    4. Test Adapter zigbee2mqtt
    • MartinP
      MartinP @biker1602 last edited by
      @biker1602 Du solltest erstmal genauer beschreiben, wie Du den bisherigen USB-Koordinator mit ioBroker verbunden hast.
      Der Einsatz des zigbee2mqtt Adapters legt ja nahe, dass der USB-Koordinator über einen zigbee2MQTT Server eingebunden ist...
      Jedenfalls ist DAS der Verwendungszweck des zigbee2mqtt Adapters.
        biker1602 @Asgothian last edited by biker1602
        @asgothian
        biker1602@iobroker:~$ /opt/zigbee2mqtt.io
        -bash: /opt/zigbee2mqtt.io: No such file or directory
        biker1602@iobroker:~$ npm audit
        # npm audit report
        axios  1.0.0 - 1.5.1
        Severity: moderate
        Axios Cross-Site Request Forgery Vulnerability - https://github.com/advisories/GHSA-wf5p-g6vw-rhxx
        fix available via `npm audit fix`
        node_modules/axios
        braces  <3.0.3
        Severity: high
        Uncontrolled resource consumption in braces - https://github.com/advisories/GHSA-grv7-fg5c-xmjg
        node_modules/braces
        follow-redirects  <=1.15.5
        Severity: moderate
        Follow Redirects improperly handles URLs in the url.parse() function - https://github.com/advisories/GHSA-jchw-25xp-jwwc
        follow-redirects' Proxy-Authorization header kept across hosts - https://github.com/advisories/GHSA-cxjh-pqwp-8mfp
        node_modules/follow-redirects
        ip  *
        Severity: high
        ip SSRF improper categorization in isPublic - https://github.com/advisories/GHSA-2p57-rm9w-gvfp
        NPM IP package incorrectly identifies some private IP addresses as public - https://github.com/advisories/GHSA-78xj-cgh5-2h22
        fix available via `npm audit fix --force`
        Will install iobroker.ring@1.2.8, which is a breaking change
        node_modules/ip
          werift  *
          Depends on vulnerable versions of ip
          node_modules/werift
            ring-client-api  >=11.0.1
            Depends on vulnerable versions of werift
            node_modules/ring-client-api
              iobroker.ring  >=2.0.0-beta.0
              Depends on vulnerable versions of ring-client-api
              node_modules/iobroker.ring
        semver  6.0.0 - 6.3.0
        Severity: moderate
        semver vulnerable to Regular Expression Denial of Service - https://github.com/advisories/GHSA-c2qf-rxjj-qqgw
        node_modules/semver
        tar  <6.2.1
        Severity: moderate
        Denial of service while parsing a tar file due to lack of folders count validation - https://github.com/advisories/GHSA-f5x3-32g6-xq36
        node_modules/tar
        ws  7.0.0 - 7.5.9 || 8.0.0 - 8.17.0
        Severity: high
        ws affected by a DoS when handling a request with many HTTP headers - https://github.com/advisories/GHSA-3h5v-q93c-6h6q
        node_modules/engine.io-client/node_modules/ws
        node_modules/ws
          engine.io-client  0.7.0 || 0.7.8 - 0.7.9 || 3.5.0 - 3.5.3 || 4.0.0-alpha.0 - 5.2.0
          Depends on vulnerable versions of ws
        11 vulnerabilities (4 moderate, 7 high)
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues (including breaking changes), run:
        -bash: /opt/zigbee2mqtt: Is a directory
        # npm audit report
        axios  1.0.0 - 1.5.1
        Severity: moderate
        node_modules/axios
        braces  <3.0.3
        Severity: high
        node_modules/braces
        Severity: moderate
        ip  *
        Severity: high
        node_modules/ip
          werift  *
          node_modules/werift
        Severity: moderate
        node_modules/semver
        tar  <6.2.1
        Severity: moderate
        node_modules/tar
        Severity: high
        node_modules/ws
          npm audit fix
        iker1602@iobroker:~$ cd /opt/zigbee2mqtt
        biker1602@iobroker:/opt/zigbee2mqtt$ npm audit
        found 0 vulnerabilities
        Irgendwie findet er da nichts oder?
        • MartinP
          @biker1602 Okay, also arbeitest Du mit einer dem zigbee2mqtt Adapter vorgeschalteten zigbee2MQTT Server - Instanz...
            biker1602 @MartinP last edited by
            @martinp said in Test Adapter zigbee2mqtt:
            Der USB Koordinator wird durgeschliffen bei Proxmox und wird nur für den normalen Zigbee Adapter genutzt.
              biker1602 @MartinP last edited by biker1602
              Ich weiß schon garnichts mehr. Den SLZB-06 habe ich erst kurz. Mein Plan war Zigbee2mqtt zu nutzen und den anderen (sonoff) und den Zigbee Adapter zu deaktivieren.
              Ich bekommen zigbee2mqtt aber nicht deinstalliert um alles nochmal neu zu machen.
              Wenn ich den Status abfrage kommt folgende Meldung
              biker1602@iobroker:~$ systemctl status zigbee2mqtt.service
              ● zigbee2mqtt.service - zigbee2mqtt
                   Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
                   Active: activating (auto-restart) (Result: exit-code) since Thu 2024-07-11 11:00:35 CEST; 2s ago
                  Process: 72010 ExecStart=/usr/bin/node index.js (code=exited, status=1/FAILURE)
                 Main PID: 72010 (code=exited, status=1/FAILURE)
                      CPU: 562ms
              Asgothian 1Topf 2 Replies Last reply Reply Quote 0
              • Asgothian
                Asgothian Developer @biker1602 last edited by Asgothian
                @biker1602 Ich denke damit kommt das hier zum Tragen:
                @asgothian sagte in Test Adapter zigbee2mqtt:
                Beim Zigbee2mqtt.io Projekt nachschauen - die haben eigentlich gute Doku zu solchen Fällen.
                Nachtrag: wenn Du dir den Text der Fehlermeldung genau anschaust, dann beschwert er sich darüber das im YAML das Schlüsselwort "serial:" doppelt vorkommt. Das kommt von Deiner Anpassung als du den TCP Port eingetragen hast. berichtige das mal, dann sollte der laufen.
                A.
                  biker1602 last edited by biker1602
                  @asgothian
                  Ich habe probiert und versucht. Jetzt habe ich ihn im ioBroker drin kann ihn auch aufrufen.
                  Im Protokoll sind aber Fehlermeldungen
                  2024-07-11 16:16:04.346 - warn: zigbee2mqtt.0 (89552) Start try again in 1 seconds...
                  2024-07-11 16:16:09.744 - error: zigbee2mqtt.0 (89588) ===================================================
                  2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) ===================================================
                  2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) Legacy api is activated, so the adapter can not work correctly!!!
                  2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
                  2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) advanced:
                  2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) legacy_api: false
                  2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588)
                  2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) Legacy Availability Payload is activated, thus the adapter cannot represent the availability of the devices!!!
                  2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
                  2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) advanced:
                  2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) legacy_availability_payload: false
                  2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) Device Legacy Payload is activated, therefore the adapter may process the states of the devices correctly!!!
                  2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
                  2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) device_options:
                  2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) legacy: false
                  2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) ===================================================
                  und der Adapter wird nicht grün
                  Asgothian crunchip 2 Replies Last reply Reply Quote 0
                  • Asgothian
                    @biker1602 Hast du den getan wozu dich das Log auffordert ?
                      crunchip Forum Testing Most Active @biker1602 last edited by
                      @biker1602 sagte in Test Adapter zigbee2mqtt:
                      configuration.yaml
                      Wie sieht die denn im Ganzen aus?
                        @asgothian said in Test Adapter zigbee2mqtt:
                        Soll ich das in der Configuration eintragen?
                        legacy_api: false
                          biker1602 @crunchip last edited by
                          @crunchip said in Test Adapter zigbee2mqtt:
                          configuration.yaml
                          Das ist Protokoll im iobroker da ist nicht mehr.
                            configuration.yaml
                            Das ist die Config
                            # Home Assistant integration (MQTT discovery)
                            homeassistant: false
                            # Enable the frontend, runs on port 8080 by default
                            frontend: true
                            # allow new device to join
                            # permit_join: true
                            # MQTT settings
                            mqtt:
                              # MQTT base topic for zigbee2mqtt MQTT messages
                              base_topic: zigbee2mqtt
                              # MQTT server URL
                              server: 'mqtt://localhost'
                              # MQTT server authentication, uncomment if required:
                               user: biker1602
                               password: Ulli1602
                            # Serial settings
                              # Achtung: Wenn Sie das Z2M-Add-on für HA verwenden, ist es besser, die Yaml-Konfigurationsdatei direkt zu bearbeiten
                            serial:
                            # Location of SLZB-06
                              port: tcp://192.168.57.90:6638
                              baudrate: 115200
                              adapter: zstack
                            # Grüne LED deaktivieren?
                              disable_led: false
                            # Ausgangsleistung auf max. 20 einstellen
                            advanced:
                              transmit_power: 20
                            # Advanced settings
                              network_key: GENERATE
                              pan_id: GENERATE
                              ext_pan_id: GENERATE
                            crunchip D 2 Replies Last reply Reply Quote 0
                              @biker1602 da fehlt bisserl was, im ersten Beitrag steht was zwingend eingetragen werden muss und in der Adapterbeschreibung steht es etwas ausführlicher
                                biker1602 @crunchip last edited by biker1602
                                Ich mache einen anderen Tag weiter oder lasse es ganz. Ich sehe den Wald vor lauter Bäumen nicht mehr.
                                Kann mir jemand sagen wie ich das ganze in putty deinstallieren kann das auch alles verschwindet und nicht irgendwo noch versteckte Dateien sind dich nicht gelöscht werden?
                                  arteck Developer Most Active @biker1602 last edited by
                                  @biker1602 es gibt keine versteckten Datei .. bist ja nicht unter Windows
                                  und wenn du die config richtig machst dann geht das auch..man muss sich halt einlesen.. es ist nicht reinstöpseln ..fettisch
                                  es ist alles gut Dokumentiert (wozu schreiben wir den quatsch)
                                    @arteck said in Test Adapter zigbee2mqtt:
                                    Entschuldigung Vielleicht war ich ja gestern auch genervt weil es nicht funktioniert hat. Ich hatte es dann gestern doch noch hinbekommen und war auch glücklich das ich Geräte anlernen konnte. Heute Morgen denke ich mal sehen was bei HA passiert und da war der Adapter auch zu sehen. Ich in meinem Übermut wollte ihne konfigurieren und habe plötzlich Panik bekommen und abgebrochen. seitdem kann ich keine Geräte mehr anlernen und es kommt ein Roter Warnhinweis unter Protokolle.
                                    zh:zstack:znp: Error while parsing to ZpiObject 'TypeError: Cannot read properties of undefined (reading 'name') at Function.readParameters (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:88:63) at Function.fromUnpiFrame (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:73:30) at Znp.onUnpiParsed (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:93:38) at Parser.emit (node:events:519:28) at Parser.parseNext (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/unpi/parser.ts:45:26) at Parser._transform (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/unpi/parser.ts:19:14) at Parser.Transform._write (node:internal/streams/transform:171:8) at writeOrBuffer (node:internal/streams/writable:564:12) at _write (node:internal/streams/writable:493:10) at Parser.Writable.write (node:internal/streams/writable:502:10)'
                                    Das kann doch nur mit dem HA zusamenhängen oder? Ich hatte in der Configurationstatei nachgesehen da war eine Zeile mit HA dazu gekommen. Die habe ich gelöscht aber das hat das Problem nicht behoben. Hast du eine Ahnung was ich da noch machen kann?
                                    2024-07-12 00:00:00.009 - info: hekr.0 (65528) Scheduled restart.
                                    2024-07-12 00:00:00.032 - info: hekr.0 (65528) terminating
                                    2024-07-12 00:00:00.032 - info: hekr.0 (65528) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2024-07-12 00:00:00.523 - info: hekr.0 (65528) terminating
                                    2024-07-12 00:00:01.000 - debug: javascript.0 (64883) [sunTimeSchedules] Times: {"solarNoon":"2024-07-12T11:24:45.080Z","nadir":"2024-07-12T23:24:45.080Z","sunrise":"2024-07-12T03:12:14.591Z","sunset":"2024-07-12T19:37:15.569Z","sunriseEnd":"2024-07-12T03:16:42.195Z","sunsetStart":"2024-07-12T19:32:47.965Z","dawn":"2024-07-12T02:25:23.002Z","dusk":"2024-07-12T20:24:07.158Z","nauticalDawn":"2024-07-12T01:14:32.792Z","nauticalDusk":"2024-07-12T21:34:57.368Z","nightEnd":null,"night":null,"goldenHourEnd":"2024-07-12T04:06:04.637Z","goldenHour":"2024-07-12T18:43:25.523Z"}
                                    2024-07-12 00:00:01.023 - debug: javascript.0 (64883) [sunTimeSchedules] Next: 2024-07-12T22:00:01.000Z
                                    2024-07-12 00:00:02.476 - info: hekr.0 (98780) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.hekr, node: v20.15.1, js-controller: 5.0.19
                                    2024-07-12 00:00:03.511 - info: hekr.0 (98780) Login successful
                                    2024-07-12 00:00:04.163 - info: hekr.0 (98780) 1 devices found.
                                    2024-07-12 00:00:04.479 - info: hekr.0 (98780) 1 template found.
                                    2024-07-12 00:00:08.690 - info: feiertage.0 (98901) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v20.15.1, js-controller: 5.0.19
                                    2024-07-12 00:00:08.824 - info: feiertage.0 (98901) Next holiday: Tag der deutschen Einheit is in 83 days on 03.10.2024
                                    2024-07-12 00:00:08.831 - info: feiertage.0 (98901) all objects written
                                    2024-07-12 00:00:08.875 - info: feiertage.0 (98901) Terminated (NO_ERROR): Without reason
                                    2024-07-12 02:01:17.300 - warn: fb-checkpresence.0 (66044) checkDevices: getDeviceList: AxiosError maxContentLength size of -1 exceeded
                                    2024-07-12 03:00:11.924 - warn: broadlink2.0 (99046) device RM:RMMINI-1a-02-40 not found, please rescan later again or delete it! It was: 192.168.57.109,80,10039,Broadlink Mini,0,[object Object],78:0f:77:1a:02:40,RM,RM:RMMINI-1a-02-40,0x2737,RM Mini,RMMINI-1a-02-40,RM:RMMINI-1a-02-40,50
                                    2024-07-12 04:46:32.180 - warn: fb-checkpresence.0 (66044) checkDevices: getDeviceList: AxiosError maxContentLength size of -1 exceeded
                                    2024-07-12 05:04:03.167 - info: javascript.0 (64883) script.js.Meine_Schalter.Büro.Test_Telegram_Menü:
                                    2024-07-12 06:00:00.009 - info: hekr.0 (98780) Scheduled restart.
                                    2024-07-12 06:00:00.015 - info: hekr.0 (98780) terminating
                                    2024-07-12 06:00:00.015 - info: hekr.0 (98780) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2024-07-12 06:00:00.515 - info: hekr.0 (98780) terminating
                                    2024-07-12 06:00:02.482 - info: hekr.0 (99264) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.hekr, node: v20.15.1, js-controller: 5.0.19
                                    2024-07-12 06:00:03.257 - info: hekr.0 (99264) Login successful
                                    2024-07-12 06:00:03.876 - info: hekr.0 (99264) 1 devices found.
                                    2024-07-12 06:00:04.723 - info: hekr.0 (99264) 1 template found.
                                    2024-07-12 06:31:34.430 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Kaffeeautomat einschalten und spülen ist fertig
                                    2024-07-12 06:39:06.821 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Caffè Crema ist fertig
                                    2024-07-12 06:44:13.448 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Caffè Crema ist fertig
                                    2024-07-12 06:45:48.277 - warn: zigbee2mqtt.0 (98069) z2m: Device '0x00158d000487408c' left the network
                                    2024-07-12 06:58:14.862 - info: javascript.0 (64883) Stopping script script.js.Meine_Schalter.Schlafzimmer.Ventilator
                                    2024-07-12 06:58:14.907 - info: javascript.0 (64883) Start JavaScript script.js.Meine_Schalter.Schlafzimmer.Ventilator (Blockly)
                                    2024-07-12 06:58:14.925 - info: javascript.0 (64883) script.js.Meine_Schalter.Schlafzimmer.Ventilator: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                    2024-07-12 07:25:00.649 - info: javascript.0 (64883) Stopping script script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder
                                    2024-07-12 07:25:00.696 - info: javascript.0 (64883) Start JavaScript script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder (Blockly)
                                    2024-07-12 07:25:00.711 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-07-12 07:38:11.826 - error: zigbee2mqtt.0 (98069) zh:zstack:znp: Error while parsing to ZpiObject 'TypeError: Cannot read properties of undefined (reading 'name')
                                    2024-07-12 07:44:33.170 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/2, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":211,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,87,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                                    2024-07-12 07:44:36.178 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 2/2, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":212,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,88,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                                    2024-07-12 07:54:37.189 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":213,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,89,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                                    2024-07-12 07:56:06.936 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 07:56:16.769 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 07:56:23.430 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 07:56:30.058 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 07:56:41.258 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 07:57:31.211 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 07:58:51.162 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:00:12.992 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:00:19.085 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:00:45.364 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:02:50.022 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:04:38.197 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":214,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,90,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                                    2024-07-12 08:07:40.767 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:11:40.196 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:11:50.666 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:14:39.206 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":215,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,91,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                                    2024-07-12 08:18:41.767 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:18:50.614 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                                    2024-07-12 08:24:40.215 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":216,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,92,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                                    • 1Topf
                                      1Topf @biker1602 last edited by
                                      Nur falls es dich noch interessiert, wie man es löscht:
                                      sudo rm -rf /opt/zigbee2mqtt
                                        arteck Developer Most Active @1Topf last edited by
                                        @1topf sagte in Test Adapter zigbee2mqtt:
                                        /opt/zigbee2mqtt
                                        wenns da installiert wurde....
                                        das ist jetzt nicht dein erst oder.. währe da dein Haus explodiert oder hättest du das Internet damit gelöscht oder wie...
                                        kein plan was du da anstellst .. vor allem im HA bareich..
                                        prüfe nochmal alles angefangen von zigbee2mqtt (läuft es ohne fehler) dann den adapter verbindet sich dieser mit zigbee2mqtt ohne fehler..
                                          Ich habe jetzt erst bei HA ein Backup eingespielt den den SLZB neu gestartet und ich kann jetzt wieder Geräte anlernen und obwohl ich availability: true hinterlegt habe, zeigt er mir unter Objekte die Geräte mit Gelb und als nicht verbunden an.
                                          Die Geräte reagieren aber so z.B Bewegungsmelder oder so. Das macht mich stutzig.
                                            @biker1602 hast du alle gesetzt
                                            advanced:
                                                 legacy_api: false
                                                 output: json
                                            device_options:
                                                 legacy: false
                                            availability: true
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            107720
