    4. IoBroker Web nicht mehr unter :8081 verfügbar
    • MartinP
      MartinP last edited by
      Da ein Update sowieso einen iob-Neustart gemacht hat hier mal die Logging von meiner iob Instanz
      93
      Log-Größe: 115.3 KB
      Zeit
      Nachricht
      web.0
      	2024-07-01 13:16:05.855	info	starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.15.0, js-controller: 5.0.19
      web.0
      	2024-07-01 13:16:07.182	info	socket.io server listening on port 8082
      web.0
      	2024-07-01 13:16:07.225	info	http server listening on port 8082
        Homoran Global Moderator Administrators @MartinP last edited by
        @martinp Was willst du uns damit sagen?
          marcelinho last edited by
          Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.6.28+rpt-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           15:48:00 up  1:02,  3 users,  load average: 1.04, 1.22, 1.50
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Mon 2024-07-01 15:48:00 CEST
                     Universal time: Mon 2024-07-01 13:48:00 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            4.0G        2.6G        202M        1.1M        1.3G        1.4G
          Swap:           209M        524K        209M
          Total:          4.2G        2.6G        411M
          Active iob-Instances:   24
                   3792 M total memory
                   2443 M used memory
                   1952 M active memory
                   1434 M inactive memory
                    193 M free memory
                    104 M buffer memory
                   1127 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 15:48:00 up  1:02,  3 users,  load average: 1.04, 1.22, 1.50
          Tasks: 220 total,   1 running, 219 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 20.0 us, 20.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3792.1 total,    192.1 free,   2444.2 used,   1232.4 buff/cache
          MiB Swap:    200.0 total,    199.5 free,      0.5 used.   1347.8 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.3M  378M   1% /run
          /dev/mmcblk0p2 ext4       29G   24G  4.2G  85% /
          tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
          /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
          tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
          [Mon Jul  1 14:45:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Mon Jul  1 14:45:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add-4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
          [Mon Jul  1 14:45:12 2024] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab98-e9f0235e06b3 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET                                                  SOURCE         FSTYPE      OPTIONS
          /                                                       /dev/mmcblk0p2 ext4        rw,noatime
          |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
          | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
          |-/proc                                                 proc           proc        rw,relatime
          | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5370
          |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
          |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1668360k,nr_inodes=417090,mode=755
          | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
          | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
          |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
          | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
          | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
          `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          11G     /var/
          8.8G    /var/lib
          8.4G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
          Archived and active journals take up 869.0M in the file system.
          /opt/iobroker/backups:
          2.7G    /opt/iobroker/backups/
          1.3G    /opt/iobroker/backups/influxDB_2024_06_11-09_25_30_backupiobroker
          434M    /opt/iobroker/backups/influxDB_2024_06_11-09_35_27_backupiobroker
          /opt/iobroker/iobroker-data:
          396M    /opt/iobroker/iobroker-data/
          273M    /opt/iobroker/iobroker-data/files
          138M    /opt/iobroker/iobroker-data/files/javascript.admin
          118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          25M     /opt/iobroker/iobroker-data/objects.jsonl
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
          8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
          8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.3
          /usr/local/bin/node             v22.2.0
          /usr/local/bin/npm              10.8.1
          /usr/local/bin/npx              10.8.1
          /usr/local/bin/corepack         0.28.1
          *** nodejs is NOT correctly installed ***
          nodejs:
            Installed: 18.20.3-1nodesource1
            Candidate: 18.20.3-1nodesource1
            Version table:
           *** 18.20.3-1nodesource1 600
                  100 /var/lib/dpkg/status
               18.20.2-1nodesource1 600
               18.20.1-1nodesource1 600
               18.20.0-1nodesource1 600
               18.19.1-1nodesource1 600
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
               18.19.0-1nodesource1 600
               18.18.2-1nodesource1 600
               18.18.1-1nodesource1 600
               18.18.0-1nodesource1 600
               18.17.1-1nodesource1 600
               18.17.0-1nodesource1 600
               18.16.1-1nodesource1 600
               18.16.0-1nodesource1 600
               18.15.0-1nodesource1 600
               18.14.2-1nodesource1 600
               18.14.1-1nodesource1 600
               18.14.0-1nodesource1 600
               18.13.0-1nodesource1 600
               18.12.0-1nodesource1 600
               18.11.0-1nodesource1 600
               18.10.0-1nodesource1 600
               18.9.1-1nodesource1 600
               18.9.0-1nodesource1 600
               18.8.0-1nodesource1 600
               18.7.0-1nodesource1 600
               18.6.0-1nodesource1 600
               18.5.0-1nodesource1 600
               18.4.0-1nodesource1 600
               18.3.0-1nodesource1 600
               18.2.0-1nodesource1 600
               18.1.0-1nodesource1 600
               18.0.0-1nodesource1 600
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          admin:          6.17.14
          javascript:     8.3.1
          nodejs modules from github:     3
          +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
          +-- iobroker.fusionsolar@1.2.4 (git+ssh://git@github.com/KornSW/ioBroker.fusionsolar.git#50f776fd8f991d0832be3d660de7a38a4763093d)
          +-- iobroker.smart-eq@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.smart-eq.git#9030604bbf5c6ad568873f80bb24c614600d3c51)
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
          + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
          + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
          + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
          + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.smart-eq.0               : smart-eq              : raspberrypi                              - disabled
          + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.17.14  , installed 6.17.14
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "daikin"       : 1.4.2    , installed 1.4.2
          Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
          Adapter    "homekit-controller": 0.5.10, installed 0.5.10
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
          Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
          Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "openhab"      : 1.2.0    , installed 1.2.0
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
          Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "ws"           : 2.6.1    , installed 2.6.1
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
          Objects and States
          Objects:        16130
          States:         14417
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:8 https://repo.homebridge.io stable InRelease
          Reading package lists...
          Pending Updates: 127
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:46721         0.0.0.0:*               LISTEN      112        12956      2366/homebridge: ho
          tcp        0      0 127.0.0.1:46833         0.0.0.0:*               LISTEN      112        7839       1241/homebridge: ho
          tcp        0      0 127.0.0.1:38099         0.0.0.0:*               LISTEN      112        7122       1227/homebridge: ho
          tcp        0      0 127.0.0.1:33999         0.0.0.0:*               LISTEN      112        7127       1221/homebridge: @0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6677       783/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       12820      2178/node
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       37539      4541/io.mqtt.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        8443       778/mosquitto
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       37524      4530/io.shelly.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       38975      4314/node-red
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7319       769/cupsd
          tcp        0      0 127.0.0.1:37791         0.0.0.0:*               LISTEN      112        7817       1213/homebridge: ho
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37945      4243/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37939      4243/iobroker.js-co
          tcp        0      0 127.0.0.1:34933         0.0.0.0:*               LISTEN      112        9350       1246/homebridge: ho
          tcp        0      0 127.0.0.1:39197         0.0.0.0:*               LISTEN      112        9363       1207/homebridge: ho
          tcp        0      0 127.0.0.1:41305         0.0.0.0:*               LISTEN      112        9019       1206/homebridge: ho
          tcp        0      0 127.0.0.1:43369         0.0.0.0:*               LISTEN      112        7856       1230/homebridge: @t
          tcp6       0      0 :::52120                :::*                    LISTEN      112        7785       1246/homebridge: ho
          tcp6       0      0 :::3000                 :::*                    LISTEN      113        6075       965/grafana
          tcp6       0      0 :::47961                :::*                    LISTEN      112        7776       1206/homebridge: ho
          tcp6       0      0 :::39667                :::*                    LISTEN      112        9333       1213/homebridge: ho
          tcp6       0      0 :::51798                :::*                    LISTEN      112        8984       1171/homebridge
          tcp6       0      0 :::8581                 :::*                    LISTEN      112        6135       1099/hb-service
          tcp6       0      0 :::45391                :::*                    LISTEN      112        9054       1221/homebridge: @0
          tcp6       0      0 :::37166                :::*                    LISTEN      112        9014       1207/homebridge: ho
          tcp6       0      0 :::22                   :::*                    LISTEN      0          6679       783/sshd: /usr/sbin
          tcp6       0      0 :::53299                :::*                    LISTEN      112        7099       1227/homebridge: ho
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        8632       884/influxd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       37986      4262/io.admin.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      112        9022       1230/homebridge: @t
          tcp6       0      0 :::1883                 :::*                    LISTEN      114        8444       778/mosquitto
          tcp6       0      0 :::36476                :::*                    LISTEN      112        9028       1230/homebridge: @t
          tcp6       0      0 :::44253                :::*                    LISTEN      112        9013       1241/homebridge: ho
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7318       769/cupsd
          tcp6       0      0 :::52403                :::*                    LISTEN      112        13594      2366/homebridge: ho
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       39954      4445/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       39955      4445/io.tuya.0
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          7444       875/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        7810       1213/homebridge: ho
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        6132       1099/hb-service
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7187       564/avahi-daemon: r
          udp        0      0 0.0.0.0:36310           0.0.0.0:*                           104        7189       564/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       40071      4563/io.shelly.1
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        9025       1230/homebridge: @t
          udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          5908       696/NetworkManager
          udp6       0      0 :::33612                :::*                                104        7190       564/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        7188       564/avahi-daemon: r
            marcelinho @Homoran last edited by
            @homoran ist drin
              Homoran Global Moderator Administrators @marcelinho last edited by Homoran
              @marcelinho sagte in IoBroker Web nicht mehr unter :8081 verfügbar:
              @homoran ist drin
              was?
              und
              der läuft aber nicht
              leider ist die Ausgabe unvollständig
              Da blockieren einige andere Anwendungen die Ports.
              ggf. hat IoBroker bei der Installation nicht die standardmäßigen Ports genommen, weil die belegt waren.
              Außerdem sind 8081 und 8082 nur per tcpv6 erreichbar
                Thomas Braun Most Active @marcelinho last edited by Thomas Braun
                @marcelinho
                Du hast da auch noch andere Böcke drin...
                Bring das erstmal das Untergeschoß in Ordnung, dann kannst du dich um die oberen Etagen kümmern.
                iob nodejs-update 20
                Nach dem nodejs-update einmal sauber neustarten.
                  @marcelinho zusätzlich ist nodejs vollkommen schief installiert und dein Betriebssystem braucht dringend Pflege
                    @homoran ```
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     16:03:44 up  1:18,  3 users,  load average: 0.64, 0.43, 0.81
                    CPU threads: 4
                    Current issues:
                                   Local time: Mon 2024-07-01 16:03:44 CEST
                               Universal time: Mon 2024-07-01 14:03:44 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.0G        2.6G        240M        1.1M        1.3G        1.4G
                    Total:          4.2G        2.6G        449M
                             3792 M total memory
                             2446 M used memory
                             1961 M active memory
                             1389 M inactive memory
                              229 M free memory
                              110 M buffer memory
                             1082 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    top - 16:03:44 up  1:18,  3 users,  load average: 0.64, 0.43, 0.81
                    Tasks: 216 total,   1 running, 215 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3792.1 total,    229.4 free,   2446.3 used,   1193.0 buff/cache
                    MiB Swap:    200.0 total,    199.5 free,      0.5 used.   1345.7 avail Mem
                    *** FILESYSTEM ***
                    /var:
                    11G     /var/
                    8.8G    /var/lib
                    397M    /opt/iobroker/iobroker-data/
                    26M     /opt/iobroker/iobroker-data/objects.jsonl
                    9.3M    /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.17.14
                    javascript:     8.3.1
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        16130
                    States:         14417
                    2024-07-01 15:49:27.648  - warn: influxdb.0 (4307) Error on writePoint("{"value":1499,"time":"2024-07-01T13:49:13.690Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                    2024-07-01 15:49:27.648  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=6
                    2024-07-01 15:49:27.651  - warn: influxdb.0 (4307) Point could not be written to database: admin
                    2024-07-01 15:49:27.652  - warn: influxdb.0 (4307) Error on writePoint("{"value":3.6327,"time":"2024-07-01T13:49:10.003Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                    2024-07-01 15:49:27.652  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh to buffer again, error-count=3
                    2024-07-01 15:49:27.655  - warn: influxdb.0 (4307) Point could not be written to database: admin
                    2024-07-01 15:49:27.655  - warn: influxdb.0 (4307) Error on writePoint("{"value":25.5,"time":"2024-07-01T13:49:12.997Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                    2024-07-01 15:49:27.656  - info: influxdb.0 (4307) Add point that had error for KuecheThermostat to buffer again, error-count=4
                    2024-07-01 15:49:27.659  - warn: influxdb.0 (4307) Point could not be written to database: admin
                    2024-07-01 15:49:27.659  - warn: influxdb.0 (4307) Error on writePoint("{"value":1982,"time":"2024-07-01T13:49:10.936Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                    2024-07-01 15:49:27.659  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_Power to buffer again, error-count=3
                    2024-07-01 15:49:27.664  - warn: influxdb.0 (4307) Point could not be written to database: admin
                    2024-07-01 15:49:27.665  - warn: influxdb.0 (4307) Error on writePoint("{"value":25,"time":"2024-07-01T13:49:15.744Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                    2024-07-01 15:49:27.665  - info: influxdb.0 (4307) Add point that had error for KuecheThermostat to buffer again, error-count=5
                    2024-07-01 15:49:27.670  - warn: influxdb.0 (4307) Point could not be written to database: admin
                    2024-07-01 15:49:27.670  - warn: influxdb.0 (4307) Error on writePoint("{"value":0.254289,"time":"2024-07-01T13:49:10.005Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                    2024-07-01 15:49:27.670  - info: influxdb.0 (4307) Add point that had error for Netzeinspeisung_Tag_Euro to buffer again, error-count=3
                    2024-07-01 15:49:46.507  - warn: zigbee2mqtt.0 (4515) Failed to ping 'Nachtlicht Schlafzimmer' (attempt 1/1, Read 0xa4c1388d509aac33/1 genBasic(["zclVersion"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205)))
                    2024-07-01 15:52:41.401  - info: tuya.0 (4445) 73103057e868e767b347: Connect locally to device
                    2024-07-01 15:52:41.402  - info: tuya.0 (4445) 73103057e868e767b347 Init with IP=192.168.2.128, Key=5xJDx8!3L%N;&}6E, Version=3.3
                    2024-07-01 15:59:51.457  - warn: zigbee2mqtt.0 (4515) Failed to ping 'Nachtlicht Schlafzimmer' (attempt 1/1, Read 0xa4c1388d509aac33/1 genBasic(["zclVersion"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205)))
                    2024-07-01 16:00:43.795  - info: awtrix-light.0 (4682) error ECONNABORTED from custom?name=pvleistung: timeout of 3000ms exceeded
                    2024-07-01 16:00:43.796  - warn: awtrix-light.0 (4682) (custom?name=pvleistung) Unable to update custom app "pvleistung": AxiosError: timeout of 3000ms exceeded
                    2024-07-01 16:01:16.414  - info: tuya.0 (4445) 73103057e868e767b347: Connect locally to device
                    2024-07-01 16:01:16.415  - info: tuya.0 (4445) 73103057e868e767b347 Init with IP=192.168.2.128, Key=5xJDx8!3L%N;&}6E, Version=3.3
                      marcelinho @Thomas Braun last edited by
                      @thomas-braun danke mache ich
                        @homoran danke bin gerade dabei mache einen neustart und lade eine neue iob diag hoch
                          marcelinho @marcelinho last edited by marcelinho
                          @Homoran und @Thomas-Braun so hat etwas länger gedauert, habe nun: iob nodejs-update 20 und einen restart gemacht, nun die neue:
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                           16:31:41 up  1:46,  3 users,  load average: 6.76, 4.50, 3.06
                          CPU threads: 4
                          Current issues:
                                         Local time: Mon 2024-07-01 16:31:41 CEST
                                     Universal time: Mon 2024-07-01 14:31:41 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            4.0G        2.6G         49M        823K        1.4G        1.4G
                          Swap:           209M        3.9M        205M
                          Total:          4.2G        2.6G        254M
                          Active iob-Instances:   16
                                   3792 M total memory
                                   2490 M used memory
                                   2659 M active memory
                                    806 M inactive memory
                                     46 M free memory
                                    220 M buffer memory
                                   1111 M swap cache
                                    199 M total swap
                                      3 M used swap
                                    196 M free swap
                          top - 16:31:41 up  1:46,  3 users,  load average: 6.76, 4.50, 3.06
                          Tasks: 217 total,   2 running, 215 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 14.3 us, 28.6 sy,  0.0 ni, 42.9 id,  0.0 wa,  0.0 hi, 14.3 si,  0.0 st
                          MiB Mem :   3792.1 total,     43.1 free,   2493.4 used,   1332.3 buff/cache
                          MiB Swap:    200.0 total,    196.2 free,      3.8 used.   1298.7 avail Mem
                          *** FILESYSTEM ***
                          /dev/mmcblk0p2 ext4       29G   24G  3.7G  87% /
                          [Mon Jul  1 14:45:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
                          [Mon Jul  1 14:45:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add        -4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
                          [Mon Jul  1 14:45:12 2024] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab        98-e9f0235e06b3 r/w. Quota mode: none.
                          | |-/sys/kernel/security                                securityfs     securityf        s  rw,nosuid,nodev,noexec,relatime
                          |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_mi        sc rw,nosuid,nodev,noexec,relatime
                          | |-/run/rpc_pipefs                                     sunrpc         rpc_pipef        s  rw,relatime
                          | `-/run/user/1000                                      tmpfs          tmpfs        rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1        000
                          `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixe        d,errors=remount-ro
                          /var:
                          12G     /var/
                          8.8G    /var/lib
                          403M    /opt/iobroker/iobroker-data/
                          31M     /opt/iobroker/iobroker-data/objects.jsonl
                          9.8M    /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          /usr/bin/nodejs         v20.15.0
                          /usr/bin/node           v20.15.0
                          /usr/bin/npm            10.7.0
                          /usr/bin/npx            10.7.0
                          /usr/bin/corepack       0.28.1
                          nodejs:
                            Installed: 20.15.0-1nodesource1
                            Candidate: 20.15.0-1nodesource1
                            Version table:
                           *** 20.15.0-1nodesource1 600
                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                               20.14.0-1nodesource1 600
                               20.13.1-1nodesource1 600
                               20.13.0-1nodesource1 600
                               20.12.2-1nodesource1 600
                               20.12.1-1nodesource1 600
                               20.12.0-1nodesource1 600
                               20.11.1-1nodesource1 600
                               20.11.0-1nodesource1 600
                               20.10.0-1nodesource1 600
                               20.9.0-1nodesource1 600
                               20.8.1-1nodesource1 600
                               20.8.0-1nodesource1 600
                               20.7.0-1nodesource1 600
                               20.6.1-1nodesource1 600
                               20.6.0-1nodesource1 600
                               20.5.1-1nodesource1 600
                               20.5.0-1nodesource1 600
                               20.4.0-1nodesource1 600
                               20.3.1-1nodesource1 600
                               20.3.0-1nodesource1 600
                               20.2.0-1nodesource1 600
                               20.1.0-1nodesource1 600
                               20.0.0-1nodesource1 600
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.17.14
                          javascript:     8.3.1
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        16130
                          States:         14429
                          Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:34457         0.0.0.0:*               LISTEN      112        98074      15199/homebridge: h
                          tcp        0      0 127.0.0.1:40099         0.0.0.0:*               LISTEN      112        97094      15160/homebridge: h
                          tcp        0      0 127.0.0.1:46159         0.0.0.0:*               LISTEN      112        98066      15192/homebridge: h
                          tcp        0      0 127.0.0.1:46189         0.0.0.0:*               LISTEN      112        99401      15179/homebridge: h
                          tcp        0      0 127.0.0.1:40347         0.0.0.0:*               LISTEN      112        99390      15173/homebridge: @
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          97314      14853/sshd: /usr/sb
                          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       111759     31894/io.mqtt.0
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       111751     31853/io.shelly.0
                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       109182     31623/node-red
                          tcp        0      0 127.0.0.1:33705         0.0.0.0:*               LISTEN      112        98044      15166/homebridge: h
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       107271     31547/iobroker.js-c
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       107266     31547/iobroker.js-c
                          tcp        0      0 127.0.0.1:33645         0.0.0.0:*               LISTEN      112        98537      15185/homebridge: @
                          tcp        0      0 127.0.0.1:45557         0.0.0.0:*               LISTEN      112        97072      15159/homebridge: h
                          tcp        0      0 127.0.0.1:41221         0.0.0.0:*               LISTEN      112        97126      15168/homebridge: h
                          tcp6       0      0 :::52120                :::*                    LISTEN      112        97079      15199/homebridge: h
                          tcp6       0      0 :::3000                 :::*                    LISTEN      113        94967      14664/grafana
                          tcp6       0      0 :::47961                :::*                    LISTEN      112        98025      15159/homebridge: h
                          tcp6       0      0 :::39667                :::*                    LISTEN      112        98481      15166/homebridge: h
                          tcp6       0      0 :::51798                :::*                    LISTEN      112        98419      15079/homebridge
                          tcp6       0      0 :::8581                 :::*                    LISTEN      112        96103      15037/hb-service
                          tcp6       0      0 :::45391                :::*                    LISTEN      112        97115      15173/homebridge: @
                          tcp6       0      0 :::37166                :::*                    LISTEN      112        98476      15160/homebridge: h
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          97316      14853/sshd: /usr/sb
                          tcp6       0      0 :::53299                :::*                    LISTEN      112        98548      15179/homebridge: h
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       109851     31571/io.admin.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      112        98498      15185/homebridge: @
                          tcp6       0      0 :::36476                :::*                    LISTEN      112        97092      15185/homebridge: @
                          tcp6       0      0 :::44253                :::*                    LISTEN      112        98037      15192/homebridge: h
                          tcp6       0      0 :::52403                :::*                    LISTEN      112        97065      15168/homebridge: h
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       111705     31735/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       111706     31735/io.tuya.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        98083      15166/homebridge: h
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        96100      15037/hb-service
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       111790     31915/io.shelly.1
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        97083      15185/homebridge: @
                          was compiled against a different Node.js version using
                          NODE_MODULE_VERSION 120. This version of Node.js requires
                          NODE_MODULE_VERSION 115. Please try re-compiling or re-installing
                          the module (for instance, using `npm rebuild` or `npm install`).
                          2024-07-01 16:31:47.421  - warn: ecovacs-deebot.0 (32008) The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                          2024-07-01 16:31:47.643  - warn: ecovacs-deebot.0 (32008) The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                          2024-07-01 16:31:50.194  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus1-fcb467bf172c" connected!
                          2024-07-01 16:31:54.649  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-d4d4dae918f0" connected!
                          2024-07-01 16:31:58.510  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-fcb467a697e8" connected!
                          2024-07-01 16:31:59.599  - error: zigbee2mqtt.0 (31821) Publish 'set' 'state' to 'Nachtlicht Schlafzimmer' failed: 'Error: Command 0xa4c1388d509aac33/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
                          2024-07-01 16:31:59.602  - error: zigbee2mqtt.0 (31821) Publish 'set' 'system_mode' to 'Thermostat Badezimmer OG' failed: 'Error: Command 0xa4c1380ceefe7b79/1 manuSpecificTuya.dataRequest({"seq":1,"dpValues":[{"dp":2,"datatype":4,"data":[2]}]}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
                          2024-07-01 16:32:00.442  - info: cloud.0 (31736) Trying to connect as system.user.admin to cloud
                          2024-07-01 16:32:00.551  - info: cloud.0 (31736) Connection changed: connect
                          2024-07-01 16:32:04.600  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-fcb467a5f910" connected!
                          2024-07-01 16:32:22.028  - error: zigbee2mqtt.0 (31821) Publish 'get' 'state' to 'Nachtlicht Schlafzimmer' failed: 'Error: Read 0xa4c1388d509aac33/1 genOnOff(["onOff"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
                          2024-07-01 16:32:22.033  - error: zigbee2mqtt.0 (31821) Publish 'get' 'color_temp' to 'Nachtlicht Schlafzimmer' failed: 'Error: Cluster 'lightingColorCtrl' has no attribute 'currentLevel''
                          2024-07-01 16:32:22.038  - error: zigbee2mqtt.0 (31821) Publish 'get' 'color' to 'Nachtlicht Schlafzimmer' failed: 'Error: Cluster 'lightingColorCtrl' has no attribute 'currentLevel''
                            tc
                            8081 für den admin wird hier bereits genutzt
                            der web Adapter läuft nicht weil 8082 hier
                            für den Admin verwendet wird, obwohl er hier
                            mit Port 8081 konfiguriert ist
                              @homoran habe nun auf :8083 geändert jetzt läuft es anscheinend Screenshot 2024-07-01 164108.png Screenshot 2024-07-01 164119.png
                                und der admin?
                                  marcelinho @Homoran last edited by marcelinho
                                                          v.2024-05-22
                                         Icon name: computer
                                      Architecture: arm64
                                  Installation:           native
                                  Kernel:                 aarch64
                                  Userland:               64 bit
                                  Timezone:               Europe/Berlin (CEST, +0200)
                                  User-ID:                1000
                                  Pending OS-Updates:     0
                                  Pending iob updates:    0
                                  Nodejs-Installation:
                                  /usr/bin/npm            10.7.0
                                  /usr/bin/npx            10.7.0
                                  Recommended versions are nodejs 18.20.3 and npm 10.7.0
                                  MEMORY:
                                  Mem:            4.0G        2.4G        208M        147K        1.5G        1.6G
                                  Swap:           209M        4.7M        204M
                                  Total:          4.2G        2.4G        413M
                                  ioBroker Core:          js-controller           5.0.19
                                                          admin                   6.17.14
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                16130
                                  States:                 14429
                                  Size of iob-Database:
                                  32M     /opt/iobroker/iobroker-data/objects.jsonl
                                  11M     /opt/iobroker/iobroker-data/states.jsonl
                                    web noch auf 8082 und läuft nicht
                                    admin auf 8081umd läuft.
                                    Hast du 2 Installationen parallel laufen?
                                      @homoran eigentlich nicht - zumindest nicht das ich wüsste
                                        die Daten in iob diag passen nicht zu deinen Aussagen und Screenshots
                                          @homoran auf die Weboberfläche bin ich immer mit :8081 gekommen jetzt komme ich mit :8082 drauf seit ich den oben erwähnten Adapter installiert habe auf der :8082 bin ich in IoBroker Oberfläche und auf der :8082 kommt das: Screenshot 2024-07-01 165102.png was eigentlich vorher die Weboberfläche von IoBroker war deswegen bin ich verwirrt. Screenshot 2024-07-01 165202.png
                                            das passt ja zu
                                            @homoran sagte in IoBroker Web nicht mehr unter :8081 verfügbar:
                                            tc
                                            4104
