    4. Shelly 2.5 nicht in den Objekten zu finden
      Erich 1 @Homoran last edited by Homoran
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: debian-iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-23-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       16:55:46 up 122 days,  1:43,  2 users,  load average: 0.91, 0.59, 0.46
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Sat 2024-06-29 16:55:46 CEST
                 Universal time: Sat 2024-06-29 14:55:46 UTC
                       RTC time: Sat 2024-06-29 14:55:47
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      erich
      HOME=/home/erich
      GROUPS=erich cdrom floppy sudo audio dip video plugdev netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.9G        2.9G        186M        0.0K        858M        806M
      Swap:           974M        963M         11M
      Total:          4.9G        3.8G        197M
      Active iob-Instances:   16
               3919 M total memory
               2874 M used memory
               1360 M active memory
               2184 M inactive memory
                186 M free memory
                265 M buffer memory
                593 M swap cache
                974 M total swap
                963 M used swap
                 11 M free swap
      top - 16:55:47 up 122 days,  1:43,  2 users,  load average: 0.91, 0.59, 0.46
      Tasks: 107 total,   2 running, 105 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 12.5 us,  6.2 sy,  0.0 ni, 81.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3919.7 total,    185.6 free,   2874.9 used,    859.1 buff/cache
      MiB Swap:    975.0 total,     11.1 free,    963.9 used.    806.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  512K  392M   1% /run
      /dev/sda1      ext4       39G  5.8G   31G  16% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
      [Wed Feb 28 14:12:15 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Feb 28 14:12:16 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      [Wed Mar  6 11:06:16 2024]  ext4_filemap_fault+0x2d/0x50 [ext4]
      Show mounted filesystems:
      TARGET                       SOURCE     FSTYPE     OPTIONS
      /                            /dev/sda1  ext4       rw,relatime,errors=remount-ro
      |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc       proc       rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=10976
      |-/dev                       udev       devtmpfs   rw,nosuid,relatime,size=1989032k,nr_inodes=497258,mode=755
      | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/hugepages           hugetlbfs  hugetlbfs  rw,relatime,pagesize=2M
      | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
      `-/run                       tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=401380k,mode=755
        |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
        `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=401376k,nr_inodes=100344,mode=700,uid=1000,gid=1000
      /var:
      669M    /var/
      287M    /var/log
      273M    /var/log/journal/4782ab7b08f9440cb38008c40dbc892b
      222M    /var/cache
      Archived and active journals take up 32.0M in the file system.
      /opt/iobroker/backups:
      1.5G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      569M    /opt/iobroker/iobroker-data/
      319M    /opt/iobroker/iobroker-data/backupDir
      183M    /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      47M     /opt/iobroker/iobroker-data/backup-objects
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      /usr/bin/corepack       0.17.0
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
           18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
       *** 18.16.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.17.14
      javascript:     7.8.0
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : debian-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : debian-iobroker                          -  enabled
        system.adapter.birthdays.0              : birthdays             : debian-iobroker                          -  enabled
      + system.adapter.cloud.0                  : cloud                 : debian-iobroker                          -  enabled
        system.adapter.devices.0                : devices               : debian-iobroker                          - disabled
      + system.adapter.discovery.0              : discovery             : debian-iobroker                          -  enabled
      + system.adapter.email.0                  : email                 : debian-iobroker                          -  enabled
        system.adapter.flot.0                   : flot                  : debian-iobroker                          - disabled
      + system.adapter.fritzdect.0              : fritzdect             : debian-iobroker                          -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : debian-iobroker                          -  enabled
        system.adapter.habpanel.0               : habpanel              : debian-iobroker                          - disabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : debian-iobroker                          - disabled
      + system.adapter.history.0                : history               : debian-iobroker                          -  enabled
      + system.adapter.javascript.0             : javascript            : debian-iobroker                          -  enabled
      + system.adapter.javascript.1             : javascript            : debian-iobroker                          -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : debian-iobroker                          -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : debian-iobroker                          -  enabled
        system.adapter.openweathermap.0         : openweathermap        : debian-iobroker                          -  enabled
      + system.adapter.shelly.0                 : shelly                : debian-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : debian-iobroker                          -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.tuya.0                   : tuya                  : debian-iobroker                          -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian-iobroker                          - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian-iobroker                          - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian-iobroker                          - disabled
        system.adapter.vis.0                    : vis                   : debian-iobroker                          -  enabled
      + system.adapter.web.0                    : web                   : debian-iobroker                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.17.14  , installed 6.17.14
      Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
      Adapter    "birthdays"    : 3.0.0    , installed 2.4.1  [Updatable]
      Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
      Adapter    "discovery"    : 4.5.0    , installed 4.2.0  [Updatable]
      Adapter    "email"        : 1.3.1    , installed 1.2.2  [Updatable]
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "heatingcontrol": 2.12.8  , installed 2.12.3 [Updatable]
      Adapter    "javascript"   : 8.3.1    , installed 7.8.0  [Updatable]
      Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "shelly"       : 7.0.0    , installed 6.6.1  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
      Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
      Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
      Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
      Objects and States
      Objects:        3393
      States:         2772
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 112
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10985      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12851      433/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19439518   86415/io.mqtt.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       9428820    42316/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8973119    39064/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8973112    39064/iobroker.js-c
      tcp6       0      0 :::45295                :::*                    LISTEN      1001       35791376   147244/io.backitup.
      tcp6       0      0 :::111                  :::*                    LISTEN      0          10993      1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       164846244  665521/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9430790    42478/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12862      433/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       164842096  665455/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12547      390/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10988      1/init
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       28122492   119634/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       28122493   119634/io.tuya.0
      udp6       0      0 :::111                  :::*                                0          10998      1/init
      2024-06-29 16:43:26.486  - info: admin.0 (665521) ==> Connected system.user.admin from ::ffff:192.168.178.91
      2024-06-29 16:43:27.840  - info: admin.0 (665521) <== Disconnect system.user.admin from ::ffff:192.168.178.91 admin
      2024-06-29 16:43:29.048  - info: admin.0 (665521) ==> Connected system.user.admin from ::ffff:192.168.178.91
      2024-06-29 16:43:29.070  - info: admin.0 (665521) <== Disconnect system.user.admin from ::ffff:192.168.178.91 admin
      2024-06-29 16:43:30.541  - info: admin.0 (665521) ==> Connected system.user.admin from ::ffff:192.168.178.91
      2024-06-29 16:43:57.475  - info: history.0 (41612) Delete old history "/opt/iobroker/iobroker-data/backupDir/20230627/history.shelly.0.SHPLG2-1#BCFF4D4A2FBE#1.Relay0.Energy.json"
      2024-06-29 16:43:57.477  - info: history.0 (41612) Delete old history dir "/opt/iobroker/iobroker-data/backupDir/20230627"
      2024-06-29 16:45:00.036  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 started with pid 665537
      2024-06-29 16:45:01.716  - info: netatmo-crawler.0 (665537) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.16.0, js-controller: 4.0.24
      2024-06-29 16:45:01.780  - info: netatmo-crawler.0 (665537) Getting data for stationid:70:ee:50:1b:2f:26
      2024-06-29 16:45:02.805  - info: netatmo-crawler.0 (665537) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-06-29 16:45:03.336  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-06-29 16:48:16.384  - info: tuya.0 (119634) 30082515ecfabc579c1e: Connect locally to device
      2024-06-29 16:48:16.384  - info: tuya.0 (119634) 30082515ecfabc579c1e Init with IP=192.168.178.59, Key=C?'}]gT)j2twV<<$, Version=3.3
      2024-06-29 16:48:58.063  - info: admin.0 (665521) <== Disconnect system.user.admin from ::ffff:192.168.178.91 admin
      2024-06-29 16:50:00.037  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 started with pid 665554
      2024-06-29 16:50:01.648  - info: netatmo-crawler.0 (665554) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.16.0, js-controller: 4.0.24
      2024-06-29 16:50:01.708  - info: netatmo-crawler.0 (665554) Getting data for stationid:70:ee:50:1b:2f:26
      2024-06-29 16:50:03.939  - info: netatmo-crawler.0 (665554) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-06-29 16:50:04.463  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-06-29 16:55:00.037  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 started with pid 666634
      2024-06-29 16:55:01.632  - info: netatmo-crawler.0 (666634) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.16.0, js-controller: 4.0.24
      2024-06-29 16:55:01.724  - info: netatmo-crawler.0 (666634) Getting data for stationid:70:ee:50:1b:2f:26
      2024-06-29 16:55:02.868  - info: netatmo-crawler.0 (666634) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-06-29 16:55:03.394  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      iob diag has finished.
      Press any key for a summary
      Homoran 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Erich 1 last edited by
        @erich-1 sagte in Shelly 2.5 nicht in den Objekten zu finden:
        da ist ja alles veraltet
          Homoran Global Moderator Administrators @Erich 1 last edited by Homoran
          auch das Betriebssystem!
          112 Updates fehlen bei bullseye, upgrade auf bookworm wäre sowieso an der Reihe
          und die
            @homoran Ich weiss, ich setze das auf und dann läuft es lange, bis wieder ein neues Gerät dazu kommt. Da muss ich künftig wohl öfters updaten.
            ABER: Jetzt ist der Shelly in den Objekten aufgefürt, was genau die Ursache war, kann ich nicht feststellen. Aber ich kann auf alle Datenpunkte zugreifen ...
              alle 2-3 Wochen das OS, und iobroker sobald im Admin ein Update angezeigt wird.
              du bist ja im stable Repo unterwegs, da solltest du immer zügig dranbleiben
                @homoran Das werde ich mir hinter die Ohren schreiben. Wichtig ist, dass es jetzt funktioniert.
                DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                • DJMarc75
                  DJMarc75 @Erich 1 last edited by
                  Ja, aber viel wichtiger wäre es vom System immer aktuell zu sein - somit gibts auch weniger Trouble.
                    tut es das wirklich? oder nur scheinbar?
                      @homoran Wirklich !!!
                      Ich komme an die Datenpunkte vom Shelly, an die ich vorher nicht gekommen bin ...
                        weil du anscheinend keine Credentials im Shelly vergeben hast, diese aber i der Instanz eingetragen waren.
                        Die Frage bezog sich aber auf dein gesamtes System.
                        Wie viele Zeitbomben da wohl schlummern....
                        • da_Woody
                          da_Woody last edited by
                          @erich-1 manchmal dauert es bis ein Shelly im Adapter auftaucht.
                          Nicht in Panik verfallen und rumkonfigurieren!
                          Aus der Blacklist alles löschen. Da braucht's nix.
                          Wie schon geschrieben, setz das Ding neu auf. Updaten geht da imho nicht mehr...
                          Du wirst von einem Problem ins nächste taumeln.
                            Erich 1 @da_Woody last edited by
                            @da_woody Im Moment läuft es wieder, wie es soll. Die Arbeit mit neu aufsetzen steht dann wohl mal an.
                            Homoran haselchen 2 Replies Last reply Reply Quote 0
                              Du hast dann aber sicher Verständnis dass eine Unterstützung bei Problemen mit so einer windschiefen Installation nicht wirklich möglich ist.
                              • haselchen
                                haselchen Most Active @Erich 1 last edited by
                                @erich-1
                                Ich kann auch nur hoffen, dass das nicht nur leere Versprechungen sind.
                                Leider ist Dein System komplett veraltet.
                                Dein Speicher (RAM) quasi aufgebraucht.
                                Auch wenn der Shelly jetzt funktioniert, ist ne Frage der Zeit, dass Dein komplettes System abschmiert.
                                • mcm1957
                                  mcm1957 @haselchen last edited by
                                  Ohne jetzt extra draufzahlen- bringt niemand was:
                                  Denk an BACKUPS und schau dass die regelmässig gemacht werden. Und wenn du die Möglichkeit eines Zweitsydtems hast dann schau auch das das Restaurieren funktioniert.
                                    @mcm1957
                                    laut iob diag hat er
                                    eine VM.
                                    @Erich-1
                                    da kannst du doch ganz leicht parallel eine zweite VM aufbauen und dein System anschließend in einer halben Stunde umziehen
                                      @homoran Ja, das war auch der Grund, warum ich das so installiert habe. Aber das Betriebssyststem updaten wird für mich eine Herausforderung.
                                        Thomas Braun Most Active @Erich 1 last edited by Thomas Braun
                                        @erich-1
                                        Mach es einfach danach:
                                        https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                                        Und dann regelmäßig auf Stand halten. Sowohl das Betriebssystem wie auch den ioBroker.
                                          Erich 1 @Thomas Braun last edited by
                                          @thomas-braun said in Shelly 2.5 nicht in den Objekten zu finden:
                                          @erich-1
                                          Mein ioBroker läuft auf Proxmox in einer VM und die habe ich damals mit 4 GB wohl zu klein angelegt. Kann man die vergrößern, ohne das System neu aufsetzen zu müssen?
                                            Ja, deutlich zu klein. Bei Proxmox bin ich aber im weiteren raus, kenn ich nicht.
                                            Aber mehr RAM zuweisen sollte eigentlich kein Problem sein.
                                            2048
