    4. Test Adapter minuvis 2.x
      flisse last edited by flisse
      Ich bekomme grad leider gar nicht erst eine Instanz installiert von dem Adapter. Ich hatte die Instanz damals, als es Probleme gab wieder entfernt.
      Hier mal die Logs:
      $ iobroker add minuaru auto --host ioBroker --debug
      NPM version: 10.7.0
      Installing iobroker.minuaru@1.1.0... (System call)
      npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
      > better-sqlite3@7.6.2 install
      > prebuild-install || npm run build-release
      prebuild-install warn install No prebuilt binaries found (target=20.15.0 runtime=node arch=x64 libc= platform=linux)
      > better-sqlite3@7.6.2 build-release> node-gyp rebuild --release
      gyp info it worked if it ends with ok
      gyp info using node-gyp@10.1.0gyp info using node@20.15.0 | linux | x64
      gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"
      gyp info spawn /usr/bin/python3
      gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/better-sqlite3/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.15.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.15.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.15.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/better-sqlite3',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
      gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      ACTION deps_sqlite3_gyp_locate_sqlite3_target_copy_builtin_sqlite3 ba23eeee118cd63e16015df367567cb043fed872.intermediate
      TOUCH Release/obj.target/deps/locate_sqlite3.stamp
      CC(target) Release/obj.target/sqlite3/gen/sqlite3/sqlite3.o
      rm -f Release/obj.target/deps/sqlite3.a Release/obj.target/deps/sqlite3.a.ar-file-list; mkdir -p `dirname Release/obj.target/deps/sqlite3.a`
      CXX(target) Release/obj.target/better_sqlite3/src/better_sqlite3.o
      In file included from ./src/better_sqlite3.lzz:11,
      ./src/util/macros.lzz: In function 'void SetPrototypeGetter(v8::Isolate*, v8::Local<v8::External>, v8::Local<v8::FunctionTemplate>, const char*, v8::AccessorGetterCallback)':./src/util/macros.lzz:157:21: error: 'v8::AccessorSignature' has not been declared
      ./src/util/binder.lzz: In static member function 'static bool Binder::IsPlainObject(v8::Isolate*, v8::Local<v8::Object>)':./src/util/binder.lzz:37:51: error: 'class v8::Object' has no member named 'CreationContext'; did you mean 'GetCreationContext'?
      ./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_stmt*, int, bool)':./src/util/data.lzz:73:92: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:73:197: note: here
      ./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_value*, bool)':./src/util/data.lzz:77:81: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:77:175: note: here
      make: *** [better_sqlite3.target.mk:120: Release/obj.target/better_sqlite3/src/better_sqlite3.o] Error 1rm ba23eeee118cd63e16015df367567cb043fed872.intermediatemake: Leaving directory '/opt/iobroker/node_modules/better-sqlite3/build'
      gyp ERR! not ok
      npm error code 1npm error path /opt/iobroker/node_modules/better-sqlite3
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-08T18_41_17_515Z-debug-0.log
      npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fsprebuild-install warn install No prebuilt binaries found (target=20.15.0 runtime=node arch=x64 libc= platform=linux)gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.15.0 | linux | x64gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/better-sqlite3/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.15.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.15.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.15.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/better-sqlite3',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]In file included from ./src/better_sqlite3.lzz:11, from ../src/better_sqlite3.cpp:4:/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1248:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>)' to 'node::addon_context_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>, void*)'} [-Wcast-function-type] 1248 | (node::addon_context_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1266:3: note: in expansion of macro 'NODE_MODULE_CONTEXT_AWARE_X' 1266 | NODE_MODULE_CONTEXT_AWARE_X(modname, regfunc, NULL, 0) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1297:3: note: in expansion of macro 'NODE_MODULE_CONTEXT_AWARE' 1297 | NODE_MODULE_CONTEXT_AWARE(NODE_GYP_MODULE_NAME, \ | ^~~~~~~~~~~~~~~~~~~~~~~~~./src/better_sqlite3.lzz:67:1: note: in expansion of macro 'NODE_MODULE_INIT'./src/util/macros.lzz: In function 'void SetPrototypeGetter(v8::Isolate*, v8::Local<v8::External>, v8::Local<v8::FunctionTemplate>, const char*, v8::AccessorGetterCallback)':./src/util/macros.lzz:157:21: error: 'v8::AccessorSignature' has not been declared./src/util/binder.lzz: In static member function 'static bool Binder::IsPlainObject(v8::Isolate*, v8::Local<v8::Object>)':./src/util/binder.lzz:37:51: error: 'class v8::Object' has no member named 'CreationContext'; did you mean 'GetCreationContext'?./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_stmt*, int, bool)':./src/util/data.lzz:73:92: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:73:197: note: here./src/util/data.lzz: In function 'v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_value*, bool)':./src/util/data.lzz:77:81: warning: this statement may fall through [-Wimplicit-fallthrough=]./src/util/data.lzz:77:175: note: heremake: *** [better_sqlite3.target.mk:120: Release/obj.target/better_sqlite3/src/better_sqlite3.o] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.8.8-1-pvegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--release"gyp ERR! cwd /opt/iobroker/node_modules/better-sqlite3gyp ERR! node -v v20.15.0gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/better-sqlite3npm error command failednpm error command sh -c prebuild-install || npm run build-releasenpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-08T18_41_17_515Z-debug-0.log
      host.ioBroker Cannot install iobroker.minuaru@1.1.0: 1
      ERROR: Process exited with code 25
      mcm1957 Thomas Braun SVallant 3 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @flisse last edited by
        @flisse said in Test Adapter minuvis 2.x:
        Hier mal die Logs:
        NPM version: 10.7.0
        gyp ERR! not ok
        Bist du auf Windows?
        Dann fehlen dir wahrscheinlich die build Tools.
        Hab im Moment nur Handy .. hoff es können andere bei Bedarf genauer helfen. Sonst bitte im Forum od auf Google suchen
          flisse @mcm1957 last edited by
          @mcm1957
          Andere Adapter oder Instanzen kann ich problemlos installieren.
          Mein ioBroker läuft als lxc-Container auf Proxmox.
          • mcm1957
            @flisse
            Ok
            Dann vergiss mal meinen Input.
              Thomas Braun Most Active @flisse last edited by
              @flisse
              Hier baut es auch nicht.
              Da scheint sqlite aus den Sourcen gebaut zu werden, ich kapier aber gerade nicht was da alles fehlt. Und ein aktuelles python 3.12 wird wohl auch empfohlen.
              Es springt hier jedenfalls mit diesen Meldungen aus dem Gleis:
              iobroker add minuaru auto --debug
              NPM version: 10.7.0
              prebuild-install warn install No prebuilt binaries found (target=20.15.0 runtime=node arch=arm64 libc= platform=linux)
              gyp info using node@20.15.0 | linux | arm64
              gyp info find Python using Python version 3.12.4 found at "/usr/bin/python3"
              gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
              gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',
              gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
              gyp info spawn make
              make: Entering directory '/opt/iobroker/node_modules/better-sqlite3/build'
                TOUCH ba23eeee118cd63e16015df367567cb043fed872.intermediate
              ar crs Release/obj.target/deps/sqlite3.a @Release/obj.target/deps/sqlite3.a.ar-file-list
                COPY Release/sqlite3.a
              /home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1248:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>)’ to ‘node::addon_context_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Context>, void*)’} [-Wcast-function-type]
              /home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1266:3: note: in expansion of macro ‘NODE_MODULE_CONTEXT_AWARE_X’
              /home/iobroker/.cache/node-gyp/20.15.0/include/node/node.h:1297:3: note: in expansion of macro ‘NODE_MODULE_CONTEXT_AWARE’
              ./src/better_sqlite3.lzz:67:1: note: in expansion of macro ‘NODE_MODULE_INIT’
              ./src/util/macros.lzz: In function ‘void SetPrototypeGetter(v8::Isolate*, v8::Local<v8::External>, v8::Local<v8::FunctionTemplate>, const char*, v8::AccessorGetterCallback)’:
              ./src/util/macros.lzz:157:21: error: ‘v8::AccessorSignature’ has not been declared
              ./src/util/binder.lzz: In static member function ‘static bool Binder::IsPlainObject(v8::Isolate*, v8::Local<v8::Object>)’:
              ./src/util/binder.lzz:37:51: error: ‘class v8::Object’ has no member named ‘CreationContext’; did you mean ‘GetCreationContext’?
              ./src/util/data.lzz: In function ‘v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_stmt*, int, bool)’:
              ./src/util/data.lzz: In function ‘v8::Local<v8::Value> Data::GetValueJS(v8::Isolate*, sqlite3_value*, bool)’:
              make: *** [better_sqlite3.target.mk:118: Release/obj.target/better_sqlite3/src/better_sqlite3.o] Error 1
              gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-gyp/lib/build.js:209:23)
              gyp ERR! System Linux 6.6.31+rpt-rpi-v8
              gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild" "--release"
              gyp ERR! not ok
              npm error code 1
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-08T19_10_46_128Z-debug-0.log
              gyp info spawn make
              gyp ERR! not ok
              npm error code 1
              host.chet Cannot install iobroker.minuaru@1.1.0: 1
              • mcm1957
                mcm1957 @Thomas Braun last edited by
                @Homoran
                Kann eigentlich wer erklären warum der Adapter.minuaru im topic zu minuvis diskutiert wird???
                Ev wär da Abspaltung angesagt..
                Homoran SVallant 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @mcm1957 last edited by
                  @mcm1957 sagte in Test Adapter minuvis 2.x:
                  ist etwa hier https://forum.iobroker.net/post/1156123 reingerutscht.
                  ich hatte den Eindruck das gehört zusammen
                  • SVallant
                    SVallant @mcm1957 last edited by
                    @mcm1957 Gibt es dafür eine Funktion oder einfach neuer Thread ?
                    • SVallant
                      SVallant @flisse last edited by
                      @flisse beim SQL-Adapter https://github.com/ioBroker/ioBroker.sql habe ich das gefunden:
                      *SQLite DB must not be installed extra. It is just a file on disk, but to install it you require build tools on your system. For linux, just write:
                      sudo apt-get install build-essential
                      For windows:
                      c:>npm install --global --production windows-build-tools*
                      Vielleicht fehlt dir das ....
                        Thomas Braun Most Active @SVallant last edited by
                        @svallant
                        Nein, das ist es nicht.
                        Denn:
                        echad@chet:~ $ apt policy build-essential
                        build-essential:
                          Installed: 12.10
                          Candidate: 12.10
                          Version table:
                         *** 12.10 500
                                500 http://deb.debian.org/debian trixie/main arm64 Packages
                                100 /var/lib/dpkg/status
                        echad@chet:~ $
                        • mcm1957
                          Der Vollständigkeit halber möchte ich darauf hinweisen dass der Adapter minuvis seit längerem keine Updstes mehr erhalten hat. Weiters hat der Adspter (noch) nicht das minimale Guthub basierte Testing eingebunden.
                            @SVallant
                            Wir der Adapter denn noch weiterentwickelt?
                            SVallant 1 Reply Last reply Reply Quote 0
                            • SVallant
                              @flisse Moin, ja. Aber derzeit funktioniert bei minuvis alles ohne Probleme. Ein Update der Abhängigkeiten und der Tests wird es diesen Winter geben
                              31.7k
                              79.8k
                              visualisation visualisierung
                              15
                              125
                              10977
