    4. Pi3 Stretch, ioBroker macht keinen Autostart
      C-3po last edited by
      So, jetzt geht es bei mir.
      wie weiter oben schon genannt:
      pi@BrokerPi:/etc/init.d $ ./iobroker.sh
      -bash: ./iobroker.sh: /bin/bash^M: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden
      Problem beseitigt
      und die Rechte angepasst.
      danach noch diese Änderung durchgef.
      END INIT INFO
      (( EUID )) && echo .You need to have root privileges.. && exit 1
      PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
      NODECMD=@@node
      NODECMD=/usr/bin/node
      IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      RETVAL=0
      IOBROKERUSER=@@user
      IOBROKERUSER=root
      start() {
      jetzt startet ioBroker sauber nach einem Reboot durch.
      siehe:
      root@io-broker-pi:~# systemctl status iobroker
      ● iobroker.service - LSB: starts ioBroker
      Loaded: loaded (/etc/init.d/iobroker.sh; generated; vendor preset: enabled)
      Active: active (running) since Sat 2017-12-30 14:20:43 CET; 13s ago
      Docs: man:systemd-sysv-generator(8)
      Process: 597 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=0/SUCCESS)
      CGroup: /system.slice/iobroker.service
      ├─ 932 iobroker.js-controller
      ├─1254 io.admin.0
      ├─1953 io.discovery.0
      ├─2489 io.tr-064.4
      └─3113 /usr/bin/node /opt/iobroker/node_modules/iobroker.web/main.js 0 info
      Dez 30 14:20:37 io-broker-pi systemd[1]: Starting LSB: starts ioBroker…
      Dez 30 14:20:38 io-broker-pi sudo[606]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start
      Dez 30 14:20:38 io-broker-pi sudo[606]: pam_unix(sudo:session): session opened for user root by (uid=0)
      Dez 30 14:20:40 io-broker-pi iobroker.sh[597]: Starting ioBrokerStarting iobroker controller daemon…
      Dez 30 14:20:43 io-broker-pi iobroker.sh[597]: iobroker controller daemon started. PID: 932
      Dez 30 14:20:43 io-broker-pi sudo[606]: pam_unix(sudo:session): session closed for user root
      Dez 30 14:20:43 io-broker-pi systemd[1]: Started LSB: starts ioBroker.
        B3ta last edited by
        Könnte wer nochmal schritt weise erklären ? wie er es behoben habt. Habe auch kein autostart mehr und verstehe nicht ganz was ihr gemacht habt.
          Bitte auf jeden Fall bei allen Änderungen an Dateien keinen Windows-Editor benutzen.
          Unter Windows sollte das Notepad++ verwendet werden, und der Zeilenumbruch auf UNIX gestellt sein.
          Die Zeile:
          @C-3po:
          -bash: ./iobroker.sh: /bin/bash^M: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden `
          deutet darauf hin, dass diese Datei bereits mit einem Windows-Editor bearbeitet wurde.
          In der Installationsdatei ist der Windowsumbruch nicht drin!
          Wo kommt der her?
          Rainer
            B3ta last edited by
            bei mir kommt immer
            pi@raspberrypi:~ $ /etc/init.d $ ./iobroker.sh
            -bash: /etc/init.d: Ist ein Verzeichnis
              B3ta last edited by
              sorry war falsch in der zwischenablage
              pi@raspberrypi:/etc/init.d $ ./iobroker.sh
              pi@raspberrypi:/etc/init.d $ systemctl status iobroker
                 Loaded: loaded (/etc/init.d/iobroker.sh)
                 Active: failed (Result: exit-code) since Sa 2017-12-30 17:17:23 CET; 7min ago
                Process: 509 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=203/EXEC)
                paul53 last edited by
                @B3ta:
                Da hat sich ein CR eingeschlichen. Wurde die Datei mal aktualisiert / modiziert ? Prüfe bitte Länge und Datum:
                ls -l /etc/init.d/iobroker.sh
                  B3ta last edited by
                  habe die iobroker.sh nochmal neu erzeugen lassen grade. aber halt selbe fehler.
                  root@raspberrypi:/etc/init.d# ls -l /etc/init.d/iobroker.sh
                  -rwxrwxrwx 1 root root 1145 Dez 30 18:06 /etc/init.d/iobroker.sh
                    @B3ta:
                    habe die iobroker.sh nochmal neu erzeugen lassen grade. `
                    Wie ?
                    Die Datei ist 47 Byte zu groß.
                      B3ta last edited by
                      #!/bin/bash
                      ### BEGIN INIT INFO
                      # Provides:          iobroker.sh
                      # Required-Start:    $network $local_fs $remote_fs
                      # Required-Stop::    $network $local_fs $remote_fs
                      # Default-Start:     2 3 4 5
                      # Default-Stop:      0 1 6
                      # Short-Description: starts ioBroker
                      # Description:       starts ioBroker
                      ### END INIT INFO
                      NODECMD=@@node
                      RETVAL=0
                      IOBROKERUSER=@@user
                      start() {
                                  export IOBROKER_HOME=/opt/iobroker
                                  echo -n "Starting ioBroker"
                                  sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
                                  RETVAL=$?
                      stop() {
                                  echo -n "Stopping ioBroker"
                                  sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
                                  RETVAL=$?
                      case "$1" in
                          start)
                            start
                          stop)
                            stop
                          restart)
                            stop
                            start
                            echo "Usage: iobroker {start|stop|restart}"
                            exit 1
                      esac
                      exit $RETVAL
                      das ist der inhalt…
                        @B3ta:
                        das ist der inhalt… `
                        …und der enthält 47 Zeilen. Mit welchem Editor wird der Inhalt angezeigt und abgespeichert ?
                          B3ta last edited by
                          Nodepad++
                          aber wie gesagt die habe ich jetzt schon 2mal frisch erzeugen lassen ohne sie überhaupt zu öffnen.
                            bei mir unter armbian(!) ist die Ausgabe:
                            root@linaro-alip:~# ls -l /etc/init.d/iobroker.sh
                            -rwxr-xr-x 1 root root 1098 Nov 21 21:36 /etc/init.d/iobroker.sh
                            Rainer
                              und wenn ich richtig liege (was hier auf keinen Fall stimmen muss!!!) ist es diese Datei:
                              https://github.com/ioBroker/ioBroker/bl … obroker.sh
                              von März 2016 und seitdem nicht geändert worden.
                              Kann es sein, dass Raspbian 2017-11-29 da Mist baut?
                              Rainer
                                Dann konvertiere die Datei vom DOS- in das Linux-Format:
                                mv /etc/init.d/iobroker.sh /etc/init.d/iobroker.dos
                                tr -d '\r' < /etc/init.d/iobroker.dos > /etc/init.d/iobroker.sh
                                oder
                                cd /etc/init.d
                                mv iobroker.sh iobroker.dos
                                tr -d '\r' < iobroker.dos > iobroker.sh
                                ls -l iob*
                                  @Homoran:
                                  Kann es sein, dass Raspbian 2017-11-29 da Mist baut? `
                                  Dass Raspbian aus einer Linux- ein DOS-Textdatei macht, ist schwer vorstellbar. Aber vielleicht greift Raspbian auf eine andere (ältere) Quelle zurück ?
                                    B3ta last edited by
                                    So habe jetzt SD Karte formatiert.
                                    2017-07-05-raspbian-jessie installiert.
                                    iobroker nach der Anleitung installiert http://www.iobroker.net/docu/?page_id=5106&lang=de.
                                    Nach der Installation iobroker eingerichtet in der Weboberfläche.
                                    Raspberry rebootet.
                                    Und gleich das selbe kein Auto Start !
                                    pi@raspberrypi:~ $ ls -l /etc/init.d/iobroker.sh
                                    -rw-r--r-- 1 root root 1138 Dez 30 20:18 /etc/init.d/iobroker.sh
                                    pi@raspberrypi:~ $ sudo systemctl status iobroker
                                    ● iobroker.service
                                       Loaded: not-found (Reason: No such file or directory)
                                       Active: inactive (dead)
                                    -bash: ./iobroker.sh: Keine Berechtigung
                                      da fehlt sudo davor
                                      Rainer
                                      …da kommt wieder das ^M
                                        B3ta last edited by
                                        mit sudo…
                                        pi@raspberrypi:/etc/init.d $ sudo ./iobroker.sh
                                        sudo: ./iobroker.sh: Kommando nicht gefunden
                                          GASMAST3R last edited by
                                          Hallo ich bin neu hier da ich bei IoBroker mal reinschauen wollte.
                                          Habe auch ein frisches sys aufgestellt und kein Autostart, dies konnte ich nach ändern der rechte anpassen der iobrocker.sh und das konvertieren zu .dos zu .sh beheben.
                                          Werde das system für einen bekannten anfertigen, mal schauen ob ich von FHEM irgendwann mal umsteige.
                                            @B3ta:
                                            Die Dateigröße passt weder zu Linux (Soll: 1098) noch zu DOS (1145). Außerdem fehlen die Rechte zum Ausführen.
                                            5011
