    4. Grösste Probleme mit Auflösung, Widget-Breiten usw.
      Delphinis @Homoran last edited by
      @homoran said in Grösste Probleme mit Auflösung, Widget-Breiten usw.:
      iob diag
      Hab leider kein iob diag (Windows Mini-PC) und unter dem Befehl iobroker hab ich nichts vergleichbares gefunden:
      c:\ioBroker>iob diag
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
        Homoran Global Moderator Administrators @Delphinis last edited by
        @delphinis iob update oder iob list adapters sollte die verfügbaren Versionen des ausgewählten Repos (hoffentlich stable) sowie die installierten Versionen anzeigen.
        Da sollte nichts drin höher sein als verfügbar.
          Delphinis @Homoran last edited by Delphinis
          Ok, hab den Befehl
          iobroker list adapters
          gefunden:
          C:\ioBroker>iobroker list adapters
          system.adapter.admin                   : admin          - v6.13.16
          system.adapter.alias-manager           : alias-manager  - v1.2.6
          system.adapter.backitup                : backitup       - v2.9.8
          system.adapter.cloud                   : cloud          - v4.4.1
          system.adapter.discovery               : discovery      - v4.2.0
          system.adapter.echarts                 : echarts        - v1.7.2
          system.adapter.flot                    : flot           - v1.12.0
          system.adapter.history                 : history        - v3.0.1
          system.adapter.iqontrol                : iqontrol       - v2.3.0
          system.adapter.javascript              : javascript     - v7.8.0
          system.adapter.modbus                  : modbus         - v6.1.0
          system.adapter.ping                    : ping           - v1.6.2
          system.adapter.sayit                   : sayit          - v3.0.5
          system.adapter.sonoff                  : sonoff         - v3.0.3
          system.adapter.vis                     : vis            - v1.5.4
          system.adapter.web                     : web            - v6.1.4
          system.adapter.whatsapp-cmb            : whatsapp-cmb   - v0.2.3
          system.adapter.zigbee                  : zigbee         - v1.10.3
          Da sollte eigentlich nichts mehr drin sein, was mit der vis zu tun hat. Ausser die vis selbst narürlich.
          Oder ist da echarts vielleicht? Versuch das mal noch zu deinstallieren. Ist das ein gute Weg über die Konsole?
          Da gibts einen Befehl iobroker del <adapter>.<instance>
            @delphinis bitte iob update zeigen
              C:\ioBroker>iobroker update
              Used repository: stable
              Adapter    "admin"        : 6.17.14  , installed 6.13.16 [Updatable]
              Adapter    "backitup"     : 2.11.0   , installed 2.9.8  [Updatable]
              Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
              Adapter    "discovery"    : 4.5.0    , installed 4.2.0  [Updatable]
              Adapter    "javascript"   : 8.3.1    , installed 7.8.0  [Updatable]
              Adapter    "modbus"       : 6.1.0    , installed 6.1.0
              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
              Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
              Adapter    "socketio"     : 6.7.0    , installed 6.5.7  [Updatable]
              Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
              Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
              Adapter    "web"          : 6.2.5    , installed 6.1.4  [Updatable]
              Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
              Adapter    "ws"           : 2.6.1    , installed 2.5.7  [Updatable]
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Ok, da sind ein paar zum updaten...
              Den echarts abdapter hab ich deinstalliert. Mal testen, ob der es war. War nämlich nicht in der GUI zu finden.
                Homoran Global Moderator Administrators @Delphinis last edited by Homoran
                @delphinis sagte in Grösste Probleme mit Auflösung, Widget-Breiten usw.:
                wichtiger sind ja die, die es so im stable gar nicht gibt.
                dazu musst du jetzt beide Ausgaben vergleichen
                Andererseits weist dieser Updatestau auf eine insgesamt iernachlässigte Installation hin.
                  Werden in Adapter alle aufgelistet:
                  Ein paar sind in dieser Auflistung anders bezeichnet, z.B. discovery - Gerätesuche
                    siehe download.iobroker.net/list.html
                    aber in dei em Screenshot siehst du auch die update versionen.
                    und links die (10) bei Adapter
                      Das hab ich nicht verstanden.
                      Jedenfalls hab ich keinen Adapter gefunden, der dort nicht in der Liste ist.
                      Bin jetzt am Updaten aller Adapter. Aber ausser der Vis hat wohl kein Adapter damit zu tun, und vis hab ich schon updated und getestet.
                        Es bringt alles nichts. Aber nachdem ich die problematische View exportiert und auf einem anderen System importiert hab und das dann funktioniert hat, denke ich es wäre am besten, diese Altlasten zu eliminieren.
                        Weisst du wie ich am gescheitesten vogehe, wenn ich das ganze System neu aufsetzen möchte? Vielleicht nur die Vis?
                        Mögliches Vorgehen:
                        1. Sicherheitskopie mit BackitUp
                        2. Alle Views exportieren
                        3. Vis-Adapter deinstallieren. -> es werden da hoffentlich alle CSS gelöscht?
                        4. Vis-Adapter neu installieren
                        5. Alle Views wieder importieren
                        Oder muss ich den ganzen iob neu aufsetzen? Aber z.B. Javascript, alle Datenpunkte, oder die Zigbee-Geräte haben ja mit der Vis nichts direkt am Hut?
                          ja, war doof formuliert! Hab's jetzt geändert
                            @OliverIO
                            Ich glaub ich komme dem Problem langsam näher
                            So, hab jetzt, bevor ich alles neu aufsetze mal testhalber alle Views Exportiert und gesichert.
                            Dabei konnte ich bei einem Import der Views in einen anderen iob ein View isolieren, welches den Fehler provoziert.
                            Dieses View ist quasi eine Kopie eines ersten Views. 13hsol und 13sol_
                            In diesen zwei Views werden die Solarwerte einerseits in den letzten stunden/Tage anzeigt und
                            im anderen kann man die Solarwerte von bis anzeigen. Ich hab das nicht in einem View hingekriegt.
                            In beiden Views ist auch ein HTML-Widget mit Tabellen von aktuellen Solardaten. In diesen hab ich eigene CSS-Regeln definiert. Diese Tabelle macht Probleme, aber nur im zweiten view.
                            Um anderes auszuschliessen hab ich nun in beiden Views, ausser den Tabellen, alles gelöscht.
                            Nun kommts:
                            • Lösche ich nur die Tabellen im zweiten View 13sol_ funktionieren die Buttons/valueList wieder
                            • Lösche ich nur die Tabellen im ersten View 13sol funktionieren die Buttons/valueList nicht
                              Beide Tabellen sind aber identisch. Es kommt offenbar nicht darauf an, ob die Tabellen zweimal drin sind, sondern in welchem View???
                            Hier mal der Code des HTML-Widgets:
                            <style>
                            table {
                              margin: 10px;
                              width: 356px;
                              border: 1px solid black;
                              border-collapse: collapse;
                            div {
                              padding-left: 10px;
                            .mainTitle {
                              font-weight: bold;
                              font-size: 25px;
                              text-align: center;
                            .mainTitleLeft {
                              font-weight: bold;
                              font-size: 25px;
                              text-align: left;
                            .title {
                              font-weight: bold;
                              font-size: 20px;
                              text-align: center;
                            .titleLeft {
                              font-weight: bold;
                              font-size: 20px;
                              text-align: left;
                            .titleRight {
                              font-weight: bold;
                              font-size: 19px;
                              text-align: right;
                            .subtitle {
                              font-weight: bold;
                              font-size: 14px;
                              text-align: center;
                            .value {
                              font-size: 30px;
                              font-weight: bold;
                              text-align: right;
                            .valuesmall {
                              font-size: 20px;
                              font-weight: bold;
                              text-align: right;
                            .csolar {
                              background: #FFFFA0;
                            .cdiag {
                              background: #FFAAAA;
                            .cnetz {
                              background: #AAAAAA;
                            .cnetzein {
                              background: #FFFF00;
                            .cnetzbezug {
                              background: #FF0000;
                            .cnetzeigen {
                              background: #9ACD32;
                            .cbat {
                              background: #FF8C00;
                            .noBorderTitle {
                            	background: #FFFFFF;
                            	border-style:none;
                              font-weight: bold;
                              font-size: 20px;
                              text-align: left;
                            </style>
                            <table class="csolar" rules="all">
                              <tr class="mainTitle">
                                <td colspan=3; width="40px";>Leistung Solar Eingang</td>
                              </tr>
                              <tr class="title">
                                <td width="33%">String 1</td>
                                <td width="33%">String 2</td>
                                <td width="34%">Total</td>
                              </tr>
                              <tr class="valuesmall">
                                <!--td>8888W</td-->
                                <td class=", value";>{modbus.0.inputRegisters.30773_PV_Leistung_Eingang_1}W</td>
                                <!--td>8888W</td-->
                                <td class=", value";>{modbus.0.inputRegisters.30961_PV_Leistung_Eingang_2}W</td>
                                <!--td>18888W</td-->
                            	<td class=", value";>{a:modbus.0.inputRegisters.30773_PV_Leistung_Eingang_1;b:modbus.0.inputRegisters.30961_PV_Leistung_Eingang_2;parseInt(a)+parseInt(b)}W</td>
                              </tr>
                              <tr class="titleLeft">
                                <td colspan=2; width="40px";>Leistung nach Verlusten</td>
                            		<td colspan=3; class=", value"; align="right">{0_userdata.0.Solar.Leistung.PVin_Netto}W</td>
                              </tr>
                            </table>
                            <p> </p>
                            <table class="cnetz" rules="all">
                              <tr class="mainTitleLeft">
                                <td colspan=2; width="40px";>Leistung 230V Netz</td>
                            		<td colspan=3; class=", value"; align="right">{modbus.0.inputRegisters.30775_Messwert_Leistung}W</td>
                              </tr>
                              <tr class="subtitle">
                                <td class="cnetzbezug"; width="33%">Netzbezug</td>
                                <td class="cnetzein";  width="33%">Einspeisung</td>
                                <td  class="cnetzeigen"; width="34%">Direktverbrauch</td>
                              </tr>
                              <tr class="value">
                                <!--td class="cnetzbezug">18888W</td-->
                                <td class="cnetzbezug">{modbus.0.inputRegisters.30865_Leistung_Bezug}W</td>
                                <!--td class="cnetzein">18888W</td-->
                                <td class="cnetzein">{modbus.0.inputRegisters.30867_Messwert_Leistung_Einspeisung}W</td>
                                <!--td class="cnetzeigen">18888W</td><!--Test Textgrösse-->
                            	<td class="cnetzeigen"; width="40%";  align="right">
                            		{0_userdata.0.Solar.Leistung.Direktverbrauch}W
                            	</td>
                              </tr>
                            </table>
                            <p> </p>
                            <table class="cbat" rules="all">
                                <td colspan=3; width="40px";>Leistung/Ladestand Batterie</td>
                              </tr>
                                <td width="33%">Laden</td>
                                <td width="33%">Entladen</td>
                                <td width="34%">Ladung</td>
                              </tr>
                              </tr>
                              <tr class="value">
                                <!--td class="cbat">18888W</td-->
                                <td class="cbat">{modbus.0.inputRegisters.31393_Batterieladung}W</td>
                                <td class="cbat">{modbus.0.inputRegisters.31395_Batterieentladung}W</td>
                                <!--td class="cbat">18888W</td><!--Test Textgrösse-->
                            	<td class="cbat"; width="40%";  align="right">
                            		{modbus.1.inputRegisters.30845_Batterie_SoC}%
                            	</td>
                              </tr>
                            </table>
                            <br>
                            <div class="csolar noBorderTitle" rules="all">
                            	 Bilanz
                            </div>
                              <tr class="csolar">
                                <td class="titleLeft"; colspan=2; width="60%">Solarertrag Heute</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Energie.sHeute}Wh</td>
                              </tr>
                              <tr class="csolar">
                                <td class="titleLeft"; colspan=2; width="60%">Solarertrag Total</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Energie.sGesamt}Wh</td>
                              </tr>
                              <tr class="csolar">
                                <td class="titleLeft"; colspan=2; width="60%">Netzeinspeisung Heute</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Energie.sEinspeisungHeute}Wh</td>
                              </tr>
                              <tr class="csolar">
                                <td class="titleLeft"; colspan=2; width="60%">Netzeinspeisung Total</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Energie.sEinspeisungTot}Wh</td>
                              </tr>
                              <tr class="csolar">
                                <td class="titleLeft"; colspan=2; width="60%">Netzbezug</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Energie.sBezug}Wh</td>
                              </tr>
                            </table>
                            <br>
                            	 Diagnosewerte
                            </div>
                            <table class="cdiag" rules="all" background="FFAAAA">
                                <td>Solar</td>
                                <td class="title">U</td>
                                <td class="title">I</td>
                              </tr>
                              <tr>
                                <td class="titleLeft">String1</td>
                                <td class="title">{a:modbus.1.inputRegisters.30771_PV_Spannung_1;a/100}V</td>
                                <td class="title" width="34%">{a:modbus.1.inputRegisters.30769_PV_Strom_1;a/1000}A</td>
                              </tr>
                              <tr>
                                <td class="titleLeft">String2</td>
                                <td class="title">{a:modbus.1.inputRegisters.30959_PV_Spannung_2;a/100}V</td>
                                <td class="title" width="34%">{a:modbus.1.inputRegisters.30957_PV_Strom_2;a/1000}A</td>
                              </tr>
                            </table>
                                <td colspan=3>Batterie</td>
                              </tr>
                                <td colspan=2; width="60%">Diag Kapazität</td>
                                <td class="valuesmall" width="40%">{modbus.1.inputRegisters.30847_Diagnose_Aktuelle_Kapazität}%</td>
                              </tr>
                                <td colspan=2; width="60%">Temperatur</td>
                                <td class="valuesmall" width="40%">{a:modbus.1.inputRegisters.30849_Batterietemperatur;a/10}°C</td>
                              </tr>
                                <td colspan=2; width="60%">Spannung</td>
                                <td class="valuesmall" width="40%">{modbus.1.inputRegisters.30851_Batteriespannung}V</td>
                              </tr>
                                <td colspan=2; width="60%">Betriebsart</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Diverses.sBatBetriebsart}</td>
                              </tr>
                                <td colspan=2; width="60%">Batteriezustand</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Diverses.sBatZustand}</td>
                              </tr>
                            </table>
                            <table class="cdiag" rules="all" background="FFAAAA">  <tr class="titleLeft">
                                <td colspan=3>Wechselrichter</td>
                              </tr>
                                <td colspan=2; width="60%">WR-Zustand</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Diverses.sWRZustand}</td>
                              </tr>
                                <td colspan=2; width="60%">Reset Komm.-Proz.</td>
                                <td class="valuesmall" width="40%">{0_userdata.0.Solar.Diverses.sWRNeustart}</td>
                              </tr>
                            </table>
                            Ich werde nun mal CSS-Regel für CSS-Regel rausnehmen und schauen, ob da eine reinspielt.
                            Ist für mich aber sehr seltsam, dass das nur in dem zweiten View diese Auswirkung hat.
                              wo?
                              im widget oder im Reiter CSS?
                                Im Widget, der Reiter CSS ist leer.
                                Aber ich glaube das wär sowieso egal, da offenbar die Styles im gesamten vis überall global sind?
                                  Im Widget,
                                  sollte dann nur in diesem Widget gelten
                                  (nichts bösartiges reinprogrammiert vorausgesetzt)
                                    Ja, das hab ich auch gedacht. Aber offenbar funktioniert es, wenn ich den ganzen <style> block rausnehme...
                                      was ist das denn?
                                      also doch bösartig manipuliert? 😉
                                      ich rede nur von Einstellungen in der rechten Sidebar
                                        Ich meine im Code des HTML-Widgets, siehe oben. Sind da keine Style-Angaben erlaubt?
                                        D Homoran 2 Replies Last reply Reply Quote 0
                                          Delphinis @Delphinis last edited by
                                          Ich wollte ja gerade vermeiden, dass die eigenen Style-Regeln global wirken...
                                            aaah!
                                            deep diving!
                                            hab ich keine Ahnung von wie du das programmieren musst.
                                            4603
