    4. Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
    • I
      icke2002 last edited by
      @simatec Stimmt github wahrscheinlich nicht nochmal .angeklickt.
      Leider bricht die Installation mit Fehler ab:
      $ iobroker url simatec/ioBroker.solax --host PC-Wolfgang --debug
      install simatec/ioBroker.solax
      Installing simatec/ioBroker.solax... (System call)
      npm error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache_logs\2024-06-27T14_25_10_988Z-debug-0.log
      host.PC-Wolfgang Cannot install simatec/ioBroker.solax: 4294963238
      ERROR: Process exited with code 25
      • I
        icke2002 @icke2002 last edited by Homoran
        @icke2002
        0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
        1 info using npm@10.7.0
        2 info using node@v20.15.0
        3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc
        4 silly config:load:file:C:\ioBroker\.npmrc
        5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc
        6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc
        7 verbose title npm install simatec/ioBroker.solax
        8 verbose argv "install" "simatec/ioBroker.solax"
        9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-
        10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-debug-0.log
        11 silly logfile done cleaning log files
        12 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.solax
        13 verbose stack Error: An unknown git error occurred
        13 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
        13 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
        13 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        14 verbose cwd C:\ioBroker
        15 verbose Windows_NT 10.0.19045
        16 verbose node v20.15.0
        17 verbose npm  v10.7.0
        18 error code ENOENT
        19 error syscall spawn git
        20 error path git
        21 error errno -4058
        22 error enoent An unknown git error occurred
        23 error enoent This is related to npm not being able to find a file.
        23 error enoent
        24 verbose exit -4058
        25 verbose code -4058
        26 silly unfinished npm timer reify 1719498311579
        27 silly unfinished npm timer reify:loadTrees 1719498311583
        28 silly unfinished npm timer idealTree:userRequests 1719498311824
        29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-debug-0.log
          Homoran Global Moderator Administrators @icke2002 last edited by
          @icke2002 Bitte keine 4K Briefmarken posten!
          24% davon sind zu wenig zum erkennen.
          • I
            icke2002 @Homoran last edited by
            @homoran verstehe ich nicht - bei mir ist alles zu erkennen???
            simatec Homoran 2 Replies Last reply Reply Quote 0
            • simatec
              simatec Developer Most Active @icke2002 last edited by
              @icke2002 Also bei mir läuft es sauber durch ...
              $ iobroker url simatec/ioBroker.solax --host iobroker-dev --debug
              NPM version: 10.7.0
              removed 362 packages, and changed 1 package in 4s157 packages are looking for funding run `npm fund` for details
              upload [16] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/admin.d.ts admin.d.ts video/mp2t
              upload [14] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/en/translations.json i18n/en/translations.json application/json
              upload [12] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              upload [11] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/it/translations.json i18n/it/translations.json application/json
              upload [9] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [6] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              upload [5] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              upload [3] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/jsonConfig.json jsonConfig.json application/json
              upload [2] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/solax.png solax.png image/png
              upload [0] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/words.js words.js application/javascript
              Update "system.adapter.solax.0"
              Process exited with code 0
              • simatec
                simatec Developer Most Active @simatec last edited by
                @simatec Starte mal dein System komplett neu und versuche es erneut
                I 2 Replies Last reply Reply Quote 0
                • I
                  icke2002 @simatec last edited by
                  @simatec ok mach ich!
                    @icke2002 sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
                    ich denke mal dein Bildschirm ist breiter als 7cm.
                    • I
                      @homoran richtig?
                      • I
                        icke2002 @simatec last edited by Homoran
                        @simatec hat nichts genützt - bricht mit Fehler ab!?
                        9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-
                        10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
                        20 error path git
                        23 error enoent
                        26 silly unfinished npm timer reify 1719164066510
                        27 silly unfinished npm timer reify:loadTrees 1719164066570
                        28 silly unfinished npm timer idealTree:userRequests 1719164066788
                        29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
                        • simatec
                          @icke2002 Dann lösche den Adapter vorher komplett. Also auch im Tab Adapter. Sprich Instanzen und Adapter löschen.
                          Im Anschluss dann nochmals die Installation via Github siehe Screenshot
                          • I
                            @simatec Wird leider immer schlimmer!?
                            Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?
                            Punkt 13 und 18 - 23 - ich verstehe es nicht!
                            9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-
                            10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
                            11 silly logfile start cleaning logs, removing 1 files
                            12 silly logfile done cleaning log files
                            20 error path git
                            23 error enoent
                            26 silly unfinished npm timer reify 1719507201733
                            27 silly unfinished npm timer reify:loadTrees 1719507201739
                            28 silly unfinished npm timer idealTree:userRequests 1719507201999
                            29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
                              20 error path git
                              23 error enoent
                              da war doch was mit dem installer für Win.
                              Ich glaube der installiert das Paket git nicht standardmäßig
                              • I
                                @homoran ok - danke - wie kann ich das Problem als newbee lösen?
                                Homoran simatec 2 Replies Last reply Reply Quote 0
                                  Suche benutzen und u.a. dieses finden:
                                  https://forum.iobroker.net/post/1166454
                                  • simatec
                                    @icke2002 oder du wartest, bis ich die Version auf npm habe und installierst von npm über die Katze
                                    I 2 Replies Last reply Reply Quote 1
                                    • I
                                      @homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!👍 😳
                                      • I
                                        @simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
                                        Super - Danke!👍 👍 👍
                                        • simatec
                                          simatec Developer Most Active @icke2002 last edited by simatec
                                          @icke2002 Poste mal bitte die Objekte, die nun alle erzeugt wurden. Sind die Daten alle korrekt und plausibel?
                                          • I
                                            @simatec
                                            1576
