Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
@homoran verstehe ich nicht - bei mir ist alles zu erkennen???
@icke2002 Also bei mir läuft es sauber durch ...
$ iobroker url simatec/ioBroker.solax --host iobroker-dev --debug install simatec/ioBroker.solax NPM version: 10.7.0 Installing simatec/ioBroker.solax... (System call) removed 362 packages, and changed 1 package in 4s157 packages are looking for funding run `npm fund` for details upload [16] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/admin.d.ts admin.d.ts video/mp2t upload [14] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [12] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [11] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [9] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [6] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/uk/translations.json i18n/uk/translations.json application/json upload [5] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [3] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/jsonConfig.json jsonConfig.json application/json upload [2] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/solax.png solax.png image/png upload [0] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/words.js words.js application/javascript Update "system.adapter.solax.0" Process exited with code 0
@simatec Starte mal dein System komplett neu und versuche es erneut
@simatec ok mach ich!
@icke2002 sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
ich denke mal dein Bildschirm ist breiter als 7cm.
@homoran richtig?
@simatec hat nichts genützt - bricht mit Fehler ab!?
0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js 1 info using npm@10.7.0 2 info using node@v20.15.0 3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc 4 silly config:load:file:C:\ioBroker\.npmrc 5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc 6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc 7 verbose title npm install simatec/ioBroker.solax 8 verbose argv "install" "simatec/ioBroker.solax" 9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z- 10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log 11 silly logfile done cleaning log files 12 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.solax 13 verbose stack Error: An unknown git error occurred 13 verbose stack at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13) 13 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26 13 verbose stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5) 14 verbose cwd C:\ioBroker 15 verbose Windows_NT 10.0.19045 16 verbose node v20.15.0 17 verbose npm v10.7.0 18 error code ENOENT 19 error syscall spawn git 20 error path git 21 error errno -4058 22 error enoent An unknown git error occurred 23 error enoent This is related to npm not being able to find a file. 23 error enoent 24 verbose exit -4058 25 verbose code -4058 26 silly unfinished npm timer reify 1719164066510 27 silly unfinished npm timer reify:loadTrees 1719164066570 28 silly unfinished npm timer idealTree:userRequests 1719164066788 29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
@icke2002 Dann lösche den Adapter vorher komplett. Also auch im Tab Adapter. Sprich Instanzen und Adapter löschen.
Im Anschluss dann nochmals die Installation via Github siehe Screenshot -
@simatec Wird leider immer schlimmer!?
Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?Punkt 13 und 18 - 23 - ich verstehe es nicht!
0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js 1 info using npm@10.7.0 2 info using node@v20.15.0 3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc 4 silly config:load:file:C:\ioBroker\.npmrc 5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc 6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc 7 verbose title npm install simatec/ioBroker.solax 8 verbose argv "install" "simatec/ioBroker.solax" 9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z- 10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log 11 silly logfile start cleaning logs, removing 1 files 12 silly logfile done cleaning log files 13 verbose stack Error: An unknown git error occurred 13 verbose stack at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13) 13 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26 13 verbose stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5) 14 verbose cwd C:\ioBroker 15 verbose Windows_NT 10.0.19045 16 verbose node v20.15.0 17 verbose npm v10.7.0 18 error code ENOENT 19 error syscall spawn git 20 error path git 21 error errno -4058 22 error enoent An unknown git error occurred 23 error enoent This is related to npm not being able to find a file. 23 error enoent 24 verbose exit -4058 25 verbose code -4058 26 silly unfinished npm timer reify 1719507201733 27 silly unfinished npm timer reify:loadTrees 1719507201739 28 silly unfinished npm timer idealTree:userRequests 1719507201999 29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
20 error path git
23 error enoentda war doch was mit dem installer für Win.
Ich glaube der installiert das Paket git nicht standardmäßig -
@homoran ok - danke - wie kann ich das Problem als newbee lösen?
Suche benutzen und u.a. dieses finden:
https://forum.iobroker.net/post/1166454 -
@icke2002 oder du wartest, bis ich die Version auf npm habe und installierst von npm über die Katze
@homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!
@simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
Super - Danke! -
@icke2002 Poste mal bitte die Objekte, die nun alle erzeugt wurden. Sind die Daten alle korrekt und plausibel?
@simatec schein erstmal ok zu sein - werde ich morgen nochmal prüfen, wenn mehr Sonne ist.
Ich will das Ganze dann sowieso auf einer Raspi4 zum Laufen bringen. Ich habe heute auf jeden Fall viel gelernt - danke nochmal! -
@homoran sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
@icke2002 Bitte keine 4K Briefmarken posten!
24% davon sind zu wenig zum erkennen.
3.1k ist nicht viel besser lesbar
