    4. Z-Wave Adapter Problem
      RDevil63 last edited by
      ich bräuchte mal Hilfe.
      Habe Open-Zwave compiliert und kann den Adapter auch im Open-ZWave-Control Panel initialisieren und sehe meine Devices.
      Im iobroker gibt es beimHinzufügen des Adapters und auswählen des Devices folgenden Fehler.
      Kann mir da jemand weiterhelfen?
      host.raspberrypi	2018-03-22 16:48:58.514	info	Restart adapter system.adapter.zwave.0 because enabled
      host.raspberrypi	2018-03-22 16:48:58.514	error	instance system.adapter.zwave.0 terminated with code 0 (OK)
      Caught	2018-03-22 16:48:58.514	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      Caught	2018-03-22 16:48:58.514	error	by controller[0]: at Module._compile (module.js:577:32)
      Caught	2018-03-22 16:48:58.514	error	by controller[0]: at Object. (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
      Caught	2018-03-22 16:48:58.513	error	by controller[0]: at require (internal/module.js:20:19)
      Caught	2018-03-22 16:48:58.513	error	by controller[0]: at Module.require (module.js:504:17)
      Caught	2018-03-22 16:48:58.513	error	by controller[0]: at Function.Module._load (module.js:445:3)
      Caught	2018-03-22 16:48:58.513	error	by controller[0]: at tryModuleLoad (module.js:453:12)
      Caught	2018-03-22 16:48:58.513	error	by controller[0]: at Module.load (module.js:494:32)
      Caught	2018-03-22 16:48:58.513	error	by controller[0]: at Object.Module._extensions..node (module.js:604:18)
      Caught	2018-03-22 16:48:58.512	error	by controller[0]: at Error (native)
      Caught	2018-03-22 16:48:58.510	error	by controller[0]: Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0	2018-03-22 16:48:58.494	info	terminating
      zwave.0	2018-03-22 16:48:58.433	error	at Object.Module._extensions..js (module.js:586:10)
      zwave.0	2018-03-22 16:48:58.433	error	at Module._compile (module.js:577:32)
      zwave.0	2018-03-22 16:48:58.433	error	at Object. (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
      zwave.0	2018-03-22 16:48:58.433	error	at require (internal/module.js:20:19)
      zwave.0	2018-03-22 16:48:58.433	error	at Module.require (module.js:504:17)
      zwave.0	2018-03-22 16:48:58.433	error	at Function.Module._load (module.js:445:3)
      zwave.0	2018-03-22 16:48:58.433	error	at tryModuleLoad (module.js:453:12)
      zwave.0	2018-03-22 16:48:58.433	error	at Module.load (module.js:494:32)
      zwave.0	2018-03-22 16:48:58.433	error	at Object.Module._extensions..node (module.js:604:18)
      zwave.0	2018-03-22 16:48:58.433	error	at Error (native)
      zwave.0	2018-03-22 16:48:58.433	error	Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0	2018-03-22 16:48:58.430	error	uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0	2018-03-22 16:48:58.331	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v6.13.1
      host.raspberrypi	2018-03-22 16:48:56.830	info	instance system.adapter.zwave.0 started with pid 4622
        da fehlt der symlink
        machmal
        sudo ldconfig
          Problem gelöst,
          danke für die Info 😄
          • AlCalzone
            Nächstes Mal einen Blick in die Adapter-Anleitung werfen 😉
            Steht alles da: https://github.com/ioBroker/ioBroker.zw … stallation
              mrmomba last edited by
              Leider fehlen da zwei Kommandos unter den Known-Issue:
              Die Befehle müssen genau so abgesetzt werden, in der Reihenfolge.
              $ sudo ln -s /usr/local/lib64/libopenzwave.so /usr/local/lib/libopenzwave.so
              $ sudo ln -s /usr/local/lib64/libopenzwave.so.1.4 /usr/local/lib/libopenzwave.so.1.4
              $ sudo ldconfig
                @mrmomba:
                $ sudo ldconfig `
                dir ist klar das die Ordner nicht auf jedem System da sind.. ist dir klar was du da machst ?? oder hast das irgendwo mal gefunden ..
                auf meinem pi ist das total unfug da die /usr/local/lib64/ nicht da sind also was soll ich da als verlinkung reinstellen….
                  Nun,
                  so klar ist es mir nicht, aber es war die Lösung für mein Ubuntu auf dem x64.
                  Alles andere aus der Anleitung brachte bei mir keine Lösung.
                  Es sollte zumindest irgendwo stehen - der Hinweis kommt von der OpenZwave-Seite…
                    und da sind wir wieder bei Systemspezifikationen….
                    • AlCalzone
                      @mrmomba:
                      Es sollte zumindest irgendwo stehen - der Hinweis kommt von der OpenZwave-Seite… `
                      Danke. Für sowas bitte Github Issues erstellen, damit die richtigen Leute es auch sicher lesen. Habe das mal getan.
                        @AlCalzone:
                        @mrmomba:
                        Danke. Für sowas bitte Github Issues erstellen, damit die richtigen Leute es auch sicher lesen. Habe das mal getan. `
                        Ich muss gestehen, ich bin ein Git-Hub-Dau und ich müsste mich registrieren.
                        3356
