    4. Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
    • I
      icke2002 @simatec last edited by Homoran
      @simatec Wird leider immer schlimmer!?
      Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?
      Punkt 13 und 18 - 23 - ich verstehe es nicht!
      0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
      1 info using npm@10.7.0
      2 info using node@v20.15.0
      3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc
      4 silly config:load:file:C:\ioBroker\.npmrc
      5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc
      6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc
      7 verbose title npm install simatec/ioBroker.solax
      8 verbose argv "install" "simatec/ioBroker.solax"
      9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-
      10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
      11 silly logfile start cleaning logs, removing 1 files
      12 silly logfile done cleaning log files
      13 verbose stack Error: An unknown git error occurred
      13 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
      13 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
      13 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      14 verbose cwd C:\ioBroker
      15 verbose Windows_NT 10.0.19045
      16 verbose node v20.15.0
      17 verbose npm  v10.7.0
      18 error code ENOENT
      19 error syscall spawn git
      20 error path git
      21 error errno -4058
      22 error enoent An unknown git error occurred
      23 error enoent This is related to npm not being able to find a file.
      23 error enoent
      24 verbose exit -4058
      25 verbose code -4058
      26 silly unfinished npm timer reify 1719507201733
      27 silly unfinished npm timer reify:loadTrees 1719507201739
      28 silly unfinished npm timer idealTree:userRequests 1719507201999
      29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
        Homoran Global Moderator Administrators @icke2002 last edited by
        @icke2002 sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
        20 error path git
        23 error enoent
        da war doch was mit dem installer für Win.
        Ich glaube der installiert das Paket git nicht standardmäßig
        • I
          icke2002 @Homoran last edited by
          @homoran ok - danke - wie kann ich das Problem als newbee lösen?
          Homoran simatec 2 Replies Last reply Reply Quote 0
            Suche benutzen und u.a. dieses finden:
            https://forum.iobroker.net/post/1166454
            • simatec
              simatec Developer Most Active @icke2002 last edited by
              @icke2002 oder du wartest, bis ich die Version auf npm habe und installierst von npm über die Katze
              I 2 Replies Last reply Reply Quote 1
              • I
                @homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!👍 😳
                • I
                  @simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
                  Super - Danke!👍 👍 👍
                  • simatec
                    simatec Developer Most Active @icke2002 last edited by simatec
                    @icke2002 Poste mal bitte die Objekte, die nun alle erzeugt wurden. Sind die Daten alle korrekt und plausibel?
                    • I
                      @simatec
                      • I
                        icke2002 @simatec last edited by icke2002
                        @simatec schein erstmal ok zu sein - werde ich morgen nochmal prüfen, wenn mehr Sonne ist.
                        Ich will das Ganze dann sowieso auf einer Raspi4 zum Laufen bringen. Ich habe heute auf jeden Fall viel gelernt - danke nochmal!
                          @icke2002
                          @homoran sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
                          @icke2002 Bitte keine 4K Briefmarken posten!
                          24% davon sind zu wenig zum erkennen.
                          3.1k ist nicht viel besser lesbar 😉
                          • simatec
                            @icke2002 feddInEnergy sieht irgendwie komisch aus vom Wert... Prüfe das mal, ob das passt
                            • I
                              @homoran ich weiss leider nicht, wie es besser geht - es wird noch dem Einfügen immer auf resized gesetzt?
                                Fenster deutlich schmaler ziehen, ohne dass Informationen verloren gehen.
                                siehe auch: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
                                Bin zwar jetzt am "großen" Monitor, aber mit
                                lässt sich kein 4k sinnvoll darstellen
                                • simatec
                                  @icke2002 consumeenergy bitte auch mal prüfen
                                  • I
                                    @simatec consumeenergy ist noch um den Faktor 10 zu hoch - sollte ca. 154 kWh sein.
                                    • simatec
                                      @icke2002 wird in v0.9.9 gefixt. Die Version kommt heute Nacht ins latest
                                      • I
                                        @simatec Was mir noch aufgefallen ist:
                                        1. der Wert für Feed-in Energy ist ebenfalls um den Faktor 10 zu hoch und sollte vom Wert her Total Feed-in Energy entsprechen.
                                          2.Total Feed-in Energy ist ebenfalls um den Faktor 10 zu hoch und sollte der tägliche Feed-in Energy sein.
                                        den Rest versuche ich morgen bei Sonnenschein nochmal überprüfen - eventuell gleich mit Version 0.9.9
                                        • simatec
                                          @icke2002 Ja bitte alle Werte mal checken. Aufgrund fehlender Hardware hab ich den Code blind geschrieben.
                                          • I
                                            @simatec sieht erstmal ganz gut aus. Die Bedeutung von feedinenergy könnte (Gesamteinspeisung sein?) und totalFeed (diesen Wert kann ich im Moment gar nicht zuordnen?) erschließt sich mir noch nicht.
                                            1576
