    4. Admin v6.17.14 - fehlende Icons
      Thomas Braun Most Active @ManfredHi last edited by
      @manfredhi sagte in Admin v6.17.14 - fehlende Icons:
      Übrigens ein Downgrade funktioniert nicht.
      Mit welcher Meldung funktioniert das nicht?
        ManfredHi @Thomas Braun last edited by
        Would you like to downgrade admin from @6.17.14 to @6.13.16 now? [(y)es, (n)o]: Y
        Update admin from @6.17.14 to @6.13.16
        host.iobroker Adapter "system.adapter.admin.0" is stopped.
        host.iobroker Adapter "system.adapter.admin.1" is stopped.
        NPM version: 10.7.0
        Installing iobroker.admin@6.13.16... (System call)
        upload [53] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json
        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript
        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.bdd08e35.chunk.js custom/static/js/node_modules_react_index_js.bdd08e35.chunk.js application/javascript
        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        host.iobroker Adapter "system.adapter.admin.0" is started
        host.iobroker Adapter "system.adapter.admin.1" is started
          Thomas Braun Most Active @ManfredHi last edited by Thomas Braun
          @manfredhi
          Bitte immer vollständige Ein- wie Ausgaben zeigen.
          Funktioniert nämlich auf meiner Kiste:
          echad@chet:~ $ iob upgrade admin@6.13.16
          This downgrade of "admin" will at least remove the following changes:
          -> 7.0.2
          Working on Json-Custom-Components
          on js-controller updater correctly determine the ip of slave hosts
          removed "@iobroker/types" from production dependencies
          -> 7.0.1
          Because of the breaking change in GUI components, the GUI was updated. Users will see no difference, but developers should check their packages.
          Rewritten many GUI components to TypeScript
          Added support for the adapter's auto-update option. New version of js-controller required.
          GUI was re-written to typescript to 100%
          Shows only installed adapters in the adapter tab or first 100 adapters
          -> 6.17.14
          Only some packages updated
          -> 6.17.13
          Alias editing corrected
          Web-extension indicator corrected
          -> 6.17.12
          support of Node.js upgrade via UI (with js-controller Kiera - v6)
          Corrected CRON settings
          -> 6.17.11
          Corrected custom configuration dialog
          BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
          Would you like to downgrade admin from @7.0.2 to @6.13.16 now? [(y)es, (n)o]: y
          Update admin from @7.0.2 to @6.13.16
          host.chet Adapter "system.adapter.admin.0" is stopped.
          NPM version: 10.8.1
          added 3 packages, removed 7 packages, and changed 6 packages in 15s
          190 packages are looking for funding
            run `npm fund` for details
          Update "system.adapter.admin.0"
          host.chet Adapter "system.adapter.admin.0" is started
          echad@chet:~ $ ^C
          echad@chet:~ $ cd /opt/iobroker/
          echad@chet:/opt/iobroker $ npm ls | grep admin
          ├── iobroker.admin@6.13.16
            Hier das vollständige:
            iobuser@iobroker:~$ iob upgrade admin@6.13.16
            -> 6.17.14
            -> 6.17.13
            -> 6.17.12
            -> 6.17.11
            -> 6.17.9
            Corrected style of time picker in JSON config
            Corrected saving of tab color
            -> 6.17.7
            Improved category tab
            -> 6.17.6
            Extend the table JSON Config with the encryption possibility
            Do not read historical data if instance is not active
            Would you like to downgrade admin from @6.17.14 to @6.13.16 now? [(y)es, (n)o]: y
            NPM version: 10.7.0
            Thomas Braun T 2 Replies Last reply Reply Quote 0
              @manfredhi
              Und wo steht, das die Version nicht installiert wurde?
              • JLeg
                JLeg @Thomas Braun last edited by
                @thomas-braun sagte in Admin v6.17.14 - fehlende Icons:
                Keine Ahnung was du da umgestellt hast, jedenfalls ruft
                https://remote-files.iobroker.in einen Server aus der TLD für Indien an. Das der nicht unbedingt Icons für deinen lokalen iobroker ausliefert sollte klar sein.
                nö. Die Domain gehört Registrant Organization: ioBroker GmbH - und der Server läuft in AWS.
                rtl.tv läuft ja auch nicht in Tuvalu.. 😉
                • David G.
                  Da läuft wohl einiges drüber.
                  Auch der cloudadapter
                  Finde das auch nicht so glücklich gelöst.
                  Viele Leute denken bestimmt, dass man da mit irgendwelchen Dienstleistern aus Indien zusammenarbeitet.
                  Der Gedanke war wohl bestimmt in/out.
                  Da kommen die Daten rein ^^.
                  Aber das ist jetzt was Offtopic....
                  JLeg 1 Reply Last reply Reply Quote 0
                    Thomas Braun Most Active @JLeg last edited by
                    @jleg
                    Die adresse ist mir noch nie untergekommen. Aber ich schau mir den Traffic auch nicht an.
                    Jedenfalls überraschend für mich.
                    • JLeg
                      JLeg @David G. last edited by
                      @david-g sagte in Admin v6.17.14 - fehlende Icons:
                      ...hatte ich auch dran gedacht 🙂 - aber .out gibt's nicht. Dafür wäre "iobroker.io" noch zu haben...
                        TT-Tom @ManfredHi last edited by TT-Tom
                        @manfredhi
                        Warum laufen bei dir zwei Admin Instanzen?
                          ManfredHi @TT-Tom last edited by
                          @tt-tom sagte in Admin v6.17.14 - fehlende Icons:
                          Puhhh, ich weiß es selbst nicht mehr so genau. Der ist bei mir mit dem Cloud-Adapter verknüpft. Ich hab das schon ewig so drinnen. Mit irgendeinem Adapter gabs da mal ein problem, ich weiß es aber ehrlich gesagt nicht mehr genau.
                          Aber guter Hinweis, hab die Instanz jetzt mal deaktiviert und den Cloud-Adapter mit admin.0 verknpüft. Mal schauen, ob dann irgendwas nicht funktioniert.
                          1204
