    4. Test Adapter Weather-Warnings
    • SBorg
      SBorg Forum Testing Most Active @Negalein last edited by
      @negalein sagte in Test Adapter Weather-Warnings:
      Hallo
      Kann mir jemand sagen, wie ich zu dieser Karte (ohne Buttons, usw.) komme?
      Möchte den Link in VIS in ein Image oder anderes Widger einbaun.
      https://warnungen.zamg.at/wsapp/de/alle/heute/57581,224276,745081,567757
      Da der Link so schon funktioniert würde sich PhantomJS anbieten. Damit kannst du die kpl. Seite capturen bzw. dann nur den Bildausschnitt den du möchtest. Anders wird es nicht gehen, da die Karte ansich keine jpg, gif, PNG... ist.
      • Nashra
        Nashra Most Active Forum Testing @Negalein last edited by
        @nashra sagte in Test Adapter Weather-Warnings:
        Erledigt, habe es hinbekommen
        sorry, habs übersehn.
        Ich mach es mit Material Design Widget.
        Du?
        Mit vis-inventwo-universal für Popup
        [{"tpl":"i-vis-universal","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iUniversalWidgetType":"ViewInPopup","iValueType":"boolean","iValueComparison":"not","iStateResponseTime":"0","iStateResetValueTime":"0","iNavWait":"100","iPopUpBackground":"#fff","iPopUpPreventClickOutside":"","iPopUpShowTitle":false,"iPopUpTitle":"Wetterwarnung","iPopUpTitleColor":"#000","iPopUpCloseBtnColor":"#dc2e2e","iPopUpWidth":"590px","iPopUpHeight":"230px","iPopUpHeightTitle":"50","iPopUpTitleSize":"28","iPopUpPosition":"center","iPopUpPositionX":"0","iPopUpPositionY":"0","iPopUpCloseAfterSeconds":"0","iPopUpCornerRadiusUL":"12","iPopUpCornerRadiusUR":"12","iPopUpCornerRadiusLR":"12","iPopUpCornerRadiusLL":"12","iPopUpShadowXOffset":"2","iPopUpShadowYOffset":"2","iPopUpShadowBlur":"2","iPopUpShadowSpread":"1","iPopUpShadowColor":"#111111","iButtonCol":"","iButtonActive":"","iButtonColHover":"","iOpacityBack":"1","iCornerRadiusUL":"0","iCornerRadiusUR":"0","iCornerRadiusLR":"0","iCornerRadiusLL":"5","iContentFlexDirection":"vertical","iContentVertAlign":"iSpace-between","iContentOrder":"orderTextImg","iOpacityCtn":"1","iTextColor":"#ffffff","iTextSize":"16","iTextAlign":"iCenter","iTextSpaceTop":"-5","iTextSpaceBottom":"0","iTextSpaceLeft":"0","iTextSpaceRight":"0","iIconSize":"65","iImgAlign":"iCenter","iImgSpaceTop":"0","iImgSpaceBottom":"0","iImgSpaceLeft":"0","iImgSpaceRight":"0","iImgRotation":"0","iImgBlinkFalse":"0","iImgBlinkTrue":"0","iImgColorFalse":"red","iImgColorTrue":"#18f737","iShadowXOffset":"0","iShadowYOffset":"0","iShadowBlur":"0","iShadowSpread":"0","iShadowColor":"#111111","iShadowColorActive":"#111111","iShadowColorHover":"","iShadowInnerXOffset":"0","iShadowInnerYOffset":"0","iShadowInnerBlur":"0","iShadowInnerSpread":"0","iShadowInnerColor":"#111111","iShadowInnerColorActive":"#111111","iShadowInnerColorHover":"","iBorderSize":"0","iBorderStyle":"solid","iBorderColor":"#44739E","iBorderColorActive":"#18f737","iBorderColorHover":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"","iImageFalse":"/icons-open-icon-library-png/emblems/emblem-important-red.png","iImageTrue":"/icons-open-icon-library-png/emblems/emblem-important-red.png","iTextFalse":"","iTextTrue":"","iImgColorInvertTrue":false,"iFlipImage":false,"iImgColorInvertFalse":false,"nav_view":"wetterwarnings","iContentType":"image","iTextColorActive":"#ffffff","iImgClockFace":"01","iImgClockHands":"01","iImgClockShowBorder":"1","iImgColorClockFace":"#ffffff","iImgColorHands":"#ffffff","iImgColorHandSecond":"#ff0000","iClockShowSeconds":"","iClockTimezone":"Europe/Berlin","iHtmlTextFieldFalse":"","iHtmlTextFieldTrue":"","iShadowTextXOffset":"0","iShadowTextYOffset":"0","iShadowTextBlur":"0","iShadowTextColor":"#111111","iShadowTextColorActive":"#111111","iHttpType":"iSend","iTextDecoration":"none"},"style":{"left":"9px","top":"137px","width":"62px","height":"61px","z-index":"50","font-family":"RobotoCondensed-Regular"},"widgetSet":"vis-inventwo"}]
        • Negalein
          Negalein Global Moderator @SBorg last edited by
          @sborg sagte in Test Adapter Weather-Warnings:
          PhantomJS
          hatte ich schon bei einer anderen Seite.
          wirklich zufriedenstellend war es nicht.
          Für kleine Ausschnitte ist es Ok. Aber umso größer, umso negativer.
          Ich werde wohl dann die ganze Seite im Iframe anzeigen lassen. Leider dann mit den unnötigen Buttons.
          • SBorg
            @negalein
            Vermutlich per Adapter? Der ist ziemlich eingeschränkt in den Möglichkeiten. PhantomJS ist, wie der Name schon vermuten lässt, ein Javascript. Auf Betriebssystemebene installiert stehen alle Möglichkeiten offen. Da ist ein Screengrab 1:1 vom Original, wenn man die gewünschte Auflösung nicht runter schraubt. Die NodeRed-Version habe ich mir noch nicht angesehen 😉
            Negalein SBorg 2 Replies Last reply Reply Quote 0
            • Negalein
              Ja, war der Adapter.
              Muss ich mir mal genauer anschaun wie das installiert wird, usw.
                deta Most Active @deta last edited by deta
                Hab es gefunden. Die Echos müssen Räume zugeordnet sein. Dann Speichern und wenn man dann nach den Echos schaut, erscheint die Liste..
                • SBorg
                  SBorg Forum Testing Most Active @SBorg last edited by
                  Genauso beschränkt wie der Adapter...
                  • Negalein
                    @ticaki
                    Ich habe ein Problem. 😉
                    In den Settings habe ich im Filter die Warnung für Hitze herausgefiltert.
                    Trotzdem kommt aktuell täglich die Warnung per Mail, Telegram und Alexa.
                    • Q
                      quorle last edited by
                      Wenn man sich die Warnungen per Telegram schicken lässt, wie macht man dann eine neue Zeile?
                      • Q
                        quorle @quorle last edited by
                        @quorle Selbst gefunden. Funktioniert tip top
                        • Nashra
                          Moin @ticaki , bei mir machen die Ruhezeiten Probleme.
                          Eingestellt ist einmal 21:00 bis 24:00 Uhr und 00:00 bis 08:00 Uhr.
                          Gestern Abend ballert Alexa los um 22:05 Uhr, zwar mit einer Entwarnung,
                          nur habe ich noch einen Sound dabei und dadurch hat sich meine Holde
                          doch etwas erschrocken zu dieser Zeit 😀
                          Ist leider auch nicht das erste Mal passiert. Letzte Aktion war vor einigen Tagen
                          um 01:33 Uhr.
                          rtwl 1 Reply Last reply Reply Quote 0
                          • rtwl
                            rtwl @Nashra last edited by rtwl
                            21:00 bis 24:00 Uhr
                            versuche mal... bis 23:59 Uhr statt 24:00
                            obwohl wenn es um 1 Uhr auch passiert, kanns das eh nicht sein.
                            • Nashra
                              Nashra Most Active Forum Testing @rtwl last edited by
                              @rtwl sagte in Test Adapter Weather-Warnings:
                              21:00 bis 24:00 Uhr
                              jein, habe mal etwas die Logs der letzten Tage durchgesehen und da ist mir was aufgefallen.
                              Kommt eine Warnung z.B. um 15:00 Uhr und die Entwarnung um 22:00 Uhr dann wird die
                              Entwarnung angesagt obwohl Ruhezeit ab 21:00 Uhr.
                              Kommt aber eine Warnung und Entwarnung innerhalb der Ruhezeiten passiert nichts bzw.
                              gibt es keine Ansage 🙂
                              Ergo, liegt eine Warnung vor und die Entwarnung kommt erst innerhalb der Ruhezeiten wird dann
                              diese Ruhezeit nicht beachtet, also Bug sag ich jetzt mal dazu 🙂
                              Zeit nicht
                                deta Most Active last edited by
                                warum kommen die Warnungen immer zu spät? Wenigstens Alexa plappert Sie zu spät.
                                Beispiel Warnung Regen um 8:23, wird aber erst 8:35 angesagt. Mh.
                                Hab ich da was übersehen? Oder ist das normal?
                                cu Deta
                                • Nashra
                                  Nashra Most Active Forum Testing last edited by Nashra
                                  Und noch ein, sagen wir mal Schönheitsfehler, der nach einer Entwarnung in der VIS angezeigt wird.
                                  Wie man hier sieht wird in den DP'ten der Ortsname und Farbe gelöscht sowie die Stufe auf -1 gesetzt.
                                  Nach einer erneuten Abfrage des Adapters ist alles wieder ok.
                                    Flugschüler @Nashra last edited by
                                    Adapter funktioniert bei mir nicht mehr.
                                    [zamg-48.196417251634216,14.42410737276077] Warn(21) axios error for zamgService url: https://warnungen.zamg.at/wsapp/api/getWarningsForCoords?lat=48.196417251634216&lon=14.424107372760771&lang=de
                                      sigi234 Forum Testing Most Active @Flugschüler last edited by
                                      @flugschüler sagte in Test Adapter Weather-Warnings:
                                      Dito
                                      • Negalein
                                        Negalein Global Moderator @sigi234 last edited by
                                        @sigi234
                                        @Flugschüler
                                        liegt an ZAMG
                                          @negalein o.k. Wird das so bleiben. Weiß man wahrscheinlich nicht.
                                          sigi234 Negalein 2 Replies Last reply Reply Quote 0
                                            Denke mal Serverwartung oder die haben ein Problem.
                                            1077
                                            267974
