    5. Warten auf successful bei Linux Control
      Felsdrache @Felsdrache last edited by
      @felsdrache sagte in Warten auf successful bei Linux Control:
      @djmarc75
      > <xml xmlns="https://developers.google.com/blockly/xml">
      >   <variables>
      >     <variable type="interval" id="Warten auf wahr">Warten auf wahr</variable>
      >   </variables>
      >   <block type="on_ext" id="Uq`tK$rMggfE-2hTSX;@" x="108" y="80">
      >     <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation>
      >     <field name="CONDITION">ne</field>
      >     <field name="ACK_CONDITION"></field>
      >     <value name="OID0">
      >       <shadow type="field_oid" id="99)Shngn!J_J!G@iGi}i">
      >         <field name="oid">linux-control.0.command.command</field>
      >       </shadow>
      >     </value>
      >     <statement name="STATEMENT">
      >       <block type="timeouts_wait" id="Z|iNO]n;!|v33c4dfZ^N">
      >         <field name="DELAY">1000</field>
      >         <field name="UNIT">ms</field>
      >         <next>
      >           <block type="timeouts_setinterval" id="E6~JvQKzoB/Rt(y44RGL">
      >             <field name="NAME">Warten auf wahr</field>
      >             <field name="INTERVAL">1000</field>
      >               <block type="controls_if" id=":;!-|wJn3g;A.e.k![YZ">
      >                 <value name="IF0">
      >                   <block type="logic_compare" id="O=1=z`!QR?i+VtvD(a{]">
      >                     <field name="OP">EQ</field>
      >                     <value name="A">
      >                       <block type="get_value" id="H{xxuoD6NH!)Rtlm%_L+">
      >                         <field name="ATTR">val</field>
      >                         <field name="OID">linux-control.0.command.response</field>
      >                       </block>
      >                     </value>
      >                     <value name="B">
      >                       <block type="text" id="hg(I{2:TA[_(%r8v@T+P">
      >                         <field name="TEXT">successful</field>
      >                       </block>
      >                     </value>
      >                   </block>
      >                 </value>
      >                 <statement name="DO0">
      >                   <block type="timeouts_clearinterval" id="H5?;-UjfnTA?tDL!Pi(K">
      >                     <next>
      >                       <block type="debug" id="XoN:*:k|VVbSiok$d78:">
      >                         <field name="Severity">info</field>
      >                         <value name="TEXT">
      >                           <shadow type="text" id="koiCOPOyTqq6V`T)m#Ok">
      >                             <field name="TEXT">es läuft</field>
      >                           </shadow>
      >                         </value>
      >                       </block>
      >                     </next>
      >                   </block>
      >                 </statement>
      >               </block>
      >             </statement>
      >           </block>
      >         </next>
      >       </block>
      >     </statement>
      >   </block>
      > </xml>
      • DJMarc75
        DJMarc75 @Felsdrache last edited by
        @felsdrache
        trigger doch auf den ResponseDP:
          Felsdrache @DJMarc75 last edited by
          @djmarc75
            @felsdrache Das wäre am Thema vorbei ich möchte ja nicht immer reponcse triggern sondern warten bis mein Befehl mit reponce bestätigt wird
            F DJMarc75 2 Replies Last reply Reply Quote 0
              Felsdrache @Felsdrache last edited by Felsdrache
              @felsdrache Das wäre am Thema vorbei ich möchte ja nicht immer reponcse triggern sondern warten bis mein Befehl mit reponce bestätigt wird.
              Der Grosche fällt ja so kannn es gehen. Danke
              • DJMarc75
                Was genau ? Du setzt ja den Befehl irgendwie manuell ab - und wenn dann als Ergebnis "succesfull" kommt ist doch alles gut 🙂
                  Felsdrache @DJMarc75 last edited by Felsdrache
                  @djmarc75
                  Nein ich setzte mit einem script einen Befehl über ssh ab. und warte zurzeit eine Zeit x ab und dann den nächsten Befehl.
                  Das geht aber ist natürlich handwerklich falsch. und ich würde es jetzt gerne richtig machen.
                  Das ist wohl so besser
                  • OliverIO
                    OliverIO @Felsdrache last edited by
                    @felsdrache
                    programme unter linux geben als ergebnis einen sogenannten errorlevel/exit codes zurück
                    0 ist alles ok
                    1 ist fehlerhaft
                    dann gibt es noch ein paar reservierte codes und sonst könnte der programmierer auch noch benutzer spezifische codes zurückgeben. der code wird normalerweise nicht mit ausgegeben.
                    welche es sonst noch gibt, müsste in der jeweiligen man dokumentation liegen
                    wenn befehle mit ssh ausgeführt werden, dann gibt ssh den code des letzen befehls zurück
                    mit ssh hab ich das selbst noch nicht ausprobiert, aber damit kannst du in die richtige richtung recherchieren.
                    hier ein kleines tutorial
                    https://shapeshed.com/unix-exit-codes/
                      Felsdrache @OliverIO last edited by
                      @oliverio
                      Ja Oliver aber ich gebe dem execute Command ein wahr uund möchte dann warten bis responce command mir ein successful zurück gibt. ich weiß nur nicht wie ich das über blockly anstellen soll.
                        @felsdrache
                        So klappt es dann
                        492
