    4. JsonConfig] Cannot parse json5 config!
      stoffel67 @Thomas Braun last edited by stoffel67
      so system upgedatet😌
      pi@raspip:~ $ sudo apt update
      OK:1 http://deb.debian.org/debian bookworm InRelease
      OK:2 http://deb.debian.org/debian-security bookworm-security InRelease
      OK:3 http://deb.debian.org/debian bookworm-updates InRelease
      OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      OK:5 http://archive.raspberrypi.com/debian bookworm InRelease
      Abh�ngigkeitsbaum wird aufgebaut... Fertig
      Statusinformationen werden eingelesen... Fertig
      Alle Pakete sind aktuell.
      System neu gestartet .... läuft wieder , aber der Adapter-Fehler kommt immer noch
      bekomme jetzt zusätzlich:
      host.raspip
      2024-06-27 12:52:43.569	error	Cannot download and install adapter "js2fs@0.1.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      host.raspip
      2024-06-27 12:52:42.499	error	iobroker npm-install: host.raspip Unknown packetName js2fs. Please install packages from outside the repository using npm!
      host.raspip
      2024-06-27 12:52:38.746	error	iobroker npm-install: host.raspip Unknown packetName js2fs. Please install packages from outside the repository using npm!
      host.raspip
      2024-06-27 12:52:35.033	error	iobroker npm-install: host.raspip Unknown packetName js2fs. Please install packages from outside the repository using npm!
      host.raspip
      2024-06-27 12:52:31.318	error	iobroker npm-install: host.raspip Unknown packetName js2fs. Please install packages from outside the repository using npm!
      Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @stoffel67 last edited by Homoran
        @stoffel67 sagte in JsonConfig] Cannot parse json5 config!:
        und was hast du gemacht?
        was sagt iob update?
          Thomas Braun Most Active @stoffel67 last edited by
          @stoffel67
          Ist der Desktop-Mist aus? Hat auf einem Server nix zu suchen.
          sudo systemctl set-default multi-user.target
          Und bring nodejs auf die empfohlene Version 20
          iobroker nodejs-update 20
          Wo kommt der js2fs her?
          cd /opt/iobroker
          npm ls js2fs
            @thomas-braun sagte in JsonConfig] Cannot parse json5 config!:
            ich tippe auf ein npm modul für js
              Thomas Braun Most Active last edited by Thomas Braun
              Das muss aber eine ganz alte Altlast sein.
              https://forum.iobroker.net/topic/9331/gelöst-js2fs-und-javascript-blockly
              https://github.com/soef/iobroker.js2fs
                @stoffel67
                Da hängt der
                + system.adapter.js2fs.0                  : js2fs                 : raspip                                   -  enabled
                schief. Den würde ich komplett rauswerfen, wenn du nicht weißt wofür du den brauchst.
                  @stoffel67
                  Da hängt der
                  kenn ich gar nicht.
                  der ist in keinem Repo.
                  Daher passt die Meldung
                    soef macht ja seit Jahren nix mehr. Und die Funktion des Adapters ist auch nicht mehr notwendig, du kannst ja mittlerweile ein Spiegelverzeichnis mit den Skripten haben.
                    Also raus mit dem uralten Code. Macht nur Ärger in aktuellen Setups.
                      pi@raspip:~ $ npm ls js2fs
                      pi@ /home/pi
                      `-- (empty)
                      also schmeiß ich den Adapter raus.... ich hatte mal ein javascript was auf die lokal Platte geschrieben hat...
                        Du stehst im falschen Verzeichnis...
                        Aber ja, raus mit dem alten Kram.
                          pi@raspip:~ $ cd /opt/iobroker/
                          pi@raspip:/opt/iobroker $ npm ls js2fs
                          iobroker.inst@3.0.0 /opt/iobroker
                          `-- (empty)
                          wie oben gesagt, beim DS18B20-Adaüter kommt nach wie vor der Fehler :[JsonConfig] Cannot parse json5 config!
                          und er bleibt dann in der Config-Seite hängen..
                            Glückwunsch, du hast wohl ein Issue gefunden.
                            Trags im GitHub ein, damit es gefixt werden kann.
                              zeigen!
                              Thomas Braun S 2 Replies Last reply Reply Quote 0
                                Stimmt, das Popup kommt bei mir auch im Admin, wenn man in die Einstellungen des Adapters gehen möchte.
                                Also ein Bug.
                                  stoffel67 @Homoran last edited by
                                    @stoffel67
                                    also "nur" ein popup, so wie @Thomas-Braun es beschreibt.
                                    im debug-log gibt es keine weiteren Informationen?
                                      das gibts im LOG, er liest die Sensoren nicht mehr
                                      ds18b20.0
                                      2024-06-27 14:51:07.212	warn	Error reading sensor 28-01204db3acbf: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01204db3acbf/w1_slave'
                                      ds18b20.0
                                      2024-06-27 14:50:38.157	warn	Error reading sensor 10-000801ef2087: Error: Read error
                                      ds18b20.0
                                      2024-06-27 14:50:37.344	warn	Error reading sensor 28-01204fed9b9a: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01204fed9b9a/w1_slave'
                                      ds18b20.0
                                      2024-06-27 14:50:37.290	warn	Error reading sensor 10-000801d0136f: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/10-000801d0136f/w1_slave'
                                      ds18b20.0
                                      2024-06-27 14:50:37.214	warn	Error reading sensor 28-01204db3acbf: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01204db3acbf/w1_slave'
                                      ds18b20.0
                                      2024-06-27 14:50:37.068	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v20.15.0, js-controller: 5.0.19
                                      mir ist schleierhaft warum nicht, bzw. warum die Config-Seite nicht mehr aufgeht...
                                        das gibts im LOG,
                                        ist allerdings kein debug-log.
                                        die genannten fehlenden Pfade sagen mir nichts
                                          debug-log??
                                          ds18b20.0
                                          2024-06-27 15:00:58.345	debug	Got value null from sensor 28-01204db3acbf
                                          ds18b20.0
                                          2024-06-27 15:00:58.344	warn	Error reading sensor 28-01204db3acbf: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01204db3acbf/w1_slave'
                                          ds18b20.0
                                          2024-06-27 15:00:30.131	debug	Error state of sensor 28-01204fed9b9a changed to false
                                          ds18b20.0
                                          2024-06-27 15:00:30.129	debug	Got value 25 from sensor 28-01204fed9b9a
                                          ds18b20.0
                                          2024-06-27 15:00:28.531	debug	Loaded 4 enabled sensors
                                          ds18b20.0
                                          2024-06-27 15:00:28.476	debug	Got value null from sensor 10-000801d0136f
                                          ds18b20.0
                                          2024-06-27 15:00:28.475	warn	Error reading sensor 10-000801d0136f: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/10-000801d0136f/w1_slave'
                                          ds18b20.0
                                          2024-06-27 15:00:28.422	debug	Got value null from sensor 10-000801ef2087
                                          ds18b20.0
                                          2024-06-27 15:00:28.420	warn	Error reading sensor 10-000801ef2087: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/10-000801ef2087/w1_slave'
                                          ds18b20.0
                                          2024-06-27 15:00:28.346	debug	Got value null from sensor 28-01204db3acbf
                                          ds18b20.0
                                          2024-06-27 15:00:28.344	warn	Error reading sensor 28-01204db3acbf: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01204db3acbf/w1_slave'
                                          ds18b20.0
                                          2024-06-27 15:00:28.226	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v20.15.0, js-controller: 5.0.19
                                          kann es auch am 1-wire Bus liegen...
                                          aber warum geht die Konfigurationsseite nicht auf?
                                            @stoffel67
                                            Ist in
                                            sudo raspi-config
                                            das Interface aktiviert?
                                            3804
