    4. Beta Test js-controller Kiera (v6.0)
    • Feuersturm
      Feuersturm @foxriver76 last edited by
      @foxriver76
      Update vom Master mit Admin 7.0.9 und js-controller Update von 6.0.5 auf 6.0.6
      Auch mit Admin 7.0.9 bleibt am Ende vom js-controller Update auf 6.0.6 das hier stehen:
      Nach einiger Zeit startet Admin neu und das System fährt hoch.
      Im Log steht noch folgendes:
      2024-07-02 20:47:42.171 - info: host.ioBrokerTestsystem instance system.adapter.radar-trap.0 terminated with code 0 (NO_ERROR)
      2024-07-02 20:47:42.174 - info: host.ioBrokerTestsystem instance system.adapter.worx.0 terminated with code 0 (NO_ERROR)
      2024-07-02 20:47:42.177 - info: host.ioBrokerTestsystem All instances are stopped.
      2024-07-02 20:47:42.848 - warn: host.ioBrokerTestsystem instance system.adapter.hm-rega.0 terminated due to SIGKILL
      2024-07-02 20:47:42.851 - info: host.ioBrokerTestsystem instance system.adapter.hm-rega.0 terminated with code null ()
      2024-07-02 20:47:42.854 - info: host.ioBrokerTestsystem All instances are stopped.
      2024-07-02 20:47:42.934 - warn: host.ioBrokerTestsystem instance system.adapter.hue.0 terminated due to SIGKILL
      2024-07-02 20:47:42.937 - info: host.ioBrokerTestsystem instance system.adapter.hue.0 terminated with code null ()
      2024-07-02 20:47:42.940 - info: host.ioBrokerTestsystem All instances are stopped.
      2024-07-02 20:47:42.942 - warn: host.ioBrokerTestsystem instance system.adapter.samsung.0 terminated due to SIGKILL
      2024-07-02 20:47:42.945 - info: host.ioBrokerTestsystem instance system.adapter.samsung.0 terminated with code null ()
      2024-07-02 20:47:42.947 - info: host.ioBrokerTestsystem All instances are stopped.
      2024-07-02 20:47:43.035 - warn: host.ioBrokerTestsystem instance system.adapter.web.0 terminated due to SIGKILL
      2024-07-02 20:47:43.037 - info: host.ioBrokerTestsystem instance system.adapter.web.0 terminated with code null ()
      2024-07-02 20:47:43.039 - info: host.ioBrokerTestsystem All instances are stopped.
      2024-07-02 20:47:43.113 - warn: host.ioBrokerTestsystem instance system.adapter.echarts.0 terminated due to SIGKILL
      2024-07-02 20:47:43.116 - info: host.ioBrokerTestsystem instance system.adapter.echarts.0 terminated with code null ()
      2024-07-02 20:47:43.118 - info: host.ioBrokerTestsystem All instances are stopped.
      2024-07-02 20:47:43.122 - error: host.ioBrokerTestsystem Caught by controller[0]: Error: DB closed
      2024-07-02 20:47:43.124 - error: host.ioBrokerTestsystem Caught by controller[0]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
      2024-07-02 20:47:43.127 - error: host.ioBrokerTestsystem Caught by controller[0]: at Redis.setex (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
      2024-07-02 20:47:43.129 - error: host.ioBrokerTestsystem Caught by controller[0]: at StateRedisClient.setSession (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1403:31)
      2024-07-02 20:47:43.132 - error: host.ioBrokerTestsystem Caught by controller[0]: at Admin._setSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1400:22)
      2024-07-02 20:47:43.135 - error: host.ioBrokerTestsystem Caught by controller[0]: at Admin.setSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1390:21)
      2024-07-02 20:47:43.137 - error: host.ioBrokerTestsystem Caught by controller[0]: at AdapterStore.set (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/session.ts:73:26)
      2024-07-02 20:47:43.140 - error: host.ioBrokerTestsystem Caught by controller[0]: at Session.save (/opt/iobroker/node_modules/express-session/session/session.js:72:25)
      2024-07-02 20:47:43.143 - error: host.ioBrokerTestsystem Caught by controller[0]: at Session.save (/opt/iobroker/node_modules/express-session/index.js:414:15)
      2024-07-02 20:47:43.146 - error: host.ioBrokerTestsystem Caught by controller[0]: at ServerResponse.end (/opt/iobroker/node_modules/express-session/index.js:343:21)
      2024-07-02 20:47:43.149 - error: host.ioBrokerTestsystem Caught by controller[0]: at ServerResponse.send (/opt/iobroker/node_modules/express/lib/response.js:233:10)
      2024-07-02 20:47:43.151 - warn: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated due to SIGKILL
      2024-07-02 20:47:43.153 - info: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated with code null ()
      2024-07-02 20:47:43.156 - info: host.ioBrokerTestsystem All instances are stopped.
      2024-07-02 20:47:43.280 - info: host.ioBrokerTestsystem terminated
      2024-07-02 20:47:47.578 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
      2024-07-02 20:47:47.597 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
      2024-07-02 20:49:06.766 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Final information delivered
      2024-07-02 20:49:06.889 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
      2024-07-02 20:49:11.056 - info: host.ioBrokerTestsystem iobroker.js-controller version 6.0.6 js-controller starting
      2024-07-02 20:49:11.073 - info: host.ioBrokerTestsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2024-07-02 20:49:11.078 - info: host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v18.20.3
      2024-07-02 20:49:11.083 - info: host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
      2024-07-02 20:49:15.013 - info: host.ioBrokerTestsystem connected to Objects and States
      2024-07-02 20:49:15.058 - info: host.ioBrokerTestsystem added notifications configuration of host
      2024-07-02 20:49:16.840 - info: host.ioBrokerTestsystem 65 instances found
      2024-07-02 20:49:16.951 - info: host.ioBrokerTestsystem starting 33 instances
      • UweRLP
        UweRLP @Gaspode last edited by
        @gaspode sagte in Beta Test js-controller Kiera (v6.0):
        @uwerlp said in Beta Test js-controller Kiera (v6.0):
        Wäre es möglich das dieses Kommando ioBroker nicht startet? Wenn ich den Aufrufe dann habe ich Wartungsarbeiten an Windows/Software durchgeführt und der Rechner wird im Nachgang neu gestartet dazu stoppe ich IOB erst wieder.
        Beim Windows Neustart werden ja sowieso alle Services gestoppt, insofern schadet es nicht, wenn ioBroker läuft.
        Ich habe leider die Erfahrung machen müssen das ioBroker sich nicht immer vollständig beendet, zumindest mit iobroker stop, selbst mit js-controller 6.x besteht das Problem noch.
        Wollen wir hoffen das es bei einem Neustart von Windows anderst ist 🙂
        Ich plädiere also dafür, das zu lassen wie es ist.
        Alles gut, war nur ne' Frage 😊
          apollon77 @UweRLP last edited by
          @uwerlp Hast Du dazu mehr Details? ALso unter Linux passiert das nicht. Wäre dann super mal ein Log davon zu sehen als Issue im GitHub mit der Info was denn noch lief
          UweRLP 1 Reply Last reply Reply Quote 0
          • UweRLP
            UweRLP @apollon77 last edited by
            @apollon77 Leider nicht wirklich mehr Details.
            Ich habe den Eindruck, dass der javascript Adapter (ja meine den Script Adapter) beendet wird bei iob stop aber dann wieder neu startet. Ist dies der Fall dann werden auch die anderen Adapter nicht gestoppt. Kann man sehr schön über den Windows Taskmanager verfolgen, die Auslastung des Systems geht dann auch hoch.
            Wenn ich nach einem iob stop feststelle, dass sich ioBroker nicht beendet dann schicke ich einen iob stop javascript hinterher, dann werden auch alle anderen Adapter beendet.
            Leider passiert das häufig aber nicht immer, gerade habe ich ioBroker gestoppt und dieser wurde einwandfrei beendet.
            Welches Log ist dann für dich interessant? Wenn ich nächstes mal auf das Problem stoße werde ich in GitHub ein Issue auf machen.
              @uwerlp sagte in Beta Test js-controller Kiera (v6.0):
              Der Shutdown Prozess sollte an sich dinge loggen, also /opt/iobroker/log/...
              Gaspode UweRLP 2 Replies Last reply Reply Quote 0
              • Gaspode
                Gaspode @apollon77 last edited by
                @apollon77 said in Beta Test js-controller Kiera (v6.0):
                Unter Windows wird da leider wenig bis nix gelogged, @mcm1957 hat dafür mal ein Issue geschrieben:
                https://github.com/ioBroker/ioBroker.js-controller/issues/2764
                Das Verhalten, dass da einzelne Adapter Prozesse wieder gestartet werden, kenne ich nicht. Es kommt jedoch sehr selten vor, dass die Node-Prozesse nicht gestoppt werden. Ich hab da aber noch keine Systematik erkannt.
                mcm1957 created this issue in ioBroker/ioBroker.js-controller
                closed [enhancement]: graceful shutdown on windows #2764
                • UweRLP
                  @apollon77 sagte in Beta Test js-controller Kiera (v6.0):
                  Heute rein gestellt.
                  https://github.com/ioBroker/ioBroker.js-controller/issues/2834
                  UweRP created this issue in ioBroker/ioBroker.js-controller
                  closed [bug]: iob beendet sich nicht immer unter Windows #2834
                  Gaspode 1 Reply Last reply Reply Quote 0
                  • UweRLP
                    Beim javascript Adapter ist es bei mir halt auffällig da zum start des Adapters Blocklys gestartet werden.
                    • Feuersturm
                      Feuersturm last edited by Feuersturm
                      @foxriver76 Ich weiß nicht ob dieses Thema ein js-controller oder admin Thema ist.
                      Ich habe Admin heute auf 7.0.12 aktualisiert. Changelog von 7.0.12: " (bluefox) Changed a recommended node.js version from 18 to 20"
                      Durch Zufall hab ich auf der Übersichtsseite vom Admin diesen kleinen Updatebutton gefunden
                      Todesmutig draufgedrückt kommt die Meldung
                      Nach Bestätigung passiert Magie im Hintergrund. So sieht das log aus:
                      2024-07-10 20:30:23.899 - info: dwd.0 (16439) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.3, js-controller: 6.0.6
                      2024-07-10 20:30:24.529 - info: host.ioBrokerTestsystem instance system.adapter.ical.5 having pid 16378 terminated with code 0 (NO_ERROR)
                      2024-07-10 20:30:25.561 - info: dwd.0 (16439) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-07-10 20:30:26.233 - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 having pid 16439 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-07-10 20:30:52.692 - info: host.ioBrokerTestsystem Restart js-controller because desired after package upgrade
                      2024-07-10 20:30:53.099 - info: host.ioBrokerTestsystem received SIGTERM
                      2024-07-10 20:30:53.183 - info: hm-rpc.0 (440) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
                      2024-07-10 20:30:53.166 - info: backitup.0 (400) cleaned everything up...
                      2024-07-10 20:30:53.236 - info: hm-rpc.0 (440) Disconnected
                      2024-07-10 20:30:53.261 - info: admin.0 (16303) terminating http server on port 8081
                      2024-07-10 20:30:53.225 - info: unifi.0 (517) cleaned everything up...
                      2024-07-10 20:30:53.329 - info: trashschedule.0 (594) cleaned everything up...
                      2024-07-10 20:30:53.319 - warn: web.0 (683) setTimeout called, but adapter is shutting down
                      2024-07-10 20:30:53.376 - info: javascript.0 (351) Stopping script script.js.Skripte.Kalender.muellkalender
                      2024-07-10 20:30:53.345 - info: vis-inventwo.0 (646) cleaned everything up...
                      2024-07-10 20:30:53.298 - info: valloxmv.0 (609) cleaned everything up...
                      2024-07-10 20:30:53.243 - info: device-watcher.0 (407) cleaned everything up...
                      2024-07-10 20:30:53.110 - info: host.ioBrokerTestsystem stopInstance system.adapter.admin.0 (force=false, process=true)
                      2024-07-10 20:30:53.114 - info: host.ioBrokerTestsystem stopInstance system.adapter.influxdb.0 (force=false, process=true)
                      2024-07-10 20:30:53.120 - info: host.ioBrokerTestsystem stopInstance system.adapter.javascript.0 (force=false, process=true)
                      2024-07-10 20:30:53.125 - info: host.ioBrokerTestsystem stopInstance system.adapter.scenes.0 (force=false, process=true)
                      2024-07-10 20:30:53.128 - info: host.ioBrokerTestsystem stopInstance system.adapter.scheduler.0 (force=false, process=true)
                      2024-07-10 20:30:53.132 - info: host.ioBrokerTestsystem stopInstance system.adapter.telegram.0 (force=false, process=false)
                      2024-07-10 20:30:53.140 - info: host.ioBrokerTestsystem stopInstance system.adapter.backitup.0 (force=false, process=true)
                      2024-07-10 20:30:53.144 - info: host.ioBrokerTestsystem stopInstance system.adapter.device-watcher.0 (force=false, process=true)
                      2024-07-10 20:30:53.148 - info: host.ioBrokerTestsystem stopInstance system.adapter.fritzbox.0 (force=false, process=true)
                      2024-07-10 20:30:53.152 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rega.0 (force=false, process=true)
                      2024-07-10 20:30:53.156 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
                      2024-07-10 20:30:53.160 - info: host.ioBrokerTestsystem stopInstance system.adapter.hue.0 (force=false, process=true)
                      2024-07-10 20:30:53.166 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.0 (force=false, process=false)
                      2024-07-10 20:30:53.180 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.1 (force=false, process=false)
                      2024-07-10 20:30:53.399 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.2 (force=false, process=false)
                      2024-07-10 20:30:53.469 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.3 (force=false, process=false)
                      2024-07-10 20:30:53.517 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.4 (force=false, process=false)
                      2024-07-10 20:30:53.533 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.5 (force=false, process=false)
                      2024-07-10 20:30:53.556 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.ical.5
                      2024-07-10 20:30:53.563 - info: host.ioBrokerTestsystem stopInstance system.adapter.mqtt.0 (force=false, process=false)
                      2024-07-10 20:30:53.571 - info: host.ioBrokerTestsystem stopInstance system.adapter.openweathermap.0 (force=false, process=false)
                      2024-07-10 20:30:53.574 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.openweathermap.0
                      2024-07-10 20:30:53.578 - info: host.ioBrokerTestsystem stopInstance system.adapter.proxmox.0 (force=false, process=true)
                      2024-07-10 20:30:53.583 - info: host.ioBrokerTestsystem stopInstance system.adapter.rainbird.0 (force=false, process=false)
                      2024-07-10 20:30:53.587 - info: host.ioBrokerTestsystem stopInstance system.adapter.spotify-premium.0 (force=false, process=false)
                      2024-07-10 20:30:53.591 - info: host.ioBrokerTestsystem stopInstance system.adapter.tr-064.0 (force=false, process=true)
                      2024-07-10 20:30:53.595 - info: host.ioBrokerTestsystem stopInstance system.adapter.unifi.0 (force=false, process=true)
                      2024-07-10 20:30:53.599 - info: host.ioBrokerTestsystem stopInstance system.adapter.worx.0 (force=false, process=true)
                      2024-07-10 20:30:53.604 - info: host.ioBrokerTestsystem stopInstance system.adapter.samsung.0 (force=false, process=true)
                      2024-07-10 20:30:53.608 - info: host.ioBrokerTestsystem stopInstance system.adapter.benchmark.0 (force=false, process=false)
                      2024-07-10 20:30:53.613 - info: host.ioBrokerTestsystem stopInstance system.adapter.daswetter.0 (force=false, process=false)
                      2024-07-10 20:30:53.619 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.daswetter.0
                      2024-07-10 20:30:53.623 - info: host.ioBrokerTestsystem stopInstance system.adapter.dwd.0 (force=false, process=false)
                      2024-07-10 20:30:53.627 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.dwd.0
                      2024-07-10 20:30:53.631 - info: host.ioBrokerTestsystem stopInstance system.adapter.fully-tablet-control.0 (force=false, process=false)
                      2024-07-10 20:30:53.636 - info: host.ioBrokerTestsystem stopInstance system.adapter.nina.0 (force=false, process=true)
                      2024-07-10 20:30:53.641 - info: host.ioBrokerTestsystem stopInstance system.adapter.sayit.0 (force=false, process=false)
                      2024-07-10 20:30:53.647 - info: host.ioBrokerTestsystem stopInstance system.adapter.simple-api.0 (force=false, process=false)
                      2024-07-10 20:30:53.652 - info: host.ioBrokerTestsystem stopInstance system.adapter.socketio.0 (force=false, process=false)
                      2024-07-10 20:30:53.657 - info: host.ioBrokerTestsystem stopInstance system.adapter.tankerkoenig.0 (force=false, process=true)
                      2024-07-10 20:30:53.662 - info: host.ioBrokerTestsystem stopInstance system.adapter.trashschedule.0 (force=false, process=true)
                      2024-07-10 20:30:53.671 - info: host.ioBrokerTestsystem stopInstance system.adapter.valloxmv.0 (force=false, process=true)
                      2024-07-10 20:30:53.676 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-energy.0 (force=false, process=false)
                      2024-07-10 20:30:53.684 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-gauges.0 (force=false, process=false)
                      2024-07-10 20:30:53.701 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-jaeger-design.0 (force=false, process=false)
                      2024-07-10 20:30:53.705 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-material.0 (force=false, process=false)
                      2024-07-10 20:30:53.711 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2.0 (force=false, process=true)
                      2024-07-10 20:30:53.718 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
                      2024-07-10 20:30:53.724 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
                      2024-07-10 20:30:53.729 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-history.0 (force=false, process=false)
                      2024-07-10 20:30:53.733 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
                      2024-07-10 20:30:53.748 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
                      2024-07-10 20:30:53.751 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-justgage.0 (force=false, process=false)
                      2024-07-10 20:30:53.759 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-map.0 (force=false, process=false)
                      2024-07-10 20:30:53.762 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
                      2024-07-10 20:30:53.764 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
                      2024-07-10 20:30:53.768 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis.0 (force=false, process=false)
                      2024-07-10 20:30:53.772 - info: host.ioBrokerTestsystem stopInstance system.adapter.web.0 (force=false, process=true)
                      2024-07-10 20:30:53.776 - info: host.ioBrokerTestsystem stopInstance system.adapter.echarts.0 (force=false, process=true)
                      2024-07-10 20:30:53.782 - info: host.ioBrokerTestsystem stopInstance system.adapter.device-manager.0 (force=false, process=true)
                      2024-07-10 20:30:53.785 - info: host.ioBrokerTestsystem stopInstance system.adapter.discovery.1 (force=false, process=true)
                      2024-07-10 20:30:53.794 - info: host.ioBrokerTestsystem stopInstance system.adapter.radar-trap.0 (force=false, process=true)
                      2024-07-10 20:30:54.130 - info: admin.0 (16303) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.169 - info: device-watcher.0 (407) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.168 - info: backitup.0 (400) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.132 - info: scenes.0 (362) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.193 - info: hm-rega.0 (425) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.200 - info: hm-rpc.0 (440) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.190 - info: fritzbox.0 (418) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.151 - info: scheduler.0 (393) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.215 - info: hue.0 (462) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.227 - info: worx.0 (524) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.263 - info: web.0 (683) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.223 - info: unifi.0 (517) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.260 - info: vis-inventwo.0 (646) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.249 - info: tankerkoenig.0 (587) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.230 - info: nina.0 (572) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.259 - info: valloxmv.0 (609) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.253 - info: trashschedule.0 (594) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.225 - info: samsung.0 (539) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.219 - info: tr-064.0 (506) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.259 - info: vis-2.0 (16265) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.211 - info: proxmox.0 (499) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.263 - info: echarts.0 (690) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.303 - info: device-manager.0 (701) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.350 - info: radar-trap.0 (715) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.333 - info: discovery.1 (708) Got terminate signal TERMINATE_YOURSELF
                      2024-07-10 20:30:54.618 - info: scenes.0 (362) terminating with timeout
                      2024-07-10 20:30:54.651 - info: scheduler.0 (393) terminating with timeout
                      2024-07-10 20:30:54.633 - info: scenes.0 (362) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.681 - info: fritzbox.0 (418) terminating with timeout
                      2024-07-10 20:30:54.679 - info: hm-rega.0 (425) terminating with timeout
                      2024-07-10 20:30:54.689 - info: fritzbox.0 (418) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.657 - info: scheduler.0 (393) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.726 - info: backitup.0 (400) terminating with timeout
                      2024-07-10 20:30:54.696 - info: hm-rega.0 (425) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.753 - info: fritzbox.0 (418) terminating
                      2024-07-10 20:30:54.753 - info: vis-inventwo.0 (646) terminating
                      2024-07-10 20:30:54.753 - info: scheduler.0 (393) terminating
                      2024-07-10 20:30:54.758 - info: fritzbox.0 (418) terminating
                      2024-07-10 20:30:54.768 - info: tankerkoenig.0 (587) terminating
                      2024-07-10 20:30:54.775 - info: valloxmv.0 (609) terminating
                      2024-07-10 20:30:54.767 - info: radar-trap.0 (715) terminating
                      2024-07-10 20:30:54.780 - info: unifi.0 (517) terminating
                      2024-07-10 20:30:54.786 - info: unifi.0 (517) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.763 - info: echarts.0 (690) terminating with timeout
                      2024-07-10 20:30:54.766 - info: hm-rpc.0 (440) terminating
                      2024-07-10 20:30:54.774 - info: tankerkoenig.0 (587) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.760 - info: scheduler.0 (393) terminating
                      2024-07-10 20:30:54.795 - info: unifi.0 (517) terminating
                      2024-07-10 20:30:54.795 - info: tankerkoenig.0 (587) terminating
                      2024-07-10 20:30:54.804 - info: tankerkoenig.0 (587) terminating with timeout
                      2024-07-10 20:30:54.783 - info: hm-rpc.0 (440) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.750 - info: worx.0 (524) terminating with timeout
                      2024-07-10 20:30:54.756 - info: device-watcher.0 (407) terminating
                      2024-07-10 20:30:54.790 - info: nina.0 (572) terminating with timeout
                      2024-07-10 20:30:54.817 - info: discovery.1 (708) terminating with timeout
                      2024-07-10 20:30:54.775 - info: vis-2.0 (16265) terminating
                      2024-07-10 20:30:54.770 - info: device-manager.0 (701) terminating
                      2024-07-10 20:30:54.745 - info: tr-064.0 (506) terminating with timeout
                      2024-07-10 20:30:54.778 - info: trashschedule.0 (594) terminating
                      2024-07-10 20:30:54.828 - info: discovery.1 (708) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.848 - info: web.0 (683) terminating with timeout
                      2024-07-10 20:30:54.816 - info: samsung.0 (539) terminating with timeout
                      2024-07-10 20:30:54.861 - info: web.0 (683) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.824 - info: nina.0 (572) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.801 - info: valloxmv.0 (609) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.874 - info: unifi.0 (517) terminating with timeout
                      2024-07-10 20:30:54.874 - info: hue.0 (462) terminating with timeout
                      2024-07-10 20:30:54.842 - info: vis-inventwo.0 (646) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.718 - info: proxmox.0 (499) terminating with timeout
                      2024-07-10 20:30:54.848 - info: worx.0 (524) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.919 - info: hm-rega.0 (425) terminating
                      2024-07-10 20:30:54.918 - info: vis-inventwo.0 (646) terminating
                      2024-07-10 20:30:54.850 - info: admin.0 (16303) terminating with timeout
                      2024-07-10 20:30:54.934 - info: discovery.1 (708) terminating
                      2024-07-10 20:30:54.902 - info: backitup.0 (400) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.941 - info: vis-inventwo.0 (646) terminating with timeout
                      2024-07-10 20:30:54.940 - info: discovery.1 (708) terminating
                      2024-07-10 20:30:54.880 - info: hue.0 (462) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.957 - info: influxdb.0 (340) terminating
                      2024-07-10 20:30:54.965 - warn: host.ioBrokerTestsystem instance system.adapter.javascript.0 terminated due to SIGTERM
                      2024-07-10 20:30:54.888 - info: proxmox.0 (499) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.971 - info: host.ioBrokerTestsystem instance system.adapter.javascript.0 terminated with code null ()
                      2024-07-10 20:30:54.993 - info: web.0 (683) terminating
                      2024-07-10 20:30:54.999 - info: valloxmv.0 (609) terminating with timeout
                      2024-07-10 20:30:54.936 - info: admin.0 (16303) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.907 - info: samsung.0 (539) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.922 - info: scenes.0 (362) terminating
                      2024-07-10 20:30:55.052 - info: backitup.0 (400) terminating
                      2024-07-10 20:30:54.974 - info: worx.0 (524) terminating
                      2024-07-10 20:30:54.914 - info: device-watcher.0 (407) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.883 - info: echarts.0 (690) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:55.048 - info: hue.0 (462) terminating
                      2024-07-10 20:30:54.995 - info: host.ioBrokerTestsystem stopInstance system.adapter.admin.0 send kill signal
                      2024-07-10 20:30:55.011 - info: host.ioBrokerTestsystem stopInstance system.adapter.javascript.0 send kill signal
                      2024-07-10 20:30:55.018 - info: host.ioBrokerTestsystem stopInstance system.adapter.scenes.0 send kill signal
                      2024-07-10 20:30:55.024 - info: host.ioBrokerTestsystem stopInstance system.adapter.scheduler.0 send kill signal
                      2024-07-10 20:30:55.029 - info: host.ioBrokerTestsystem stopInstance system.adapter.backitup.0 send kill signal
                      2024-07-10 20:30:55.036 - info: host.ioBrokerTestsystem stopInstance system.adapter.device-watcher.0 send kill signal
                      2024-07-10 20:30:55.040 - info: host.ioBrokerTestsystem stopInstance system.adapter.fritzbox.0 send kill signal
                      2024-07-10 20:30:55.045 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rega.0 send kill signal
                      2024-07-10 20:30:55.049 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 send kill signal
                      2024-07-10 20:30:55.053 - info: host.ioBrokerTestsystem stopInstance system.adapter.hue.0 send kill signal
                      2024-07-10 20:30:55.031 - info: nina.0 (572) terminating
                      2024-07-10 20:30:55.057 - info: worx.0 (524) terminating
                      2024-07-10 20:30:55.056 - info: backitup.0 (400) terminating
                      2024-07-10 20:30:54.969 - info: influxdb.0 (340) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:55.091 - info: echarts.0 (690) terminating
                      2024-07-10 20:30:55.089 - info: device-watcher.0 (407) terminating with timeout
                      2024-07-10 20:30:55.218 - info: hm-rpc.0 (440) terminating with timeout
                      2024-07-10 20:30:54.887 - info: tr-064.0 (506) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.944 - info: tr-064.0 (506) terminating
                      2024-07-10 20:30:55.053 - info: tr-064.0 (506) terminating
                      2024-07-10 20:30:55.067 - info: scenes.0 (362) terminating
                      2024-07-10 20:30:55.108 - info: nina.0 (572) terminating
                      2024-07-10 20:30:54.894 - info: trashschedule.0 (594) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.977 - info: trashschedule.0 (594) terminating with timeout
                      2024-07-10 20:30:55.121 - info: trashschedule.0 (594) terminating
                      2024-07-10 20:30:55.269 - info: valloxmv.0 (609) terminating
                      2024-07-10 20:30:54.784 - info: radar-trap.0 (715) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.927 - info: radar-trap.0 (715) terminating with timeout
                      2024-07-10 20:30:55.078 - info: radar-trap.0 (715) terminating
                      2024-07-10 20:30:55.102 - info: host.ioBrokerTestsystem stopInstance system.adapter.proxmox.0 send kill signal
                      2024-07-10 20:30:55.109 - info: host.ioBrokerTestsystem stopInstance system.adapter.tr-064.0 send kill signal
                      2024-07-10 20:30:55.118 - info: host.ioBrokerTestsystem stopInstance system.adapter.unifi.0 send kill signal
                      2024-07-10 20:30:55.122 - info: host.ioBrokerTestsystem stopInstance system.adapter.worx.0 send kill signal
                      2024-07-10 20:30:55.125 - info: host.ioBrokerTestsystem stopInstance system.adapter.samsung.0 send kill signal
                      2024-07-10 20:30:55.129 - info: host.ioBrokerTestsystem stopInstance system.adapter.nina.0 send kill signal
                      2024-07-10 20:30:55.133 - info: host.ioBrokerTestsystem stopInstance system.adapter.tankerkoenig.0 send kill signal
                      2024-07-10 20:30:55.136 - info: host.ioBrokerTestsystem stopInstance system.adapter.trashschedule.0 send kill signal
                      2024-07-10 20:30:55.139 - info: host.ioBrokerTestsystem stopInstance system.adapter.valloxmv.0 send kill signal
                      2024-07-10 20:30:55.143 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2.0 send kill signal
                      2024-07-10 20:30:55.147 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-inventwo.0 send kill signal
                      2024-07-10 20:30:55.150 - info: host.ioBrokerTestsystem stopInstance system.adapter.web.0 send kill signal
                      2024-07-10 20:30:55.153 - info: host.ioBrokerTestsystem stopInstance system.adapter.echarts.0 send kill signal
                      2024-07-10 20:30:55.157 - info: host.ioBrokerTestsystem stopInstance system.adapter.device-manager.0 send kill signal
                      2024-07-10 20:30:55.160 - info: host.ioBrokerTestsystem stopInstance system.adapter.discovery.1 send kill signal
                      2024-07-10 20:30:55.164 - info: host.ioBrokerTestsystem stopInstance system.adapter.radar-trap.0 send kill signal
                      2024-07-10 20:30:55.030 - info: proxmox.0 (499) terminating
                      2024-07-10 20:30:55.136 - info: proxmox.0 (499) terminating
                      2024-07-10 20:30:54.836 - info: device-manager.0 (701) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.862 - info: device-manager.0 (701) terminating with timeout
                      2024-07-10 20:30:55.148 - info: device-manager.0 (701) terminating
                      2024-07-10 20:30:55.082 - info: samsung.0 (539) terminating
                      2024-07-10 20:30:55.086 - info: samsung.0 (539) terminating
                      2024-07-10 20:30:54.835 - info: vis-2.0 (16265) Terminated (NO_ERROR): Without reason
                      2024-07-10 20:30:54.984 - info: vis-2.0 (16265) terminating with timeout
                      2024-07-10 20:30:55.113 - info: vis-2.0 (16265) terminating
                      2024-07-10 20:30:55.015 - info: admin.0 (16303) terminating
                      2024-07-10 20:30:55.118 - info: admin.0 (16303) terminating
                      2024-07-10 20:30:55.691 - info: hm-rpc.0 (440) terminating
                      2024-07-10 20:30:55.704 - info: device-watcher.0 (407) terminating
                      2024-07-10 20:30:55.746 - info: hue.0 (462) cleaned everything up...
                      2024-07-10 20:30:55.788 - warn: hue.0 (462) get state error: Connection is closed.
                      2024-07-10 20:30:55.794 - info: hue.0 (462) terminating
                      2024-07-10 20:30:55.844 - warn: admin.0 (16303) redis get system.host.ioBrokerTestsystem.alive, error - Connection is closed.
                      2024-07-10 20:30:56.082 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.admin.0 killing pid 16303
                      2024-07-10 20:30:56.098 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.scenes.0 killing pid 362
                      2024-07-10 20:30:56.117 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.scheduler.0 killing pid 393
                      2024-07-10 20:30:56.120 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.backitup.0 killing pid 400
                      2024-07-10 20:30:56.148 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.device-watcher.0 killing pid 407
                      2024-07-10 20:30:56.158 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.fritzbox.0 killing pid 418
                      2024-07-10 20:30:56.168 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.hm-rega.0 killing pid 425
                      2024-07-10 20:30:56.172 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.hm-rpc.0 killing pid 440
                      2024-07-10 20:30:56.176 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.hue.0 killing pid 462
                      2024-07-10 20:30:56.229 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.proxmox.0 killing pid 499
                      2024-07-10 20:30:56.258 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.tr-064.0 killing pid 506
                      2024-07-10 20:30:56.300 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.unifi.0 killing pid 517
                      2024-07-10 20:30:56.305 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.worx.0 killing pid 524
                      2024-07-10 20:30:56.308 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.samsung.0 killing pid 539
                      2024-07-10 20:30:56.311 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.nina.0 killing pid 572
                      2024-07-10 20:30:56.315 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.tankerkoenig.0 killing pid 587
                      2024-07-10 20:30:56.318 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.trashschedule.0 killing pid 594
                      2024-07-10 20:30:56.322 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.valloxmv.0 killing pid 609
                      2024-07-10 20:30:56.338 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.vis-2.0 killing pid 16265
                      2024-07-10 20:30:56.346 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.vis-inventwo.0 killing pid 646
                      2024-07-10 20:30:56.357 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.web.0 killing pid 683
                      2024-07-10 20:30:56.372 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.echarts.0 killing pid 690
                      2024-07-10 20:30:56.390 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.device-manager.0 killing pid 701
                      2024-07-10 20:30:56.406 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.discovery.1 killing pid 708
                      2024-07-10 20:30:56.432 - info: host.ioBrokerTestsystem stopInstance timeout system.adapter.radar-trap.0 killing pid 715
                      2024-07-10 20:31:00.868 - warn: host.ioBrokerTestsystem instance system.adapter.scenes.0 terminated due to SIGKILL
                      2024-07-10 20:31:00.872 - info: host.ioBrokerTestsystem instance system.adapter.scenes.0 terminated with code null ()
                      2024-07-10 20:31:01.437 - warn: host.ioBrokerTestsystem instance system.adapter.scheduler.0 terminated due to SIGKILL
                      2024-07-10 20:31:01.447 - info: host.ioBrokerTestsystem instance system.adapter.scheduler.0 terminated with code null ()
                      2024-07-10 20:31:01.451 - warn: host.ioBrokerTestsystem instance system.adapter.backitup.0 terminated due to SIGKILL
                      2024-07-10 20:31:01.454 - info: host.ioBrokerTestsystem instance system.adapter.backitup.0 terminated with code null ()
                      2024-07-10 20:31:01.527 - warn: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated due to SIGKILL
                      2024-07-10 20:31:01.532 - info: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated with code null ()
                      2024-07-10 20:31:01.737 - warn: host.ioBrokerTestsystem instance system.adapter.device-watcher.0 terminated due to SIGKILL
                      2024-07-10 20:31:01.740 - info: host.ioBrokerTestsystem instance system.adapter.device-watcher.0 terminated with code null ()
                      2024-07-10 20:31:01.743 - warn: host.ioBrokerTestsystem instance system.adapter.fritzbox.0 terminated due to SIGKILL
                      2024-07-10 20:31:01.746 - info: host.ioBrokerTestsystem instance system.adapter.fritzbox.0 terminated with code null ()
                      2024-07-10 20:31:02.273 - warn: host.ioBrokerTestsystem instance system.adapter.hm-rega.0 terminated due to SIGKILL
                      2024-07-10 20:31:02.279 - info: host.ioBrokerTestsystem instance system.adapter.hm-rega.0 terminated with code null ()
                      2024-07-10 20:31:02.282 - warn: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated due to SIGKILL
                      2024-07-10 20:31:02.288 - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code null ()
                      2024-07-10 20:31:02.450 - warn: host.ioBrokerTestsystem instance system.adapter.hue.0 terminated due to SIGKILL
                      2024-07-10 20:31:02.453 - info: host.ioBrokerTestsystem instance system.adapter.hue.0 terminated with code null ()
                      2024-07-10 20:31:02.603 - warn: host.ioBrokerTestsystem instance system.adapter.proxmox.0 terminated due to SIGKILL
                      2024-07-10 20:31:02.606 - info: host.ioBrokerTestsystem instance system.adapter.proxmox.0 terminated with code null ()
                      2024-07-10 20:31:02.610 - warn: host.ioBrokerTestsystem instance system.adapter.tr-064.0 terminated due to SIGKILL
                      2024-07-10 20:31:02.614 - info: host.ioBrokerTestsystem instance system.adapter.tr-064.0 terminated with code null ()
                      2024-07-10 20:31:02.826 - warn: host.ioBrokerTestsystem instance system.adapter.unifi.0 terminated due to SIGKILL
                      2024-07-10 20:31:02.837 - info: host.ioBrokerTestsystem instance system.adapter.unifi.0 terminated with code null ()
                      2024-07-10 20:31:02.976 - warn: host.ioBrokerTestsystem instance system.adapter.worx.0 terminated due to SIGKILL
                      2024-07-10 20:31:02.979 - info: host.ioBrokerTestsystem instance system.adapter.worx.0 terminated with code null ()
                      2024-07-10 20:31:02.983 - warn: host.ioBrokerTestsystem instance system.adapter.samsung.0 terminated due to SIGKILL
                      2024-07-10 20:31:02.986 - info: host.ioBrokerTestsystem instance system.adapter.samsung.0 terminated with code null ()
                      2024-07-10 20:31:03.200 - warn: host.ioBrokerTestsystem instance system.adapter.nina.0 terminated due to SIGKILL
                      2024-07-10 20:31:03.205 - info: host.ioBrokerTestsystem instance system.adapter.nina.0 terminated with code null ()
                      2024-07-10 20:31:03.209 - warn: host.ioBrokerTestsystem instance system.adapter.trashschedule.0 terminated due to SIGKILL
                      2024-07-10 20:31:03.212 - info: host.ioBrokerTestsystem instance system.adapter.trashschedule.0 terminated with code null ()
                      2024-07-10 20:31:03.319 - warn: host.ioBrokerTestsystem instance system.adapter.valloxmv.0 terminated due to SIGKILL
                      2024-07-10 20:31:03.322 - info: host.ioBrokerTestsystem instance system.adapter.valloxmv.0 terminated with code null ()
                      2024-07-10 20:31:03.460 - warn: host.ioBrokerTestsystem instance system.adapter.vis-inventwo.0 terminated due to SIGKILL
                      2024-07-10 20:31:03.463 - info: host.ioBrokerTestsystem instance system.adapter.vis-inventwo.0 terminated with code null ()
                      2024-07-10 20:31:03.466 - warn: host.ioBrokerTestsystem instance system.adapter.web.0 terminated due to SIGKILL
                      2024-07-10 20:31:03.469 - info: host.ioBrokerTestsystem instance system.adapter.web.0 terminated with code null ()
                      2024-07-10 20:31:03.741 - warn: host.ioBrokerTestsystem instance system.adapter.echarts.0 terminated due to SIGKILL
                      2024-07-10 20:31:03.744 - info: host.ioBrokerTestsystem instance system.adapter.echarts.0 terminated with code null ()
                      2024-07-10 20:31:03.748 - warn: host.ioBrokerTestsystem instance system.adapter.device-manager.0 terminated due to SIGKILL
                      2024-07-10 20:31:03.753 - info: host.ioBrokerTestsystem instance system.adapter.device-manager.0 terminated with code null ()
                      2024-07-10 20:31:04.137 - warn: host.ioBrokerTestsystem instance system.adapter.discovery.1 terminated due to SIGKILL
                      2024-07-10 20:31:04.142 - info: host.ioBrokerTestsystem instance system.adapter.discovery.1 terminated with code null ()
                      2024-07-10 20:31:04.249 - warn: host.ioBrokerTestsystem instance system.adapter.vis-2.0 terminated due to SIGKILL
                      2024-07-10 20:31:04.252 - info: host.ioBrokerTestsystem instance system.adapter.vis-2.0 terminated with code null ()
                      2024-07-10 20:31:04.254 - warn: host.ioBrokerTestsystem instance system.adapter.tankerkoenig.0 terminated due to SIGKILL
                      2024-07-10 20:31:04.257 - info: host.ioBrokerTestsystem instance system.adapter.tankerkoenig.0 terminated with code null ()
                      2024-07-10 20:31:04.304 - warn: host.ioBrokerTestsystem instance system.adapter.radar-trap.0 terminated due to SIGKILL
                      2024-07-10 20:31:04.308 - info: host.ioBrokerTestsystem instance system.adapter.radar-trap.0 terminated with code null ()
                      2024-07-10 20:31:04.529 - info: host.ioBrokerTestsystem instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
                      2024-07-10 20:31:04.533 - info: host.ioBrokerTestsystem All instances are stopped.
                      2024-07-10 20:31:04.757 - info: host.ioBrokerTestsystem terminated
                      2024-07-10 20:31:12.212 - info: host.ioBrokerTestsystem iobroker.js-controller version 6.0.6 js-controller starting
                      2024-07-10 20:31:12.228 - info: host.ioBrokerTestsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2024-07-10 20:31:12.234 - info: host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v18.20.4
                      2024-07-10 20:31:12.238 - info: host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
                      2024-07-10 20:31:17.237 - info: host.ioBrokerTestsystem connected to Objects and States
                      2024-07-10 20:31:17.322 - info: host.ioBrokerTestsystem added notifications configuration of host
                      2024-07-10 20:31:17.380 - info: host.ioBrokerTestsystem Node.js version has changed from 18.20.3 to 18.20.4
                      2024-07-10 20:31:17.597 - info: host.ioBrokerTestsystem Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                      2024-07-10 20:31:19.219 - info: host.ioBrokerTestsystem 65 instances found
                      2024-07-10 20:31:19.374 - info: host.ioBrokerTestsystem starting 33 instances
                      2024-07-10 20:31:20.799 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeCurrent"
                      2024-07-10 20:31:21.096 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeNewest"
                      2024-07-10 20:31:21.165 - info: host.ioBrokerTestsystem instance system.adapter.admin.0 started with pid 16660
                      2024-07-10 20:31:21.198 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeNewestNext"
                      2024-07-10 20:31:21.264 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.npmCurrent"
                      2024-07-10 20:31:21.289 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.npmNewest"
                      2024-07-10 20:31:21.300 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.npmNewestNext"
                      2024-07-10 20:31:21.311 - info: host.ioBrokerTestsystem Some obsolete host states deleted.
                      2024-07-10 20:31:25.542 - info: host.ioBrokerTestsystem instance system.adapter.influxdb.0 started with pid 16667
                      2024-07-10 20:31:29.090 - info: host.ioBrokerTestsystem instance system.adapter.javascript.0 started with pid 16678
                      2024-07-10 20:31:33.159 - info: host.ioBrokerTestsystem instance system.adapter.scenes.0 started with pid 16689
                      2024-07-10 20:31:37.225 - info: host.ioBrokerTestsystem instance system.adapter.scheduler.0 started with pid 16700
                      Ich sehe hier u.a. folgendes:
                      Ich hätte mit dem Changelog Eintrag vom Admin erwartet, das das System von nodejs 18 auf 20 aktualisiert wird. Was sagst du? 🙂
                      Kannst du sagen, warum der Updatebutton so versteckt ist? Ich hätte eine entsprechenden Button / Updatemöglichkeit im Host Menü erwartet. Ich kann dazu mal ein admin issue erstellen (https://github.com/ioBroker/ioBroker.admin/issues/2543).
                      Feuer-sturm created this issue in ioBroker/ioBroker.admin
                      open [enhancement]: Provide button for nodejs update in admin host menu #2543
                        Thomas Braun Most Active @Feuersturm last edited by Thomas Braun
                        @feuersturm sagte in Beta Test js-controller Kiera (v6.0):
                        Jein. Im Changelog geht es darum, das im Admin noch die Version 18 hardcoded drin stand. Hat dann z. B. bei iob nodejs-update zu widersprüchlichen Meldungen geführt.
                        Der Update-Button den du da jetzt gefunden hast aktualisiert nur auf die aktuellste Version, die auch über den Paketmanager 'apt' verfügbar ist. Ein Release-Wechsel ist damit nicht möglich. Sollte es auch imho nicht sein. Die Verwaltung der OS-Pakete und der entsprechenden Quellen sollte dem Paketmanager vorbehalten bleiben.
                        • Feuersturm
                          Feuersturm @Thomas Braun last edited by
                          @thomas-braun Dann ist die Information in der Kachel und und in dem Popup aber noch nicht ausreichend. Ich hätte jetzt auf Basis der sichtbaren Informationen erwartet, dass auf nodejs 20.x aktualisiert wird und nicht auf die aktuelle Minor/Patch Version im aktuellen Major Strang (in diesem Fall 18).
                            @feuersturm
                            Deswegen steht ja auch 'in den konfigurierten apt-Quellen' dabei.
                            Feuersturm mcm1957 2 Replies Last reply Reply Quote 0
                            • Feuersturm
                              @thomas-braun Ich hab daraus gelesen, dass die Paketquellen Quellen auch im Hintergrund aktualisiert werden in dem Fall auf nodejs 20
                              • mcm1957
                                mcm1957 @Thomas Braun last edited by mcm1957
                                Sorry - Aber das verstehen 90% der User nicht.
                                Denen sagt apt quellen nix. Auch ich weiss nur sehr ca. Um was es sa geht. Anpassen / ändern könnt ich da nix.
                                Und warum sollte node nicht auf die empfohlene Version aktualisiert werden? Das node Update script macht es ja auch?
                                Thomas Braun 3 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @mcm1957 last edited by
                                  @mcm1957 sagte in Beta Test js-controller Kiera (v6.0):
                                  Ja, das hat sich aber aus einem nodejs-fix heraus entwickelt, das genau das tun sollte. Verfummelte Paketquellen wieder gerade rücken. Das macht es dann auch (z. T. auch mit der Brechstange).
                                  Dann müsste man im Grunde zwei Buttons haben:
                                  nodejs update -> Update auf die aktuellste Version aus dem derzeitig aktiven Major-Tree
                                  nodejs upgrade -> Upgrade (wenn nötig mit geändertem Repo) auf die aktuell empfohlene Version
                                    Da ist aber Schade, denn das sind absolute Basics im Umgang mit einem Linux. Der Paketmanager ist das Herz und Hirn der Software- und Update-Verwaltung. Ohne mindestens in den Grundzügen das Konzept verstanden zu haben wirst du dich auf ewig mit deiner Distribution schwer tun.
                                    Feuersturm 1 Reply Last reply Reply Quote 1
                                    • Feuersturm
                                      @thomas-braun Wir können ja eine entsprechende Doku beilegen / verlinken 😉
                                        @feuersturm Die dann wieder niemand liest.
                                        Jedenfalls dürfte das dazu führen, das die allgemeine Systempflege noch stärker vernachlässig werden wird.
                                        Da wird der User sagen: Ich halte die Adapter an einer Stelle im Admin aktuell, den js-controller an einer anderen Stelle und nodejs wieder an einer anderen Stelle und dann muss ich auch noch das OS irgendie aktuell halten? Weiß ich nicht, kann ich nicht, mach ich nicht.
                                        Und deswegen wollte ich nodejs-update auch nie im iob-GUI haben und auch immer gesagt, das es auf keinen Fall die vollumfängliche Systempflege ersetzen soll. nodejs-update ist/war nur dazu gedacht die nodesource-Quelle sauber einzurichten, im weiteren soll weiterhin die übliche Prozedur aus 'apt update && apt full-upgrade' ausgeführt werden.
                                          Aber nur nach Rückfrage beim user und nicht ungefragt/unerwartet:
                                          Nothing to do - Your installation is using the correct paths.
                                          You are running nodejs v22.4.1. Do you want to install recommended version 20.15.1?
                                          Press <y> to continue or any other key to quit
                                          We are not fixing your installation. Exiting.
                                          Der erste Teil von nodejs-update setzt deine aktuelle Version wieder auf die richtigen Pfade, der zweite Teil erst verändert die Quellen, die zuvor im aktuellen Status angezeigt werden.
                                          • Feuersturm
                                            @thomas-braun sagte in Beta Test js-controller Kiera (v6.0):
                                            Du hast meinen Smily ignoriert 🙂
                                            beta js-controller kiera test
                                            39
                                            331
                                            73334
