    2. English
    3. Scripting / Logic
    4. JavaScript
    5. JavaScript adapter wont detect modbus-serial
      Homoran Global Moderator Administrators @Jack 3 last edited by
      @jack-3 sagte in JavaScript adapter wont detect modbus-serial:
      that I have downloaded this module already.
      how did you do this?
      I am doing this in the JavaScript adapter.
      and added you the npm package via its instance?
      Jack 3 1 Reply Last reply Reply Quote 0
      • Jack 3
        Jack 3 @Homoran last edited by
        @homoran i did so by typing 'npm install modbus-serial' into the terminal in iobroker, im not sure what you mean by add the npm package via its instance.
          Homoran Global Moderator Administrators @Jack 3 last edited by Homoran
          not ok!
          hopefully you did it in the correct directory at least.
          there is a line in the configuration of the javascript instance, where you just have to enter the name of the package(s) followed by <ENTER>
          that's all
          Jack 3 1 Reply Last reply Reply Quote 1
          • Jack 3
            @homoran I did add it to the npm modules in the javascript instance but there is still the error, I think maybe its because I didnt download it to the correct directory , where do I need to download it to?
              nowhere!
              you just have to add it in the config.
              save and exit, the instance should restart and load it itself.
              • Jack 3
                @homoran Im still getting this error even after adding modbus-serial to the instance, are there perhaps other steps I can take to troubleshoot this?
                  I think so, but I cannot tell which ones.
                  maybe that @thomas-braun may help to find the issue if something went wrong by your installation method and is blocking the built in method
                  oooh!
                  is there a whitespace too much at the end? before the closing '
                    fastfoot @Jack 3 last edited by
                    @jack-3 do something with ModbusRTU, the error might only be visually(because of some restriction the sandbox has). Only if yo get additional errors when using the module you can tell the module is not loaded
                    Jack 3 1 Reply Last reply Reply Quote 2
                    • Jack 3
                      Jack 3 @fastfoot last edited by
                      @fastfoot I tried this code which I copied and edited from the modbus serial documentation and I am getting these errors 48aac906-bd54-4c26-8cd4-eb3e6a7f5078-image.png
                        @jack-3 ok, thats a real error. Which version of JS-Adapter do you have? I think there is a bug in the newest Beta not installing modules that were entered in the instance config. Remove these lines, leave the config and enter them again. After leaving the config then have a look to the Log Tab, you schould see the that module(s) are getting installed.
                        Workaround on the cli:
                        • cd /opt/iobroker
                        • npm i modbus-serial
                        • js-adapter should recognize the module now, though the red underline might still be there
                        let us know, there should be no need to install module in /opt/iobroker/node_modules/iobroker.javascript instead of /opt/iobroker
                        • Jack 3
                          @fastfoot Thats the thing, I do not have an /opt/iobroker directory, it does not exist is what the terminal tells me
                            @jack-3 what system are you running iobroker, windows? There it schould be C:\iobroker. All Linux Systems use /opt/iobroker. Though not sure where tis is on a Mac
                            Jack 3 2 Replies Last reply Reply Quote 0
                            • Jack 3
                              @fastfoot I use windows
                              • Jack 3
                                @fastfoot I ran the command again using the directory you said and Im still getting the same errors, I can even see in the node_modules directory that I do have Modbus-serial installed
                                  @jack-3 the try cd C:\iobroker and then npm i modbus-serial
                                    fastfoot @fastfoot last edited by
                                    @fastfoot please log the error instead of the data, works fine here though i have no modbus hardware
                                    • Jack 3
                                      Jack 3 last edited by Jack 3
                                      @fastfoot
                                      2024-07-09 09:07:46.559 - error: modbus.0 (604) Socket Error
                                      2024-07-09 09:07:46.564 - error: modbus.0 (604) Client in error state.
                                      2024-07-09 09:07:46.564 - warn: modbus.0 (604) On error: {"errno":-4039,"code":"ETIMEDOUT","syscall":"connect","address":"131.246.75.233","port":5020}
                                      2024-07-09 09:07:46.592 - error: modbus.1 (12848) Socket Error
                                      2024-07-09 09:07:46.601 - error: modbus.1 (12848) Client in error state.
                                      2024-07-09 09:07:46.601 - warn: modbus.1 (12848) On error: {"errno":-4078,"code":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                                      2024-07-09 09:08:47.615 - error: modbus.1 (12848) Socket Error
                                      2024-07-09 09:08:47.615 - error: modbus.1 (12848) Client in error state.
                                      2024-07-09 09:08:47.615 - warn: modbus.1 (12848) On error: {"errno":-4078,"code":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                                      2024-07-09 09:09:08.775 - error: modbus.0 (604) Socket Error
                                      2024-07-09 09:09:08.775 - error: modbus.0 (604) Client in error state.
                                      2024-07-09 09:09:08.775 - warn: modbus.0 (604) On error: {"errno":-4039,"code":"ETIMEDOUT","syscall":"connect","address":"131.246.75.233","port":5020}
                                      2024-07-09 09:09:12.133 - info: admin.0 (5516) ==> Connected system.user.admin from ::1
                                      2024-07-09 09:09:12.221 - error: host.PCRT49 cannot call visUtils: Not exists
                                      2024-07-09 09:09:18.930 - info: admin.0 (5516) ==> Connected system.user.admin from ::1
                                      2024-07-09 09:09:21.197 - info: javascript.0 (12652) Start JavaScript script.js.Test (Javascript/js)
                                      2024-07-09 09:09:21.206 - error: javascript.0 (12652) script.js.Test compile failed:
                                      at script.js.Test:4
                                      is that what you mean?
                                      1206
