    4. Homematic IP Cloud Access Point Adapter
      apollon77 last edited by
      Komisch ... Dann ehrlich langsam keine Idee mehr 😞
      O Mathias Meister 2 Replies Last reply Reply Quote 0
      • O
        oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
        @apollon77
        Es geht bis heute mit einer älteren Adapterversion vor Umstellung auf Axios. Es kann also nicht so kompliziert sein. Ja, ich weiß, das ist leicht gesagt...
          LukasWPT last edited by
          Aktuell habe ich zwei Probleme mit meinem HMIP Adapter, in der Suche konnte ich nichts vergleichbares finden.
          1. Aus irgendeinem Grund bekomme ich folgende Log-Einträge ausgegeben, obwohl ich weder per Skript noch manuell Objekteinstellungen ändere:
          2024-07-06 08:22:12.133 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.1.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
          2024-07-06 08:22:12.179 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.2.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
          2024-07-06 08:22:12.185 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.3.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
          2024-07-06 08:22:12.208 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.4.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
          2024-07-06 08:22:14.181 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.1.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
          2024-07-06 08:22:14.186 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.2.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
          2024-07-06 08:22:14.191 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.3.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
          2024-07-06 08:22:14.199 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.4.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
          Das selbe Spiel scheint auch mit den Jalousien zu geben (da allerdings mit dem Objekt previousShutterlevel (wird auch nicht angesteuert). Ich habe etwas Sorgen, dass damit irgendwann die Cloud überlastet wird und meine IP HMIP-seitig gesperrt wird.
          1. Bei dem RGBW Controller werden keine Einstellungen für Farbe und Sättigung (Hue und Saturationlevel) übernommen. D.h. ich kann zwar eine Zahl eingeben, diese wird allerdings nicht übertragen. Umgekehrt werden aber Zahlen in IoBroker übertragen die ich in der App einstelle.
          Besten Dank für eure Hilfe!
            TT-Tom @LukasWPT last edited by TT-Tom
            @lukaswpt schau mal in die Datenpunkt Einstellung. Der Typ numbern gibt es nicht, der heißt number/zahl.
            Das wird in dem log bemängelt.
            Wie trägst du dort Werte ein?
            Homoran L 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @TT-Tom last edited by
              @tt-tom sagte in Homematic IP Cloud Access Point Adapter:
              ich tippe daher auf eine Tippfehler im Code, der beim Anlegen der states diesen falschen Typ verwendet.
                TT-Tom @Homoran last edited by TT-Tom
                Ja ist ein Fehler im Adapter.
                bug im Code
                Muss ein Issue erstellt werden.
                Edit: ist erstellt, kurz und knapp 😉
                  apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
                  @ofbeqnpolkkl6mby5e13 Dann bitte debug log mit alt und neu als issue im Github. Müssen wir ansehen. Es tut halt für viele USer, daher ists scheinbar irgendwas in den Details
                    LukasWPT @TT-Tom last edited by LukasWPT
                    @tt-tom Danke für die Antwort - ich trage da eben gar nichts ein (weder durch Skripte, noch manuell). Ich hab in der Doku den Punkt von „Numbers“ auf „number“ Geändert allerdings ist nach einem Neustart der Instanz alles beim Alten.
                    • edit: gerade die restlichen Antworten gesehen. Danke euch! Dann warte ich auf ein Update 🙂
                    • Edit2: für previous.Shutterlevel ist es dann ein ähnlicher Bug - siehe Log:
                    hmip.0
                    2024-07-06 14:23:23.416	info	State value to set for "hmip.0.devices.3014F711A000369F29AE921C.channels.1.previousShutterLevel" has to be type "string" but received type "number"
                      @lukaswpt kommt die Meldung beim Beschreiben des Datenpunkt oder wenn der Adapter Daten abruft??
                      Edit: was für ein Gerät ist es Shutter oder Blind?
                        @tt-tom in dem Fall wenn ich den shutter (ist ein shutter) öffne oder schließe. Natürlich nicht über den beschriebenen Datenpunkt sondern den dafür vorgesehenen.
                        Bei dem RGBW Controller ist es allerdings gefühlt random.
                          @lukaswpt
                          Es gab mal ein Issue dafür wurde aber von Ersteller wieder geschlossen.
                          @apollon77 Öffnest du Ihn neu oder soll ich es in dem Aktuellen mit reinschreiben?
                          Das mit dem RGBW bedeutet jetzt es klappt mal, mal nicht?
                          L T 2 Replies Last reply Reply Quote 0
                            @tt-tom also bzgl des RGBW:
                            Ein/Aus sowie Dimmen des LED streifen klappt immer, Farbe einstellen & Farbsättigung nie. Bei den restlichen Parametern die per IOB steuerbar sind klappen meiner Meinung nach auch nicht. Ich weiß aber nicht ob das zwingend mit dem „Numbern“ Fehler zusammenhängt oder was separates ist. Die o.g. Meldung tritt nur (für mich) recht zufällig auf und scheint nicht mit Interaktionen von mir / einem Skript zusammen zu hängen.
                              @lukaswpt
                              Das RGBW-Problem ist separat zu betrachten.
                              Habe leider nicht so ein Modul, um das zu verifizieren.
                              Mach dazu mal bitte auf Github ein Issue auf, damit es bearbeitet wird und hier nicht untergeht.
                                TT-Tom @TT-Tom last edited by
                                @apollon77 habe das Issue #571 jetzt angepasst für die Type - Fehler bei den States.
                                L apollon77 2 Replies Last reply Reply Quote 0
                                  @tt-tom erledigt, danke!
                                    @lukaswpt
                                    habe dein Issue gesehen, bist du wirklich noch auf Buster unterwegs. Solltest mal auf ein aktuelles System wechseln. Es gibt hier genug Beiträge zum Wechsel auf Bookworm.
                                      @tt-tom nehme ich mir auch schon länger vor. Bzw. ebenfalls eine Trennung von iobroker und Nextcloud (läuft auf dem selben PI), bisher sind meine Versuche upzugraden an Nextcloud gescheitert, da hab ich es leider nicht sauber hinbekommen.
                                      • Mathias Meister
                                        Mathias Meister @apollon77 last edited by
                                        @apollon77 Was nun?
                                        Gibt es irgendwas, das ich noch probieren und testen kann? Mit der App von Homematic IP funktioniert ja alles bestens, aber ich würde das schon lieber mit dem ioBroker machen...
                                        Mathias Meister 1 Reply Last reply Reply Quote 0
                                          apollon77 @TT-Tom last edited by
                                          @tt-tom GitHub updated. Bitte verifizieren und zurückmelden
                                            TT-Tom @apollon77 last edited by
                                            @LukasWPT
                                            Kannst du bitte das Update von Github installieren und prüfen. Rückmeldung an @apollon77
                                            homematic cloud adapter homematic ip cloud adapter
                                            92
                                            400
                                            69749
