    4. Test Adapter Philips-TV v0.2.x
    • teletapi
      teletapi @teletapi last edited by teletapi
      So der Adapter ist endlich grün
      Der Fehler bzw. die Lösung....
      Ein einfaches " iob upload all" brachte das in Ordnung
      Danke für eure Mühe, hätte ich eigentlich auch schon früher drauf kommen können.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       01:33:11 up 15:12,  1 user,  load average: 1.32, 0.86, 0.90
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2023-12-25 01:33:11 CET
                 Universal time: Mon 2023-12-25 00:33:11 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.8G        3.0G        1.1G        1.0M        3.7G        4.7G
      Swap:            99M          0B         99M
      Total:          7.9G        3.0G        1.2G
               7811 M total memory
               3022 M used memory
               5054 M active memory
               1437 M inactive memory
               1067 M free memory
                184 M buffer memory
               3536 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       59G   12G   45G  21% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
      [Sun Dec 24 10:20:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Dec 24 10:20:58 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Dec 24 10:20:58 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sun Dec 24 10:20:59 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.9G    /var/
      1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
      1.1G    /var/log
      629M    /var/lib
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      1.5G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      352M    /opt/iobroker/iobroker-data/
      183M    /opt/iobroker/iobroker-data/files
      76M     /opt/iobroker/iobroker-data/backup-objects
      71M     /opt/iobroker/iobroker-data/node-red/node_modules
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.9
      javascript:     7.5.1
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
      + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
      + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
      + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.13.9   , installed 6.13.9
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "ical"         : 1.13.5   , installed 1.13.5
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iopooleco"    : 0.5.1    , installed 0.5.1
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
      Adapter    "javascript"   : 7.5.1    , installed 7.5.1
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "node-red"     : 5.0.2    , installed 5.0.2
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
      Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
      Adapter    "shelly"       : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Objects and States
      Objects:        9665
      States:         9732
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       16204      1300/io.hm-rpc.1
      tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       16953      1317/io.hm-rpc.2
      tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       2425281    140650/io.simple-ap
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18345      1486/io.sonoff.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       16919      1212/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        1999       559/mosquitto
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17227      1511/io.shelly.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30562      3094/sshd: /usr/sbi
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21874      1876/io.jarvis.0
      tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       14136      1278/io.hm-rpc.0
      tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       17963      1375/io.hm-rpc.3
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15623      656/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15141      656/iobroker.js-con
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2228473    128643/cupsd
      tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       22276      1910/io.nuki.0
      tcp6       0      0 :::1883                 :::*                    LISTEN      116        2000       559/mosquitto
      tcp6       0      0 :::22                   :::*                    LISTEN      0          30564      3094/sshd: /usr/sbi
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       2421701    140580/io.socketio.
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15452      549/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2351329    136052/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2426005    140522/io.web.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2228472    128643/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      117        15499      655/grafana
      udp        0      0 0.0.0.0:48065           0.0.0.0:*                           108        14876      400/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15056      464/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2226608    128646/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14874      400/avahi-daemon: r
      udp6       0      0 :::36425                :::*                                108        14877      400/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15086      464/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14875      400/avahi-daemon: r
      2023-12-25 01:22:52.333  - info: philips-tv.0 (141369) Got terminate signal TERMINATE_YOURSELF
      2023-12-25 01:22:52.451  - info: host.iobroker stopInstance system.adapter.philips-tv.0 send kill signal
      2023-12-25 01:22:52.518  - info: philips-tv.0 (141369) terminating
      2023-12-25 01:22:52.520  - info: philips-tv.0 (141369) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-25 01:22:52.839  - info: philips-tv.0 (141369) terminating
      2023-12-25 01:22:53.150  - info: host.iobroker instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-12-25 01:22:55.591  - info: host.iobroker instance system.adapter.philips-tv.0 started with pid 141384
      2023-12-25 01:22:58.922  - info: philips-tv.0 (141384) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.19.0, js-controller: 5.0.17
      2023-12-25 01:22:58.948  - info: philips-tv.0 (141384) Starting with ip "192.168.178.136" (API v6 - Android)
      2023-12-25 01:23:01.146  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
      2023-12-25 01:23:02.120  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.23
      2023-12-25 01:26:35.217  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
      2023-12-25 01:26:40.999  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.23
      2023-12-25 01:27:24.211  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
      2023-12-25 01:30:00.200  - info: host.iobroker instance system.adapter.ical.0 started with pid 142393
      2023-12-25 01:30:03.335  - info: ical.0 (142393) starting. Version 1.13.5 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2023-12-25 01:30:09.489  - info: ical.0 (142393) Terminated (NO_ERROR): Without reason
      2023-12-25 01:30:10.076  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-12-25 01:32:39.084  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.63
      2023-12-25 01:33:57.940  - info: web.0 (140522) ==> Connected system.user.admin from ::ffff:192.168.178.63
      2023-12-25 01:34:21.433  - info: web.0 (140522) <== Disconnect system.user.admin from ::ffff:192.168.178.63
        ltsalvatore last edited by
        hey, erst mal danke, dass dieser adapter zur verfügung gestellt wird.
        ich habe gestern etwas damit rumgespielt und es scheint alles einwandfrei zu funktionieren.
        ich muss sagen, so toll ich meinen Philips - 65OLED807-12 finde so wahr ist es aber auch, dass das OS der letzte rotz ist. es ist tatsächlich so negativ wie alle im netz behaupten.
        hinzu kommt auch noch, dass der alexa skill alles andere als nützlich ist. wenig bis keine funktionen und was die zuverlässigkeit angeht, da kann man auch lotto spielen.
        hinzu kommt noch, dass es auch wirklich keine einzige funktionierende android app gibt, welche man als virtuelle tastatur hätte nutzen können.
        umso erfreulicher, dass ich mit dem adapter hier beides mir jetzt selbst mit VIS und IoT Adapter zusammenbasteln kann.
        und jetzt zu meiner eigentlichen frage.. hat jemand zufälligerweise einen bereits fertigen VIS, den er bereit ist zu teilen? 😊🙏🏾
          Lucky_ESA Developer Most Active @ltsalvatore last edited by
          @ltsalvatore Schau mal hier nach. Die sind zwar für LG aber das kann man ja ändern.
          Gruß//Lucky
            PrinzVonBillAir last edited by
            Ich erhalte folgenden Fehler beim Versuch das TV (55PUS8808) zu pairen. Ich hatte das TV vor einigen Monaten (8-10) bereits mal gepaired, aber dann den Adapter zwischenzeitlich nochmal gelöscht und soeben wieder neu installiert. Nun erscheint nur folgende Fehlermeldung, auch bei den Protokollen kommt keine Meldung eines Fehlers, selbst bei Logstufe "Alles/Silly". Mir scheint es so, als dass überhaupt nichts an das TV gesendet wird und daher auch kein Pairing-Code angezeigt wird. Oder muss ich irgendwo im TV zuerst das alte Pairing löschen? Wenn ja, wo? Ich habe in den TV-Einstellungen bestimmt über eine Stunde jedes Untermenü durchsucht und finde nichts.
              RappiRN Most Active @PrinzVonBillAir last edited by
              @prinzvonbillair
              Hast du zufällig auch vor ein paar Tagen ein Update am TV gemacht? Bei mir kamen die Fehlermeldungen just in dem Moment, wo der TV nach dem Update neu gestartet ist.
              Habe auch schon ne ganze Menge probiert, das letzte, was ich jetzt noch machen könnte, wäre ein Downgrade am TV.
              Das Pairen (des TV) an sich scheint zu funktionieren, eine App hat sich angemeldet und es wurde ein Code am TV angezeigt.
              Enrico
                RappiRN Most Active @RappiRN last edited by
                @rappirn
                Also den TV habe ich mal auf die vorherige Version zurückgesetzt, es hat nichts gebracht.
                Habe auch noch einmal alle Adapterversionen ab 0.3.0 versucht, auch ohne Erfolg. Heute Abend werde ich nochmal versuchen, die Adapterversionen jeweils mit einer kompletten Neuinstallation zu installieren.
                Was mir mal immer wieder aufgefallen ist. Meist kam die Fehlermeldung sofort und manchmal, vielleicht nach einer Installation oder einem Adapterneustart (das kann ich noch nicht genau sagen), dauert es einige Sekunden, bis die Fehlermeldung kommt. Leider gibt es im log keine brauchbaren Infos.
                Enrico
                  Dimi @RappiRN last edited by
                  @rappirn
                  Ich habe das selbe Problem mit meinem TV. Beim Pairing kommt die Fehlermeldung "Unknown message payload for "Pairing": null". Ich habe das Modell 65OLED854 mit dem seit kurzem verfügbaren Android TV 11. Ich habe es mit der Version 0.5.3 und mit der 0.5.2 probiert.
                  Dimi
                    Adri525 @Dimi last edited by
                    ich habe einen 65OLED935/12 Philips TV mit der aktuellsten Software und Android 11, welcher via LAN verbunden ist.
                    Ohne MAC Adresse für WOL wird der Adapter grün und funktioniert einwandfrei.
                    Ich möchte den Adapter aber nur nutzen um das Ambilght einschalten zu können und dazu benötige ich WOL. Sobald ich die MAC (welche in den Netzwerkeinstellungen vom TV steht / Ethernet MAC Adresse) eintrage wird der Adapter nicht mehr grün.
                    Anbei der Log:
                    2024-07-02 20:30:15.001 - debug: philips-tv.0 (12498) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2024-07-02 20:30:15.122 - debug: philips-tv.0 (12498) Objects client ready ... initialize now
                    2024-07-02 20:30:15.159 - debug: philips-tv.0 (12498) Objects create System PubSub Client
                    2024-07-02 20:30:15.162 - debug: philips-tv.0 (12498) Objects create User PubSub Client
                    2024-07-02 20:30:15.337 - debug: philips-tv.0 (12498) Objects client initialize lua scripts
                    2024-07-02 20:30:15.351 - debug: philips-tv.0 (12498) Objects connected to redis: 127.0.0.1:9001
                    2024-07-02 20:30:15.457 - debug: philips-tv.0 (12498) Redis States: Use Redis connection: 127.0.0.1:9000
                    2024-07-02 20:30:15.512 - debug: philips-tv.0 (12498) States create System PubSub Client
                    2024-07-02 20:30:15.514 - debug: philips-tv.0 (12498) States create User PubSub Client
                    2024-07-02 20:30:15.618 - debug: philips-tv.0 (12498) States connected to redis: 127.0.0.1:9000
                    2024-07-02 20:30:16.290 - info: philips-tv.0 (12498) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.20.2, js-controller: 5.0.19
                    2024-07-02 20:30:16.324 - info: philips-tv.0 (12498) Starting with ip "192.168.1.50" (API v6 - Android)
                    2024-07-02 20:30:16.331 - error: philips-tv.0 (12498) Cannot create API client Provided MAC is not an MAC Address!
                    Der Log sagt ja dass die MAC keine MAC Adresse ist.
                    Habe die MAC Adresse auch nochmal in meiner Unifi Dream Machine Pro geprüft, Sie stimmt...
                    Hat jemand eine Idee und kann mir helfen?
                    Vielen Dank im Voraus!
                    Adri
                    DJMarc75 1 Reply Last reply Reply Quote 1
                    • DJMarc75
                      DJMarc75 @Adri525 last edited by
                      @adri525 sagte in Test Adapter Philips-TV v0.2.x:
                      die MAC Adresse
                      zeig mal die MAC welche Du im Adapter einträgst bitte.
                        Adri525 @DJMarc75 last edited by
                        @djmarc75
                        • DJMarc75
                          @adri525 hmmm... copy paste mit Leerzeichen am Ende ?
                          Sonst passt das ja eigentlich.
                            @djmarc75
                            Nein, es ist kein Leerzeichen o.ä. drin.
                            Habe die MAC händisch eingetragen und nicht kopiert...
                              ltsalvatore @Adri525 last edited by
                              @djmarc75
                              bei mir hab ich alles mit großbuchstaben drin.. wäre ein versuch wert.
                                Adri525 @ltsalvatore last edited by
                                @ltsalvatore
                                Vielen Dank!!!!
                                Der Adapter wird jetzt Grün 🙂
                                Teste jetzt noch WOL, sollte aber alles funktionieren.
                                Nochmals VIELEN DANK!!!!
                                L A 2 Replies Last reply Reply Quote 0
                                  @ltsalvatore
                                  Vielen Dank!!!!
                                  😊 freut mich zu hören
                                    Adri525 @Adri525 last edited by Adri525
                                    @adri525
                                    zu früh gefreut...
                                    Nachdem der TV in den Standby/Deep Standby gegangen ist war die Verbindung weg.
                                    Dann wollte ich den Adapter erneut mit dem TV pairen, was zur Folge hatte dass die Fehlermeldung "Unknown message payload for "pairing": null" gekommen ist (egal ob mit oder ohne MAC).
                                    Habe den Adapter dann gelöscht und neu installiert, der Fehler bleibt bestehen und der TV lässt sich nicht mehr pairen.
                                    Anbei der Log:
                                    2024-07-02 21:05:56.034 - info: philips-tv.0 (16240) Got terminate signal TERMINATE_YOURSELF
                                    2024-07-02 21:05:56.034 - info: host.raspberrypi stopInstance system.adapter.philips-tv.0 send kill signal
                                    2024-07-02 21:05:56.327 - info: philips-tv.0 (16240) terminating
                                    2024-07-02 21:05:56.329 - info: philips-tv.0 (16240) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-07-02 21:05:56.540 - info: philips-tv.0 (16240) terminating
                                    2024-07-02 21:05:57.059 - info: host.raspberrypi instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-07-02 21:05:59.369 - info: host.raspberrypi instance system.adapter.philips-tv.0 started with pid 16383
                                    2024-07-02 21:06:03.027 - info: philips-tv.0 (16383) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.20.2, js-controller: 5.0.19
                                    2024-07-02 21:06:03.053 - info: philips-tv.0 (16383) Starting with ip "192.168.1.50" (API v6 - Android)
                                    2024-07-02 21:06:03.058 - warn: philips-tv.0 (16383) Please authenticate via the adapter configuration page
                                      Lucky_ESA Developer Most Active @Adri525 last edited by
                                      @adri525 Poste mal den Inhalt von http://192.168.1.50:1925/system
                                        Adri525 @Lucky_ESA last edited by
                                        @lucky_esa
                                        Guten Morgen,
                                        anbei der Post:
                                        {"notifyChange":"http","menulanguage":"German","name":"65OLED935/12","country":"Germany","serialnumber_encrypted":"IMtBPlUPvjuZu4MewNVZhwBRJh8gXJQjyTYELR/YvO8=\n","softwareversion_encrypted":"3HskqLZKXeO0F1/l82USBd5af7no8gjkw4ZHaPk+9TxPz0n0+9slqidyeDWGDxkV\n","model_encrypted":"BO8N4c0hC+zuAVaOLZ0tan48fgC0Y6CC86cdhJY3Dgw=\n","deviceid_encrypted":"TsaoGV/o5uVb3Da4nHIF6ZlTicH/IdXhQWnpXlIDelo=\n","nettvversion":"9.0.0","epgsource":"broadcast","api_version":{"Major":6,"Minor":4,"Patch":0},"featuring":{"jsonfeatures":{"editfavorites":["TVChannels","SatChannels"],"recordings":["List","Schedule","Manage"],"ambilight":["LoungeLight","Hue","Ambilight","HueStreaming"],"menuitems":["Setup_Menu"],"textentry":["not_available"],"applications":["TV_Apps","TV_Games","TV_Settings"],"pointer":["not_available"],"inputkey":["key"],"activities":["intent"],"channels":["preset_string"],"mappings":["server_mapping"]},"systemfeatures":{"tvtype":"consumer","content":["dmr","pvr"],"tvsearch":"intent","pairing_type":"digest_auth_pairing","secured_transport":"true","companion_screen":"true"}},"os_type":"MSAF_2019_P"}
                                          @adri525 Das sieht gut aus.
                                          Wahrscheinlich ist dein Problem eher ein Fall für @Thomas-Braun und iob diag
                                          Vorab gesagt: Die MAC muss immer Großbuchstaben haben und der PIN darf nur Zahlen beinhalten.
                                          Welchen Browser nutzt du, welche Admin Version hast du und bist du mit Windows oder Linux unterwegs?
                                          Du kannst nun mehrere Möglichkeiten ausprobieren:
                                          Adapter löschen: Bitte links Adapter auswählen, dann den Expertmodus aktivieren, den Adapter suchen und die Mülltonnenzeichen drücken. Danach in deiner Konsole das eingeben
                                          iob stop
                                          iob fix
                                          iob start
                                          Danach am besten deinen Cache vom Browser leeren und eine neu Instanz von philips-tv unter adpter hinzufügen. Jetzt dann bitte nur deine IP eintragen und den Pairing Button drücken.
                                          Kommt dann wieder deine Fehlermeldung dann bitte mal das probieren.
                                          Javascript Adapter installieren und 2 Javascripte anlegen.
                                          Das erst mit diesem Inhalt füllen..ggf. deine IP anpassen.
                                          sendTo("philips-tv.0", "pairing", "192.168.1.50"
                                          , async function (result) {
                                              console.log(result);
                                          In das 2te diesen Inhalt kopieren und speichern. Hier musst du später die 0000 mit dem Code auf deinem Fernseher ersetzen.
                                          sendTo("philips-tv.0", "submitPin", "0000"
                                          Nun starte das erste Script mit deiner IP und deaktiviere es nach 3 Sekunden. Hier sollte nun der Code in deinem Fernseher erscheinen (hoffentlich)
                                          Dann die 0000 mit den Code ersetzen und dieses Script starten und den Adapter NICHT neu starten.
                                          Was kannst du im Log sehen?
                                          Gruß//Lucky
                                          A P paradoxe Situation 3 Replies Last reply Reply Quote 0
                                            Michaelnorge last edited by
                                            Hier das gleiche Problem, mein Philips hat sich auf Android 11 upgedated und seitdem funktioniert der Addapter nicht mehr.
                                            Could not poll API: {"statusCode":401,"body":"<html>\n<head>\n <title>Status page</title>\n</head>\n<body style=\"font-family: sans-serif;\">\n<p style=\"font-size: 1.2em;font-weight: bold;margin: 1em 0px;\">Unauthorized</p>\n<p>The request requires user authentication</p>\n<p>You can get technical details <a href=\"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.4.2\">here</a>.<br>\nPlease continue your visit at our <a href=\"/\">home page</a>.\n</p>\n</body>\n</html>\n","headers":{"date":"Wed, 03 Jul 2024 17:18:57 GMT","accept-ranges":"bytes","server":"Restlet-Framework/2.3.12","www-authenticate":"Digest realm=\"XTV\", domain=\"/\", nonce=\"MTcyMDAyNzEzNzA1Njo2MDVkMzI3ZjM5ZjNhZTdiNTk0OTE5YzE2NWJkNzhhNQ==\", algorithm=MD5, qop=\"auth\"","content-length":"424","content-type":"text/html; charset=UTF-8"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.177:1926","port":"1926","hostname":"192.168.178.177","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"https://192.168.178.177:1926/6/audio/volume"},"method":"GET","headers":{"authorization":"Digest username=\"thdRK4quOUoh9nGV\", realm=\"XTV\", nonce=\"MTcyMDAyNzEzNzAzNzpiMWU5NjZiMzhmNDFiNjFhN2JiOTE1ZTUwOTE2MTkxMA==\", uri=\"/6/audio/volume\", qop=auth, response=\"79fbee052dd5e76eeb4566b828565e7b\", nc=00000001, cnonce=\"f609e2997c8c4f74a99a45fb2266d454\", algorithm=MD5","referer":"https://192.168.178.177:1926/6/audio/volume"}}}
                                            Das ist was im Log steht....
                                            31.7k
                                            79.8k
                                            philips philips tv
                                            84
                                            550
                                            115356
