    3. Einsteigerfragen
    4. Zigbee Adapter nach Stromausfall keine Verbindung (gelöst)
    • Asgothian
      Asgothian Developer @stefu87_CH last edited by
      @stefu87_ch ich würde einen neuen bestellen.
      A.
        stefu87_CH last edited by stefu87_CH
        @asgothian Ok werde einen neuen bestellen und nochmals neu aufsetzen
          stefu87_CH @Asgothian last edited by
          @asgothian Ich dreh jetzt denn komplett durch. Auch mit einem neuen Stick bringe ich die Verbindung nicht mehr zum laufen.
          2024-07-02 19:01:57.065 - info: zigbee.0 (3418) Got terminate signal TERMINATE_YOURSELF
          2024-07-02 19:01:57.066 - info: zigbee.0 (3418) cleaned everything up...
          2024-07-02 19:01:57.066 - info: zigbee.0 (3418) Zigbee: disabling joining new devices.
          2024-07-02 19:01:57.072 - warn: zigbee.0 (3418) Failed to stop zigbee during startup
          2024-07-02 19:01:57.072 - info: zigbee.0 (3418) terminating
          2024-07-02 19:01:57.072 - info: zigbee.0 (3418) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-07-02 19:01:57.189 - info: host.Iobroker stopInstance system.adapter.zigbee.0 send kill signal
          2024-07-02 19:01:57.566 - info: zigbee.0 (3418) terminating
          2024-07-02 19:01:57.630 - info: host.Iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-07-02 19:02:00.240 - info: host.Iobroker instance system.adapter.zigbee.0 started with pid 3669
          2024-07-02 19:02:01.549 - info: zigbee.0 (3669) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.0, js-controller: 5.0.19
          2024-07-02 19:02:01.573 - info: zigbee.0 (3669) delete old Backup files. keep only last 10
          2024-07-02 19:02:01.574 - info: zigbee.0 (3669) Starting Zigbee npm ...
          2024-07-02 19:02:01.723 - info: zigbee.0 (3669) Installed Version: iobroker.zigbee@1.10.3
          2024-07-02 19:02:18.283 - info: admin.0 (441) ==> Connected system.user.admin from ::ffff:192.168.0.20
          2024-07-02 19:02:18.380 - error: zigbee.0 (3669) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
          2024-07-02 19:02:18.465 - info: zigbee.0 (3669) List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
          2024-07-02 19:02:21.805 - error: zigbee.0 (3669) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          2024-07-02 19:02:21.805 - error: zigbee.0 (3669) Failed to start Zigbee
          2024-07-02 19:02:21.806 - error: zigbee.0 (3669) Error herdsman start
          2024-07-02 19:02:31.807 - info: zigbee.0 (3669) Try to reconnect. 1 attempts left
          2024-07-02 19:02:31.807 - info: zigbee.0 (3669) Starting Zigbee npm ...
          2024-07-02 19:02:31.810 - info: zigbee.0 (3669) Installed Version: iobroker.zigbee@1.10.3
          2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
          2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Failed to start Zigbee
          2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Error herdsman start
          2024-07-02 19:02:44.154 - info: admin.0 (441) <== Disconnect system.user.admin from ::ffff:192.168.0.20
          Thomas Braun Asgothian 3 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @stefu87_CH last edited by
            @stefu87_ch
            Schau nach was da zugreift. Beispiel aus meiner Kiste:
            echad@chet:~ $ sudo fuser -n file /dev/ttyUSB0
            /dev/ttyUSB0:        701687
            echad@chet:~ $ ps aux | grep 701687
            iobroker  701687  4.6  2.0 11465680 162436 ?     Sl   19:27   0:10 io.zigbee.0
            echad     702214  0.0  0.0   6448  1920 pts/2    S+   19:31   0:00 grep --color=auto 701687
            /dev/ttyXYZ halt auf dein System anpassen.
              @stefu87_ch
              Alternativ:
              echad@chet:~ $ sudo lsof /dev/ttyUSB0
              COMMAND      PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
              io.zigbee 701687 iobroker   27uW  CHR  188,0      0t0  486 /dev/ttyUSB0
              echad@chet:~ $
                stefu87_CH @Thomas Braun last edited by stefu87_CH
                @thomas-braun sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                @stefu87_ch
                Also ich erhalte diese Sachen bei den folgenden Befehlen:
                admin@Iobroker:~$ sudo fuser -n file /dev/ttyACM0
                admin@Iobroker:~$  /dev/ttyACM0
                -bash: /dev/ttyACM0: Permission denied
                admin@Iobroker:~$ ps aux
                USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
                root           1  0.0  0.1 165668 10624 ?        Ss   19:06   0:00 /sbin/init
                root          43  0.0  0.3  72760 23232 ?        Ss   19:06   0:00 /lib/systemd/systemd-journald
                systemd+      86  0.0  0.1  16128  8064 ?        Ss   19:06   0:00 /lib/systemd/systemd-networkd
                _rpc          99  0.0  0.0   8104  3840 ?        Ss   19:06   0:00 /sbin/rpcbind -f -w
                systemd+     102  0.0  0.2  25540 13144 ?        Ss   19:06   0:00 /lib/systemd/systemd-resolved
                root         103  0.0  0.0   3888  2432 ?        Ss   19:06   0:00 /usr/sbin/cron -f -P
                message+     104  0.0  0.0   8448  4352 ?        Ss   19:06   0:00 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-o
                root         107  0.0  0.3  30096 18816 ?        Ss   19:06   0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
                syslog       108  0.0  0.0 152768  4864 ?        Ssl  19:06   0:00 /usr/sbin/rsyslogd -n -iNONE
                root         109  0.0  0.1  14912  6912 ?        Ss   19:06   0:00 /lib/systemd/systemd-logind
                iobroker     115  0.0  9.4 12214272 590972 ?     Ssl  19:06   4:37 iobroker.js-controller
                root         118  0.0  0.0   2820  1792 pts/0    Ss+  19:06   0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud console 115200,38400,9600 linux
                root         120  0.0  0.0   2820  1920 pts/2    Ss+  19:06   0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud tty2 115200,38400,9600 linux
                root         285  0.0  0.0  41232  4544 ?        Ss   19:06   0:00 /usr/lib/postfix/sbin/master -w
                postfix      286  0.0  0.1  41556  6784 ?        S    19:06   0:00 pickup -l -t unix -u -c
                postfix      287  0.0  0.1  41600  6912 ?        S    19:06   0:00 qmgr -l -t unix -u
                iobroker     309  0.0  2.9 11894272 187224 ?     Sl   19:06   0:21 io.admin.0
                iobroker     336  0.0  1.1 11525724 72380 ?      Sl   19:06   0:01 io.email.0
                iobroker     351  0.0  1.2 11530596 79128 ?      Sl   19:06   0:03 io.history.0
                iobroker     392  0.0  2.0 11644788 127052 ?     Sl   19:06   0:48 io.influxdb.1
                iobroker     407  0.0  5.6 11985608 351776 ?     Sl   19:06   1:09 io.javascript.0
                iobroker     422  0.0  1.1 11526560 71960 ?      Sl   19:06   0:01 io.scenes.0
                iobroker     437  0.0  1.2 11791676 77500 ?      Sl   19:06   0:03 io.sql.0
                iobroker     452  0.0  1.5 11737892 95340 ?      Sl   19:06   0:03 io.telegram.0
                iobroker     467  0.0  1.2 11528972 75708 ?      Sl   19:06   0:01 io.whatsapp-cmb.0
                iobroker     482  0.0  1.2 11528456 75300 ?      Sl   19:06   0:01 io.whatsapp-cmb.1
                iobroker     497  0.0  1.4 22089100 91152 ?      Sl   19:07   0:01 io.backitup.0
                iobroker     512  0.0  1.3 11804348 84700 ?      Sl   19:07   0:05 io.alexa2.0
                iobroker     527  0.0  1.2 11725900 76852 ?      Sl   19:07   0:01 io.cloud.0
                iobroker     542  0.0  1.3 11539488 83848 ?      Sl   19:07   0:16 io.device-watcher.0
                iobroker     632  0.0  1.6 11822796 100200 ?     Sl   19:07   0:03 io.mihome-vacuum.0
                iobroker     662  0.0  1.1 11526404 72744 ?      Sl   19:07   0:01 io.nut.0
                iobroker     677  0.0  1.2 11532652 79816 ?      Sl   19:07   0:10 io.ping.0
                iobroker     770  0.0  1.1 11656424 72892 ?      Sl   19:07   0:01 io.proxmox.0
                iobroker     785  0.0  2.1 11577712 132788 ?     Sl   19:07   1:16 io.shelly.0
                iobroker     800  0.0  1.6 11548452 104084 ?     Sl   19:08   0:17 io.shelly.1
                iobroker     815  0.0  1.1 11527420 74084 ?      Sl   19:08   0:01 io.snmp.0
                iobroker     830  0.0  1.5 11611524 93996 ?      Sl   19:08   0:04 io.spotify-premium.0
                iobroker     845  0.0  1.5 11804652 98924 ?      Sl   19:08   0:17 io.unifi.0
                iobroker     968  0.0  1.1 11523916 69900 ?      Sl   19:08   0:01 io.alexa-timer-vis.0
                iobroker    1013  0.0  1.3 11796564 84704 ?      Sl   19:08   0:02 io.bring.0
                iobroker    1028  0.0  1.4 11805400 92192 ?      Sl   19:08   0:10 io.nuki-extended.0
                iobroker    1039  0.0  1.1 11526652 73480 ?      Sl   19:08   0:02 io.countdown.0
                iobroker    1166  0.0  1.3 11531640 82212 ?      Sl   19:08   0:03 io.eventlist.0
                iobroker    1181  0.0  1.5 11613940 96352 ?      Sl   19:08   0:02 io.iot.0
                iobroker    1196  0.0  1.1 11523836 70072 ?      Sl   19:09   0:01 io.mytime.0
                iobroker    1211  0.0  1.3 11535016 82468 ?      Sl   19:09   0:02 io.octoprint.0
                iobroker    1226  0.0  1.2 11727092 77544 ?      Sl   19:09   0:01 io.parser.0
                iobroker    1241  0.0  1.1 11525704 72988 ?      Sl   19:09   0:02 io.sainlogic.0
                iobroker    1334  0.0  1.1 11527012 73440 ?      Sl   19:09   0:01 io.socketio.0
                iobroker    1349  0.0  1.0 11522884 67928 ?      Sl   19:09   0:01 io.telegram-menu.0
                iobroker    1364  0.0  1.1 11526072 72224 ?      Sl   19:09   0:01 io.trashschedule.0
                iobroker    1379  0.0  1.5 11608256 94576 ?      Sl   19:09   0:01 io.vis-2.0
                iobroker    1394  0.0  1.0 11522180 68576 ?      Sl   19:09   0:01 io.vis-inventwo.0
                iobroker    1424  0.0  1.4 11801828 87656 ?      Sl   19:09   0:03 io.vw-connect.0
                iobroker    1439  0.0  1.5 11707296 99452 ?      Sl   19:09   0:03 io.web.0
                root        6993  0.0  0.0   7812  5112 pts/1    Ss   19:42   0:00 /bin/login -p --
                admin       7011  0.0  0.0   5648  4736 pts/1    S    19:42   0:00 -bash
                iobroker    8051  0.0  2.1 11839864 132816 ?     Sl   19:48   0:02 io.zigbee.0
                admin       8228  0.0  0.0   7064  2944 pts/1    R+   19:49   0:00 ps aux
                  Und
                  @stefu87_ch
                  Alternativ:
                  echad@chet:~ $
                  Und mit diesem Befehl:
                  admin@Iobroker:~$ sudo lsof /dev/ttyACM0
                  systemd      1            root    0u   CHR    1,3      0t0    5 /dev/null
                  systemd      1            root    1u   CHR    1,3      0t0    5 /dev/null
                  systemd      1            root    2u   CHR    1,3      0t0    5 /dev/null
                  systemd-j   43            root    0r   CHR    1,3      0t0    5 /dev/null
                  systemd-j   43            root    1w   CHR    1,3      0t0    5 /dev/null
                  systemd-j   43            root    2w   CHR    1,3      0t0    5 /dev/null
                  systemd-n   86 systemd-network    0r   CHR    1,3      0t0    5 /dev/null
                  rpcbind     99            _rpc    0r   CHR    1,3      0t0    5 /dev/null
                  systemd-r  102 systemd-resolve    0r   CHR    1,3      0t0    5 /dev/null
                  cron       103            root    0r   CHR    1,3      0t0    5 /dev/null
                  dbus-daem  104      messagebus    0u   CHR    1,3      0t0    5 /dev/null
                  networkd-  107            root    0r   CHR    1,3      0t0    5 /dev/null
                  rsyslogd   108          syslog    0r   CHR    1,3      0t0    5 /dev/null
                  rsyslogd   108          syslog    1w   CHR    1,3      0t0    5 /dev/null
                  rsyslogd   108          syslog    2w   CHR    1,3      0t0    5 /dev/null
                  rsyslogd   108          syslog    4r   CHR    1,9      0t0   10 /dev/urandom
                  systemd-l  109            root    0r   CHR    1,3      0t0    5 /dev/null
                  iobroker.  115        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  iobroker.  115        iobroker   17r   CHR    1,3      0t0    5 /dev/null
                  master     285            root    0u   CHR    1,3      0t0    5 /dev/null
                  master     285            root    1u   CHR    1,3      0t0    5 /dev/null
                  master     285            root    2u   CHR    1,3      0t0    5 /dev/null
                  master     285            root    4u   CHR    1,3      0t0    5 /dev/null
                  master     285            root    6u   CHR    1,3      0t0    5 /dev/null
                  master     285            root    7u   CHR    1,3      0t0    5 /dev/null
                  master     285            root    8u   CHR    1,3      0t0    5 /dev/null
                  master     285            root    9u   CHR    1,3      0t0    5 /dev/null
                  pickup     286         postfix    0u   CHR    1,3      0t0    5 /dev/null
                  pickup     286         postfix    1u   CHR    1,3      0t0    5 /dev/null
                  pickup     286         postfix    2u   CHR    1,3      0t0    5 /dev/null
                  qmgr       287         postfix    0u   CHR    1,3      0t0    5 /dev/null
                  qmgr       287         postfix    1u   CHR    1,3      0t0    5 /dev/null
                  qmgr       287         postfix    2u   CHR    1,3      0t0    5 /dev/null
                  io.admin.  309        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.admin.  309        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.admin.  309        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.email.  336        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.email.  336        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.email.  336        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.histor  351        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.histor  351        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.histor  351        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.influx  392        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.influx  392        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.influx  392        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.javasc  407        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.javasc  407        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.javasc  407        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.scenes  422        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.scenes  422        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.scenes  422        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.sql.0   437        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.sql.0   437        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.sql.0   437        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.telegr  452        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.telegr  452        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.telegr  452        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.whatsa  467        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.whatsa  467        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.whatsa  467        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.whatsa  482        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.whatsa  482        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.whatsa  482        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.backit  497        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.backit  497        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.backit  497        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.alexa2  512        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.alexa2  512        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.alexa2  512        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.cloud.  527        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.cloud.  527        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.cloud.  527        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.device  542        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.device  542        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.device  542        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.mihome  632        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.mihome  632        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.mihome  632        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.nut.0   662        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.nut.0   662        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.nut.0   662        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.ping.0  677        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.ping.0  677        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.ping.0  677        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.proxmo  770        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.proxmo  770        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.proxmo  770        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.shelly  785        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.shelly  785        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.shelly  785        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.shelly  800        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.shelly  800        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.shelly  800        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.snmp.0  815        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.snmp.0  815        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.snmp.0  815        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.spotif  830        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.spotif  830        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.spotif  830        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.unifi.  845        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.unifi.  845        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.unifi.  845        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.alexa-  968        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.alexa-  968        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.alexa-  968        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.bring. 1013        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.bring. 1013        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.bring. 1013        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.nuki-e 1028        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.nuki-e 1028        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.nuki-e 1028        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.countd 1039        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.countd 1039        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.countd 1039        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.eventl 1166        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.eventl 1166        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.eventl 1166        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.iot.0  1181        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.iot.0  1181        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.iot.0  1181        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.mytime 1196        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.mytime 1196        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.mytime 1196        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.octopr 1211        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.octopr 1211        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.octopr 1211        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.parser 1226        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.parser 1226        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.parser 1226        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.sainlo 1241        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.sainlo 1241        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.sainlo 1241        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.socket 1334        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.socket 1334        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.socket 1334        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.telegr 1349        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.telegr 1349        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.telegr 1349        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.trashs 1364        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.trashs 1364        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.trashs 1364        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.vis-2. 1379        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.vis-2. 1379        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.vis-2. 1379        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.vis-in 1394        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.vis-in 1394        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.vis-in 1394        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.vw-con 1424        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.vw-con 1424        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.vw-con 1424        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.web.0  1439        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.web.0  1439        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.web.0  1439        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.zigbee 8051        iobroker    0r   CHR    1,3      0t0    5 /dev/null
                  io.zigbee 8051        iobroker    1u   CHR    1,3      0t0    5 /dev/null
                  io.zigbee 8051        iobroker   18r   CHR    1,3      0t0    5 /dev/null
                  io.zigbee 8051        iobroker   28uW  CHR  166,0      0t0 1013 /dev/ttyACM0
                  sudo      7528            root    8u   CHR    5,0      0t0   12 /dev/tty
                  sudo      7529            root    8u   CHR    5,0      0t0   12 /dev/tty
                    @stefu87_ch
                    Seltsame Ausgaben...
                    sudo lsof /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
                    sagt?
                      @stefu87_ch
                      sagt?
                      admin@Iobroker:~$ sudo lsof /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
                      lsof: status error on /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00: No such file or directory
                      lsof 4.93.2
                       latest revision: https://github.com/lsof-org/lsof
                       latest FAQ: https://github.com/lsof-org/lsof/blob/master/00FAQ
                       latest (non-formatted) man page: https://github.com/lsof-org/lsof/blob/master/Lsof.8
                       usage: [-?abhKlnNoOPRtUvVX] [+|-c c] [+|-d s] [+D D] [+|-E] [+|-e s] [+|-f[gG]]
                       [-F [f]] [-g [s]] [-i [i]] [+|-L [l]] [+m [m]] [+|-M] [-o [o]] [-p s]
                       [+|-r [t]] [-s [p:s]] [-S [t]] [-T [t]] [-u s] [+|-w] [-x [fl]] [--] [names]
                      Use the ``-h'' option to get more help information.
                        @stefu87_ch
                        Achso, neuer Stick...
                        Der hat auch eine neue ID.
                        Schau die halt nach.
                          @stefu87_ch
                          Das war ein LXC da, oder?
                          Dann bin ich auch wieder raus, kann sein das die Dinger an der Stelle anders als ein natives System reagieren.
                            @stefu87_ch
                            Ja ist ein LXC.
                            Er zeigt im Log auch immer wieder eine andere Pan ID an.
                            • Asgothian
                              @stefu87_ch sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                              Beschreib doch noch mal bitte den gesamten Aufbau. Ich weiss ich kann mir das hier auch irgendwo heraus suchen, aber es ist einfacher wenn du die betroffenen Komponenten beschreibst. Die Meldung
                              deutet darauf hin das die Emulation des seriellen Ports prinzipiell klappt, aber keine Kommunikation mit der Firmware möglich ist. Das kann auch mit dem verwendeten USB Port / USB Verlängerungskabel zu tun haben. Auch hier solltest du ggf. einmal wechseln, bzw. den Stick (sofern du hast) mit einem RPI ausprobieren, bei dem du vorher WLAN und Bluetooth per boot Optionen deaktiviert hast.
                              A.
                                @asgothian Also habe einen komplett neuen Sonoff Zigbee Stick gekauft. Der steckt direkt am USB Port meines Proxmox Server. Der Proxmox Server läuft auf einem GIGABYTE mit diesen Informationen:
                                Ein RPI habe ich leider keins zur Verfügung.
                                Ich habe nur 3 USB Anschlüsse zur Verfügung. 2 davon sind USB 2.0 und 1 x USB 3.0
                                Homoran crunchip 2 Replies Last reply Reply Quote 0
                                  Homoran Global Moderator Administrators @stefu87_CH last edited by
                                  und wo läuft in dem Konstrukt iobroker?
                                    stefu87_CH @Homoran last edited by
                                    @homoran iobroker läuft in einem Ubuntu Container
                                      und dem sind alle USB Ports bekannt?
                                        crunchip Forum Testing Most Active @stefu87_CH last edited by
                                        hast du beide mal probiert?
                                        2te Frage, hast du nun den Stick nach der herkömmlichen Anleitung eingebunden oder nach der neuen Variante, die seit kurzen möglich ist?
                                          @homoran sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                                          Wird jedenfalls mit dem Befehl
                                          admin@Iobroker:~$ lsusb
                                          Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                          Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                          Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                          Bus 001 Device 004: ID 8087:0aa7 Intel Corp. Wireless-AC 3168 Bluetooth
                                          Bus 001 Device 010: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongle Plus V2
                                          Bus 001 Device 008: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
                                          Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                          erkannt.
                                            stefu87_CH @crunchip last edited by
                                            @crunchip sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                                            Bis jetzt immer mit dem gleichen Port wie mit dem alten USB Stick.
                                            Ich habe es nach der alten Variante versucht, da mit der neuen Variante ich es auch nicht geschafft habe.
                                            10835
