Zigbee Adapter nach Stromausfall keine Verbindung (gelöst)
@asgothian Ok werde einen neuen bestellen und nochmals neu aufsetzen
@asgothian Ich dreh jetzt denn komplett durch. Auch mit einem neuen Stick bringe ich die Verbindung nicht mehr zum laufen.
2024-07-02 19:01:57.065 - info: zigbee.0 (3418) Got terminate signal TERMINATE_YOURSELF 2024-07-02 19:01:57.066 - info: zigbee.0 (3418) cleaned everything up... 2024-07-02 19:01:57.066 - info: zigbee.0 (3418) Zigbee: disabling joining new devices. 2024-07-02 19:01:57.072 - warn: zigbee.0 (3418) Failed to stop zigbee during startup 2024-07-02 19:01:57.072 - info: zigbee.0 (3418) terminating 2024-07-02 19:01:57.072 - info: zigbee.0 (3418) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-07-02 19:01:57.189 - info: host.Iobroker stopInstance system.adapter.zigbee.0 send kill signal 2024-07-02 19:01:57.566 - info: zigbee.0 (3418) terminating 2024-07-02 19:01:57.630 - info: host.Iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-07-02 19:02:00.240 - info: host.Iobroker instance system.adapter.zigbee.0 started with pid 3669 2024-07-02 19:02:01.549 - info: zigbee.0 (3669) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.0, js-controller: 5.0.19 2024-07-02 19:02:01.573 - info: zigbee.0 (3669) delete old Backup files. keep only last 10 2024-07-02 19:02:01.574 - info: zigbee.0 (3669) Starting Zigbee npm ... 2024-07-02 19:02:01.723 - info: zigbee.0 (3669) Installed Version: iobroker.zigbee@1.10.3 2024-07-02 19:02:18.283 - info: admin.0 (441) ==> Connected system.user.admin from ::ffff:192.168.0.20 2024-07-02 19:02:18.380 - error: zigbee.0 (3669) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups') 2024-07-02 19:02:18.465 - info: zigbee.0 (3669) List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}] 2024-07-02 19:02:21.805 - error: zigbee.0 (3669) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)" 2024-07-02 19:02:21.805 - error: zigbee.0 (3669) Failed to start Zigbee 2024-07-02 19:02:21.806 - error: zigbee.0 (3669) Error herdsman start 2024-07-02 19:02:31.807 - info: zigbee.0 (3669) Try to reconnect. 1 attempts left 2024-07-02 19:02:31.807 - info: zigbee.0 (3669) Starting Zigbee npm ... 2024-07-02 19:02:31.810 - info: zigbee.0 (3669) Installed Version: iobroker.zigbee@1.10.3 2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port" 2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Failed to start Zigbee 2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Error herdsman start 2024-07-02 19:02:44.154 - info: admin.0 (441) <== Disconnect system.user.admin from ::ffff:192.168.0.20
Schau nach was da zugreift. Beispiel aus meiner Kiste:
echad@chet:~ $ sudo fuser -n file /dev/ttyUSB0 /dev/ttyUSB0: 701687 echad@chet:~ $ ps aux | grep 701687 iobroker 701687 4.6 2.0 11465680 162436 ? Sl 19:27 0:10 io.zigbee.0 echad 702214 0.0 0.0 6448 1920 pts/2 S+ 19:31 0:00 grep --color=auto 701687
/dev/ttyXYZ halt auf dein System anpassen.
Alternativ:
echad@chet:~ $ sudo lsof /dev/ttyUSB0 COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME io.zigbee 701687 iobroker 27uW CHR 188,0 0t0 486 /dev/ttyUSB0 echad@chet:~ $
@thomas-braun sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
Also ich erhalte diese Sachen bei den folgenden Befehlen:
admin@Iobroker:~$ sudo fuser -n file /dev/ttyACM0 admin@Iobroker:~$ /dev/ttyACM0 -bash: /dev/ttyACM0: Permission denied admin@Iobroker:~$ ps aux USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND root 1 0.0 0.1 165668 10624 ? Ss 19:06 0:00 /sbin/init root 43 0.0 0.3 72760 23232 ? Ss 19:06 0:00 /lib/systemd/systemd-journald systemd+ 86 0.0 0.1 16128 8064 ? Ss 19:06 0:00 /lib/systemd/systemd-networkd _rpc 99 0.0 0.0 8104 3840 ? Ss 19:06 0:00 /sbin/rpcbind -f -w systemd+ 102 0.0 0.2 25540 13144 ? Ss 19:06 0:00 /lib/systemd/systemd-resolved root 103 0.0 0.0 3888 2432 ? Ss 19:06 0:00 /usr/sbin/cron -f -P message+ 104 0.0 0.0 8448 4352 ? Ss 19:06 0:00 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-o root 107 0.0 0.3 30096 18816 ? Ss 19:06 0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers syslog 108 0.0 0.0 152768 4864 ? Ssl 19:06 0:00 /usr/sbin/rsyslogd -n -iNONE root 109 0.0 0.1 14912 6912 ? Ss 19:06 0:00 /lib/systemd/systemd-logind iobroker 115 0.0 9.4 12214272 590972 ? Ssl 19:06 4:37 iobroker.js-controller root 118 0.0 0.0 2820 1792 pts/0 Ss+ 19:06 0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud console 115200,38400,9600 linux root 120 0.0 0.0 2820 1920 pts/2 Ss+ 19:06 0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud tty2 115200,38400,9600 linux root 285 0.0 0.0 41232 4544 ? Ss 19:06 0:00 /usr/lib/postfix/sbin/master -w postfix 286 0.0 0.1 41556 6784 ? S 19:06 0:00 pickup -l -t unix -u -c postfix 287 0.0 0.1 41600 6912 ? S 19:06 0:00 qmgr -l -t unix -u iobroker 309 0.0 2.9 11894272 187224 ? Sl 19:06 0:21 io.admin.0 iobroker 336 0.0 1.1 11525724 72380 ? Sl 19:06 0:01 io.email.0 iobroker 351 0.0 1.2 11530596 79128 ? Sl 19:06 0:03 io.history.0 iobroker 392 0.0 2.0 11644788 127052 ? Sl 19:06 0:48 io.influxdb.1 iobroker 407 0.0 5.6 11985608 351776 ? Sl 19:06 1:09 io.javascript.0 iobroker 422 0.0 1.1 11526560 71960 ? Sl 19:06 0:01 io.scenes.0 iobroker 437 0.0 1.2 11791676 77500 ? Sl 19:06 0:03 io.sql.0 iobroker 452 0.0 1.5 11737892 95340 ? Sl 19:06 0:03 io.telegram.0 iobroker 467 0.0 1.2 11528972 75708 ? Sl 19:06 0:01 io.whatsapp-cmb.0 iobroker 482 0.0 1.2 11528456 75300 ? Sl 19:06 0:01 io.whatsapp-cmb.1 iobroker 497 0.0 1.4 22089100 91152 ? Sl 19:07 0:01 io.backitup.0 iobroker 512 0.0 1.3 11804348 84700 ? Sl 19:07 0:05 io.alexa2.0 iobroker 527 0.0 1.2 11725900 76852 ? Sl 19:07 0:01 io.cloud.0 iobroker 542 0.0 1.3 11539488 83848 ? Sl 19:07 0:16 io.device-watcher.0 iobroker 632 0.0 1.6 11822796 100200 ? Sl 19:07 0:03 io.mihome-vacuum.0 iobroker 662 0.0 1.1 11526404 72744 ? Sl 19:07 0:01 io.nut.0 iobroker 677 0.0 1.2 11532652 79816 ? Sl 19:07 0:10 io.ping.0 iobroker 770 0.0 1.1 11656424 72892 ? Sl 19:07 0:01 io.proxmox.0 iobroker 785 0.0 2.1 11577712 132788 ? Sl 19:07 1:16 io.shelly.0 iobroker 800 0.0 1.6 11548452 104084 ? Sl 19:08 0:17 io.shelly.1 iobroker 815 0.0 1.1 11527420 74084 ? Sl 19:08 0:01 io.snmp.0 iobroker 830 0.0 1.5 11611524 93996 ? Sl 19:08 0:04 io.spotify-premium.0 iobroker 845 0.0 1.5 11804652 98924 ? Sl 19:08 0:17 io.unifi.0 iobroker 968 0.0 1.1 11523916 69900 ? Sl 19:08 0:01 io.alexa-timer-vis.0 iobroker 1013 0.0 1.3 11796564 84704 ? Sl 19:08 0:02 io.bring.0 iobroker 1028 0.0 1.4 11805400 92192 ? Sl 19:08 0:10 io.nuki-extended.0 iobroker 1039 0.0 1.1 11526652 73480 ? Sl 19:08 0:02 io.countdown.0 iobroker 1166 0.0 1.3 11531640 82212 ? Sl 19:08 0:03 io.eventlist.0 iobroker 1181 0.0 1.5 11613940 96352 ? Sl 19:08 0:02 io.iot.0 iobroker 1196 0.0 1.1 11523836 70072 ? Sl 19:09 0:01 io.mytime.0 iobroker 1211 0.0 1.3 11535016 82468 ? Sl 19:09 0:02 io.octoprint.0 iobroker 1226 0.0 1.2 11727092 77544 ? Sl 19:09 0:01 io.parser.0 iobroker 1241 0.0 1.1 11525704 72988 ? Sl 19:09 0:02 io.sainlogic.0 iobroker 1334 0.0 1.1 11527012 73440 ? Sl 19:09 0:01 io.socketio.0 iobroker 1349 0.0 1.0 11522884 67928 ? Sl 19:09 0:01 io.telegram-menu.0 iobroker 1364 0.0 1.1 11526072 72224 ? Sl 19:09 0:01 io.trashschedule.0 iobroker 1379 0.0 1.5 11608256 94576 ? Sl 19:09 0:01 io.vis-2.0 iobroker 1394 0.0 1.0 11522180 68576 ? Sl 19:09 0:01 io.vis-inventwo.0 iobroker 1424 0.0 1.4 11801828 87656 ? Sl 19:09 0:03 io.vw-connect.0 iobroker 1439 0.0 1.5 11707296 99452 ? Sl 19:09 0:03 io.web.0 root 6993 0.0 0.0 7812 5112 pts/1 Ss 19:42 0:00 /bin/login -p -- admin 7011 0.0 0.0 5648 4736 pts/1 S 19:42 0:00 -bash iobroker 8051 0.0 2.1 11839864 132816 ? Sl 19:48 0:02 io.zigbee.0 admin 8228 0.0 0.0 7064 2944 pts/1 R+ 19:49 0:00 ps aux
Und
Alternativ:
Und mit diesem Befehl:
admin@Iobroker:~$ sudo lsof /dev/ttyACM0 COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME systemd 1 root 0u CHR 1,3 0t0 5 /dev/null systemd 1 root 1u CHR 1,3 0t0 5 /dev/null systemd 1 root 2u CHR 1,3 0t0 5 /dev/null systemd-j 43 root 0r CHR 1,3 0t0 5 /dev/null systemd-j 43 root 1w CHR 1,3 0t0 5 /dev/null systemd-j 43 root 2w CHR 1,3 0t0 5 /dev/null systemd-n 86 systemd-network 0r CHR 1,3 0t0 5 /dev/null rpcbind 99 _rpc 0r CHR 1,3 0t0 5 /dev/null systemd-r 102 systemd-resolve 0r CHR 1,3 0t0 5 /dev/null cron 103 root 0r CHR 1,3 0t0 5 /dev/null dbus-daem 104 messagebus 0u CHR 1,3 0t0 5 /dev/null networkd- 107 root 0r CHR 1,3 0t0 5 /dev/null rsyslogd 108 syslog 0r CHR 1,3 0t0 5 /dev/null rsyslogd 108 syslog 1w CHR 1,3 0t0 5 /dev/null rsyslogd 108 syslog 2w CHR 1,3 0t0 5 /dev/null rsyslogd 108 syslog 4r CHR 1,9 0t0 10 /dev/urandom systemd-l 109 root 0r CHR 1,3 0t0 5 /dev/null iobroker. 115 iobroker 0r CHR 1,3 0t0 5 /dev/null iobroker. 115 iobroker 17r CHR 1,3 0t0 5 /dev/null master 285 root 0u CHR 1,3 0t0 5 /dev/null master 285 root 1u CHR 1,3 0t0 5 /dev/null master 285 root 2u CHR 1,3 0t0 5 /dev/null master 285 root 4u CHR 1,3 0t0 5 /dev/null master 285 root 6u CHR 1,3 0t0 5 /dev/null master 285 root 7u CHR 1,3 0t0 5 /dev/null master 285 root 8u CHR 1,3 0t0 5 /dev/null master 285 root 9u CHR 1,3 0t0 5 /dev/null pickup 286 postfix 0u CHR 1,3 0t0 5 /dev/null pickup 286 postfix 1u CHR 1,3 0t0 5 /dev/null pickup 286 postfix 2u CHR 1,3 0t0 5 /dev/null qmgr 287 postfix 0u CHR 1,3 0t0 5 /dev/null qmgr 287 postfix 1u CHR 1,3 0t0 5 /dev/null qmgr 287 postfix 2u CHR 1,3 0t0 5 /dev/null io.admin. 309 iobroker 0r CHR 1,3 0t0 5 /dev/null io.admin. 309 iobroker 1u CHR 1,3 0t0 5 /dev/null io.admin. 309 iobroker 18r CHR 1,3 0t0 5 /dev/null io.email. 336 iobroker 0r CHR 1,3 0t0 5 /dev/null io.email. 336 iobroker 1u CHR 1,3 0t0 5 /dev/null io.email. 336 iobroker 18r CHR 1,3 0t0 5 /dev/null io.histor 351 iobroker 0r CHR 1,3 0t0 5 /dev/null io.histor 351 iobroker 1u CHR 1,3 0t0 5 /dev/null io.histor 351 iobroker 18r CHR 1,3 0t0 5 /dev/null io.influx 392 iobroker 0r CHR 1,3 0t0 5 /dev/null io.influx 392 iobroker 1u CHR 1,3 0t0 5 /dev/null io.influx 392 iobroker 18r CHR 1,3 0t0 5 /dev/null io.javasc 407 iobroker 0r CHR 1,3 0t0 5 /dev/null io.javasc 407 iobroker 1u CHR 1,3 0t0 5 /dev/null io.javasc 407 iobroker 18r CHR 1,3 0t0 5 /dev/null io.scenes 422 iobroker 0r CHR 1,3 0t0 5 /dev/null io.scenes 422 iobroker 1u CHR 1,3 0t0 5 /dev/null io.scenes 422 iobroker 18r CHR 1,3 0t0 5 /dev/null io.sql.0 437 iobroker 0r CHR 1,3 0t0 5 /dev/null io.sql.0 437 iobroker 1u CHR 1,3 0t0 5 /dev/null io.sql.0 437 iobroker 18r CHR 1,3 0t0 5 /dev/null io.telegr 452 iobroker 0r CHR 1,3 0t0 5 /dev/null io.telegr 452 iobroker 1u CHR 1,3 0t0 5 /dev/null io.telegr 452 iobroker 18r CHR 1,3 0t0 5 /dev/null io.whatsa 467 iobroker 0r CHR 1,3 0t0 5 /dev/null io.whatsa 467 iobroker 1u CHR 1,3 0t0 5 /dev/null io.whatsa 467 iobroker 18r CHR 1,3 0t0 5 /dev/null io.whatsa 482 iobroker 0r CHR 1,3 0t0 5 /dev/null io.whatsa 482 iobroker 1u CHR 1,3 0t0 5 /dev/null io.whatsa 482 iobroker 18r CHR 1,3 0t0 5 /dev/null io.backit 497 iobroker 0r CHR 1,3 0t0 5 /dev/null io.backit 497 iobroker 1u CHR 1,3 0t0 5 /dev/null io.backit 497 iobroker 18r CHR 1,3 0t0 5 /dev/null io.alexa2 512 iobroker 0r CHR 1,3 0t0 5 /dev/null io.alexa2 512 iobroker 1u CHR 1,3 0t0 5 /dev/null io.alexa2 512 iobroker 18r CHR 1,3 0t0 5 /dev/null io.cloud. 527 iobroker 0r CHR 1,3 0t0 5 /dev/null io.cloud. 527 iobroker 1u CHR 1,3 0t0 5 /dev/null io.cloud. 527 iobroker 18r CHR 1,3 0t0 5 /dev/null io.device 542 iobroker 0r CHR 1,3 0t0 5 /dev/null io.device 542 iobroker 1u CHR 1,3 0t0 5 /dev/null io.device 542 iobroker 18r CHR 1,3 0t0 5 /dev/null io.mihome 632 iobroker 0r CHR 1,3 0t0 5 /dev/null io.mihome 632 iobroker 1u CHR 1,3 0t0 5 /dev/null io.mihome 632 iobroker 18r CHR 1,3 0t0 5 /dev/null io.nut.0 662 iobroker 0r CHR 1,3 0t0 5 /dev/null io.nut.0 662 iobroker 1u CHR 1,3 0t0 5 /dev/null io.nut.0 662 iobroker 18r CHR 1,3 0t0 5 /dev/null io.ping.0 677 iobroker 0r CHR 1,3 0t0 5 /dev/null io.ping.0 677 iobroker 1u CHR 1,3 0t0 5 /dev/null io.ping.0 677 iobroker 18r CHR 1,3 0t0 5 /dev/null io.proxmo 770 iobroker 0r CHR 1,3 0t0 5 /dev/null io.proxmo 770 iobroker 1u CHR 1,3 0t0 5 /dev/null io.proxmo 770 iobroker 18r CHR 1,3 0t0 5 /dev/null io.shelly 785 iobroker 0r CHR 1,3 0t0 5 /dev/null io.shelly 785 iobroker 1u CHR 1,3 0t0 5 /dev/null io.shelly 785 iobroker 18r CHR 1,3 0t0 5 /dev/null io.shelly 800 iobroker 0r CHR 1,3 0t0 5 /dev/null io.shelly 800 iobroker 1u CHR 1,3 0t0 5 /dev/null io.shelly 800 iobroker 18r CHR 1,3 0t0 5 /dev/null io.snmp.0 815 iobroker 0r CHR 1,3 0t0 5 /dev/null io.snmp.0 815 iobroker 1u CHR 1,3 0t0 5 /dev/null io.snmp.0 815 iobroker 18r CHR 1,3 0t0 5 /dev/null io.spotif 830 iobroker 0r CHR 1,3 0t0 5 /dev/null io.spotif 830 iobroker 1u CHR 1,3 0t0 5 /dev/null io.spotif 830 iobroker 18r CHR 1,3 0t0 5 /dev/null io.unifi. 845 iobroker 0r CHR 1,3 0t0 5 /dev/null io.unifi. 845 iobroker 1u CHR 1,3 0t0 5 /dev/null io.unifi. 845 iobroker 18r CHR 1,3 0t0 5 /dev/null io.alexa- 968 iobroker 0r CHR 1,3 0t0 5 /dev/null io.alexa- 968 iobroker 1u CHR 1,3 0t0 5 /dev/null io.alexa- 968 iobroker 18r CHR 1,3 0t0 5 /dev/null io.bring. 1013 iobroker 0r CHR 1,3 0t0 5 /dev/null io.bring. 1013 iobroker 1u CHR 1,3 0t0 5 /dev/null io.bring. 1013 iobroker 18r CHR 1,3 0t0 5 /dev/null io.nuki-e 1028 iobroker 0r CHR 1,3 0t0 5 /dev/null io.nuki-e 1028 iobroker 1u CHR 1,3 0t0 5 /dev/null io.nuki-e 1028 iobroker 18r CHR 1,3 0t0 5 /dev/null io.countd 1039 iobroker 0r CHR 1,3 0t0 5 /dev/null io.countd 1039 iobroker 1u CHR 1,3 0t0 5 /dev/null io.countd 1039 iobroker 18r CHR 1,3 0t0 5 /dev/null io.eventl 1166 iobroker 0r CHR 1,3 0t0 5 /dev/null io.eventl 1166 iobroker 1u CHR 1,3 0t0 5 /dev/null io.eventl 1166 iobroker 18r CHR 1,3 0t0 5 /dev/null io.iot.0 1181 iobroker 0r CHR 1,3 0t0 5 /dev/null io.iot.0 1181 iobroker 1u CHR 1,3 0t0 5 /dev/null io.iot.0 1181 iobroker 18r CHR 1,3 0t0 5 /dev/null io.mytime 1196 iobroker 0r CHR 1,3 0t0 5 /dev/null io.mytime 1196 iobroker 1u CHR 1,3 0t0 5 /dev/null io.mytime 1196 iobroker 18r CHR 1,3 0t0 5 /dev/null io.octopr 1211 iobroker 0r CHR 1,3 0t0 5 /dev/null io.octopr 1211 iobroker 1u CHR 1,3 0t0 5 /dev/null io.octopr 1211 iobroker 18r CHR 1,3 0t0 5 /dev/null io.parser 1226 iobroker 0r CHR 1,3 0t0 5 /dev/null io.parser 1226 iobroker 1u CHR 1,3 0t0 5 /dev/null io.parser 1226 iobroker 18r CHR 1,3 0t0 5 /dev/null io.sainlo 1241 iobroker 0r CHR 1,3 0t0 5 /dev/null io.sainlo 1241 iobroker 1u CHR 1,3 0t0 5 /dev/null io.sainlo 1241 iobroker 18r CHR 1,3 0t0 5 /dev/null io.socket 1334 iobroker 0r CHR 1,3 0t0 5 /dev/null io.socket 1334 iobroker 1u CHR 1,3 0t0 5 /dev/null io.socket 1334 iobroker 18r CHR 1,3 0t0 5 /dev/null io.telegr 1349 iobroker 0r CHR 1,3 0t0 5 /dev/null io.telegr 1349 iobroker 1u CHR 1,3 0t0 5 /dev/null io.telegr 1349 iobroker 18r CHR 1,3 0t0 5 /dev/null io.trashs 1364 iobroker 0r CHR 1,3 0t0 5 /dev/null io.trashs 1364 iobroker 1u CHR 1,3 0t0 5 /dev/null io.trashs 1364 iobroker 18r CHR 1,3 0t0 5 /dev/null io.vis-2. 1379 iobroker 0r CHR 1,3 0t0 5 /dev/null io.vis-2. 1379 iobroker 1u CHR 1,3 0t0 5 /dev/null io.vis-2. 1379 iobroker 18r CHR 1,3 0t0 5 /dev/null io.vis-in 1394 iobroker 0r CHR 1,3 0t0 5 /dev/null io.vis-in 1394 iobroker 1u CHR 1,3 0t0 5 /dev/null io.vis-in 1394 iobroker 18r CHR 1,3 0t0 5 /dev/null io.vw-con 1424 iobroker 0r CHR 1,3 0t0 5 /dev/null io.vw-con 1424 iobroker 1u CHR 1,3 0t0 5 /dev/null io.vw-con 1424 iobroker 18r CHR 1,3 0t0 5 /dev/null io.web.0 1439 iobroker 0r CHR 1,3 0t0 5 /dev/null io.web.0 1439 iobroker 1u CHR 1,3 0t0 5 /dev/null io.web.0 1439 iobroker 18r CHR 1,3 0t0 5 /dev/null io.zigbee 8051 iobroker 0r CHR 1,3 0t0 5 /dev/null io.zigbee 8051 iobroker 1u CHR 1,3 0t0 5 /dev/null io.zigbee 8051 iobroker 18r CHR 1,3 0t0 5 /dev/null io.zigbee 8051 iobroker 28uW CHR 166,0 0t0 1013 /dev/ttyACM0 sudo 7528 root 8u CHR 5,0 0t0 12 /dev/tty sudo 7529 root 8u CHR 5,0 0t0 12 /dev/tty
Seltsame Ausgaben...
sudo lsof /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
sagt?
sagt?
admin@Iobroker:~$ sudo lsof /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00 lsof: status error on /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00: No such file or directory lsof 4.93.2 latest revision: https://github.com/lsof-org/lsof latest FAQ: https://github.com/lsof-org/lsof/blob/master/00FAQ latest (non-formatted) man page: https://github.com/lsof-org/lsof/blob/master/Lsof.8 usage: [-?abhKlnNoOPRtUvVX] [+|-c c] [+|-d s] [+D D] [+|-E] [+|-e s] [+|-f[gG]] [-F [f]] [-g [s]] [-i [i]] [+|-L [l]] [+m [m]] [+|-M] [-o [o]] [-p s] [+|-r [t]] [-s [p:s]] [-S [t]] [-T [t]] [-u s] [+|-w] [-x [fl]] [--] [names] Use the ``-h'' option to get more help information.
Achso, neuer Stick...
Der hat auch eine neue ID.
Schau die halt nach. -
Das war ein LXC da, oder?
Dann bin ich auch wieder raus, kann sein das die Dinger an der Stelle anders als ein natives System reagieren. -
Dann bin ich auch wieder raus, kann sein das die Dinger an der Stelle anders als ein natives System reagieren.Ja ist ein LXC.
Er zeigt im Log auch immer wieder eine andere Pan ID an.
@stefu87_ch sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
Beschreib doch noch mal bitte den gesamten Aufbau. Ich weiss ich kann mir das hier auch irgendwo heraus suchen, aber es ist einfacher wenn du die betroffenen Komponenten beschreibst. Die Meldung
deutet darauf hin das die Emulation des seriellen Ports prinzipiell klappt, aber keine Kommunikation mit der Firmware möglich ist. Das kann auch mit dem verwendeten USB Port / USB Verlängerungskabel zu tun haben. Auch hier solltest du ggf. einmal wechseln, bzw. den Stick (sofern du hast) mit einem RPI ausprobieren, bei dem du vorher WLAN und Bluetooth per boot Optionen deaktiviert hast.
A.
@asgothian Also habe einen komplett neuen Sonoff Zigbee Stick gekauft. Der steckt direkt am USB Port meines Proxmox Server. Der Proxmox Server läuft auf einem GIGABYTE mit diesen Informationen:
Ein RPI habe ich leider keins zur Verfügung.
Ich habe nur 3 USB Anschlüsse zur Verfügung. 2 davon sind USB 2.0 und 1 x USB 3.0
und wo läuft in dem Konstrukt iobroker?
@homoran iobroker läuft in einem Ubuntu Container
und dem sind alle USB Ports bekannt?
hast du beide mal probiert?
2te Frage, hast du nun den Stick nach der herkömmlichen Anleitung eingebunden oder nach der neuen Variante, die seit kurzen möglich ist?
@homoran sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
Wird jedenfalls mit dem Befehl
admin@Iobroker:~$ lsusb Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 004: ID 8087:0aa7 Intel Corp. Wireless-AC 3168 Bluetooth Bus 001 Device 010: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongle Plus V2 Bus 001 Device 008: ID 051d:0002 American Power Conversion Uninterruptible Power Supply Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
erkannt.
@crunchip sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
Bis jetzt immer mit dem gleichen Port wie mit dem alten USB Stick.
Ich habe es nach der alten Variante versucht, da mit der neuen Variante ich es auch nicht geschafft habe.
dann steck doch mal um und passe die Eingaben entsprechend an
