    4. Homeconnect Fehlermeldung
      TT-Tom @TimoWald last edited by
      @timowald
      Setzte mal den Adapter in den Debug Modus. Dann sieht man vielleicht im log etwas.
        TimoWald @TT-Tom last edited by
        @tt-tom Habe ich jetzt mal gemacht. Warte jetzt mal etwas und setze den LOG hier rein.
          @tt-tom Hier mal der LOG nach 3 Minuten.
          Jede Minute passiert etwas.
          2024-07-04 16:52:01.914 - info: host.iobroker "system.adapter.homeconnect.0" enabled
          2024-07-04 16:52:02.309 - info: host.iobroker instance system.adapter.homeconnect.0 started with pid 101249
          2024-07-04 16:52:03.207 - debug: homeconnect.0 (101249) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2024-07-04 16:52:03.275 - debug: homeconnect.0 (101249) Objects client ready ... initialize now
          2024-07-04 16:52:03.277 - debug: homeconnect.0 (101249) Objects create System PubSub Client
          2024-07-04 16:52:03.277 - debug: homeconnect.0 (101249) Objects create User PubSub Client
          2024-07-04 16:52:03.441 - debug: homeconnect.0 (101249) Objects client initialize lua scripts
          2024-07-04 16:52:03.446 - debug: homeconnect.0 (101249) Objects connected to redis: 127.0.0.1:9001
          2024-07-04 16:52:03.535 - debug: homeconnect.0 (101249) Redis States: Use Redis connection: 127.0.0.1:9000
          2024-07-04 16:52:03.638 - debug: homeconnect.0 (101249) States create System PubSub Client
          2024-07-04 16:52:03.639 - debug: homeconnect.0 (101249) States create User PubSub Client
          2024-07-04 16:52:03.768 - debug: homeconnect.0 (101249) States connected to redis: 127.0.0.1:9000
          2024-07-04 16:52:03.837 - debug: homeconnect.0 (101249) Plugin sentry Initialize Plugin (enabled=true)
          2024-07-04 16:52:04.158 - info: homeconnect.0 (101249) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v18.17.1, js-controller: 5.0.19
          2024-07-04 16:52:04.231 - debug: homeconnect.0 (101249) Found current session
          2024-07-04 16:52:04.232 - debug: homeconnect.0 (101249) Refresh Token
          2024-07-04 16:52:04.554 - debug: homeconnect.0 (101249) {"access_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.h05vzbNvOhLkpk6CTBVW8QUDpCTpPUzI9tHoDJGyPFqpNtX-oifpS7gRj_5KGQAb7ifxkzM_etF_wuvUVIHPVSSkSO0UWHaxQRHw8DLgyUKLTVDM4T7FAJ8cHAz6YM-e4_cd1Fbg8bq_O3-OYyMuWIQ1_w7Gp3X3tkUYiT5F1YEhQxHANgGGAtjrUUuw1AEnhIAmzmmJiX_6tYLFunAJ69zXrdc-ilE-BdVuLN6Yo6bonvayzI265D4bmLwIww_4x7enGUsUoLlkNx3ZDf4dEV1SWrZn2M6lwoMqxwzgdLQgGKCUdO7bIwD1mxLRoJzgV3kE6gEpLOKSPSs4XlDQOA","expires_in":86400,"id_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.h05vzbNvOhLkpk6CTBVW8QUDpCTpPUzI9tHoDJGyPFqpNtX-oifpS7gRj_5KGQAb7ifxkzM_etF_wuvUVIHPVSSkSO0UWHaxQRHw8DLgyUKLTVDM4T7FAJ8cHAz6YM-e4_cd1Fbg8bq_O3-OYyMuWIQ1_w7Gp3X3tkUYiT5F1YEhQxHANgGGAtjrUUuw1AEnhIAmzmmJiX_6tYLFunAJ69zXrdc-ilE-BdVuLN6Yo6bonvayzI265D4bmLwIww_4x7enGUsUoLlkNx3ZDf4dEV1SWrZn2M6lwoMqxwzgdLQgGKCUdO7bIwD1mxLRoJzgV3kE6gEpLOKSPSs4XlDQOA","refresh_token":"eyJyZWdpb24iOiJFVSIsInN0YWdlIjoiUFJEIiwiY3JlZiI6IjA4MjUxMkJEIiwidG9rZW4iOiJiZThjOTA5OC1hYmZlLTQ3N2ItODAwMi1kMzQwYjJhYjVjZmQiLCJjbHR5IjoicHJpdmF0ZSIsIngtcmVnIjoiRVUiLCJ4LWVudiI6IlBSRCJ9","scope":"IdentifyAppliance Monitor Settings Control","token_type":"Bearer"}
          2024-07-04 16:52:04.555 - debug: homeconnect.0 (101249) Get device list
          2024-07-04 16:52:04.735 - error: homeconnect.0 (101249) AxiosError: Request failed with status code 429
          2024-07-04 16:52:04.736 - error: homeconnect.0 (101249) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 85880 seconds.","key":"429"}}
          2024-07-04 16:52:04.737 - debug: homeconnect.0 (101249) Start EventStream
          2024-07-04 16:52:04.838 - error: homeconnect.0 (101249) 429 Too Many Requests
          2024-07-04 16:52:04.838 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
          2024-07-04 16:52:04.838 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
          2024-07-04 16:52:14.813 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
          2024-07-04 16:52:14.814 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
          2024-07-04 16:52:40.625 - info: solax.0 (21770) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
          2024-07-04 16:53:14.742 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
          2024-07-04 16:53:14.743 - debug: homeconnect.0 (101249) Start EventStream
          2024-07-04 16:53:14.817 - error: homeconnect.0 (101249) 429 Too Many Requests
          2024-07-04 16:53:14.818 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
          2024-07-04 16:53:14.818 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
          2024-07-04 16:53:16.253 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
          2024-07-04 16:53:16.254 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
          2024-07-04 16:54:13.597 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
          2024-07-04 16:54:13.598 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
          2024-07-04 16:54:24.749 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
          2024-07-04 16:54:24.750 - debug: homeconnect.0 (101249) Start EventStream
          2024-07-04 16:54:24.826 - error: homeconnect.0 (101249) 429 Too Many Requests
          2024-07-04 16:54:24.826 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
          2024-07-04 16:54:24.826 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
          2024-07-04 16:55:15.037 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
          2024-07-04 16:55:15.038 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
          2024-07-04 16:55:34.756 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
          2024-07-04 16:55:34.756 - debug: homeconnect.0 (101249) Start EventStream
          2024-07-04 16:55:34.862 - error: homeconnect.0 (101249) 429 Too Many Requests
          2024-07-04 16:55:34.862 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
          2024-07-04 16:55:34.862 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
          Thomas Braun T haselchen 3 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @TimoWald last edited by
            @timowald sagte in Homeconnect Fehlermeldung:
            node: v18.17.1
            Bring das auf eine aktuelle Version.
            iob nodejs-update 20
              TimoWald @Thomas Braun last edited by
              @thomas-braun Den Befehl in der Console?
                @timowald
                Ja. Deine Installation steht auf dem falschen Gleis.
                  @thomas-braun Da kommt diese Meldung:
                  Zur Info: IoBroker läuft auf Proxmox.
                    @timowald
                    Du sollst ja auch NICHT als root herumhampeln. Auch nicht im Proxmox-Container.
                    Als USER:
                    iob stop
                    iob fix
                      TT-Tom @TimoWald last edited by TT-Tom
                      @timowald schalte mal den Adapter ab bis morgen. Heute kommen da eh keine sinnvolle Meldungen zurück, weil du kein Connect mehr bekommst.
                        Thomas Braun Most Active @TT-Tom last edited by
                        @tt-tom sagte in Homeconnect Fehlermeldung:
                        Das stimmt.
                        Die Zeit kann man dann für ein vollständiges und richtiges Setup des Containers verwenden.
                          @thomas-braun said in Homeconnect Fehlermeldung:
                          Wie kann ich nachträglich noch einen Standard benutzer hinzufügen?
                            @timowald
                            Steht in der Doku drin:
                            https://www.iobroker.net/#de/documentation/install/proxmox.md
                              @thomas-braun Also geht das im nachhinein gar nicht mehr?
                                @timowald
                                Klar geht das. Einfache User können natürlich jederzeit angelegt und auch wieder gelöscht werden.
                                  TimoWald @Thomas Braun last edited by TimoWald
                                  @thomas-braun ich mus ihn doch anlegen über die konsole in proxmox oder über Putty oder liege ich da falsch?
                                  Mus ich einen Benutzer für den IObroker oder für Proxmox anlegen?
                                    @timowald
                                    Mit einem Terminal. Ich würde da aber immer was 'gescheites' verwenden.
                                    puTTY halte ich nicht für gescheit...
                                    Das Terminal aus proxmos kenne ich nicht. Keine Ahnung was die da verwenden.
                                      Das steht doch in der Anleitung drin, oder nicht?
                                        @thomas-braun Ja aber ich kann mich danach nicht einloggen mit dem Nutzer.
                                        iobroker user add <user> Add new user
                                        iobroker user del <user> Delete user
                                        iobroker user passwd <user> Change user password
                                        iobroker user enable <user> Enable user
                                        iobroker user disable <user> Disable user
                                        iobroker user get <user> Get user
                                        iobroker user check <user> Check user password
                                        Das habe ich verwendet.
                                        Thomas Braun Quad Driver 2 Replies Last reply Reply Quote 1
                                          Du sollst in dem Container einen user anlegen und den dann statt des roots verwenden.
                                          Wie das geht steht in der Anleitung drin:
                                          Jetzt legt man den zukünftigen Benutzer an. "Benutzername" in dem Fall ersetzen. Passwortvergabe für den User. Der Rest kann mit ENTER bestätigt werden.
                                          • Quad Driver
                                            Quad Driver @TimoWald last edited by
                                            ich habe aktuell auch Probleme mit homeconnect.
                                            Der Adapter ist grün und findet laut Log auch ein Gerät allerdings wird das Gerät als "connected":false angezeigt und die DP werden nicht aktualisiert. Über die App lässt sich das Gerät steuern.
                                            Kann mir hier jemand weiterhelfen?
                                            2325
