    3. Einsteigerfragen
    4. Goodwe WR 8kw mit Waveshare RS485 to Wifi -> Modbus IOBroker
    • PV Anlage
      PV Anlage @wendy2702 last edited by
      Hallo @wendy2702
      Es ist extrem komisch, die - habe ich auch gerade wahrgenommen. Mit - ist der Modbus Adapter auf grün, ohne nicht.
      Hier noch der Output:
      modbus.0
      2024-05-05 18:35:17.013	info	Disconnected from slave 10.195.14.6
      modbus.0
      2024-05-05 18:35:17.010	debug	Closing client on purpose.
      modbus.0
      2024-05-05 18:35:16.024	debug	Cleaning up request fifo.
      modbus.0
      2024-05-05 18:35:16.023	debug	Clearing timeout of the current request.
      modbus.0
      2024-05-05 18:35:16.021	debug	Socket closed with error
      modbus.0
      2024-05-05 18:35:16.015	warn	Poll error count: 1 code: {"err":"timeout","timeout":1000}
      modbus.0
      2024-05-05 18:35:16.011	error	Client in error state.
      modbus.0
      2024-05-05 18:35:16.008	error	Request timed out.
      modbus.0
      2024-05-05 18:35:16.005	warn	Error: undefined
      modbus.0
      2024-05-05 18:35:14.987	debug	[DevID_1/holdingRegs] Poll address 35124 - 2 registers
      modbus.0
      2024-05-05 18:35:14.985	debug	Initialization of scale factors done!
      modbus.0
      2024-05-05 18:35:14.981	debug	[DevID_1] Poll start ---------------------
      modbus.0
      2024-05-05 18:35:14.978	info	Connected to slave 10.195.14.6
      modbus.0
      2024-05-05 18:35:14.531	debug	Add holdingRegisters.35124_Wechselrichter_L1: {"_id":"holdingRegisters.35124_Wechselrichter_L1","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":35124,"deviceId":1,"type":"int32be","len":2,"offset":1,"factor":2,"poll":true}}
      modbus.0
      2024-05-05 18:35:14.530	debug	Initialize Objects for holdingRegs: [{"_address":35124,"name":"Wechselrichter L1","description":"","unit":"W","type":"int32be","len":2,"factor":2,"offset":1,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":35124,"deviceId":1,"id":"holdingRegisters.35124_Wechselrichter_L1"}]
      modbus.0
      2024-05-05 18:35:14.529	debug	Initialize Objects for inputRegs: []
      modbus.0
      2024-05-05 18:35:14.527	debug	Initialize Objects for coils: []
      modbus.0
      2024-05-05 18:35:14.525	debug	Initialize Objects for disInputs: []
      modbus.0
      2024-05-05 18:35:14.289	info	starting. Version 6.1.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.20.2, js-controller: 5.0.19
      modbus.0
      2024-05-05 18:35:13.512	debug	Plugin sentry Initialize Plugin (enabled=true)
      modbus.0
      2024-05-05 18:35:13.462	debug	States connected to redis: 127.0.0.1:9000
      modbus.0
      2024-05-05 18:35:13.438	debug	States create User PubSub Client
      modbus.0
      2024-05-05 18:35:13.436	debug	States create System PubSub Client
      modbus.0
      2024-05-05 18:35:13.422	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      modbus.0
      2024-05-05 18:35:13.393	debug	Objects connected to redis: 127.0.0.1:9001
      modbus.0
      2024-05-05 18:35:13.377	debug	Objects client initialize lua scripts
      modbus.0
      2024-05-05 18:35:13.340	debug	Objects create User PubSub Client
      modbus.0
      2024-05-05 18:35:13.337	debug	Objects create System PubSub Client
      modbus.0
      2024-05-05 18:35:13.333	debug	Objects client ready ... initialize now
      modbus.0
      2024-05-05 18:35:13.278	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.iobroker
      2024-05-05 18:35:11.039	info	instance system.adapter.modbus.0 started with pid 2093
      host.iobroker
      2024-05-05 18:35:08.534	info	instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      modbus.0
      2024-05-05 18:35:08.449	info	terminating
      host.iobroker
      2024-05-05 18:35:07.983	info	stopInstance system.adapter.modbus.0 send kill signal
      modbus.0
      2024-05-05 18:35:07.943	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      modbus.0
      2024-05-05 18:35:07.942	debug	Plugin sentry destroyed
      modbus.0
      2024-05-05 18:35:07.940	info	terminating
      modbus.0
      2024-05-05 18:35:07.936	debug	Closing client on purpose.
      modbus.0
      2024-05-05 18:35:07.934	info	Got terminate signal TERMINATE_YOURSELF
      host.iobroker
      2024-05-05 18:35:07.925	info	stopInstance system.adapter.modbus.0 (force=false, process=true)
      modbus.0
      2024-05-05 18:35:00.696	info	Disconnected from slave 10.195.14.6
      modbus.0
      2024-05-05 18:35:00.693	debug	Closing client on purpose.
      Ich habe jetzt nur die 1+3 gemäss Rat auf den Waveshare geführt.
      Danke und Gruss
        Homoran Global Moderator Administrators @PV Anlage last edited by Homoran
        @pv-anlage sagte in Goodwe WR 8kw mit Waveshare RS485 to Wifi -> Modbus IOBroker:
        was ist denn dein IP range?
        in den Konfiguration Screenshots steht was anderes.
        RS485 to Wifi
        hast du jetzt wifi oder ETH?
        mode server scheint nicht zu wifi zu passen.
        Hab mir gerade die Anleitung
        https://www.waveshare.com/product/rs485-to-wifi-eth.htm
        quergelesen.
        Da sind seltsame Stolpersteine in den möglichen Konfigurationen.
        kann eigentlich nicht.
        mal A/B getauscht?
        und bitte zum testen nur einen Register nehmen
        PV Anlage 1 Reply Last reply Reply Quote 0
        • PV Anlage
          PV Anlage @Homoran last edited by PV Anlage
          Guten Abend @homoran
          IOBroker: 10.195.14.2
          RS485 to wifi: 10.195.14.6
          Ich lösche jetzt mal den kompletten Modbus Adapter und konfiguriere ihn neu
          "mode server scheint nicht zu wifi zu passen." inwiefern?
          Protokoll
          modbus.0
          2024-05-05 19:47:31.977	info	Connected to slave 10.195.14.6
          modbus.0
          2024-05-05 19:47:31.638	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
          modbus.0
          2024-05-05 19:47:31.537	error	Invalid object: {"type":"state","common":{"name":"Spannung PV String1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":-4898,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":"0,1","poll":true}}
          modbus.0
          2024-05-05 19:47:31.536	error	Invalid data holdingRegisters/0: {"_address":35103,"deviceId":1,"name":"PV1 Voltage","description":"Spannung PV String1","unit":"V","type":"uint16be","len":1,"factor":"0,1","offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":-4898,"fullId":"modbus.0.0"}
          modbus.0
          2024-05-05 19:47:31.530	error	Invalid holdingRegisters address: -4898
          modbus.0
          2024-05-05 19:47:31.286	info	starting. Version 6.1.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.20.2, js-controller: 5.0.19
          host.iobroker
          2024-05-05 19:47:28.000	info	instance system.adapter.modbus.0 started with pid 2475
          host.iobroker
          2024-05-05 19:47:25.489	info	instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          modbus.0
          2024-05-05 19:47:25.409	info	terminating
          host.iobroker
          2024-05-05 19:47:24.943	info	stopInstance system.adapter.modbus.0 send kill signal
          modbus.0
          2024-05-05 19:47:24.901	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          modbus.0
          2024-05-05 19:47:24.898	info	terminating
          modbus.0
          2024-05-05 19:47:24.893	info	Got terminate signal TERMINATE_YOURSELF
          host.iobroker
          2024-05-05 19:47:24.884	info	stopInstance system.adapter.modbus.0 (force=false, process=true)
          Danke und Gruss
            wenn ich die Anleitung richtig verstanden habe gibt es bei wifi dort nur "AP" oder "STA" einzutragen.
            jetzt hast du aliases benutzen angehakt!
            und das bei 35xxx.
            Vorhin warst du in Holdingregister, die beginnen mit 40xxx. Wo bist du jetzt?
            • PV Anlage
              War ein Konfigfehler beim Modbus Adapter neu einrichten.
              Waveshare:
              Endurance 1 Reply Last reply Reply Quote 0
              • wendy2702
                Stimmt die Geräte ID mit der im WR überein?
                Mal mit einem Modbus Programm getestet ob Daten kommen?
                • Endurance
                  Endurance @PV Anlage last edited by
                  @pv-anlage
                  Hallo
                  Gibts da news zu diesem Thema?
                  Hab einen Goodwe GW8000-SDT-20 und einen Waveshare RS485 to Ethernet POE (B)
                  Hier meine config des Waveshare Adapters:
                  Connection scheint zu klappen:
                  modbus.3
                  2024-06-28 17:49:43.953	info	Connected to slave 192.168.1.125
                  modbus.3
                  2024-06-28 17:49:43.727	info	starting. Version 6.1.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.20.3, js-controller: 5.0.19
                  modbus.3
                  2024-06-28 17:49:39.929	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  modbus.3
                  2024-06-28 17:49:39.929	info	terminating
                  modbus.3
                  2024-06-28 17:49:39.928	info	Got terminate signal TERMINATE_YOURSELF
                  Aber die passenden Register finde ich nirgends.
                  Habe einen Goodwe GW8000-SDT-20, den ich mittels Waveshare RS485 to Ethernet POE (B) auslesen will.
                  In der Anleitung vom WR steht zum Thema Modbus nur folgendes:
                  Communication Protocols: Modbus-RTU (SunSpec Compliant)
                  Im Menü des WR kann ich den ModbusType einstellen. Entweder GOODWE oder SunSpec.
                  Versteh ich das richtig, dass SunSpec ein Herstellerübergreiffender Standard ist? Bzw. sich Hersteller das via SunSpec Zertifizieren lassen können?
                  Hier kann man nach Goodwe Filtern, und sich die Listen herunterladen. Leider keine für die SDT Serie.
                  https://sunspec.org/certified-registry/
                  Hab ein paar aus dem Sheet der DT Serie probiert. Scheint aber nicht zu klappen.
                  WR sollte richtig mit dem Waveshare Adapter verbunden sein:
                  1 ist mit RS485B des Waveshares verbunden.
                  3 ist mit RS485A des Waveshares verbunden.
                  • wendy2702
                    wendy2702 @Endurance last edited by
                    @endurance wenn du Sunspec versuchst musst du zu 99,9% eine andere Unit ID verwenden.
                    Bei SMA ist das z.B. die eingestellte ID + 123
                    • Endurance
                      Endurance @wendy2702 last edited by
                      @wendy2702 said in Goodwe WR 8kw mit Waveshare RS485 to Wifi -> Modbus IOBroker:
                      Unit ID im Modbus Adapter?
                      Aber der Kommuniziert doch "nur" mit dem Waveshare, oder?
                      Homoran wendy2702 2 Replies Last reply Reply Quote 0
                        Homoran Global Moderator Administrators @Endurance last edited by
                        @endurance sagte in Goodwe WR 8kw mit Waveshare RS485 to Wifi -> Modbus IOBroker:
                        nein, über den Waveshare
                        • wendy2702
                          @endurance Waveshare ist „dumm“ und macht eigentlich nur die Umwandlung TCP <-> RS485
                          • Endurance
                            Endurance @wendy2702 last edited by Endurance
                            ok, habs nun mit UnitID 1 sowie 124 und 247 probiert. Funktikoniert nicht. Connection zum Waveshare scheinz zu funktionieren, Daten zu einigen eingetragenen Registern kommen aber keine.
                            Modbusadresse im Menü des WR: 247 (das ist aber nicht die UnitID, sondern der Port, oder?
                            Finde leider keine Infos zur UnitID dazu in den Anleitungen.
                            Versteh ich das richtig, dass die IP und der Port im Modbusadapter vom Waveshare sind, und die UnitID vom WR?
                            • wendy2702
                              wendy2702 @Endurance last edited by wendy2702
                              Erstmal nur mit einem Register testen
                              Das ist die Unit ID. Port gibt es bei RS485 nicht sondern nur bei TCP
                              Ja
                              Edit: das hilft nicht https://forum.iobroker.net/topic/59207/how-to-goodwe-wechselrichter-und-modbus-tcp
                              Du hast das TCP gedöns nicht?
                              • Endurance
                                @wendy2702
                                TCP gedöns: jain: nur die V1 des Adapters, da lt dem compatibiliy sheet V2 nicht kompatibel ist.
                                Im Goodwe Forum hat mir aber jemand gesagt, dass ich den V2 brauche.
                                Ich hab einen SDT G2:
                                dh für mich, dass WiFi+LAN2.0 nicht kompatibel ist...
                                Hatte noch einen RS485 rumliegen, desswegen wollte ich erstmal diesen nutzen.
                                Hier nochmal zum nachvollziehen die Settings am WR (via SolarGo APP), RS485 Settings:
                                und vom Modbus Adapter:
                                Eventuell nutze ich die falschen Register, da bin ich mir nicht zu 100% sicher, da ich keine Liste finden konnte, bei dem der genau Typ aufgelistet war.
                                • wendy2702
                                  Stellt sich die ID automatisch auf 1 wenn du das andere Modbus Protokoll wählst?
                                  Gibt es außer der Baudrate 9600 auch noch Einstellungen zu Bits etc. ?
                                  • Endurance
                                    nein, bleibt auf 247
                                    nein, im RS485 Menü ist das alles
                                    • wendy2702
                                      @endurance Sunspec ist mir mit ioBroker und SMA nicht gelungen. Erfordert nach meinem Verständnis eine Anfrage an den WR und diese wird dann mit einem Payload beantwortet das alles enthält.
                                      Der Modbus Adapter fragt ja die Register einzeln nacheinander ab.
                                      Ich würde es ohne Sunspec probieren oder HASS mit Sunspec Integration versuchen. Hat bei mir mit SMA nach 5 Minuten funktioniert
                                      973
