    3. Einsteigerfragen
    4. Automatisierung
    5. Shuttercontrol mit Shellys 2,5
      Homoran Global Moderator Administrators @Nightfly1983 last edited by
      @nightfly1983 sagte in Shuttercontrol mit Shellys 2,5:
      @homoran Habe jetzt mal den namen geändert, damit keine Umlaute wie ü dabei sind, jetzt steht der Wert auf None.
      das hat nichts damit zu tun, sollte man aber immer machen.
      • Nightfly1983
        Nightfly1983 @Homoran last edited by Homoran
        v6.17.14
        shuttercontrol.0
        	2024-07-12 16:44:57.689	debug	status alarm pending for alias.0.WC.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:44:57.688	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:44:47.685	debug	status alarm pending for alias.0.HWR.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:44:47.685	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:44:37.679	debug	status alarm pending for alias.0.Büro.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:44:37.679	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:44:35.678	debug	outsidetemperature changed: alias.0.Aussenbereich.Temperatur_Haustür.ACTUAL Value: 24.29
        shuttercontrol.0
        	2024-07-12 16:42:02.235	debug	status alarm pending for alias.0.Wohnzimmer.Rollo_Terrasse.SET: false
        shuttercontrol.0
        	2024-07-12 16:42:02.235	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:41:52.229	debug	status alarm pending for alias.0.Wohnzimmer.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:41:52.228	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:41:42.225	debug	status alarm pending for alias.0.Sauna.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:41:42.225	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:41:32.220	debug	status alarm pending for alias.0.Schlafzimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:41:32.220	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:41:22.213	debug	status alarm pending for alias.0.Kind_Ost.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:41:22.213	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:41:15.862	debug	Shutter state changed: Buero old value = 99 new value = 30
        shuttercontrol.0
        	2024-07-12 16:41:15.860	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:41:12.208	debug	status alarm pending for alias.0.Kind_West.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:41:12.208	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:41:03.348	debug	Shutter state changed: Buero old value = 99 new value = 30
        shuttercontrol.0
        	2024-07-12 16:41:03.346	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:41:02.204	debug	status alarm pending for alias.0.Bad.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:41:02.204	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:41:02.099	debug	Shutter state changed: Buero old value = 99 new value = 30
        shuttercontrol.0
        	2024-07-12 16:41:02.097	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:40:52.201	debug	status alarm pending for alias.0.Esszimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:40:52.200	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:40:42.197	debug	status alarm pending for alias.0.Kueche.Rollo_Balkontür.SET: false
        shuttercontrol.0
        	2024-07-12 16:40:42.197	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:40:32.192	debug	status alarm pending for alias.0.Kueche.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:40:32.192	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:40:22.162	debug	status alarm pending for alias.0.WC.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:40:22.162	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:40:15.860	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:40:12.146	debug	status alarm pending for alias.0.HWR.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:40:12.145	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:40:03.346	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:40:02.145	debug	Sunprotect Buero old height: 99% new height: 30%
        shuttercontrol.0
        	2024-07-12 16:40:02.144	debug	last automatic Action for Buero: down_Sunprotect
        shuttercontrol.0
        	2024-07-12 16:40:02.144	debug	Sunprotect Buero old height: 99% new height: 30%
        shuttercontrol.0
        	2024-07-12 16:40:02.144	debug	Temperature inside: 26.27 > 22 AND ( Temperatur outside: 24.81 > 22 AND Light: 0 > 15 )
        shuttercontrol.0
        	2024-07-12 16:40:02.144	debug	Sunprotect for Buero is active
        shuttercontrol.0
        	2024-07-12 16:40:02.096	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:40:02.043	info	Sunprotect #412 Set ID: Buero value: 30%
        shuttercontrol.0
        	2024-07-12 16:40:02.043	debug	Buero: Check basis for sunprotect. Height:99 > HeightDownSun: 30 AND Height:99 == currentHeight:99 AND currentHeight:99 == heightUp:99
        shuttercontrol.0
        	2024-07-12 16:40:02.024	debug	status alarm pending for alias.0.Büro.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:40:02.024	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:40:00.006	debug	Sun Elevation: 40.6°
        shuttercontrol.0
        	2024-07-12 16:40:00.005	debug	Sun Azimut: 254°
        shuttercontrol.0
        	2024-07-12 16:40:00.005	debug	calculate astrodata ...
        shuttercontrol.0
        	2024-07-12 16:39:13.865	debug	Shutter state changed: Terrasse old value = 40 new value = 99
        shuttercontrol.0
        	2024-07-12 16:39:13.863	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:38:49.001	debug	Shutter state changed: Terrasse old value = 40 new value = 99
        shuttercontrol.0
        	2024-07-12 16:38:48.998	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:38:48.937	debug	Shutter state changed: Terrasse old value = 40 new value = 99
        shuttercontrol.0
        	2024-07-12 16:38:48.935	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:38:38.811	debug	Auto Children is: false
        shuttercontrol.0
        	2024-07-12 16:38:38.791	debug	complete down at 22:00
        shuttercontrol.0
        	2024-07-12 16:38:38.790	debug	late down at 23:00
        shuttercontrol.0
        	2024-07-12 16:38:38.790	debug	Shutdown shutters sleep area: 21:33 debug 4
        shuttercontrol.0
        	2024-07-12 16:38:38.789	debug	Shutdown shutters children area: 21:00 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	shutterDownLiving
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	Shutdown shutters living area: 19:30 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	yes, IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	check IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	Starting up shutters children area: 06:00 debug 8
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	yes, IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	check IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	check IsEqual : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	check IsEqual : 06:00 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	check IsLater : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.788	debug	check IsLater : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.787	debug	Starting up shutters sleep area: 08:00 debug 6
        shuttercontrol.0
        	2024-07-12 16:38:38.787	debug	yes, IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:38.787	debug	check IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:38.787	debug	check IsLater : 05:22 08:00
        shuttercontrol.0
        shuttercontrol.0
        	2024-07-12 16:38:38.783	debug	Starting up shutters living area: 05:22 debug 5
        shuttercontrol.0
        	2024-07-12 16:38:38.783	debug	yes, IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.783	debug	check IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.782	debug	yes, IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:38.782	debug	check IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:38.782	debug	check IsLater : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.773	debug	Shutdown shutters Sunset area: 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.773	debug	Starting up shutters Sunrise area: 05:22
        shuttercontrol.0
        	2024-07-12 16:38:38.773	debug	Shutdown shutters GoldenHour area: 20:42
        shuttercontrol.0
        	2024-07-12 16:38:38.772	debug	Starting up shutters GoldenHour area: 06:14
        shuttercontrol.0
        	2024-07-12 16:38:38.769	debug	Sunset today: 21:18
        shuttercontrol.0
        	2024-07-12 16:38:38.769	debug	Sunrise today: 05:07
        shuttercontrol.0
        	2024-07-12 16:38:38.769	debug	current day: 5
        shuttercontrol.0
        	2024-07-12 16:38:38.769	debug	goldenHour today: 20:27
        shuttercontrol.0
        	2024-07-12 16:38:38.769	debug	goldenHourEnd today: 05:59
        shuttercontrol.0
        	2024-07-12 16:38:38.768	debug	calculate astrodata ...
        shuttercontrol.0
        	2024-07-12 16:38:38.768	debug	Travel times of the shutters are calculated
        shuttercontrol.0
        	2024-07-12 16:38:38.700	debug	Auto Sleep is: false
        shuttercontrol.0
        	2024-07-12 16:38:38.688	debug	complete down at 22:00
        shuttercontrol.0
        	2024-07-12 16:38:38.687	debug	late down at 23:00
        shuttercontrol.0
        	2024-07-12 16:38:38.685	debug	Shutdown shutters sleep area: 21:33 debug 4
        shuttercontrol.0
        	2024-07-12 16:38:38.685	debug	Shutdown shutters children area: 21:00 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:38.681	debug	shutterDownLiving
        shuttercontrol.0
        	2024-07-12 16:38:38.681	debug	Shutdown shutters living area: 19:30 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:38.681	debug	yes, IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.681	debug	check IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.680	debug	Starting up shutters children area: 06:00 debug 8
        shuttercontrol.0
        	2024-07-12 16:38:38.680	debug	yes, IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.680	debug	check IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.680	debug	check IsEqual : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.680	debug	check IsEqual : 06:00 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.680	debug	check IsLater : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.680	debug	check IsLater : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.679	debug	Starting up shutters sleep area: 08:00 debug 6
        shuttercontrol.0
        	2024-07-12 16:38:38.679	debug	yes, IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:38.679	debug	check IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:38.678	debug	check IsLater : 05:22 08:00
        shuttercontrol.0
        shuttercontrol.0
        	2024-07-12 16:38:38.676	debug	Starting up shutters living area: 05:22 debug 5
        shuttercontrol.0
        	2024-07-12 16:38:38.676	debug	yes, IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.676	debug	check IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.676	debug	yes, IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:38.676	debug	check IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:38.676	debug	check IsLater : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.671	debug	Shutdown shutters Sunset area: 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.671	debug	Starting up shutters Sunrise area: 05:22
        shuttercontrol.0
        	2024-07-12 16:38:38.671	debug	Shutdown shutters GoldenHour area: 20:42
        shuttercontrol.0
        	2024-07-12 16:38:38.671	debug	Starting up shutters GoldenHour area: 06:14
        shuttercontrol.0
        	2024-07-12 16:38:38.671	debug	Sunset today: 21:18
        shuttercontrol.0
        	2024-07-12 16:38:38.670	debug	Sunrise today: 05:07
        shuttercontrol.0
        	2024-07-12 16:38:38.670	debug	current day: 5
        shuttercontrol.0
        	2024-07-12 16:38:38.670	debug	goldenHour today: 20:27
        shuttercontrol.0
        	2024-07-12 16:38:38.670	debug	goldenHourEnd today: 05:59
        shuttercontrol.0
        	2024-07-12 16:38:38.670	debug	calculate astrodata ...
        shuttercontrol.0
        	2024-07-12 16:38:38.670	debug	Travel times of the shutters are calculated
        shuttercontrol.0
        	2024-07-12 16:38:38.584	debug	Auto Living is: false
        shuttercontrol.0
        	2024-07-12 16:38:38.582	debug	complete down at 22:00
        shuttercontrol.0
        	2024-07-12 16:38:38.581	debug	late down at 23:00
        shuttercontrol.0
        	2024-07-12 16:38:38.580	debug	Shutdown shutters sleep area: 21:33 debug 4
        shuttercontrol.0
        	2024-07-12 16:38:38.579	debug	Shutdown shutters children area: 21:00 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:38.578	debug	shutterDownLiving
        shuttercontrol.0
        	2024-07-12 16:38:38.578	debug	Shutdown shutters living area: 19:30 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:38.578	debug	yes, IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.578	debug	check IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.577	debug	Starting up shutters children area: 06:00 debug 8
        shuttercontrol.0
        	2024-07-12 16:38:38.577	debug	yes, IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.577	debug	check IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.577	debug	check IsEqual : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.577	debug	check IsEqual : 06:00 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.577	debug	check IsLater : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:38.577	debug	check IsLater : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:38.576	debug	Starting up shutters sleep area: 08:00 debug 6
        shuttercontrol.0
        	2024-07-12 16:38:38.576	debug	yes, IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:38.576	debug	check IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:38.576	debug	check IsLater : 05:22 08:00
        shuttercontrol.0
        shuttercontrol.0
        	2024-07-12 16:38:38.575	debug	Starting up shutters living area: 05:22 debug 5
        shuttercontrol.0
        	2024-07-12 16:38:38.575	debug	yes, IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.575	debug	check IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.575	debug	yes, IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:38.575	debug	check IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:38.575	debug	check IsLater : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:38.570	debug	Shutdown shutters Sunset area: 21:33
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	Starting up shutters Sunrise area: 05:22
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	Shutdown shutters GoldenHour area: 20:42
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	Starting up shutters GoldenHour area: 06:14
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	Sunset today: 21:18
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	Sunrise today: 05:07
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	current day: 5
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	goldenHour today: 20:27
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	goldenHourEnd today: 05:59
        shuttercontrol.0
        	2024-07-12 16:38:38.569	debug	calculate astrodata ...
        shuttercontrol.0
        	2024-07-12 16:38:38.568	debug	Travel times of the shutters are calculated
        shuttercontrol.0
        	2024-07-12 16:38:34.082	debug	Auto Children is: false
        shuttercontrol.0
        	2024-07-12 16:38:34.070	debug	complete down at 22:00
        shuttercontrol.0
        	2024-07-12 16:38:34.064	debug	late down at 23:00
        shuttercontrol.0
        	2024-07-12 16:38:34.061	debug	Shutdown shutters sleep area: 21:33 debug 4
        shuttercontrol.0
        	2024-07-12 16:38:34.059	debug	Shutdown shutters children area: 21:00 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:34.056	debug	shutterDownLiving
        shuttercontrol.0
        	2024-07-12 16:38:34.056	debug	Shutdown shutters living area: 19:30 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:34.055	debug	yes, IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:34.055	debug	check IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:34.054	debug	Starting up shutters children area: 06:00 debug 8
        shuttercontrol.0
        	2024-07-12 16:38:34.054	debug	yes, IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:34.054	debug	check IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:34.054	debug	check IsEqual : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:34.054	debug	check IsEqual : 06:00 06:30
        shuttercontrol.0
        	2024-07-12 16:38:34.054	debug	check IsLater : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:34.054	debug	check IsLater : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:34.052	debug	Starting up shutters sleep area: 08:00 debug 6
        shuttercontrol.0
        	2024-07-12 16:38:34.052	debug	yes, IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:34.052	debug	check IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:34.052	debug	check IsLater : 05:22 08:00
        shuttercontrol.0
        	2024-07-12 16:38:34.051	debug	check IsLater : 05:22 08:00
        shuttercontrol.0
        	2024-07-12 16:38:34.049	debug	Starting up shutters living area: 05:22 debug 5
        shuttercontrol.0
        	2024-07-12 16:38:34.049	debug	yes, IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:34.049	debug	check IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:34.049	debug	yes, IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:34.049	debug	check IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:34.049	debug	check IsLater : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:34.038	debug	Shutdown shutters Sunset area: 21:33
        shuttercontrol.0
        	2024-07-12 16:38:34.037	debug	Starting up shutters Sunrise area: 05:22
        shuttercontrol.0
        	2024-07-12 16:38:34.037	debug	Shutdown shutters GoldenHour area: 20:42
        shuttercontrol.0
        	2024-07-12 16:38:34.037	debug	Starting up shutters GoldenHour area: 06:14
        shuttercontrol.0
        	2024-07-12 16:38:34.037	debug	Sunset today: 21:18
        shuttercontrol.0
        	2024-07-12 16:38:34.036	debug	Sunrise today: 05:07
        shuttercontrol.0
        	2024-07-12 16:38:34.036	debug	current day: 5
        shuttercontrol.0
        	2024-07-12 16:38:34.036	debug	goldenHour today: 20:27
        shuttercontrol.0
        	2024-07-12 16:38:34.036	debug	goldenHourEnd today: 05:59
        shuttercontrol.0
        	2024-07-12 16:38:34.036	debug	calculate astrodata ...
        shuttercontrol.0
        	2024-07-12 16:38:34.036	debug	Travel times of the shutters are calculated
        shuttercontrol.0
        	2024-07-12 16:38:33.986	debug	Auto Sleep is: false
        shuttercontrol.0
        	2024-07-12 16:38:33.971	debug	complete down at 22:00
        shuttercontrol.0
        	2024-07-12 16:38:33.971	debug	late down at 23:00
        shuttercontrol.0
        	2024-07-12 16:38:33.968	debug	Shutdown shutters sleep area: 21:33 debug 4
        shuttercontrol.0
        	2024-07-12 16:38:33.967	debug	Shutdown shutters children area: 21:00 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:33.963	debug	shutterDownLiving
        shuttercontrol.0
        	2024-07-12 16:38:33.963	debug	Shutdown shutters living area: 19:30 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:33.963	debug	yes, IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:33.963	debug	check IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:33.962	debug	Starting up shutters children area: 06:00 debug 8
        shuttercontrol.0
        	2024-07-12 16:38:33.962	debug	yes, IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:33.962	debug	check IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:33.962	debug	check IsEqual : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:33.962	debug	check IsEqual : 06:00 06:30
        shuttercontrol.0
        	2024-07-12 16:38:33.962	debug	check IsLater : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:33.962	debug	check IsLater : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:33.960	debug	Starting up shutters sleep area: 08:00 debug 6
        shuttercontrol.0
        	2024-07-12 16:38:33.960	debug	yes, IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:33.960	debug	check IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:33.960	debug	check IsLater : 05:22 08:00
        shuttercontrol.0
        shuttercontrol.0
        	2024-07-12 16:38:33.957	debug	Starting up shutters living area: 05:22 debug 5
        shuttercontrol.0
        	2024-07-12 16:38:33.957	debug	yes, IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:33.957	debug	check IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:33.957	debug	yes, IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:33.957	debug	check IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:33.956	debug	check IsLater : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:33.947	debug	Shutdown shutters Sunset area: 21:33
        shuttercontrol.0
        	2024-07-12 16:38:33.947	debug	Starting up shutters Sunrise area: 05:22
        shuttercontrol.0
        	2024-07-12 16:38:33.947	debug	Shutdown shutters GoldenHour area: 20:42
        shuttercontrol.0
        	2024-07-12 16:38:33.947	debug	Starting up shutters GoldenHour area: 06:14
        shuttercontrol.0
        	2024-07-12 16:38:33.946	debug	Sunset today: 21:18
        shuttercontrol.0
        	2024-07-12 16:38:33.946	debug	Sunrise today: 05:07
        shuttercontrol.0
        	2024-07-12 16:38:33.946	debug	current day: 5
        shuttercontrol.0
        	2024-07-12 16:38:33.946	debug	goldenHour today: 20:27
        shuttercontrol.0
        	2024-07-12 16:38:33.946	debug	goldenHourEnd today: 05:59
        shuttercontrol.0
        	2024-07-12 16:38:33.945	debug	calculate astrodata ...
        shuttercontrol.0
        	2024-07-12 16:38:33.945	debug	Travel times of the shutters are calculated
        shuttercontrol.0
        	2024-07-12 16:38:33.882	debug	Auto Living is: false
        shuttercontrol.0
        	2024-07-12 16:38:33.875	debug	complete down at 22:00
        shuttercontrol.0
        	2024-07-12 16:38:33.874	debug	late down at 23:00
        shuttercontrol.0
        	2024-07-12 16:38:33.865	debug	Shutdown shutters sleep area: 21:33 debug 4
        shuttercontrol.0
        	2024-07-12 16:38:33.864	debug	Shutdown shutters children area: 21:00 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:33.861	debug	shutterDownLiving
        shuttercontrol.0
        	2024-07-12 16:38:33.860	debug	Shutdown shutters living area: 19:30 debug 3
        shuttercontrol.0
        	2024-07-12 16:38:33.860	debug	yes, IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:33.860	debug	check IsEarlier : 19:30 21:33
        shuttercontrol.0
        	2024-07-12 16:38:33.858	debug	Starting up shutters children area: 06:00 debug 8
        shuttercontrol.0
        	2024-07-12 16:38:33.858	debug	yes, IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:33.858	debug	check IsEarlier : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:33.858	debug	check IsEqual : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:33.858	debug	check IsEqual : 06:00 06:30
        shuttercontrol.0
        	2024-07-12 16:38:33.858	debug	check IsLater : 05:22 06:00
        shuttercontrol.0
        	2024-07-12 16:38:33.857	debug	check IsLater : 05:22 06:30
        shuttercontrol.0
        	2024-07-12 16:38:33.850	debug	Starting up shutters sleep area: 08:00 debug 6
        shuttercontrol.0
        	2024-07-12 16:38:33.850	debug	yes, IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:33.850	debug	check IsEqual : 08:00 08:00
        shuttercontrol.0
        	2024-07-12 16:38:33.850	debug	check IsLater : 05:22 08:00
        shuttercontrol.0
        shuttercontrol.0
        	2024-07-12 16:38:33.846	debug	Starting up shutters living area: 05:22 debug 5
        shuttercontrol.0
        	2024-07-12 16:38:33.846	debug	yes, IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:33.846	debug	check IsEarlier : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:33.846	debug	yes, IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:33.846	debug	check IsLater : 05:22 05:00
        shuttercontrol.0
        	2024-07-12 16:38:33.846	debug	check IsLater : 05:22 07:00
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	Shutdown shutters Sunset area: 21:33
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	Starting up shutters Sunrise area: 05:22
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	Shutdown shutters GoldenHour area: 20:42
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	Starting up shutters GoldenHour area: 06:14
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	Sunset today: 21:18
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	Sunrise today: 05:07
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	current day: 5
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	goldenHour today: 20:27
        shuttercontrol.0
        	2024-07-12 16:38:33.834	debug	goldenHourEnd today: 05:59
        shuttercontrol.0
        	2024-07-12 16:38:33.833	debug	calculate astrodata ...
        shuttercontrol.0
        	2024-07-12 16:38:33.833	debug	Travel times of the shutters are calculated
        shuttercontrol.0
        	2024-07-12 16:38:13.862	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:37:58.944	debug	Shuttercontrol save all shutter states
        shuttercontrol.0
        	2024-07-12 16:37:48.998	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:37:48.944	debug	shutterUpButton Terrasse old height: 40% new height: 99%
        shuttercontrol.0
        	2024-07-12 16:37:48.935	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:37:48.885	info	Button autoAll Set ID: Terrasse value: 99%
        shuttercontrol.0
        	2024-07-12 16:37:48.885	info	Set ID: Terrasse to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:37:48.883	debug	status frost alarm for alias.0.Wohnzimmer.Rollo_Terrasse.SET: false
        shuttercontrol.0
        	2024-07-12 16:37:48.882	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:37:38.880	debug	shutterUpButton Wohnzimmer old height: 99% new height: 99%
        shuttercontrol.0
        	2024-07-12 16:37:38.872	info	Set ID: Wohnzimmer to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:37:38.870	debug	status frost alarm for alias.0.Wohnzimmer.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:37:38.869	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:37:28.868	debug	shutterUpButton Sauna old height: 99% new height: 99%
        shuttercontrol.0
        	2024-07-12 16:37:28.860	info	Set ID: Sauna to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:37:28.858	debug	status frost alarm for alias.0.Sauna.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:37:28.856	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:37:18.856	debug	shutterUpButton Schlafzimmer old height: 26% new height: 26%
        shuttercontrol.0
        	2024-07-12 16:37:18.846	info	Set ID: Schlafzimmer to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:37:18.845	debug	status frost alarm for alias.0.Schlafzimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:37:18.843	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:37:08.842	debug	shutterUpButton Kind_Ost old height: 99% new height: 99%
        shuttercontrol.0
        	2024-07-12 16:37:08.835	info	Set ID: Kind_Ost to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:37:08.833	debug	status frost alarm for alias.0.Kind_Ost.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:37:08.832	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:36:58.831	debug	shutterUpButton Kind_West old height: 30% new height: 30%
        shuttercontrol.0
        	2024-07-12 16:36:58.824	info	Set ID: Kind_West to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:36:58.823	debug	status frost alarm for alias.0.Kind_West.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:36:58.821	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:36:51.042	debug	Shutter state changed: Buero old value = new value = 99
        shuttercontrol.0
        	2024-07-12 16:36:50.943	debug	Shutter state changed: Buero old value = new value = 99
        shuttercontrol.0
        	2024-07-12 16:36:50.919	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:36:50.797	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:36:48.821	debug	shutterUpButton Bad old height: 30% new height: 30%
        shuttercontrol.0
        	2024-07-12 16:36:48.806	info	Set ID: Bad to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:36:48.804	debug	status frost alarm for alias.0.Bad.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:36:48.787	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:36:48.717	debug	Shutter state changed: Buero old value = new value = 99
        shuttercontrol.0
        	2024-07-12 16:36:48.716	debug	#0 wait for shutter check end
        shuttercontrol.0
        	2024-07-12 16:36:38.786	debug	shutterUpButton Esszimmer old height: 99% new height: 99%
        shuttercontrol.0
        	2024-07-12 16:36:38.779	info	Set ID: Esszimmer to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:36:38.778	debug	status frost alarm for alias.0.Esszimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:36:38.776	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:36:28.775	debug	shutterUpButton Balkon old height: 99% new height: 99%
        shuttercontrol.0
        	2024-07-12 16:36:28.769	info	Set ID: Balkon to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:36:28.766	debug	status frost alarm for alias.0.Kueche.Rollo_Balkontür.SET: false
        shuttercontrol.0
        	2024-07-12 16:36:28.764	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:36:18.764	debug	shutterUpButton Kuechenfenster old height: 99% new height: 99%
        shuttercontrol.0
        	2024-07-12 16:36:18.756	info	Set ID: Kuechenfenster to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:36:18.754	debug	status frost alarm for alias.0.Kueche.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:36:18.753	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:36:08.752	debug	shutterUpButton WC old height: 30% new height: 30%
        shuttercontrol.0
        	2024-07-12 16:36:08.744	info	Set ID: WC to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:36:08.742	debug	status frost alarm for alias.0.WC.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:36:08.740	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:35:58.739	debug	shutterUpButton HWR old height: 30% new height: 30%
        shuttercontrol.0
        	2024-07-12 16:35:58.731	info	Set ID: HWR to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:35:58.729	debug	status frost alarm for alias.0.HWR.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:58.727	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:35:50.919	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:35:50.796	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:35:48.727	debug	shutterUpButton Buero old height: % new height: 99%
        shuttercontrol.0
        	2024-07-12 16:35:48.715	debug	#0 wait for shutter check started
        shuttercontrol.0
        	2024-07-12 16:35:48.667	info	Button autoAll Set ID: Buero value: 99%
        shuttercontrol.0
        	2024-07-12 16:35:48.666	info	Set ID: Buero to Auto-Mode
        shuttercontrol.0
        	2024-07-12 16:35:48.665	debug	status frost alarm for alias.0.Büro.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:48.662	debug	start checking frost alarm
        shuttercontrol.0
        	2024-07-12 16:35:48.662	debug	start buttonAction
        shuttercontrol.0
        	2024-07-12 16:35:47.817	debug	status alarm pending for alias.0.Kind_West.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:47.816	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:42.128	debug	status alarm pending for alias.0.Kueche.Rollo_Balkontür.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:42.127	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:38.570	debug	status alarm pending for alias.0.Wohnzimmer.Rollo_Terrasse.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:38.570	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:37.799	debug	status alarm pending for alias.0.Bad.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:37.799	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:35.636	debug	status alarm pending for alias.0.Wohnzimmer.Rollo_Terrasse.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:35.635	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:32.124	debug	status alarm pending for alias.0.Kueche.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:32.124	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:28.567	debug	status alarm pending for alias.0.Wohnzimmer.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:28.567	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:27.786	debug	status alarm pending for alias.0.Esszimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:27.786	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:25.632	debug	status alarm pending for alias.0.Wohnzimmer.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:25.632	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:22.118	debug	status alarm pending for alias.0.WC.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:22.117	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:18.565	debug	status alarm pending for alias.0.Sauna.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:18.565	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:17.784	debug	status alarm pending for alias.0.Kueche.Rollo_Balkontür.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:17.784	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:15.629	debug	status alarm pending for alias.0.Sauna.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:15.628	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:12.113	debug	status alarm pending for alias.0.HWR.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:12.113	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:08.560	debug	status alarm pending for alias.0.Schlafzimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:08.559	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:07.781	debug	status alarm pending for alias.0.Kueche.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:07.780	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:05.623	debug	status alarm pending for alias.0.Schlafzimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:05.623	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:02.111	debug	Buero: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight: AND currentHeight: == heightUp:99
        shuttercontrol.0
        	2024-07-12 16:35:02.024	debug	status alarm pending for alias.0.Büro.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:35:02.024	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:35:00.005	debug	Sun Elevation: 41.3°
        shuttercontrol.0
        	2024-07-12 16:35:00.004	debug	Sun Azimut: 252.8°
        shuttercontrol.0
        	2024-07-12 16:35:00.004	debug	calculate astrodata ...
        shuttercontrol.0
        	2024-07-12 16:34:58.554	debug	status alarm pending for alias.0.Kind_Ost.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:58.553	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:57.776	debug	status alarm pending for alias.0.WC.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:57.776	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:55.617	debug	status alarm pending for alias.0.Kind_Ost.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:55.616	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:48.511	debug	status alarm pending for alias.0.Kind_West.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:48.510	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:47.772	debug	status alarm pending for alias.0.HWR.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:47.772	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:45.612	debug	status alarm pending for alias.0.Kind_West.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:45.612	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:38.465	debug	status alarm pending for alias.0.Bad.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:38.464	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:37.771	debug	Buero: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight: AND currentHeight: == heightUp:99
        shuttercontrol.0
        	2024-07-12 16:34:37.766	debug	status alarm pending for alias.0.Büro.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:37.766	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:35.764	debug	insidetemperature changed: alias.0.Schlafzimmer.Temperatur.ACTUAL Value: 26.4
        shuttercontrol.0
        	2024-07-12 16:34:35.608	debug	status alarm pending for alias.0.Bad.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:35.608	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:28.457	debug	status alarm pending for alias.0.Esszimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:28.457	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:25.604	debug	status alarm pending for alias.0.Esszimmer.Rollo.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:25.604	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:18.446	debug	status alarm pending for alias.0.Kueche.Rollo_Balkontür.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:18.446	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:15.601	debug	status alarm pending for alias.0.Kueche.Rollo_Balkontür.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:15.601	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:08.443	debug	status alarm pending for alias.0.Kueche.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:08.443	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        shuttercontrol.0
        	2024-07-12 16:34:05.597	debug	status alarm pending for alias.0.Kueche.Rollo_Fenster.SET: false
        shuttercontrol.0
        	2024-07-12 16:34:05.597	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
        • Nightfly1983
          @homoran Kannst den Eintrag auch löschen nach dem lesen.
          Wenn ich das richtig lese, sagt er zwar, dass er den Wert auf 30 gesetzt hat, aber das Rollo hat sich nicht bewegt, es ist immer noch offen.
            Homoran Global Moderator Administrators @Nightfly1983 last edited by Homoran
            sieht so aus, aber da verstehe ich einiges nicht.
            ist bei dir 99 ganz offen? nicht 100?
            Was ist mit den Alarmen, hast du welche definiert?
            hast du einen Helligkeitssensor?
            ich sehe Buero aber auch noch Büro
            Nightfly1983 2 Replies Last reply Reply Quote 0
            • Nightfly1983
              @homoran Habe 99% als Maxwert, damit die Motoren nicht immer bis zum Anschlag fahren.
              Habe nur den Frostalarm aktiviert.
              Helligkeitssensor habe ich keinen, da aber auch keinen Wert drin stehen.
              Büre müsste jetzt weg sein, war anfangs nach dem Umbenennen beides drin.
              • Nightfly1983
                @homoran Stimmt, warum steht da AND und nicht wie bei anderen ein OR 🤔
                  Wo steht ein OR?
                  warum steht da AND
                  weil alle Bedingungen zutreffen müssen.
                  Nightfly1983 1 Reply Last reply Reply Quote 0
                  • da_Woody
                    da_Woody @Nightfly1983 last edited by
                    was soll das für einen sinn haben? wenn der 2.5er richtig kalibriert ist, ist das kein problem.
                    sollte aber auch der motor mit den endpunkten richtig eingestellt sein.
                    endschalter haben ja ihre berechtigung. hardware/software seitig.
                    • Nightfly1983
                      Nightfly1983 @da_Woody last edited by
                      @da_woody Hat ja jetzt mit dem Problem nix zu tun.
                      • Nightfly1983
                        @homoran Na nur Innen/Außentemperatur & Himmelsrichtung kann man ja nicht wählen, die Helligkeit zählt da doch als ODER Funktion zu den ersteren, auch wenn man keinen Sensor hat. Nur was stellt man da ein?
                        Heute sind ausgerechnet die Temperaturen weniger, da geht grad keiner in dei Beschattung.
                        • Nightfly1983
                          Nightfly1983 @Nightfly1983 last edited by Nightfly1983
                          @Homoran ohne etwas zu ändern war das Rollo heute wieder im Manu_Mode
                          • da_Woody
                            @nightfly1983 bist du dir da sicher?
                            genau der adapter hat durch diverse sonderwünsche ein ausmass angenommen, wo die einstellungen kompliziert sind/wurden.
                            ist halt meine meinung...
                              wieso nicht, hab ich doch.
                              nein, immer UND
                              und was sagt der debug log zu dem Zeitpunkt?
                              • Nightfly1983
                                @homoran said in Shuttercontrol mit Shellys 2,5:
                                Gibt es doch nur in Kombination mit der Helligkeit
                                Konnte ich nicht mehr einsehen.
                                Aktuell funktioniert die Beschattung, jedoch ist das Rollo immer wieder im Manu_Mode. Setze ich diese wieder auf Auto geht es. Muss noch rauskriegen wieso dies passiert.
                                  jedoch ist das Rollo immer wieder im Manu_Mode. .... Muss noch rauskriegen wieso dies passiert.
                                  genau.
                                  Möglicherweise ist der timeout für die Erkennung der vollständigen Fahrdauer zu gering eingestellt.
                                  • da_Woody
                                    da_Woody @Homoran last edited by
                                    @homoran wäre eine möglichkeit...
                                      Homoran Global Moderator Administrators @da_Woody last edited by
                                      @da_woody ich meinte aber im Shuttercontrol.
                                      Schelliese kenn ich nicht.
                                      • Nightfly1983
                                        Sorry, dass so lange keine Reaktion kam. Family first, dann die technischen Spielereien.
                                        Also nach dem ich den Rollladen im iobroker des Öfteren auf den automatischen modus gesetzt habe (2-3 Tage in Folge), bleibt dieser in dem Modus und der Rollladen macht auch erfolgreich die Beschattung. Danke für eure Unterstützung 😊
                                        2612
