    3. Off Topic
    4. Grafana
    5. Hintergrund von Grafana Dashboard in VIS entfernen
      RkcCorian @Kail last edited by RkcCorian
      @kail Moin! Ich habe großes Interesse an Deiner index.html. Allerdings startet bei mir der Container mit Grafana v10.3.1 nicht mehr, wenn ich die index.html mit Deiner austausche.
      Bei jedem Verbindungsversuch über den Browser bekommen ich jeweils einmal die folgende Fehlermeldung...
      INFO [01-31|20:38:57] Shutdown started                         logger=server reason="System signal: terminated"
      INFO [01-31|20:38:57] Closing tracing                          logger=tracing
      INFO [01-31|20:38:57] stopped                                  logger=ticker last_tick=2024-01-31T20:38:50Z
      INFO [01-31|20:39:13] Starting Grafana                         logger=settings version=10.3.1 commit=00a22ff8b28550d593ec369ba3da1b25780f0a4a branch=HEAD compiled=2024-01-22T18:40:42Z
      INFO [01-31|20:39:13] Config loaded from                       logger=settings file=/usr/share/grafana/conf/defaults.ini
      INFO [01-31|20:39:13] Config loaded from                       logger=settings file=/etc/grafana/grafana.ini
      INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.paths.data=/var/lib/grafana"
      INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.paths.logs=/var/log/grafana"
      INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.paths.plugins=/var/lib/grafana/plugins"
      INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.paths.provisioning=/etc/grafana/provisioning"
      INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.log.mode=console"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_PATHS_DATA=/var/lib/grafana"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_PATHS_LOGS=/var/log/grafana"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_PATHS_PLUGINS=/var/lib/grafana/plugins"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_PATHS_PROVISIONING=/etc/grafana/provisioning"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_SERVER_PROTOCOL=http"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_SECURITY_ALLOW_EMBEDDING=true"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_AUTH_ANONYMOUS_ENABLED=true"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_DATE_FORMATS_FULL_DATE=DD.MM.YY HH:mm:ss"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_DATE_FORMATS_INTERVAL_HOUR=DD.MM HH:mm"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_DATE_FORMATS_INTERVAL_DAY=DD.MM"
      INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_DATE_FORMATS_INTERVAL_MONTH=MM.YY"
      INFO [01-31|20:39:13] Target                                   logger=settings target=[all]
      INFO [01-31|20:39:13] Path Home                                logger=settings path=/usr/share/grafana
      INFO [01-31|20:39:13] Path Data                                logger=settings path=/var/lib/grafana
      INFO [01-31|20:39:13] Path Logs                                logger=settings path=/var/log/grafana
      INFO [01-31|20:39:13] Path Plugins                             logger=settings path=/var/lib/grafana/plugins
      INFO [01-31|20:39:13] Path Provisioning                        logger=settings path=/etc/grafana/provisioning
      INFO [01-31|20:39:13] App mode production                      logger=settings
      INFO [01-31|20:39:13] Connecting to DB                         logger=sqlstore dbtype=sqlite3
      WARN [01-31|20:39:13] SQLite database file has broader permissions than it should logger=sqlstore path=/var/lib/grafana/grafana.db mode=-rwxrwxr-x expected=-rw-r-----
      INFO [01-31|20:39:13] Starting DB migrations                   logger=migrator
      INFO [01-31|20:39:13] migrations completed                     logger=migrator performed=0 skipped=526 duration=2.883611ms
      INFO [01-31|20:39:13] Envelope encryption state                logger=secrets enabled=true current provider=secretKey.v1
      INFO [01-31|20:39:13] Loading plugins...                       logger=plugin.store
      WARN [01-31|20:39:13] Skipping finding plugins as directory does not exist logger=local.finder path=/usr/share/grafana/plugins-bundled
      INFO [01-31|20:39:13] Plugins loaded                           logger=plugin.store count=55 duration=43.891667ms
      INFO [01-31|20:39:13] Query Service initialization             logger=query_data
      INFO [01-31|20:39:13] Live Push Gateway initialization         logger=live.push_http
      INFO [01-31|20:39:14] Starting                                 logger=ngalert.migration
      INFO [01-31|20:39:14] Migration already complete               logger=ngalert.migration CurrentType=UnifiedAlerting DesiredType=UnifiedAlerting CleanOnDowngrade=false CleanOnUpgrade=false
      WARN [01-31|20:39:14] Unexpected number of rows updating alert configuration history logger=ngalert rows=0 org=1 hash=not-yet-calculated
      INFO [01-31|20:39:14] registering usage stat providers         logger=infra.usagestats.collector usageStatsProvidersLen=2
      INFO [01-31|20:39:14] starting to provision alerting           logger=provisioning.alerting
      INFO [01-31|20:39:14] finished to provision alerting           logger=provisioning.alerting
      INFO [01-31|20:39:14] Warming state cache for startup          logger=ngalert.state.manager
      INFO [01-31|20:39:14] HTTP Server Listen                       logger=http.server address=[::]:3000 protocol=http subUrl= socket=
      INFO [01-31|20:39:14] Storage starting                         logger=grafanaStorageLogger
      INFO [01-31|20:39:14] Starting MultiOrg Alertmanager           logger=ngalert.multiorg.alertmanager
      INFO [01-31|20:39:14] Authentication is disabled               logger=grafana-apiserver
      INFO [01-31|20:39:14] Adding GroupVersion playlist.grafana.app v0alpha1 to ResourceManager logger=grafana-apiserver
      INFO [01-31|20:39:15] Update check succeeded                   logger=grafana.update.checker duration=159.940755ms
      INFO [01-31|20:39:15] Update check succeeded                   logger=plugins.update.checker duration=245.34633ms
      INFO [01-31|20:39:16] State cache has been initialized         logger=ngalert.state.manager states=0 duration=1.244056524s
      INFO [01-31|20:39:16] Starting scheduler                       logger=ngalert.scheduler tickInterval=10s
      INFO [01-31|20:39:16] starting                                 logger=ticker first_tick=2024-01-31T20:39:20Z
      ERROR[01-31|20:39:29] Request error                            logger=context userId=0 orgId=1 uname= error="Context.HTML - Error rendering template: index. You may need to build frontend assets \n template: index:19:34: executing \"index\" at <.ContentDeliveryURL>: can't evaluate field ContentDeliveryURL in type *dtos.IndexViewData" stack="github.com/grafana/grafana/pkg/web/context.go:112 (0x61c0106)\ngithub.com/grafana/grafana/pkg/api/index.go:231 (0x88ae1cb)\ngithub.com/grafana/grafana/pkg/api/response/web_hack.go:40 (0x61ce5ef)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:131 (0x61c106e)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/services/contexthandler/contexthandler.go:144 (0x88d01c9)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/render.go:44 (0x61c1bfd)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/csrf/csrf.go:66 (0x7ef039a)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/recovery.go:180 (0x88aa63d)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/loggermw/logger.go:72 (0x7ef13b6)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/request_metrics.go:83 (0x67b9975)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/request_tracing.go:88 (0x88ab315)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/requestmeta/request_metadata.go:66 (0x88cf275)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/context.go:52 (0x61bfb56)\ngithub.com/grafana/grafana/pkg/web/router.go:155 (0x61c32cd)\ngithub.com/grafana/grafana/pkg/web/router.go:211 (0x61c3e34)\ngithub.com/grafana/grafana/pkg/web/macaron.go:163 (0x61c153c)\nnet/http/server.go:2938 (0x540a40d)\nnet/http/server.go:2009 (0x54062f3)\nruntime/asm_amd64.s:1650 (0x50cdfc0)\n"
      INFO [01-31|20:40:30] Usage stats are ready to report          logger=infra.usagestats
      Hast Du eine Idee was das Problem sein könnte? Vielen Dank im Voraus!!!
      • DJMarc75
        DJMarc75 @RkcCorian last edited by
        @rkccorian Was ist denn DAS für ein Screenshot ????
        Was soll man daraus lesen / interpretieren ?
        Hammer 😰
        Text bitte immer hier in Codetags posten 😉
          RkcCorian @DJMarc75 last edited by
          @djmarc75 Stimmt 🙈 Bin glaub zu müde, sorry! Hab den Post angepasst
          • DJMarc75
            DJMarc75 @RkcCorian last edited by DJMarc75
            @rkccorian sagte in Hintergrund von Grafana Dashboard in VIS entfernen:
            jo, so ists besser lesbar 😉
              RkcCorian @DJMarc75 last edited by RkcCorian
              @djmarc75 So... jetzt auch mit der eigentlichen Fehlermeldung am Schluss. Vielen Dank im Voraus!!!
                RkcCorian @RkcCorian last edited by
                @rkccorian Konnte das Problem inzw. lösen, daher keine weitere Hilfe notwendig. Viele Grüße!!
                • DJMarc75
                  Da dies ein Forum für Hilfesuchende ist wäre es gut wenn Du Deine Lösung hier posten würdest um anderen zu helfen 😉
                    @djmarc75 Anbei die originale index.html und meine mit minimalen Änderungen, ich verwende das dark Schema, das muss bei anderem ggf. angepasst werden...
                    indexOriginal_v10.3.1.html index.html
                      moridin last edited by
                      @rkccorian
                      sorry ich muss das Thema nochmal aufnehmen.
                      Ich habe Grafana 11.1.0 installiert. Es läuft auf einem NUC mit PROXMOX und dem aktuellen ioBroker.
                      Leider bekomme ich es nicht hin, den Hintergrund auf transparent zu stellen. Das Hauptproblem ist:
                      Wenn ich die Index.html öffne ist diese leer.
                      Was mache ich hier falsch?
                      Sowohl die Index.html als auch die mygrafana.css ist leer.
                      Ro75 1 Reply Last reply Reply Quote 0
                      • Ro75
                        Ro75 @moridin last edited by
                        @moridin Grafana 11 bei mir transparent. Alles ohne Container, etc.
                        Die IP Adresse muss entsprechend deinem System angepasst werden.
                        index.html
                        Pfad: usr\share\grafana\public\views\index.html
                        vor </head> folgendes hinzufügen
                        <link rel="stylesheet" href="http://192.168.10.99:8082/vis.0/mygrafana.css" type="text/css">
                        mygrafana.css
                        Upload in Ordner "http://192.168.10.99:8082/vis.0"
                        @charset "UTF-8";
                        :root {
                           color-scheme: none !important;
                        body {
                           background: transparent !important;
                        Ro75.
                          moridin @Ro75 last edited by
                          @ro75
                          Danke schon mal für die Hilfe!
                          Ich konnte jetzt die index.html starten und anpassen!
                          (Warum das gestern nicht geklappt hat kann ich nicht sagen. Es waren die gleichen Befehlen.)
                          Zwei Fragen:
                          A)
                          vis.0 = vis.0 ?
                          Ich möchte das ganze in Lovelace (Home Assistent) verwenden.
                          Muss ich dann hier die mygrafana.css wo anders ablegen?
                          B)
                          Wie kann ich die Datei dort hochladen?
                          Ich kann mit
                          nano mygrafana.css
                          eine Datei erstellen. Aber halt unter dem Pfad wo ich mich aktuell befinde. Dies ist dann nicht unter http://xxx...
                          Ich lerne hier jeden Tag was neues 🙂
                          Danke für die Hilfe!
                          • Ro75
                            @moridin wenn du keine VIS einsetzt, dann musst du diese Datei an eine andere Stelle (auf deinem System) ablegen und den Pfad in der index.html anpassen.
                            Ro75.
                              @ro75
                              Tja jetzt muss man nur wissen wo!
                              Wie kann ich überhaupt eine Datei auf die Adresse laden?
                                DA_HOOD last edited by
                                Funktioniert es denn nun mit der 11er Version den Hintergrund transparent zu machen? Für die aktuelle 12er Version gibt es ja scheinbar keine Lösung oder? Ich nutze immer noch 9.2. und hätte gerne mal eine aktuellere Version - brauche aber zwingend den Hintergrund transparent bei den iframe.
                                Würde mich freuen wenn da jemand weiterhelfen kann, oder falls es mit der aktuellsten Version nicht mehr möglich ist, dann vielleicht die letzte Version zu nennen mit der es noch möglich ist 🙂
                                vis
                                33
                                148
                                30998
