    4. [gelöst] iobroker lässt sich nicht richtig installieren
      Homoran Global Moderator Administrators @MiPl last edited by
      @mipl sagte in iobroker lässt sich nicht richtig installieren:
      iob diag gibt nichts aus:
      iob stop
      iob fix
      iob start
      .....warten
      iob diag
        MiPl @DJMarc75 last edited by
        @djmarc75
        da kommt:
        pi@ubuntu:~$ iob fix
        library: loaded
        Library version=2024-05-24
            Welcome to the ioBroker installation fixer!
            Script version: 2024-01-04
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Hit:1 http://ports.ubuntu.com/ubuntu-ports focal InRelease
        Get:2 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [128 kB]
        Hit:3 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
        Fetched 128 kB in 3s (42.9 kB/s)
        Reading package lists... Done
            Checking ioBroker user and directory permissions (2/5)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        npm error code EACCES
        npm error syscall mkdir
        npm error path /home/iobroker
        npm error errno EACCES
        npm error FetchError: Invalid response body while trying to fetch https://registry.npmjs.org/@iobroker%2fjsonltool: EACCES: permission denied, mkdir '/home/iobroker'
        npm error     at /usr/lib/node_modules/npm/node_modules/minipass-fetch/lib/body.js:170:15
        npm error     at async Response.json (/usr/lib/node_modules/npm/node_modules/minipass-fetch/lib/body.js:75:17)
        npm error     at async RegistryFetcher.packument (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:98:25)
        npm error     at async RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:129:23)
        npm error     at async getManifest (/usr/lib/node_modules/npm/node_modules/libnpmexec/lib/index.js:27:22)
        npm error     at async missingFromTree (/usr/lib/node_modules/npm/node_modules/libnpmexec/lib/index.js:61:22)
        npm error     at async /usr/lib/node_modules/npm/node_modules/libnpmexec/lib/index.js:163:32
        npm error     at async Promise.all (index 0)
        npm error     at async exec (/usr/lib/node_modules/npm/node_modules/libnpmexec/lib/index.js:161:3)
        npm error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5) {
        npm error   code: 'EACCES',
        npm error   errno: 'EACCES',
        npm error   syscall: 'mkdir',
        npm error   path: '/home/iobroker',
        npm error   type: 'system'
        npm error }
        npm error
        npm error The operation was rejected by your operating system.
        npm error It is likely you do not have the permissions to access this file as the current user
        npm error
        npm error If you believe this might be a permissions issue, please double-check the
        npm error permissions of the file and its containing directories, or try running
        npm error the command again as root/Administrator.
        npm error Log files were not written due to an error writing to the directory: /home/iobroker/.npm/_logs
        npm error You can rerun the command with `--loglevel=verbose` to see the logs in your terminal
            Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        Homoran DJMarc75 2 Replies Last reply Reply Quote 0
          ohh, oooooh!
          Habe iobroker auf ein laufendes System "hinzuinstalliert".
          wie genau hast du das gemacht?
          klappt iob diag jetzt trotzdem?
          • DJMarc75
            DJMarc75 @MiPl last edited by
            @mipl mach es so wie @Homoran geschrieben hat.
              MiPl @Homoran last edited by
              Installation via ssh mit dem Befehl:
              curl -sLf https://iobroker.net/install.sh | bash -
              iob diag geht weiterhin nicht.
                Thomas Braun Most Active @MiPl last edited by Thomas Braun
                @mipl
                Dann ruf iob diag wie in meiner Signatur zu sehen auf.
                Also per
                curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                  als root??
                    MiPl @Thomas Braun last edited by
                    Keine Ausgabe mit curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                      Nein, nicht als root
                        @mipl
                        curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                          MiPl @Thomas Braun last edited by MiPl
                          liefert
                          pi@ubuntu:/$ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                           Dload  Upload   Total   Spent    Left  Speed
                          100   169  100   169    0     0    800      0 --:--:-- --:--:-- --:--:--   800
                          Warning: Failed to create the file diag.sh: Permission denied
                           69 23302   69 16126    0     0  37502      0 --:--:-- --:--:-- --:--:-- 37502
                          curl: (23) Failed writing body (0 != 16126)
                            @mipl
                            Bitte immer die vollständigen Ein- wie Ausgaben inkl. LoginPrompt posten.
                              nicht als root
                              wieso dann
                              System ist mit apt-get update und apt-upgrade aktualisiert.
                              ohne sudo?
                                update und upgrade wurde mit sudo ausgeführt.
                                  Homoran Global Moderator Administrators @MiPl last edited by Homoran
                                  @mipl Danke!
                                  hmm, wo klemmt's denn dann mit den Rechten?
                                    @mipl
                                    Stell dich in das home-Verzeichnis vom pi. Der darf (zum Glück) nicht in / schreiben.
                                      Du meintest so?
                                      pi@ubuntu:/$ cd /home/pi
                                      pi@ubuntu:~$ pwd
                                      /home/pi
                                      pi@ubuntu:~$ ls -l
                                      total 1872
                                      -rw-rw-r-- 1 pi pi    1800 Mar  1  2023 Cron-Send-new-IP.sh
                                      -rw-rw-r-- 1 pi pi      70 Mar  1  2023 IP-per-Email.txt
                                      -rw-rw-r-- 1 pi pi 1908226 Sep 20  2023 get-pip.py
                                        @mipl
                                        Natürlich... Was treibst du eigentlich im root? Da haste nix zu wollen.
                                          ok, curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh liefert nun:
                                          Skript v.2024-05-22
                                          *** BASE SYSTEM ***
                                             Static hostname: ubuntu
                                                   Icon name: computer
                                            Operating System: Ubuntu 20.04.6 LTS
                                                      Kernel: Linux 5.4.0-1111-raspi
                                                Architecture: arm64
                                          Model           : Raspberry Pi 3 Model B Rev 1.2
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          Systemuptime and Load:
                                           20:45:23 up  1:34,  1 user,  load average: 0.25, 0.12, 0.12
                                          CPU threads: 4
                                          *** Time and Time Zones ***
                                                         Local time: Mon 2024-07-01 20:45:23 CEST
                                                     Universal time: Mon 2024-07-01 18:45:23 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          pi
                                          HOME=/home/pi
                                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio spi i2c iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          GROUPS=iobroker tty dialout audio video plugdev gpio i2c
                                          *** Display-Server-Setup ***
                                          Display-Server: false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:           906M        223M        186M        2.0M        496M        588M
                                          Swap:            0B          0B          0B
                                          Total:         906M        223M        186M
                                          Active iob-Instances:   1
                                                    906 M total memory
                                                    223 M used memory
                                                    472 M active memory
                                                    111 M inactive memory
                                                    186 M free memory
                                                     38 M buffer memory
                                                    457 M swap cache
                                                      0 M total swap
                                                      0 M used swap
                                                      0 M free swap
                                          top - 20:45:24 up  1:34,  1 user,  load average: 0.25, 0.12, 0.12
                                          Tasks: 149 total,   1 running, 148 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  1.2 us,  6.1 sy,  0.0 ni, 92.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :    906.1 total,    186.2 free,    223.5 used,    496.5 buff/cache
                                          MiB Swap:      0.0 total,      0.0 free,      0.0 used.    589.0 avail Mem
                                          *** FAILED SERVICES ***
                                            UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                                          * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                                          LOAD   = Reflects whether the unit definition was properly loaded.
                                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                          SUB    = The low-level unit activation state, values depend on unit type.
                                          1 loaded units listed.
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  405M     0  405M   0% /dev
                                          tmpfs          tmpfs      91M  3.0M   88M   4% /run
                                          /dev/mmcblk0p2 ext4       15G  6.7G  7.1G  49% /
                                          tmpfs          tmpfs     454M   16K  454M   1% /dev/shm
                                          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                          tmpfs          tmpfs     454M     0  454M   0% /sys/fs/cgroup
                                          /dev/loop0     squashfs   60M   60M     0 100% /snap/core20/2107
                                          /dev/loop2     squashfs   62M   62M     0 100% /snap/lxd/22761
                                          /dev/loop1     squashfs   60M   60M     0 100% /snap/core20/2321
                                          /dev/loop4     squashfs   36M   36M     0 100% /snap/snapd/20674
                                          /dev/loop5     squashfs   34M   34M     0 100% /snap/snapd/21761
                                          /dev/loop3     squashfs   92M   92M     0 100% /snap/lxd/24065
                                          /dev/mmcblk0p1 vfat      253M  121M  132M  48% /boot/firmware
                                          tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                          [Mon Jul  1 19:10:44 2024] Kernel command line:  coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  elevator=deadline net.ifnames=0 console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash quiet splash
                                          [Mon Jul  1 19:10:50 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                          [Mon Jul  1 19:10:53 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                          Show mounted filesystems:
                                          TARGET                                SOURCE                 FSTYPE      OPTIONS
                                          /                                     /dev/mmcblk0p2         ext4        rw,relatime
                                          |-/sys                                sysfs                  sysfs       rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/kernel/security              securityfs             securityfs  rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/cgroup                    tmpfs                  tmpfs       ro,nosuid,nodev,noexec,mode=755
                                          | | |-/sys/fs/cgroup/unified          cgroup2                cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate
                                          | | |-/sys/fs/cgroup/systemd          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                                          | | |-/sys/fs/cgroup/blkio            cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,blkio
                                          | | |-/sys/fs/cgroup/rdma             cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,rdma
                                          | | |-/sys/fs/cgroup/perf_event       cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
                                          | | |-/sys/fs/cgroup/hugetlb          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,hugetlb
                                          | | |-/sys/fs/cgroup/freezer          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,freezer
                                          | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                                          | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                                          | | |-/sys/fs/cgroup/cpuset           cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
                                          | | |-/sys/fs/cgroup/pids             cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,pids
                                          | | `-/sys/fs/cgroup/devices          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,devices
                                          | |-/sys/fs/pstore                    pstore                 pstore      rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/bpf                       none                   bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                          | |-/sys/kernel/debug                 debugfs                debugfs     rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/kernel/tracing               tracefs                tracefs     rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/fuse/connections          fusectl                fusectl     rw,nosuid,nodev,noexec,relatime
                                          | `-/sys/kernel/config                configfs               configfs    rw,nosuid,nodev,noexec,relatime
                                          |-/proc                               proc                   proc        rw,nosuid,nodev,noexec,relatime
                                          | `-/proc/sys/fs/binfmt_misc          systemd-1              autofs      rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1192
                                          |   `-/proc/sys/fs/binfmt_misc        binfmt_misc            binfmt_misc rw,nosuid,nodev,noexec,relatime
                                          |-/dev                                udev                   devtmpfs    rw,nosuid,noexec,relatime,size=414248k,nr_inodes=103562,mode=755
                                          | |-/dev/pts                          devpts                 devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                          | |-/dev/shm                          tmpfs                  tmpfs       rw,nosuid,nodev
                                          | |-/dev/hugepages                    hugetlbfs              hugetlbfs   rw,relatime,pagesize=2M
                                          | `-/dev/mqueue                       mqueue                 mqueue      rw,nosuid,nodev,noexec,relatime
                                          |-/run                                tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=92792k,mode=755
                                          | |-/run/lock                         tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                          | |-/run/rpc_pipefs                   sunrpc                 rpc_pipefs  rw,relatime
                                          | |-/run/user/1000                    tmpfs                  tmpfs       rw,nosuid,nodev,relatime,size=92788k,mode=700,uid=1000,gid=1003
                                          | `-/run/snapd/ns                     tmpfs[/snapd/ns]       tmpfs       rw,nosuid,nodev,noexec,relatime,size=92792k,mode=755
                                          |   `-/run/snapd/ns/lxd.mnt           nsfs[mnt:[4026533439]] nsfs        rw
                                          |-/snap/core20/2107                   /dev/loop0             squashfs    ro,nodev,relatime
                                          |-/snap/lxd/22761                     /dev/loop2             squashfs    ro,nodev,relatime
                                          |-/snap/core20/2321                   /dev/loop1             squashfs    ro,nodev,relatime
                                          |-/snap/snapd/20674                   /dev/loop4             squashfs    ro,nodev,relatime
                                          |-/snap/snapd/21761                   /dev/loop5             squashfs    ro,nodev,relatime
                                          |-/snap/lxd/24065                     /dev/loop3             squashfs    ro,nodev,relatime
                                          `-/boot/firmware                      /dev/mmcblk0p1         vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          3.1G    /var/
                                          1.8G    /var/log
                                          1.5G    /var/log/journal/4d4f67eb4fe2458ca82aed624af367f8
                                          1016M   /var/lib
                                          Archived and active journals take up 1.4G in the file system.
                                          /opt/iobroker/backups:
                                          du: cannot access '/opt/iobroker/backups/': No such file or directory
                                          /opt/iobroker/iobroker-data:
                                          228K    /opt/iobroker/iobroker-data/
                                          4.0K    /opt/iobroker/iobroker-data/states.jsonl.lock
                                          4.0K    /opt/iobroker/iobroker-data/objects.jsonl.lock
                                          4.0K    /opt/iobroker/iobroker-data/backup-objects
                                          188K    /opt/iobroker/iobroker-data/states.jsonl
                                          16K     /opt/iobroker/iobroker-data/objects.jsonl
                                          8.0K    /opt/iobroker/iobroker-data/iobroker.json
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v20.15.0
                                          /usr/bin/node           v20.15.0
                                          /usr/bin/npm            10.7.0
                                          /usr/bin/npx            10.7.0
                                          /usr/bin/corepack       0.28.1
                                          nodejs:
                                            Installed: 20.15.0-1nodesource1
                                            Candidate: 20.15.0-1nodesource1
                                            Version table:
                                           *** 20.15.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                                  100 /var/lib/dpkg/status
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                               10.19.0~dfsg-3ubuntu1.6 500
                                                  500 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 Packages
                                                  500 http://ports.ubuntu.com/ubuntu-ports focal-security/universe arm64 Packages
                                               10.19.0~dfsg-3ubuntu1 500
                                                  500 http://ports.ubuntu.com/ubuntu-ports focal/universe arm64 Packages
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                           Cannot read system.config: null (OK when migrating or restoring)
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  5.0.19
                                          admin:          6.17.14
                                          javascript:     "javascript" not found
                                          nodejs modules from github:     0
                                          Adapter State
                                          + instance is alive
                                          ioBroker-Repositories
                                          List is empty
                                          Installed ioBroker-Instances
                                          Error: Object "system.config" not found
                                          Objects and States
                                          Objects:        33
                                          States:         26
                                          Hit:2 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
                                          Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
                                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Pending Updates: 2
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15414      1/init
                                          tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      0          25397      864/motion
                                          tcp        0      0 127.0.0.1:8082          0.0.0.0:*               LISTEN      0          25398      864/motion
                                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        24040      621/systemd-resolve
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          29099      1054/sshd: /usr/sbi
                                          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          26854      657/python2
                                          tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          25399      864/motion
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50450      5240/iobroker.js-co
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50445      5240/iobroker.js-co
                                          tcp6       0      0 :::111                  :::*                    LISTEN      0          15252      1/init
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          29101      1054/sshd: /usr/sbi
                                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        24039      621/systemd-resolve
                                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15415      1/init
                                          udp6       0      0 :::111                  :::*                                0          15418      1/init
                                          2024-07-01 19:27:48.803  - info: host.ubuntu iobroker.js-controller version 5.0.19 js-controller starting
                                          2024-07-01 19:27:48.817  - info: host.ubuntu Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                          2024-07-01 19:27:48.820  - info: host.ubuntu hostname: ubuntu, node: v20.15.0
                                          2024-07-01 19:27:48.822  - info: host.ubuntu ip addresses: 10.56.78.100
                                          2024-07-01 19:27:49.080  - info: host.ubuntu Objects protocol version has changed, disconnecting!
                                          2024-07-01 19:27:49.154  - error: host.ubuntu Cannot read system.config: null (OK when migrating or restoring)
                                          2024-07-01 19:27:49.225  - error: host.ubuntu Cannot find view "system" for search "host"
                                          2024-07-01 19:27:49.371  - info: host.ubuntu connected to Objects and States
                                          2024-07-01 19:27:49.454  - info: host.ubuntu Node.js version has changed from unknown to 20.15.0
                                          2024-07-01 19:27:49.542  - info: host.ubuntu added notifications configuration of host
                                          2024-07-01 19:27:49.547  - info: host.ubuntu Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                          2024-07-01 19:27:49.614  - error: host.ubuntu Cannot find view "system" for search "instance"
                                          2024-07-01 19:27:49.617  - error: host.ubuntu Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                                          2024-07-01 19:27:49.697  - info: host.ubuntu Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                          2024-07-01 19:27:49.716  - error: host.ubuntu Cannot find view "system" for search "host"
                                          2024-07-01 19:27:49.737  - error: host.ubuntu Cannot find view "system" for search "state"
                                          2024-07-01 19:27:49.739  - error: host.ubuntu Cannot find view "system" for search "instance"
                                          2024-07-01 19:27:49.741  - error: host.ubuntu Could not collect system.host.ubuntu states to check for obsolete states: Cannot find view "system"
                                          2024-07-01 19:27:49.743  - error: host.ubuntu  _design/system missing - call node iobroker.js setup
                                          2024-07-01 19:27:49.744  - info: host.ubuntu  no instances found
                                          2024-07-01 19:27:49.745  - info: host.ubuntu no instances found
                                          2024-07-01 19:27:50.339  - info: host.ubuntu Created UUID: 67b55ea4-7e7d-e632-81e0-66bd95578b60
                                          iob diag has finished.
                                            und dann
                                            und das bei nur 1GB RAM, und dann ausgerechnet
                                            motion
                                            das auch noch die Ports blockiert
                                            1177
