Beim Update einiger Adapter- "admin" not found
@line da hats dir wohl einige (?) Dateien beim Updateversuch zerschossen oder unvollständig hinterlassen.
erste Maßnahme wöre für mich mal zu versuchen den admin neu zu installieren mit
iob install admin
, und dabei zu sehen welche Meldungen kommenhier hat das Betriebssystem versucht den Schaden zu flicken
@line sagte in Beim Update einiger Adapter- "admin" not found:Tue Jul 9 11:31:00 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[Tue -
Ich habe den admin versucht zu installieren$ iob install admin NPM version: 10.7.0 Installing iobroker.admin@6.17.14... (System call) added 12 packages, and changed 33 packages in 24s 260 packages are looking for funding run `npm fund` for details host.raspberrypi install adapter admin upload [53] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.bdd08e35.chunk.js custom/static/js/node_modules_react_index_js.bdd08e35.chunk.js application/javascript upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 host.raspberrypi object system.adapter.admin created/updated $ iobroker start $ iobroker upgrade Cannot check dependencies: Required dependency "admin" not found. Cannot check dependencies: Required dependency "admin" not found. Cannot check dependencies: Required dependency "admin" not found.
Aber leider keine Verbesserung
[Tue Jul 9 11:31:00 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[Tue Jul 9 11:31:01 2024] EXT4-fs (mmcblk0p2): recovery completetausch die SD-Karte und installiere gleich Debian 12 (Bookworm 64 Bit lite ohne Desktop). Alle anderen Versuche werden gleich oder in einigen Tagen (wieder) scheitern.
Ro75.
@ro75 das kann durch die Schreibversuche bei voller Karte verursacht worden srin.
Es sind noch keine Orphans dabei gewesen. -
Und vielleicht auch gleich eine größere SD-Karte. 32GB bei alleine schon 15GB an Influxdb wird auf Dauer sehr knapp.
Ro75.
@ro75
Also dann besorge ich eine größere SD Karte.
Installiere alles neu.
Woher weiß ich wo mein Backup vom iobroker/vis liegt?
Danke -
Das lieg da, wo du es hinlegst. Kann man z. B. im Backitup-Adapter ja alles einstellen.
Mein ioBroker Oberfläche startet ja nicht mehr - von dem her kann ich den Adapter nicht mehr einsehen.Wenn ich ihn starte kommt:
$ iobroker status iobroker is running on this host. Objects type: jsonl States type: jsonl
Sieht alles gut aus, aber die Webseite kann ich trotzdem nicht öffnen.
Gibt es irgendwo eine Anleitung, wie ich die Daten von der alten SD Karte auf die Neu übertrage - mit restore von dem Backup.
Hast du denn was diesbezüglich eingestellt? Ein NAS oder sowas?
Ansonsten liegt das in /opt/iobroker/backupsProbier mal:
iob stop iob nodejs-update 20 iob stop sudo reboot
dann dürfte der admin noch nicht richtig laufen.
was sagt
iob diag
in der Langfassung?ggf. später nochmal iob drüber installieren. Das könnte noch einiges zurechtbiegen.
Aber so richtig vertrauenswürdig ist die Installation nicht mehr. -
Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 10:33:41 up 9 min, 2 users, load average: 0.58, 0.52, 0.44 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Wed 2024-07-10 10:33:41 CEST Universal time: Wed 2024-07-10 08:33:41 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': feline XDG_CONFIG_HOME=/home/feline2/.config HOME=/home/feline GROUPS=feline adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** Display-Server-Setup *** Display-Server: true Desktop: LXDE-pi Terminal: x11 Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 1.1G 5.6G 39M 1.2G 6.6G Swap: 99M 0B 99M Total: 7.9G 1.1G 5.7G Active iob-Instances: 8 7812 M total memory 1064 M used memory 1599 M active memory 479 M inactive memory 5570 M free memory 81 M buffer memory 1096 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 10:33:41 up 9 min, 2 users, load average: 0.58, 0.52, 0.44 Tasks: 228 total, 1 running, 227 sleeping, 0 stopped, 0 zombie %Cpu(s): 4.1 us, 2.7 sy, 0.0 ni, 93.2 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7812.3 total, 5570.5 free, 1063.8 used, 1178.0 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 6587.5 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 25G 3.1G 90% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 9.3M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 31M 225M 13% /boot tmpfs tmpfs 782M 28K 782M 1% /run/user/1000 tmpfs tmpfs 782M 28K 782M 1% /run/user/1002 Messages concerning ext4 filesystem in dmesg: [Wed Jul 10 10:23:42 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:38:62:0F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=b4c0fa64-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Wed Jul 10 10:23:43 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Wed Jul 10 10:23:43 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Wed Jul 10 10:23:45 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/dev devtmpfs devtmpfs rw,relatime,size=3735680k,nr_inodes=933920,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime | |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime | `-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | |-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000 | | `-/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 | `-/run/user/1002 tmpfs tmpfs rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1002,gid=1002 | `-/run/user/1002/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1002,group_id=1002 |-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro `-/home/feline2/thinclient_drives xrdp-chansrv fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1002,group_id=1002 Files in neuralgic directories: /var: 15G /var/lib 15G /var/ 14G /var/lib/influxdb/.influxdbv2/engine/data/e0d96cc0acf064a1/autogen 14G /var/lib/influxdb/.influxdbv2/engine/data/e0d96cc0acf064a1 14G /var/lib/influxdb/.influxdbv2/engine/data Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 246M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 579M /opt/iobroker/iobroker-data/ 485M /opt/iobroker/iobroker-data/files 138M /opt/iobroker/iobroker-data/files/javascript.admin 118M /opt/iobroker/iobroker-data/files/javascript.admin/static 117M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 38M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 26M /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 22M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v20.15.1 /usr/bin/node v20.15.1 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.1 nodejs: Installed: 20.15.1-1nodesource1 Candidate: 20.15.1-1nodesource1 Version table: *** 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.19 admin: 6.17.14 javascript: 8.3.1 nodejs modules from github: 6 +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#56a18d0b76c2acd8e180936cfb01cb63962fbc48) +-- iobroker.openligadb@1.3.4 (git+ssh://git@github.com/oweitman/ioBroker.openligadb.git#00633f9e8372a8e9304938f67f0efaed6bb553e8) +-- iobroker.tesla-motors@1.4.5 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.tesla-motors.git#6c5dd71e896fbd8ff65fb015df0ed182f980871f) +-- iobroker.vis-material-webfont@0.0.3 (git+ssh://git@github.com/om2804/ioBroker.vis-material-webfont.git#c65fcdf49533dc28d70ae074035b6a260e323401) +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92) `-- my-muell-ical@0.1.0 (git+ssh://git@github.com/benzman81/my-muell-ical.git#1c13794503ead416b1b5739222214e9cfbdc262b) Adapter State + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled, compact disabled system.adapter.apple-find-me.0 : apple-find-me : raspberrypi - disabled, compact disabled system.adapter.backitup.0 : backitup : raspberrypi - enabled, compact disabled system.adapter.ble.0 : ble : raspberrypi - disabled system.adapter.daswetter.0 : daswetter : raspberrypi - disabled, compact disabled system.adapter.denon.0 : denon : raspberrypi - disabled, compact disabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled, compact disabled system.adapter.dwd.0 : dwd : raspberrypi - disabled, compact disabled system.adapter.energiefluss.0 : energiefluss : raspberrypi - enabled, compact disabled + system.adapter.evcc.0 : evcc : raspberrypi - enabled, compact disabled, port: 7070 system.adapter.flot.0 : flot : raspberrypi - enabled system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled, compact disabled system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - disabled, compact disabled system.adapter.history.0 : history : raspberrypi - enabled, compact disabled system.adapter.homeconnect.0 : homeconnect : raspberrypi - disabled, compact disabled system.adapter.ical.0 : ical : raspberrypi - enabled, compact disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - enabled system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, compact disabled, port: 8086 system.adapter.iot.0 : iot : raspberrypi - enabled, compact disabled system.adapter.javascript.0 : javascript : raspberrypi - enabled, compact disabled system.adapter.lgtv.0 : lgtv : raspberrypi - enabled, compact disabled system.adapter.mediola-gateway.0 : mediola-gateway : raspberrypi - enabled, compact disabled system.adapter.meross.0 : meross : raspberrypi - disabled, compact disabled system.adapter.modbus.0 : modbus : raspberrypi - disabled, compact disabled system.adapter.mqtt-client.0 : mqtt-client : raspberrypi - disabled, compact disabled, port: 1883 system.adapter.nuki-extended.0 : nuki-extended : raspberrypi - disabled, compact disabled system.adapter.nuki.0 : nuki : raspberrypi - disabled, compact disabled system.adapter.openligadb.0 : openligadb : raspberrypi - enabled, compact disabled system.adapter.parser.0 : parser : raspberrypi - disabled, compact disabled system.adapter.pegelalarm.0 : pegelalarm : raspberrypi - enabled, compact disabled + system.adapter.pollenflug.0 : pollenflug : raspberrypi - enabled, compact disabled system.adapter.radar2.0 : radar2 : raspberrypi - enabled + system.adapter.scenes.0 : scenes : raspberrypi - enabled, compact disabled system.adapter.shelly.0 : shelly : raspberrypi - enabled, compact disabled, port: 1882, bind: 192.168.178.69 system.adapter.shelly.1 : shelly : raspberrypi - enabled, compact disabled, port: 1882, bind: 0.0.0.0 system.adapter.socketio.0 : socketio : raspberrypi - enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.solaredge.0 : solaredge : raspberrypi - enabled, compact disabled system.adapter.tesla-motors.0 : tesla-motors : raspberrypi - enabled, compact disabled system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled, compact disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - enabled, compact disabled + system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled, compact disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspberrypi - enabled system.adapter.vis-map.0 : vis-map : raspberrypi - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : raspberrypi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - enabled, compact disabled system.adapter.vw-connect.0 : vw-connect : raspberrypi - disabled, compact disabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - enabled, compact disabled system.adapter.web.0 : web : raspberrypi - enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.yahka.0 : yahka : raspberrypi - enabled, compact disabled + instance is alive Enabled adapters with bindings + system.adapter.evcc.0 : evcc : raspberrypi - enabled, compact disabled, port: 7070 system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, compact disabled, port: 8086 system.adapter.shelly.0 : shelly : raspberrypi - enabled, compact disabled, port: 1882, bind: 192.168.178.69 system.adapter.shelly.1 : shelly : raspberrypi - enabled, compact disabled, port: 1882, bind: 0.0.0.0 system.adapter.socketio.0 : socketio : raspberrypi - enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.web.0 : web : raspberrypi - enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.17.14 , installed 6.17.14 Adapter "alexa2" : 3.26.5 , installed 3.26.5 Adapter "backitup" : 2.11.0 , installed 2.11.0 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "bshb" : 0.2.8 , installed 0.2.8 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "daswetter" : 3.1.15 , installed 3.1.15 Adapter "denon" : 1.15.5 , installed 1.15.5 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "deyeidc" : 0.0.14 , installed 0.0.14 Adapter "discovery" : 4.5.0 , installed 4.5.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "evcc" : 0.1.1 , installed 0.1.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.5.9 , installed 2.5.9 Adapter "fullybrowser" : 3.0.12 , installed 3.0.12 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homeconnect" : 1.4.0 , installed 1.4.0 Adapter "homekit-controller": 0.5.10, installed 0.5.10 Adapter "ical" : 1.15.0 , installed 1.15.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 3.3.0 , installed 3.3.0 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 8.3.1 , installed 8.3.1 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "lgtv" : 2.2.0 , installed 2.2.0 Adapter "mediola-gateway": 1.1.0 , installed 1.1.0 Adapter "meross" : 1.17.0 , installed 1.17.0 Adapter "modbus" : 6.2.3 , installed 6.1.0 [Updatable] Adapter "mqtt-client" : 1.8.0 , installed 1.8.0 Adapter "net-tools" : 1.0.11 , installed 1.0.11 Adapter "nuki" : 2.0.0 , installed 1.6.0 [Updatable] Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "openligadb" : 1.4.9 , installed 1.3.4 [Updatable] Adapter "parser" : 2.1.0 , installed 2.1.0 Adapter "pegelalarm" : 1.3.3 , installed 1.3.3 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "radar2" : 2.2.0 , installed 2.2.0 Adapter "scenes" : 3.0.4 , installed 3.0.4 Adapter "shelly" : 7.0.0 , installed 7.0.0 Adapter "shuttercontrol": 1.7.0 , installed 1.7.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.0 , installed 6.7.0 Adapter "solaredge" : 1.4.1 , installed 1.4.1 Adapter "solarmanpv" : 0.5.1 , installed 0.5.1 Adapter "solarviewdatareader": 1.0.8, installed 1.0.8 Adapter "tesla-motors" : 1.3.2 , installed 1.4.5 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "tvprogram" : 1.1.2 , installed 1.1.2 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-map" : 1.0.5 , installed 1.0.5 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.94 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.1 , installed 2.6.1 Adapter "yahka" : 1.0.3 , installed 1.0.3 Objects and States Please stand by - This may take a while Objects: 15545 States: 13107 *** OS-Repositories and Updates *** Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://security.debian.org/debian-security bullseye-security InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://packages.grafana.com/oss/deb stable InRelease Get:7 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B] Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease Fetched 5127 B in 2s (2566 B/s) Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 18201 1063/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 19549 1063/iobroker.js-co tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 12778 545/cupsd tcp 0 0 127.0.0.1:45421 0.0.0.0:* LISTEN 1001 22089 2978/io.yahka.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12142 596/sshd: /usr/sbin tcp6 0 0 ::1:3350 :::* LISTEN 0 12119 577/xrdp-sesman tcp6 0 0 :::34387 :::* LISTEN 1001 21320 2978/io.yahka.0 tcp6 0 0 :::4712 :::* LISTEN 116 16400 548/evcc tcp6 0 0 :::22 :::* LISTEN 0 12144 596/sshd: /usr/sbin tcp6 0 0 :::8086 :::* LISTEN 119 16652 557/influxd tcp6 0 0 :::3389 :::* LISTEN 117 12264 613/xrdp tcp6 0 0 :::3000 :::* LISTEN 120 18146 1058/grafana tcp6 0 0 :::7070 :::* LISTEN 116 12837 548/evcc tcp6 0 0 ::1:631 :::* LISTEN 0 12777 545/cupsd udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12809 478/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 14119 619/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 116 15405 548/evcc udp 0 0 0.0.0.0:5353 0.0.0.0:* 116 12834 548/evcc udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 12707 406/avahi-daemon: r udp 0 0 0.0.0.0:56872 0.0.0.0:* 108 12709 406/avahi-daemon: r udp6 0 0 :::42139 :::* 108 12710 406/avahi-daemon: r udp6 0 0 :::5353 :::* 116 15406 548/evcc udp6 0 0 :::5353 :::* 116 12835 548/evcc udp6 0 0 :::5353 :::* 108 12708 406/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-07-10 10:25:48.359 - info: pollenflug.0 (2963) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.pollenflug, node: v20.15.1, js-controller: 5.0.19 2024-07-10 10:25:48.382 - info: pollenflug.0 (2963) Starting Adapter pollenflug.0 in version 1.0.6 2024-07-10 10:25:48.409 - info: pollenflug.0 (2963) Requesting DWD pollen information now. 2024-07-10 10:25:49.850 - error: host.raspberrypi startInstance system.adapter.trashschedule.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found! 2024-07-10 10:25:50.499 - info: pollenflug.0 (2963) Next DWD pollen request starts on Wed Jul 10 2024 11:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-07-10 10:25:53.616 - info: alexa2.0 (2267) Initialization Done ... 2024-07-10 10:25:53.896 - info: host.raspberrypi instance system.adapter.yahka.0 started with pid 2978 2024-07-10 10:25:56.728 - info: yahka.0 (2978) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yahka, node: v20.15.1, js-controller: 5.0.19 2024-07-10 10:25:56.797 - info: yahka.0 (2978) adapter ready, checking config 2024-07-10 10:25:56.833 - info: yahka.0 (2978) adding Büro Licht with UUID: 68404733-0ee7-4d39-8189-b8a42e2bb7ec 2024-07-10 10:25:56.865 - info: yahka.0 (2978) adding Wohnzimmer Licht 1 with UUID: 34598146-1bec-4fe8-99f7-07b0fb0b37f9 2024-07-10 10:25:56.889 - info: yahka.0 (2978) adding Wohnzimmer Licht 2 with UUID: c5dcfd1c-c7ab-4d65-8c8e-f000a9c98d82 2024-07-10 10:25:56.899 - info: yahka.0 (2978) adding Markise with UUID: 3f32008f-6511-41be-8743-21d5efe935fd 2024-07-10 10:25:56.919 - info: yahka.0 (2978) adding Küche Licht with UUID: 3ef44851-a815-4b48-968f-97a3c392c47d 2024-07-10 10:25:56.928 - info: yahka.0 (2978) adding Bad Licht with UUID: ea9bbccf-39c1-4b21-a31d-d205af9f4440 2024-07-10 10:25:56.934 - info: yahka.0 (2978) adding Galerie Licht with UUID: 6f9d3f0e-2096-4950-ac9c-6afcd62e984d 2024-07-10 10:25:56.944 - info: yahka.0 (2978) adding Windfang Licht with UUID: 954b6670-6f54-42a2-bb47-726a8b64bfeb 2024-07-10 10:25:56.954 - info: yahka.0 (2978) adding Schlafzimmer Licht 1 with UUID: cb37b8d7-10bf-4c95-a3cc-bfffbc6e4221 2024-07-10 10:25:56.963 - info: yahka.0 (2978) adding Schlafzimmer Licht 2 with UUID: 1123330b-5285-487a-9e4a-5aaaca340db3 2024-07-10 10:25:56.969 - info: yahka.0 (2978) adding Rolladen Küche with UUID: 5e737590-77b1-4181-98cb-0f6d79b06fb3 2024-07-10 10:25:56.976 - info: yahka.0 (2978) publishing bridge Iobroker - Live on 0.0.0.0 using avahi 2024-07-10 10:25:57.851 - error: host.raspberrypi startInstance system.adapter.socketio.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found! 2024-07-10 10:26:01.962 - error: host.raspberrypi startInstance system.adapter.openligadb.0 Adapter dependency not fulfilled on "raspberrypi": required adapter "admin" not found! 2024-07-10 10:26:05.884 - error: host.raspberrypi startInstance system.adapter.fritzdect.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found! 2024-07-10 10:26:09.865 - error: host.raspberrypi startInstance system.adapter.tesla-motors.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found!
Anbei noch die Summary:
======================= SUMMARY ======================= v.2024-05-22 Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Installation: native Kernel: aarch64 Userland: 64 bit Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 Display-Server: true Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 3 Nodejs-Installation: /usr/bin/nodejs v20.15.1 /usr/bin/node v20.15.1 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.1 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.8G 1.1G 5.5G 39M 1.3G 6.5G Swap: 99M 0B 99M Total: 7.9G 1.1G 5.6G Active iob-Instances: 8 Active repo(s): stable ioBroker Core: js-controller 5.0.19 admin 6.17.14 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: system.adapter.web.0 : web : raspberrypi - enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 15545 States: 13107 Size of iob-Database: 16M /opt/iobroker/iobroker-data/objects.jsonl 5.3M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================
ok da sind in dem Fall die Backups - perfekt. Sie enden mit tar.gz.
Die VIS ist in dem Backup auch mit enthalten oder? -
nicht perfekt!
ist echt heftig!
und der admin ist noch immer nicht installiert
$ iob install admin adapter "admin" already installed. Use "upgrade" to upgrade to a newer version. $ iob update Used repository: stable Adapter "admin" : 6.17.14 , installed 6.17.14 Adapter "alexa2" : 3.26.5 , installed 3.26.5 Adapter "backitup" : 2.11.0 , installed 2.11.0 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "bshb" : 0.2.8 , installed 0.2.8 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "daswetter" : 3.1.15 , installed 3.1.15 Adapter "denon" : 1.15.5 , installed 1.15.5 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "deyeidc" : 0.0.14 , installed 0.0.14 Adapter "discovery" : 4.5.0 , installed 4.5.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "evcc" : 0.1.1 , installed 0.1.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.5.9 , installed 2.5.9 Adapter "fullybrowser" : 3.0.12 , installed 3.0.12 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homeconnect" : 1.4.0 , installed 1.4.0 Adapter "homekit-controller": 0.5.10, installed 0.5.10 Adapter "ical" : 1.15.0 , installed 1.15.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 3.3.0 , installed 3.3.0 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 8.3.1 , installed 8.3.1 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "lgtv" : 2.2.0 , installed 2.2.0 Adapter "mediola-gateway": 1.1.0 , installed 1.1.0 Adapter "meross" : 1.17.0 , installed 1.17.0 Adapter "modbus" : 6.2.3 , installed 6.1.0 [Updatable] Adapter "mqtt-client" : 1.8.0 , installed 1.8.0 Adapter "net-tools" : 1.0.11 , installed 1.0.11 Adapter "nuki" : 2.0.0 , installed 1.6.0 [Updatable] Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "openligadb" : 1.4.9 , installed 1.3.4 [Updatable] Adapter "parser" : 2.1.0 , installed 2.1.0 Adapter "pegelalarm" : 1.3.3 , installed 1.3.3 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "radar2" : 2.2.0 , installed 2.2.0 Adapter "scenes" : 3.0.4 , installed 3.0.4 Adapter "shelly" : 7.0.0 , installed 7.0.0 Adapter "shuttercontrol": 1.7.0 , installed 1.7.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.0 , installed 6.7.0 Adapter "solaredge" : 1.4.1 , installed 1.4.1 Adapter "solarmanpv" : 0.5.1 , installed 0.5.1 Adapter "solarviewdatareader": 1.0.8, installed 1.0.8 Adapter "tesla-motors" : 1.3.2 , installed 1.4.5 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "tvprogram" : 1.1.2 , installed 1.1.2 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-map" : 1.0.5 , installed 1.0.5 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.94 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.1 , installed 2.6.1 Adapter "yahka" : 1.0.3 , installed 1.0.3 $ iob upgrade all Cannot check dependencies: Required dependency "admin" not found. Cannot check dependencies: Required dependency "admin" not found. Cannot check dependencies: Required dependency "admin" not found. feline@raspberrypi:/home/feline2 $ iob add admin.0 host.raspberrypi create instance admin host.raspberrypi object system.adapter.admin.0.alive created host.raspberrypi object system.adapter.admin.0.connected created host.raspberrypi object system.adapter.admin.0.compactMode created host.raspberrypi object system.adapter.admin.0.cpu created host.raspberrypi object system.adapter.admin.0.cputime created host.raspberrypi object system.adapter.admin.0.memHeapUsed created host.raspberrypi object system.adapter.admin.0.memHeapTotal created host.raspberrypi object system.adapter.admin.0.memRss created host.raspberrypi object system.adapter.admin.0.uptime created host.raspberrypi object system.adapter.admin.0.inputCount created host.raspberrypi object system.adapter.admin.0.outputCount created host.raspberrypi object system.adapter.admin.0.eventLoopLag created host.raspberrypi object system.adapter.admin.0.sigKill created host.raspberrypi object system.adapter.admin.0.logLevel created host.raspberrypi object admin.0.info created host.raspberrypi object admin.0 created host.raspberrypi object admin.0.info.connected created host.raspberrypi object admin.0.info.connection created host.raspberrypi object admin.0.info.newsFeed created host.raspberrypi object admin.0.info.newsETag created host.raspberrypi object admin.0.info.newsLastId created host.raspberrypi object admin.0.info.updatesList created host.raspberrypi Set default value of admin.0.info.connected: host.raspberrypi Set default value of admin.0.info.connection: false host.raspberrypi Set default value of admin.0.info.updatesList: host.raspberrypi object system.adapter.admin.0 created So jetzt läuft er wieder - danke!
@homoran said in Beim Update einiger Adapter- "admin" not found:
nicht perfekt!
was soll das heißen? Kann ich mit dem backup mein Restore nicht anfangen?
Dann zieh jetzt ein aktuelles Backup und dann ziehst du damit auf ein NEUINSTALLIERTES
Raspberry OS 12 Lite 'Bookworm' (OHNE DESKTOP) in der 64Bit-Version um.
Auf einem größeren Datenträger dann. -
@thomas-braun alles klar - Danke! Ich hoffe, es klappt! Danke für eure Hilfe
das scheinen gefühlt hunderte zu sein!
nie aufgeräumt??
