    4. Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
    • simatec
      simatec Developer Most Active @icke2002 last edited by
      @icke2002 Also bei mir läuft es sauber durch ...
      $ iobroker url simatec/ioBroker.solax --host iobroker-dev --debug
      install simatec/ioBroker.solax
      NPM version: 10.7.0
      Installing simatec/ioBroker.solax... (System call)
      removed 362 packages, and changed 1 package in 4s157 packages are looking for funding run `npm fund` for details
      upload [16] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/admin.d.ts admin.d.ts video/mp2t
      upload [14] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [12] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [11] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [9] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [5] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/jsonConfig.json jsonConfig.json application/json
      upload [2] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/solax.png solax.png image/png
      upload [0] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/words.js words.js application/javascript
      Update "system.adapter.solax.0"
      Process exited with code 0
      • simatec
        simatec Developer Most Active @simatec last edited by
        @simatec Starte mal dein System komplett neu und versuche es erneut
        I 2 Replies Last reply Reply Quote 0
        • I
          icke2002 @simatec last edited by
          @simatec ok mach ich!
            Homoran Global Moderator Administrators @icke2002 last edited by
            @icke2002 sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
            verstehe ich nicht - bei mir ist alles zu erkennen???
            ich denke mal dein Bildschirm ist breiter als 7cm.
            • I
              icke2002 @Homoran last edited by
              @homoran richtig?
              • I
                icke2002 @simatec last edited by Homoran
                @simatec hat nichts genützt - bricht mit Fehler ab!?
                0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
                1 info using npm@10.7.0
                2 info using node@v20.15.0
                3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc
                4 silly config:load:file:C:\ioBroker\.npmrc
                5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc
                6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc
                7 verbose title npm install simatec/ioBroker.solax
                8 verbose argv "install" "simatec/ioBroker.solax"
                9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-
                10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
                11 silly logfile done cleaning log files
                12 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.solax
                13 verbose stack Error: An unknown git error occurred
                13 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
                13 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
                13 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                14 verbose cwd C:\ioBroker
                15 verbose Windows_NT 10.0.19045
                16 verbose node v20.15.0
                17 verbose npm  v10.7.0
                18 error code ENOENT
                19 error syscall spawn git
                20 error path git
                21 error errno -4058
                22 error enoent An unknown git error occurred
                23 error enoent This is related to npm not being able to find a file.
                23 error enoent
                24 verbose exit -4058
                25 verbose code -4058
                26 silly unfinished npm timer reify 1719164066510
                27 silly unfinished npm timer reify:loadTrees 1719164066570
                28 silly unfinished npm timer idealTree:userRequests 1719164066788
                29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
                • simatec
                  @icke2002 Dann lösche den Adapter vorher komplett. Also auch im Tab Adapter. Sprich Instanzen und Adapter löschen.
                  Im Anschluss dann nochmals die Installation via Github siehe Screenshot
                  • I
                    @simatec Wird leider immer schlimmer!?
                    Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?
                    Punkt 13 und 18 - 23 - ich verstehe es nicht!
                    9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-
                    10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
                    11 silly logfile start cleaning logs, removing 1 files
                    12 silly logfile done cleaning log files
                    20 error path git
                    23 error enoent
                    26 silly unfinished npm timer reify 1719507201733
                    27 silly unfinished npm timer reify:loadTrees 1719507201739
                    28 silly unfinished npm timer idealTree:userRequests 1719507201999
                    29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
                      20 error path git
                      23 error enoent
                      da war doch was mit dem installer für Win.
                      Ich glaube der installiert das Paket git nicht standardmäßig
                      • I
                        @homoran ok - danke - wie kann ich das Problem als newbee lösen?
                        Homoran simatec 2 Replies Last reply Reply Quote 0
                          Suche benutzen und u.a. dieses finden:
                          https://forum.iobroker.net/post/1166454
                          • simatec
                            @icke2002 oder du wartest, bis ich die Version auf npm habe und installierst von npm über die Katze
                            I 2 Replies Last reply Reply Quote 1
                            • I
                              @homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!👍 😳
                              • I
                                @simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
                                Super - Danke!👍 👍 👍
                                • simatec
                                  simatec Developer Most Active @icke2002 last edited by simatec
                                  @icke2002 Poste mal bitte die Objekte, die nun alle erzeugt wurden. Sind die Daten alle korrekt und plausibel?
                                  • I
                                    @simatec
                                    • I
                                      icke2002 @simatec last edited by icke2002
                                      @simatec schein erstmal ok zu sein - werde ich morgen nochmal prüfen, wenn mehr Sonne ist.
                                      Ich will das Ganze dann sowieso auf einer Raspi4 zum Laufen bringen. Ich habe heute auf jeden Fall viel gelernt - danke nochmal!
                                        @icke2002
                                        @homoran sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
                                        @icke2002 Bitte keine 4K Briefmarken posten!
                                        24% davon sind zu wenig zum erkennen.
                                        3.1k ist nicht viel besser lesbar 😉
                                        • simatec
                                          @icke2002 feddInEnergy sieht irgendwie komisch aus vom Wert... Prüfe das mal, ob das passt
                                          • I
                                            @homoran ich weiss leider nicht, wie es besser geht - es wird noch dem Einfügen immer auf resized gesetzt?
                                            1576
