    4. [GELÖST] Kein Stream der Reolink (RLC 1212A)
    • wendy2702
      wendy2702 @Stefan81 0 last edited by
      @stefan81-0 sagte in Kein Stream der Reolink (RLC 1212A):
      firewall-cmd --state
      Keine Ahnung welches Linux bei dir läuft. Unter bookworm sollte es so gehen:
      sudo systemctl status nftables.service
      ○ nftables.service - nftables
          Loaded: loaded (/lib/systemd/system/nftables.service; disabled; preset: enabled)
          Active: inactive (dead)
            Docs: man:nft(8)
                  http://wiki.nftables.org
      Stefan81 0 1 Reply Last reply Reply Quote 0
      • Stefan81 0
        Stefan81 0 @wendy2702 last edited by Homoran
        @wendy2702
        genau diese Meldung kommt:
        ist also deaktiviert.
              Docs: man:nft(8)
        die Konsole sagt übrigens folgendes:
        Failed to load resource: the server responded with a status of 404 (Not Found)
        main.8e80ccb0.js:2 Mixed Content:
        The page at 'https://192.168.178.38:8082/vis-2/?Vis%20Home#Startseite' was loaded over HTTPS, but requested an insecure frame 'http://192.168.178.100:1984/api/stream.mp4?src=Haust%C3%BCr&mp4=flac'. This request has been blocked; the content must be served over HTTPS.
        The page at 'https://192.168.178.38:8082/vis-2/?Vis%20Home#Startseite' was loaded over HTTPS, but requested an insecure frame 'http://192.168.178.100:1984/stream.html?src=Haust%C3%BCr'.
        The page at 'https://192.168.178.38:8082/vis-2/?Vis%20Home#Startseite' was loaded over HTTPS, but requested an insecure frame 'http://192.168.178.100:1984/stream.html?src=Haust%C3%BCr'. This request has been blocked; the content must be served over HTTPS.
        The page at 'https://192.168.178.38:8082/vis-2/?Vis%20Home#Startseite' was loaded over HTTPS, but requested an insecure frame 'http://192.168.178.100:1984/stream.html?src=Balkon%201'. This request has been blocked; the content must be served over HTTPS.
        jquery-1.11.2.min.js:2 Uncaught TypeError:
        Cannot read properties of null (reading 'length')
            at Function.each (jquery-1.11.2.min.js:2:2821)
            at Object.redraw (trashschedule.js:368:15)
            at Object.createWidget (trashschedule.js:206:36)
            at trashschedule.js:185:44
        each @ jquery-1.11.2.min.js:2
        redraw @ trashschedule.js:368
        createWidget @ trashschedule.js:206
        (anonym) @ trashschedule.js:185
          A Former User @Stefan81 0 last edited by
          The page at 'https://192.168.178.38:8082/vis-2/?Vis Home#Startseite' was loaded over HTTPS, but requested an insecure frame 'http://192.168.178.100:1984/api/stream.mp4?src=Haustür&mp4=flac'. This request has been blocked; the content must be served over HTTPS.
          genau das ist dein Problem, hat nix mit der Firewall zu tun, du bettest ein http in ein https ein, das geht so nicht.
          • Stefan81 0
            Stefan81 0 @Guest last edited by
            @ilovegym
            okay dokay.
            Danke für die schnelle Antwort.
            Was genau muss, oder sollte ich denn jetzt genau tun?
            Sollte ja dann beides https sein, richtig?
            Muss ich also aus dem Stream von GO2RTC eine https machen?
              @stefan81-0
              genau, entweder http oder https, und zwar alles, auch die Iframes..
              • Stefan81 0
                @ilovegym
                ok was ist denn hier einfacher bzw. sicherer?
                Wie mache ich aus dem iFrame ein https iFrame?
                Für die Kameras nutze ich über GO2RTC einen RTSP link, muss dieser dann ein https link sein?
                Also anstatt:
                rtsp://admin:XXXXXXX@192.168.178.47:554/h264Preview_01_main
                das hier:
                https://admin:XXXXXXX@192.168.178.47:443/h264Preview_01_main
                Wäre zu einfach 🙂 habe ich gerade probiert. Sorry bin leider kein Informatiker. Merkt ihr wahrscheinlich schon 🤦‍♂️
                  @stefan81-0
                  bei go2rtc bin ich raus, verwende ich nicht.
                  Wenn du es einfach haben willst, dann lass dir deine Vis doch in http anzeigen, erstmal zum testen, ob alles laeuft..
                  Wer greift da alles drauf zu? Hat das einen Grund, dass da https eingestellt ist?
                  • Stefan81 0
                    @ilovegym
                    Also ich habe schon vor später auch einen Fernzugriff einzurichten, aber so weit bin ich noch nicht.
                    Bei der Einrichtung wurde immer darauf hingewiesen https zu nutzen, von wegen Sicherheit usw.?
                    Im Moment nutze ich das nut lokal hier zu Hause, aber hängt natürlich per LAN am Internet.
                    Oder kann ich falls ich keinen Fernzugriff nutze alles auf http einstellen?
                    Stefan81 0 ? Dr. Bakterius 3 Replies Last reply Reply Quote 0
                    • Stefan81 0
                      Stefan81 0 @Stefan81 0 last edited by Stefan81 0
                      @stefan81-0
                      ok es hat gereicht nur die vis auf http umzustellen. 👍
                      Danke für die Hilfe.
                        @stefan81-0 solange du keine Ports offen hast, ist alles gut.
                        https sichert deine Webseiten ab, entweder mit Passwort oder Zertifikat.
                        • Stefan81 0
                          Stefan81 0 @Guest last edited by Stefan81 0
                          @ilovegym
                          Okay danke. 👍
                          Wie checke ich denn ob Ports offen sind?
                          Habe selber keine freigegeben.
                          Ich denke dann sollten auch keine offen sein.
                          • Dr. Bakterius
                            Dr. Bakterius Most Active @Stefan81 0 last edited by
                            @stefan81-0 sagte in [GELÖST] Kein Stream der Reolink (RLC 1212A):
                            Dann am besten per VPN. Da bist du über einen verschlüsselten Tunnel mit deinem Heim-Netz verbunden.
                            • Stefan81 0
                              Stefan81 0 @Dr. Bakterius last edited by
                              @dr-bakterius
                              danke für den Tipp. Leider habe ich keine reine ipv4 Adresse von den Jungs mit dem großen T bekommen.
                              Funktioniert eine VPN Verbindung auch ohne reine ipv4 Adresse?
                              ? Dr. Bakterius 2 Replies Last reply Reply Quote 0
                                @stefan81-0
                                brauchst du nicht, richte dir Dyndns ein, dann kann die IP alle 24h wechseln..
                                Viele Router haben sowas schon eingebaut.
                                • Dr. Bakterius
                                  @stefan81-0 Meinst du, dass du nur einen DS-light Anschluss hast? Dann wende dich an das große T und sag ihnen, dass du eine öffentliche (dynamisch vergebene) IPv4-Adresse benötigst. Das müssen sie dir gewähren und kostet nichts und du bist über eine IPv4-Adressen von außen erreichbar. Für die dynamische IP richtest du dir dann einen dynDNS-Dienst ein (wie von @ilovegym schon erwähnt).
                                  • Stefan81 0
                                    @dr-bakterius
                                    alles klaro, vielen Dank für den Hinweis. 🙂 Klappt.
                                    camera vis
                                    1397
