    4. iobroker auf https umstellen
      MCU last edited by
      Ich habe versucht iobroker auf https umzustellen und bekomme einige Probleme.
      Hierfür benötige ich ein wenig Hilfe.
      Einstellungen Admin
      Einstellungen Web
      Bekomme dann im Log folgende Meldungen
      web.0
      2024-07-01 15:05:26.567	info	Secure socket.io server listening on port 8082
      web.0
      2024-07-01 15:05:26.487	warn	Falling back to self-signed certificates or to custom certificates
      web.0
      2024-07-01 15:05:26.487	warn	Could not find any certificate collections - check ACME installation or consider installing
      admin.0
      2024-07-01 15:05:26.494	info	<== Disconnect system.user.admin from ::ffff:192.168.178.77 admin
      web.0
      2024-07-01 15:05:26.442	info	starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v20.15.0, js-controller: 5.0.19
      host.iobrokerPROD
      2024-07-01 15:05:25.949	info	instance system.adapter.web.0 started with pid 860722
      host.iobrokerPROD
      2024-07-01 15:05:23.936	info	instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      web.0
      2024-07-01 15:05:23.392	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      web.0
      2024-07-01 15:05:23.387	info	terminating
      admin.0
      2024-07-01 15:05:23.262	info	<== Disconnect system.user.admin from ::ffff:192.168.178.77 web
      host.iobrokerPROD
      2024-07-01 15:05:22.918	info	stopInstance system.adapter.web.0 send kill signal
      cloud.0
      2024-07-01 15:05:22.917	info	Trying to connect as system.user.admin to cloud
      cloud.0
      2024-07-01 15:05:22.916	error	Cannot activate web.0 for cloud, because HTTPs is enabled. Please create extra instance for cloud
      cloud.0
      2024-07-01 15:05:22.890	info	Reconnect because web instance started
      cloud.0
      2024-07-01 15:05:22.884	error	Cannot activate web.0 for cloud, because HTTPs is enabled. Please create extra instance for cloud
      web.0
      2024-07-01 15:05:22.887	warn	setTimeout called, but adapter is shutting down
      web.0
      2024-07-01 15:05:22.878	info	Got terminate signal TERMINATE_YOURSELF
      Was mache ich jetzt mit der cloud? Wie muss ich jetzt die 2.Instanz einstellen?
      Warum bekomme ich jetzt den Hinweis, dass die Seite doch nicht sicher ist und ich dort keine Passwörter eingeben soll?
      Wie bekomme ich die Seiten (ioBroker) sicher?
      Bitte detaillierte Anleitung, wenn möglich. Danke.
      Homoran MartinP 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @MCU last edited by
        @mcu sagte in iobroker auf https umstellen:
        ja, eine ohne https
          MCU @Homoran last edited by
          Dann muss ich auch eine 2. Web-Instanz ohne https erstellen, damit ich diese dann der 2. Instanz von cloud zuordnen kann. Richtig?
            Homoran Global Moderator Administrators @MCU last edited by Homoran
            Richtig
            ja, aber warum deswegen 2x cloud?
              @homoran Brauchte nur die Web-Instanz umstellen. Bekomme noch bei admin
              admin.0
              2024-07-01 16:48:47.868	warn	cloud has an invalid jsonConfig: [{"instancePath":"/items/_options/items/_instanceAlive/instance","schemaPath":"#/definitions/aliveProps/properties/instance/type","keyword":"type","params":{"type":"number"},"message":"must be number"},{"instancePath":"/items/_options","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
              Was ist da zu tun?
              Homoran mcm1957 2 Replies Last reply Reply Quote 0
                Was ist da zu tun?
                keine Ahnung.
                Da war mal was mit einer "Falschmeldung" wegen json-Konfig. @mcm1957 kann sich da vielleicht dran erinnern.
                • MartinP
                  MartinP @MCU last edited by MartinP
                  @mcu Wieso benötigst Du denn https? Möchtest Du den ioBroker ins Internet stellen?
                  Dazu habe ich etwas:
                  978aae2f-2a0c-40ab-b226-d5a3e98d090c-1719844705416-2276d287-8eef-4625-8ddb-113d583e2b45-image.png
                  Liegt sicher an den "self signed certificates"....
                  web.0
                  Mir ist das auch zu viel Mühe. Ich gehe aus dem Internet per Fritzbox Wireguard VPN auf die ioBroker Webseiten und hoffe das Beste, dass im Heimnetz auch http: sicher genug ist ...
                    MCU @MartinP last edited by MCU
                    @martinp Nein, nicht ins Internet. Jarvis benötigt (zurzeit) https für die PIN-Eingabe (wird noch diskutiert). Aber um es diskutieren zu können muss ich es auch mal umgestellt haben.
                    Nun stelle ich bei der Umstellung die Probleme fest und bedenke, dass es auch bei anderen Usern so wäre.
                    EDIT: Das mache ich auch per VPN über Wireguard.
                      @martinp Das ist halt verwirrend. Auf der einen Seite richte ich https ein, damit ich die PIN / Passwörter schütze und auf der anderen Seite erhalte ich, wenn ich einstelle, den Hinweis, dass es nicht sicher ist und ich dort keine Passwörter eingeben soll.
                      Ist es jetzt sicher, was ist sicher und was nicht? Darf ich jetzt die PIN / Passwort dort eingeben und den Hinweis kann ich ignorieren bzw. muss ihn einfach ignorieren?
                      • MartinP
                        @mcu
                        Nervig, aber solche Spielchen werden einem wohl immer öfter vor die Flinte kommen ... wird wohl Zeit, sich mit dem Zertifikats-Gedöns zu beschäftigen ... neues Spielchen ist ja, dass die Anwendungen anfangen Zertifikate abzulehnen, die eine zu lange Laufzeit haben...
                        • mcm1957
                          mcm1957 @MCU last edited by
                          @mcu said in iobroker auf https umstellen:
                          admin.0
                          Was ist da zu tun?
                          Muss der Dev fixen
                          https://github.com/ioBroker/ioBroker.cloud/issues/373
                          Brainbug01 created this issue in ioBroker/ioBroker.cloud
                          open cloud has an invalid jsonConfig: #373
                          • SKB
                            SKB Developer Most Active @MCU last edited by SKB
                            @mcu Ich habe seit gestern ioBroker-Web auch mit Zertifikaten versehen.
                            Allerdings bin ich etwas anders vorgangen.
                            Ich habe mir eine Zertifikat CA (Certificate Authority) erstellt, welches als "root-Zertifikat" fungiert - muss man einmal im System einbinden. Dann kann man mit diesem root-Zertifikat Gerätezertifikate bzw. Unterzertifikate erstellen und sie bsp. in ioBroker oder anderen Geräten im Netzwerk einspeisen, damit sie vollkommen https können. Da man hier das root-Zertifikat eingespielt hat, erlauben sie auch Namen wie "meinIoBroker" oder eben "iobroker-master". Selbst IP-Adressen lassen sich signieren, was bei lokalen Adressen sonst nicht geht, weil eine 192.168.x.x gibt es ja millionenfach 😉
                            War relativ einfach 🙂
                              MCU @SKB last edited by
                              @skb
                              Hast du dazu eine detaillierte Anleitung? Links? Videos?
                              Danke.
                              Wenn man weiß wie es geht, dann sind die meisten Dinge einfach.
                              OliverIO SKB 2 Replies Last reply Reply Quote 0
                              • OliverIO
                                OliverIO @MCU last edited by
                                @mcu
                                Für linux/debian-artige
                                Kann man hier nachlesen
                                https://wiki.ubuntuusers.de/CA/
                                • SKB
                                  @mcu Natürlich. Habe 2 Links - ein relativ einfacher Prozess, der funktioniert - mit Ausnahme, dass das Zertifikat so heißt, wie das Programm.
                                  Und ein Prozess, der beschreibt, wie der eigene Name drin vorkommt (gefiel mir besser) 😉
                                  Wenn ich gleich am Rechner bin, schreibe ich dir die Links dazu.
                                  • SKB
                                    SKB Developer Most Active last edited by SKB
                                    Hier ist der Link, der einfacher ist, aber das Zertifikat den Namen des Programms trägt (nicht weiter schlimm, aber mein Monk mag keine fremden Namen 😉 )
                                    https://www.digitalocean.com/community/tutorials/how-to-set-up-and-configure-a-certificate-authority-ca-on-debian-10-de
                                    Bei diesem Link nennst Du deine CA (Cerficate Authority) wie Du möchtest. Sieht irgendwie besser aus:
                                    https://linux-admin-blog.de/2022/04/09/eigene-ca-fuer-zertifikatserstellung/
                                    https
                                    1758
