp6       0      0 :::139                  :::*                    LISTEN      0          46159      -
        tcp6       0      0 :::9900                 :::*                    LISTEN      0          82472      -
        tcp6       0      0 :::9900                 :::*                    LISTEN      0          82462      -
        tcp6       0      0 :::9901                 :::*                    LISTEN      0          82474      -
        tcp6       0      0 :::9901                 :::*                    LISTEN      0          82464      -
        tcp6       0      0 :::4045                 :::*                    LISTEN      0          44697      -
        tcp6       0      0 :::5357                 :::*                    LISTEN      0          40099      -
        tcp6       0      0 :::5357                 :::*                    LISTEN      0          40097      -
        tcp6       0      0 :::1935                 :::*                    LISTEN      233155     88859      -
        tcp6       0      0 :::111                  :::*                    LISTEN      0          23023      -
        tcp6       0      0 :::80                   :::*                    LISTEN      0          38474      -
        tcp6       0      0 :::80                   :::*                    LISTEN      0          38466      -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       14143362   4145/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       147509     613/io.web.0
        tcp6       0      0 :::21                   :::*                    LISTEN      0          44304      -
        udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          44684      -
        udp        0      0 0.0.0.0:19996           0.0.0.0:*                           233155     88677      -
        udp        0      0 0.0.0.0:19997           0.0.0.0:*                           233155     88676      -
        udp        0      0 0.0.0.0:19998           0.0.0.0:*                           233155     88675      -
        udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         33018      -
        udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          44694      -
        udp        0      0 0.0.0.0:53350           0.0.0.0:*                           0          10804005   -
        udp        0      0 0.0.0.0:37642           0.0.0.0:*                           0          31632      -
        udp        0      0 127.0.0.1:45836         0.0.0.0:*                           0          90817      -
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       151715     818/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          31630      -
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       142817     500/io.shelly.0
        udp        0      0 127.0.0.1:55184         0.0.0.0:*                           0          80071      -
        udp        0      0 192.168.1.111:55900     0.0.0.0:*                           254178     80350      -
        udp        0      0 192.168.1.111:55901     0.0.0.0:*                           0          80072      -
        udp        0      0 192.168.1.111:55902     0.0.0.0:*                           0          90818      -
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23008      -
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          32261      -
        udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          10805175   -
        udp        0      0 192.168.1.111:137       0.0.0.0:*                           0          10805174   -
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          10805132   -
        udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          10805177   -
        udp        0      0 192.168.1.111:138       0.0.0.0:*                           0          10805176   -
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          10805133   -
        udp        0      0 0.0.0.0:161             0.0.0.0:*                           0          37248      -
        udp        0      0 127.0.0.1:57644         0.0.0.0:*                           254178     80349      -
        udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          32259      -
        udp        0      0 0.0.0.0:57816           0.0.0.0:*                           0          23019      -
        udp        0      0 127.0.0.1:650           0.0.0.0:*                           0          31504      -
        udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          31522      -
        udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          31271      -
        udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          26189      -
        udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          26188      -
        udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          26187      -
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       153660     694/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       153658     694/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          90819      -
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           254178     80351      -
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          80073      -
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          40065      -
        udp6       0      0 :::2049                 :::*                                0          44686      -
        udp6       0      0 :::3702                 :::*                                99         33020      -
        udp6       0      0 :::4045                 :::*                                0          44696      -
        udp6       0      0 :::45024                :::*                                0          31633      -
        udp6       0      0 :::5353                 :::*                                0          31631      -
        udp6       0      0 :::63916                :::*                                0          23022      -
        udp6       0      0 :::111                  :::*                                0          23021      -
        udp6       0      0 :::123                  :::*                                0          32262      -
        udp6       0      0 :::161                  :::*                                0          37249      -
        udp6       0      0 ::1:323                 :::*                                0          32260      -
        udp6       0      0 :::662                  :::*                                0          31528      -
        udp6       0      0 :::892                  :::*                                0          31277      -
        2024-06-26 10:10:37.103  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:39.126  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:39.157  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:39.174  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:39.235  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:41.685  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:41.777  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:41.780  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:41.817  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:44.021  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:44.043  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:44.051  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:44.071  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:44.995  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:45.089  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:45.508  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:45.600  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:47.889  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:47.972  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:50.298  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:50.340  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:51.693  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:51.735  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        2024-06-26 10:10:51.740  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.device.nozzle.0.temp" has to be type "string" but received type "number"
        2024-06-26 10:10:51.768  - info: bambulab.0 (1078) State value to set for "bambulab.0.00M09C442300837.finishTime" has to be type "date" but received type "string"
        iob diag has finished.
        Press any key for a summary
                                v.2024-05-22
        /home/iobroker/.diag.sh: line 613: hostnamectl: command not found
        Installation:
        Kernel:                 x86_64
        Userland:               64 bit
        /home/iobroker/.diag.sh: line 622: timedatectl: command not found
        Timezone:
        User-ID:                0
        /home/iobroker/.diag.sh: line 629: systemctl: command not found
        Boot Target:
        Pending OS-Updates:     149
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        Recommended versions are nodejs 18.20.3 and npm 10.7.0
        MEMORY:
        Swap:           11G          0B         11G
        Total:          27G        5.0G         17G
        ioBroker Core:          js-controller           5.0.19
                                admin                   6.17.14
        Objects type: jsonl
        States  type: jsonl
        Objects:                28175
        States:                 0
        Size of iob-Database:
        16M     /opt/iobroker/iobroker-data/objects.json.migrated
        16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        15M     /opt/iobroker/iobroker-data/objects.json.broken
        14M     /opt/iobroker/iobroker-data/objects.jso
        43M     /opt/iobroker/iobroker-data/states.jsonl
        3.3M    /opt/iobroker/iobroker-data/states.json.migrated
        3.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        2.9M    /opt/iobroker/iobroker-data/states.json.old
        2.7M    /opt/iobroker/iobroker-data/states.JSON
        Ein Buch mit Sieben Siegeln 😀
        HappyUser20
        Homoran icebear 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Happyuser20 last edited by
          da solltest du mal suchen was dein System dermaßen auslastet
          • icebear
            icebear @Happyuser20 last edited by icebear
            @happyuser20
            Als erstes würd ich die Speicherkomprimierung in der DS218+ abschalten (wenn ich mir ansehe wie groß dein Swap ist, ist die bestimmt eingeschaltet).
            Bei soviel RAM brauchst du definitiv keine Speicherkomprimierung, und das entlastet auf jeden Fall schonmal die CPU.
              Cannot get repository compact:timeout"
              nutzst du den compact mode?
              ein üblicher Name für ein Repository ist das jedenfalls nicht.
              ist auch ziemlich sportlich, aber der meist limitierende RAM reicht.
              das ist natürlich ein noGo!
              ob damit deine Probleme gelöst würden kann ich nicht versprechen
                Hallo
                Danke für die Vorschläge.
                Aber ich habe fragen
                • Die Speicherkomprimierung in der DS?
                  -Pending OS-Updates: 149
                  IOB läuft im Docker mit dem Image von Buanet. Ich habe schon gesehen das es Updates gibt, ich traue mich aber nicht zu updaten
                • nutzst du den compact mode? was ist das genau?
                HappyUser20
                  Die Basis ist aber steinalt und abgekündigt. Da wirst du langsam nicht umhinkommen das ganze Spiel auf einen aktuellen Stand zu hieven.
                    Happyuser20 @Thomas Braun last edited by
                    @thomas-braun Wenn ich dich richtig verstehe, bezieht sich das auf das Buanet Image oder?
                    Wenn ich richtig liege, gibt es dann eine alternative zu Buanet?
                    Geht das Updaten ohne Datenverlust bzw. ohne alles nochmal neu einrichten zu müssen.
                    sorry für die Fragen
                    HappyUser20
                      sollte bei richtiger Installation und Konfiguration so sein.
                      @Andre hat dazu eine super Dokumentation bei buanet angefertigt.
                        @happyuser20
                        Kann ich dir nicht beantworten, ich verwende keine Docker.
                        Aber es gibt ganz bestimmt ein aktuelleres eingedostes Docker-Image.
                          noch etwas:
                          sind im Heizraum 2 slaves unterwegs?
                          Slave-Heizraum
                          und dein Master heisst tatsächlich
                          iobroker
                            Happyuser20 @Homoran last edited by
                            @homoran Im Heizraum ist nur ein Slave. Ein RPI3
                            und ja mein Master heisst iobroker, was ist daran verkehrt? Sicherheitsbedenken?
                            Hapyyuser20
                              Homoran Global Moderator Administrators @Happyuser20 last edited by Homoran
                              zeig mal die Seite Hosts
                              du hast 2 slaves konfiguriert!
                              und mqtt dem einen und weitere Instanzen dem anderen zugeordnet
                              nöö, nur verwirrend, weil der Systemuser so heisst.
                                @homoran said in Timeout & "Cannot read repository":
                                Ich hatte mal noch einen zweiten Slave im 3d Drucker, den habe ich aber gelöscht, evtl. sind da noch überbleibsel vorhanden.
                                Habe jetzt auch mal die Speicherkomprimierung in der DS ausgeschalten. die CPU Auslastung ging nicht runter, eher ein wenig höher.
                                Ich finde aber auch nichts was die Auslastung verursacht. Ein Prozess ist es meiner Meinung nach nicht.
                                In der Übersicht steht "Benutzer 75 Auslastung"???
                                HappyUser20
                                  und der hieß
                                  @homoran sagte in Timeout & "Cannot read repository":
                                  dann zeig mal die Objekte unter system.host.xxx
                                  nur im Expertenmodus sichtbar!
                                  und die Grafik steht kurz vor 100%, die load average sogar darüber
                                  EDIT:
                                  Was zeigst du da?
                                  ist das aus deinem Docker?
                                  was bildet diese Meinung?
                                  Fakten wie die Ausgabe von top sortiert nach CPU würde helfen.
                                    Happyuser20 @Homoran last edited by Happyuser20
                                    und der hieß
                                    MainsailOS
                                    Slave Heizraum hies mal raspbery_Heizraum_slave, bevor ich diesen neu aufgesetzt habe
                                    EDIT:
                                    Was zeigst du da?
                                    Das ist die Synology Oberfläche
                                    Ist sortiert nach Auslastung und auch von der DS Oberfläche
                                    Das ist die Auslastung im Docker, und die ist sehe sehr hoch würde ich sagen 😧
                                    HappyUser20
                                      dann hast du den alten host nicht gelöscht, oder die Installation nicht mit iob host this initialisiert.
                                      auf jeden Fall sucht die Instanz MQTT nach wie vor den alten Slave.
                                      sieh in den Instanzen nach!
                                      das ist nicht top
                                      aber dass bei 150% Auslastung alles zu langsam ist, ist klar!
                                        das ist nicht top
                                        noch eine Frage zwischendurch
                                        bezieht sich das auf das Buanet bzw Docker Image oder den IOB?
                                        HappyUser20
                                          Auf das Image. Weswegen du das aktuell halten sollst.
                                            bitte erst ein Thema abarbeiten!
                                            Sonst verzettelst du dich noch mehr
                                            2387
