    4. Panasonic comfort cloud Adapter funktioniert nicht mehr
    • FragMike
      FragMike @emil70 last edited by
      @emil70 eben auf neue Version geändert und noch einmal mein Passwort eingegeben. Geht jetzt wieder.
      • Marcel 2
        Marcel 2 last edited by
        Hallo, der Adapter bringt bei mir wieder folgenden Fehler.
        Neue Passworteingabe habe ich probiert, bisher ohne Erfolg.
        panasonic-comfort-cloud.0
        2024-06-25 11:14:32.107	error	Service error: Request failed with status code 403 undefined. Code=undefined. Stack: ServiceError: Request failed with status code 403 undefined at new ServiceError (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/model/ServiceError.js:23:28) at ComfortCloudClient.handleError (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:193:31) at ComfortCloudClient.<anonymous> (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:107:30) at step (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:33:23) at Object.throw (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:14:53) at rejected (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:6:65) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          emil70 last edited by emil70
          ich habe seit 2-3 Wochen auch ein Problem
          Service error: Request failed with status code 400 Missing required header parameter or bad request for header. Code=4000. Stack: ServiceError: Request failed with status code 400 Missing required header parameter or bad request for header at new ServiceError (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/model/ServiceError.js:23:28) at ComfortCloudClient.handleError (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:193:31) at ComfortCloudClient.<anonymous> (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:228:30) at step (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:33:23) at Object.throw (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:14:53) at rejected (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:6:65) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          Über adapter nicht zu nutzen. übers App geht es
          Mein Problem ist schon bekannt
          issues
            Es gibt eine neue Version, die wieder läuft
            Danke an Marc2016
            K B 2 Replies Last reply Reply Quote 0
              lulu99 last edited by
              Ich würde gerne von 2.3.0 updaten, aber ioBroker zeigt mir beim Adapter kein Update an. Weiß vielleicht jemand was ich machen kann?
                Thomas Braun Most Active @lulu99 last edited by
                @lulu99
                latest:	3.0.1 for 1 days
                stable:	2.3.0 for 6 months
                Also derzeitig über das Beta-Repository verfügbar.
                Pick das aus dem Reiter 'npm' (ggfls. Experten-Optionen einschalten).
                  lulu99 @Thomas Braun last edited by
                  @thomas-braun Danke dir für die schnelle Hilfe!!!
                    kklaus @emil70 last edited by kklaus
                    @emil70 Hallo,
                    bei mir muss ich den Adapter nun etwa einmal am Tag neu starten, da er irgendwann gelb wird und nicht mehr funktioniert. Tritt das Problem auch bei anderen auf oder ist sogar eine Lösung bekannt? Nutze Version 3.01
                      emil70 @kklaus last edited by
                      @kklaus
                      ich lassen es bei mir auch 1 x morgen neu starten über Cron. Da er auch gelb wurden
                        @emil70 Ok, wie stelle ich das ein? Ich bin im Expertenmodus und kann dort zeitsteuerung einstellen. Was trage ich da ein?
                          @kklaus
                          so wie im Bild
                          Version 3.0.2 ist auch raus
                            @emil70 Danke
                              balu67 @emil70 last edited by
                              @emil70 said in Panasonic comfort cloud Adapter funktioniert nicht mehr:
                              funktioniert bei dir die Version noch?
                                emil70 @balu67 last edited by emil70
                                @balu67
                                Nein, gerade mal geguckt. Seit wann weiss ich nicht
                                Log
                                	2024-11-06 20:37:21.466	error	Service error: Request failed with status code 401 New version app has been published.
                                	Code=4106. Stack: ServiceError: Request failed with status code 401 New version app has been published at ComfortCloudClient.handleError
                                	(/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:147:31)
                                	at ComfortCloudClient.login (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:66:18)
                                	at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async PanasonicComfortCloud.onReady
                                	(/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:65:9)
                                Edit: Wurde auch schon gemeldet
                                  bei mir gehts seit Sonntag nicht mehr. Hab ich gleich gemerkt, weil es im Haus sau kalt war 🙂
                                    @balu67
                                    beim App gab es auch ein Update, gerade mal geschaut.
                                    Denke der Adapter muss angepasst werden. Da die Appversion eine Andere sein wird
                                      der Adapter wurde angepasst und funktioniert wieder. Danke an den Entwickler
                                      Ist müsst auf GitHub die neue Version installieren
                                      B T 4 Replies Last reply Reply Quote 0
                                        reicht es nicht, die APP-Version zu erhöhen?
                                          timaios2000 @emil70 last edited by timaios2000
                                          bei mir verbindet sich der Adapter zwar wieder, aber Werte gibt es keine. Hier mal die Fehlermeldungen:
                                          2024-11-10 11:25:36.716 - info: panasonic-comfort-cloud.0 (391) starting. Version 3.0.3 (non-npm: marc2016/ioBroker.panasonic-comfort-cloud) in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v20.18.0, js-controller: 6.0.11
                                          2024-11-10 11:25:37.074 - info: panasonic-comfort-cloud.0 (391) Loaded app version from GitHub: 1.21.0
                                          2024-11-10 11:25:41.201 - info: panasonic-comfort-cloud.0 (391) Login successful.
                                          2024-11-10 11:25:42.257 - error: panasonic-comfort-cloud.0 (391) Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid')
                                          at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:99:40
                                          at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23)
                                          at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14)
                                          at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:97:54
                                          at ComfortCloudClient.getGroups (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:96:49)
                                          at async PanasonicComfortCloud.onReady (/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:72:24)
                                          E S 2 Replies Last reply Reply Quote 0
                                            @balu67
                                            Nein, es wurden Anpassungen vorgenommen
                                            71
                                            7985
