    3. Einsteigerfragen
    4. Zigbee Adapter nach Stromausfall keine Verbindung (gelöst)
      stefu87_CH @Asgothian last edited by
      @asgothian Ich dreh jetzt denn komplett durch. Auch mit einem neuen Stick bringe ich die Verbindung nicht mehr zum laufen.
      2024-07-02 19:01:57.065 - info: zigbee.0 (3418) Got terminate signal TERMINATE_YOURSELF
      2024-07-02 19:01:57.066 - info: zigbee.0 (3418) cleaned everything up...
      2024-07-02 19:01:57.066 - info: zigbee.0 (3418) Zigbee: disabling joining new devices.
      2024-07-02 19:01:57.072 - warn: zigbee.0 (3418) Failed to stop zigbee during startup
      2024-07-02 19:01:57.072 - info: zigbee.0 (3418) terminating
      2024-07-02 19:01:57.072 - info: zigbee.0 (3418) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-07-02 19:01:57.189 - info: host.Iobroker stopInstance system.adapter.zigbee.0 send kill signal
      2024-07-02 19:01:57.566 - info: zigbee.0 (3418) terminating
      2024-07-02 19:01:57.630 - info: host.Iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-07-02 19:02:00.240 - info: host.Iobroker instance system.adapter.zigbee.0 started with pid 3669
      2024-07-02 19:02:01.549 - info: zigbee.0 (3669) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.0, js-controller: 5.0.19
      2024-07-02 19:02:01.573 - info: zigbee.0 (3669) delete old Backup files. keep only last 10
      2024-07-02 19:02:01.574 - info: zigbee.0 (3669) Starting Zigbee npm ...
      2024-07-02 19:02:01.723 - info: zigbee.0 (3669) Installed Version: iobroker.zigbee@1.10.3
      2024-07-02 19:02:18.283 - info: admin.0 (441) ==> Connected system.user.admin from ::ffff:192.168.0.20
      2024-07-02 19:02:18.380 - error: zigbee.0 (3669) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2024-07-02 19:02:18.465 - info: zigbee.0 (3669) List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
      2024-07-02 19:02:21.805 - error: zigbee.0 (3669) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      2024-07-02 19:02:21.805 - error: zigbee.0 (3669) Failed to start Zigbee
      2024-07-02 19:02:21.806 - error: zigbee.0 (3669) Error herdsman start
      2024-07-02 19:02:31.807 - info: zigbee.0 (3669) Try to reconnect. 1 attempts left
      2024-07-02 19:02:31.807 - info: zigbee.0 (3669) Starting Zigbee npm ...
      2024-07-02 19:02:31.810 - info: zigbee.0 (3669) Installed Version: iobroker.zigbee@1.10.3
      2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Failed to start Zigbee
      2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Error herdsman start
      2024-07-02 19:02:44.154 - info: admin.0 (441) <== Disconnect system.user.admin from ::ffff:192.168.0.20
      Thomas Braun Asgothian 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @stefu87_CH last edited by
        @stefu87_ch
        Schau nach was da zugreift. Beispiel aus meiner Kiste:
        echad@chet:~ $ sudo fuser -n file /dev/ttyUSB0
        /dev/ttyUSB0:        701687
        echad@chet:~ $ ps aux | grep 701687
        iobroker  701687  4.6  2.0 11465680 162436 ?     Sl   19:27   0:10 io.zigbee.0
        echad     702214  0.0  0.0   6448  1920 pts/2    S+   19:31   0:00 grep --color=auto 701687
        /dev/ttyXYZ halt auf dein System anpassen.
          @stefu87_ch
          Alternativ:
          echad@chet:~ $ sudo lsof /dev/ttyUSB0
          COMMAND      PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
          io.zigbee 701687 iobroker   27uW  CHR  188,0      0t0  486 /dev/ttyUSB0
          echad@chet:~ $
            stefu87_CH @Thomas Braun last edited by stefu87_CH
            @thomas-braun sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
            @stefu87_ch
            Also ich erhalte diese Sachen bei den folgenden Befehlen:
            admin@Iobroker:~$ sudo fuser -n file /dev/ttyACM0
            admin@Iobroker:~$  /dev/ttyACM0
            -bash: /dev/ttyACM0: Permission denied
            admin@Iobroker:~$ ps aux
            USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
            root           1  0.0  0.1 165668 10624 ?        Ss   19:06   0:00 /sbin/init
            root          43  0.0  0.3  72760 23232 ?        Ss   19:06   0:00 /lib/systemd/systemd-journald
            systemd+      86  0.0  0.1  16128  8064 ?        Ss   19:06   0:00 /lib/systemd/systemd-networkd
            _rpc          99  0.0  0.0   8104  3840 ?        Ss   19:06   0:00 /sbin/rpcbind -f -w
            systemd+     102  0.0  0.2  25540 13144 ?        Ss   19:06   0:00 /lib/systemd/systemd-resolved
            root         103  0.0  0.0   3888  2432 ?        Ss   19:06   0:00 /usr/sbin/cron -f -P
            message+     104  0.0  0.0   8448  4352 ?        Ss   19:06   0:00 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-o
            root         107  0.0  0.3  30096 18816 ?        Ss   19:06   0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
            syslog       108  0.0  0.0 152768  4864 ?        Ssl  19:06   0:00 /usr/sbin/rsyslogd -n -iNONE
            root         109  0.0  0.1  14912  6912 ?        Ss   19:06   0:00 /lib/systemd/systemd-logind
            iobroker     115  0.0  9.4 12214272 590972 ?     Ssl  19:06   4:37 iobroker.js-controller
            root         118  0.0  0.0   2820  1792 pts/0    Ss+  19:06   0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud console 115200,38400,9600 linux
            root         120  0.0  0.0   2820  1920 pts/2    Ss+  19:06   0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud tty2 115200,38400,9600 linux
            root         285  0.0  0.0  41232  4544 ?        Ss   19:06   0:00 /usr/lib/postfix/sbin/master -w
            postfix      286  0.0  0.1  41556  6784 ?        S    19:06   0:00 pickup -l -t unix -u -c
            postfix      287  0.0  0.1  41600  6912 ?        S    19:06   0:00 qmgr -l -t unix -u
            iobroker     309  0.0  2.9 11894272 187224 ?     Sl   19:06   0:21 io.admin.0
            iobroker     336  0.0  1.1 11525724 72380 ?      Sl   19:06   0:01 io.email.0
            iobroker     351  0.0  1.2 11530596 79128 ?      Sl   19:06   0:03 io.history.0
            iobroker     392  0.0  2.0 11644788 127052 ?     Sl   19:06   0:48 io.influxdb.1
            iobroker     407  0.0  5.6 11985608 351776 ?     Sl   19:06   1:09 io.javascript.0
            iobroker     422  0.0  1.1 11526560 71960 ?      Sl   19:06   0:01 io.scenes.0
            iobroker     437  0.0  1.2 11791676 77500 ?      Sl   19:06   0:03 io.sql.0
            iobroker     452  0.0  1.5 11737892 95340 ?      Sl   19:06   0:03 io.telegram.0
            iobroker     467  0.0  1.2 11528972 75708 ?      Sl   19:06   0:01 io.whatsapp-cmb.0
            iobroker     482  0.0  1.2 11528456 75300 ?      Sl   19:06   0:01 io.whatsapp-cmb.1
            iobroker     497  0.0  1.4 22089100 91152 ?      Sl   19:07   0:01 io.backitup.0
            iobroker     512  0.0  1.3 11804348 84700 ?      Sl   19:07   0:05 io.alexa2.0
            iobroker     527  0.0  1.2 11725900 76852 ?      Sl   19:07   0:01 io.cloud.0
            iobroker     542  0.0  1.3 11539488 83848 ?      Sl   19:07   0:16 io.device-watcher.0
            iobroker     632  0.0  1.6 11822796 100200 ?     Sl   19:07   0:03 io.mihome-vacuum.0
            iobroker     662  0.0  1.1 11526404 72744 ?      Sl   19:07   0:01 io.nut.0
            iobroker     677  0.0  1.2 11532652 79816 ?      Sl   19:07   0:10 io.ping.0
            iobroker     770  0.0  1.1 11656424 72892 ?      Sl   19:07   0:01 io.proxmox.0
            iobroker     785  0.0  2.1 11577712 132788 ?     Sl   19:07   1:16 io.shelly.0
            iobroker     800  0.0  1.6 11548452 104084 ?     Sl   19:08   0:17 io.shelly.1
            iobroker     815  0.0  1.1 11527420 74084 ?      Sl   19:08   0:01 io.snmp.0
            iobroker     830  0.0  1.5 11611524 93996 ?      Sl   19:08   0:04 io.spotify-premium.0
            iobroker     845  0.0  1.5 11804652 98924 ?      Sl   19:08   0:17 io.unifi.0
            iobroker     968  0.0  1.1 11523916 69900 ?      Sl   19:08   0:01 io.alexa-timer-vis.0
            iobroker    1013  0.0  1.3 11796564 84704 ?      Sl   19:08   0:02 io.bring.0
            iobroker    1028  0.0  1.4 11805400 92192 ?      Sl   19:08   0:10 io.nuki-extended.0
            iobroker    1039  0.0  1.1 11526652 73480 ?      Sl   19:08   0:02 io.countdown.0
            iobroker    1166  0.0  1.3 11531640 82212 ?      Sl   19:08   0:03 io.eventlist.0
            iobroker    1181  0.0  1.5 11613940 96352 ?      Sl   19:08   0:02 io.iot.0
            iobroker    1196  0.0  1.1 11523836 70072 ?      Sl   19:09   0:01 io.mytime.0
            iobroker    1211  0.0  1.3 11535016 82468 ?      Sl   19:09   0:02 io.octoprint.0
            iobroker    1226  0.0  1.2 11727092 77544 ?      Sl   19:09   0:01 io.parser.0
            iobroker    1241  0.0  1.1 11525704 72988 ?      Sl   19:09   0:02 io.sainlogic.0
            iobroker    1334  0.0  1.1 11527012 73440 ?      Sl   19:09   0:01 io.socketio.0
            iobroker    1349  0.0  1.0 11522884 67928 ?      Sl   19:09   0:01 io.telegram-menu.0
            iobroker    1364  0.0  1.1 11526072 72224 ?      Sl   19:09   0:01 io.trashschedule.0
            iobroker    1379  0.0  1.5 11608256 94576 ?      Sl   19:09   0:01 io.vis-2.0
            iobroker    1394  0.0  1.0 11522180 68576 ?      Sl   19:09   0:01 io.vis-inventwo.0
            iobroker    1424  0.0  1.4 11801828 87656 ?      Sl   19:09   0:03 io.vw-connect.0
            iobroker    1439  0.0  1.5 11707296 99452 ?      Sl   19:09   0:03 io.web.0
            root        6993  0.0  0.0   7812  5112 pts/1    Ss   19:42   0:00 /bin/login -p --
            admin       7011  0.0  0.0   5648  4736 pts/1    S    19:42   0:00 -bash
            iobroker    8051  0.0  2.1 11839864 132816 ?     Sl   19:48   0:02 io.zigbee.0
            admin       8228  0.0  0.0   7064  2944 pts/1    R+   19:49   0:00 ps aux
              Und
              @stefu87_ch
              Alternativ:
              echad@chet:~ $
              Und mit diesem Befehl:
              admin@Iobroker:~$ sudo lsof /dev/ttyACM0
              systemd      1            root    0u   CHR    1,3      0t0    5 /dev/null
              systemd      1            root    1u   CHR    1,3      0t0    5 /dev/null
              systemd      1            root    2u   CHR    1,3      0t0    5 /dev/null
              systemd-j   43            root    0r   CHR    1,3      0t0    5 /dev/null
              systemd-j   43            root    1w   CHR    1,3      0t0    5 /dev/null
              systemd-j   43            root    2w   CHR    1,3      0t0    5 /dev/null
              systemd-n   86 systemd-network    0r   CHR    1,3      0t0    5 /dev/null
              rpcbind     99            _rpc    0r   CHR    1,3      0t0    5 /dev/null
              systemd-r  102 systemd-resolve    0r   CHR    1,3      0t0    5 /dev/null
              cron       103            root    0r   CHR    1,3      0t0    5 /dev/null
              dbus-daem  104      messagebus    0u   CHR    1,3      0t0    5 /dev/null
              networkd-  107            root    0r   CHR    1,3      0t0    5 /dev/null
              rsyslogd   108          syslog    0r   CHR    1,3      0t0    5 /dev/null
              rsyslogd   108          syslog    1w   CHR    1,3      0t0    5 /dev/null
              rsyslogd   108          syslog    2w   CHR    1,3      0t0    5 /dev/null
              rsyslogd   108          syslog    4r   CHR    1,9      0t0   10 /dev/urandom
              systemd-l  109            root    0r   CHR    1,3      0t0    5 /dev/null
              iobroker.  115        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              iobroker.  115        iobroker   17r   CHR    1,3      0t0    5 /dev/null
              master     285            root    0u   CHR    1,3      0t0    5 /dev/null
              master     285            root    1u   CHR    1,3      0t0    5 /dev/null
              master     285            root    2u   CHR    1,3      0t0    5 /dev/null
              master     285            root    4u   CHR    1,3      0t0    5 /dev/null
              master     285            root    6u   CHR    1,3      0t0    5 /dev/null
              master     285            root    7u   CHR    1,3      0t0    5 /dev/null
              master     285            root    8u   CHR    1,3      0t0    5 /dev/null
              master     285            root    9u   CHR    1,3      0t0    5 /dev/null
              pickup     286         postfix    0u   CHR    1,3      0t0    5 /dev/null
              pickup     286         postfix    1u   CHR    1,3      0t0    5 /dev/null
              pickup     286         postfix    2u   CHR    1,3      0t0    5 /dev/null
              qmgr       287         postfix    0u   CHR    1,3      0t0    5 /dev/null
              qmgr       287         postfix    1u   CHR    1,3      0t0    5 /dev/null
              qmgr       287         postfix    2u   CHR    1,3      0t0    5 /dev/null
              io.admin.  309        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.admin.  309        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.admin.  309        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.email.  336        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.email.  336        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.email.  336        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.histor  351        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.histor  351        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.histor  351        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.influx  392        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.influx  392        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.influx  392        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.javasc  407        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.javasc  407        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.javasc  407        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.scenes  422        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.scenes  422        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.scenes  422        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.sql.0   437        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.sql.0   437        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.sql.0   437        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.telegr  452        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.telegr  452        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.telegr  452        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.whatsa  467        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.whatsa  467        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.whatsa  467        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.whatsa  482        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.whatsa  482        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.whatsa  482        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.backit  497        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.backit  497        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.backit  497        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.alexa2  512        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.alexa2  512        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.alexa2  512        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.cloud.  527        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.cloud.  527        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.cloud.  527        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.device  542        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.device  542        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.device  542        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.mihome  632        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.mihome  632        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.mihome  632        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.nut.0   662        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.nut.0   662        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.nut.0   662        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.ping.0  677        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.ping.0  677        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.ping.0  677        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.proxmo  770        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.proxmo  770        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.proxmo  770        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.shelly  785        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.shelly  785        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.shelly  785        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.shelly  800        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.shelly  800        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.shelly  800        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.snmp.0  815        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.snmp.0  815        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.snmp.0  815        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.spotif  830        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.spotif  830        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.spotif  830        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.unifi.  845        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.unifi.  845        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.unifi.  845        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.alexa-  968        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.alexa-  968        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.alexa-  968        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.bring. 1013        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.bring. 1013        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.bring. 1013        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.nuki-e 1028        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.nuki-e 1028        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.nuki-e 1028        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.countd 1039        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.countd 1039        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.countd 1039        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.eventl 1166        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.eventl 1166        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.eventl 1166        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.iot.0  1181        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.iot.0  1181        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.iot.0  1181        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.mytime 1196        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.mytime 1196        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.mytime 1196        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.octopr 1211        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.octopr 1211        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.octopr 1211        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.parser 1226        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.parser 1226        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.parser 1226        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.sainlo 1241        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.sainlo 1241        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.sainlo 1241        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.socket 1334        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.socket 1334        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.socket 1334        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.telegr 1349        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.telegr 1349        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.telegr 1349        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.trashs 1364        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.trashs 1364        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.trashs 1364        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.vis-2. 1379        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.vis-2. 1379        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.vis-2. 1379        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.vis-in 1394        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.vis-in 1394        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.vis-in 1394        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.vw-con 1424        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.vw-con 1424        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.vw-con 1424        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.web.0  1439        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.web.0  1439        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.web.0  1439        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.zigbee 8051        iobroker    0r   CHR    1,3      0t0    5 /dev/null
              io.zigbee 8051        iobroker    1u   CHR    1,3      0t0    5 /dev/null
              io.zigbee 8051        iobroker   18r   CHR    1,3      0t0    5 /dev/null
              io.zigbee 8051        iobroker   28uW  CHR  166,0      0t0 1013 /dev/ttyACM0
              sudo      7528            root    8u   CHR    5,0      0t0   12 /dev/tty
              sudo      7529            root    8u   CHR    5,0      0t0   12 /dev/tty
                @stefu87_ch
                Seltsame Ausgaben...
                sudo lsof /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
                sagt?
                  @stefu87_ch
                  sagt?
                  admin@Iobroker:~$ sudo lsof /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
                  lsof: status error on /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00: No such file or directory
                  lsof 4.93.2
                   latest revision: https://github.com/lsof-org/lsof
                   latest FAQ: https://github.com/lsof-org/lsof/blob/master/00FAQ
                   latest (non-formatted) man page: https://github.com/lsof-org/lsof/blob/master/Lsof.8
                   usage: [-?abhKlnNoOPRtUvVX] [+|-c c] [+|-d s] [+D D] [+|-E] [+|-e s] [+|-f[gG]]
                   [-F [f]] [-g [s]] [-i [i]] [+|-L [l]] [+m [m]] [+|-M] [-o [o]] [-p s]
                   [+|-r [t]] [-s [p:s]] [-S [t]] [-T [t]] [-u s] [+|-w] [-x [fl]] [--] [names]
                  Use the ``-h'' option to get more help information.
                    @stefu87_ch
                    Achso, neuer Stick...
                    Der hat auch eine neue ID.
                    Schau die halt nach.
                      @stefu87_ch
                      Das war ein LXC da, oder?
                      Dann bin ich auch wieder raus, kann sein das die Dinger an der Stelle anders als ein natives System reagieren.
                        @stefu87_ch
                        Ja ist ein LXC.
                        Er zeigt im Log auch immer wieder eine andere Pan ID an.
                        • Asgothian
                          Asgothian Developer @stefu87_CH last edited by
                          @stefu87_ch sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                          Beschreib doch noch mal bitte den gesamten Aufbau. Ich weiss ich kann mir das hier auch irgendwo heraus suchen, aber es ist einfacher wenn du die betroffenen Komponenten beschreibst. Die Meldung
                          deutet darauf hin das die Emulation des seriellen Ports prinzipiell klappt, aber keine Kommunikation mit der Firmware möglich ist. Das kann auch mit dem verwendeten USB Port / USB Verlängerungskabel zu tun haben. Auch hier solltest du ggf. einmal wechseln, bzw. den Stick (sofern du hast) mit einem RPI ausprobieren, bei dem du vorher WLAN und Bluetooth per boot Optionen deaktiviert hast.
                          A.
                            @asgothian Also habe einen komplett neuen Sonoff Zigbee Stick gekauft. Der steckt direkt am USB Port meines Proxmox Server. Der Proxmox Server läuft auf einem GIGABYTE mit diesen Informationen:
                            Ein RPI habe ich leider keins zur Verfügung.
                            Ich habe nur 3 USB Anschlüsse zur Verfügung. 2 davon sind USB 2.0 und 1 x USB 3.0
                            Homoran crunchip 2 Replies Last reply Reply Quote 0
                              Homoran Global Moderator Administrators @stefu87_CH last edited by
                              und wo läuft in dem Konstrukt iobroker?
                                stefu87_CH @Homoran last edited by
                                @homoran iobroker läuft in einem Ubuntu Container
                                  und dem sind alle USB Ports bekannt?
                                    crunchip Forum Testing Most Active @stefu87_CH last edited by
                                    hast du beide mal probiert?
                                    2te Frage, hast du nun den Stick nach der herkömmlichen Anleitung eingebunden oder nach der neuen Variante, die seit kurzen möglich ist?
                                      @homoran sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                                      Wird jedenfalls mit dem Befehl
                                      admin@Iobroker:~$ lsusb
                                      Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                      Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                      Bus 001 Device 004: ID 8087:0aa7 Intel Corp. Wireless-AC 3168 Bluetooth
                                      Bus 001 Device 010: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongle Plus V2
                                      Bus 001 Device 008: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
                                      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                      erkannt.
                                        stefu87_CH @crunchip last edited by
                                        @crunchip sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                                        Bis jetzt immer mit dem gleichen Port wie mit dem alten USB Stick.
                                        Ich habe es nach der alten Variante versucht, da mit der neuen Variante ich es auch nicht geschafft habe.
                                          dann steck doch mal um und passe die Eingaben entsprechend an
                                          S Homoran 2 Replies Last reply Reply Quote 0
                                            Ok werde ich morgen mal testen. Was ich noch vermute, ist das die Pan ID nie die richtige ist, aber im Log wird nach jedem neustarten eine neue ID angezeigt.
                                            10833
