    4. Neuer Adapter: SMA Wechselrichter mit sbfspot
    • Q
      Qlink last edited by
      ich hätte gerade probiert den Adapter zu installieren, es kommt aber folgende FM:
      $ ./iobroker add sbfspot
      npm install iobroker.sbfspot --production --prefix "C:/ioBroker" (System call)
      node-pre-gyp ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.13/node-v46-win32-x64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.13 and node@4.5.0 (node-v46 ABI) (falling back to source compile with node-gyp)
      gyp
       ERR! configure error
      gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR!
       stack     at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:449:14)gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11
      gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:82:15)
      gyp ERR! System Windows_NT 10.0.14393
      gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\\ioBroker\\node_modules\\iobroker.sbfspot\\node_modules\\sqlite3\\lib\\binding\\node-v46-win32-x64\\node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=C:\\ioBroker\\node_modules\\iobroker.sbfspot\\node_modules\\sqlite3\\lib\\binding\\node-v46-win32-x64"
      gyp ERR! cwd C:\ioBroker\node_modules\iobroker.sbfspot\node_modules\sqlite3
      gyp ERR! node -v v4.5.0
      gyp ERR! node-gyp -v v3.4.0
      gyp
      ERR!
       not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute 'node-gyp.cmd configure --fallback-to-build --module=C:\ioBroker\node_modules\iobroker.sbfspot\node_modules\sqlite3\lib\binding\node-v46-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\ioBroker\node_modules\iobroker.sbfspot\node_modules\sqlite3\lib\binding\node-v46-win32-x64' (1)node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(C:\ioBroker\node_modules\iobroker.sbfspot\node_modules\sqlite3\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
      node-pre-gyp ERR! stack     at emitTwo (events.js:87:13)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:172:7)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:829:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
      node-pre-gyp ERR! System Windows_NT 10.0.14393node-pre-gyp ERR!
      command "C:\\Program Files\\nodejs\\node.exe" "C:\\ioBroker\\node_modules\\iobroker.sbfspot\\node_modules\\sqlite3\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd C:\ioBroker\node_modules\iobroker.sbfspot\node_modules\sqlite3
      node-pre-gyp ERR! node -v v4.5.0
      node-pre-gyp ERR! node-pre-gyp -v v0.6.38
      node-pre-gyp ERR! not ok
      npm
      ERR! Windows_NT 10.0.14393npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.sbfspot" "--production" "--prefix" "C:/ioBroker"
      npm ERR! node v4.5.0npm ERR! npm  v2.15.9
      npm ERR! code ELIFECYCLE
      npm ERR! sqlite3@3.1.13 install: `node-pre-gyp install --fallback-to-build`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the sqlite3@3.1.13 install script 'node-pre-gyp install --fallback-to-build'.
      npm
      ERR! This is most likely a problem with the sqlite3 package,npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node-pre-gyp install --fallback-to-build
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs sqlite3
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR!     npm owner ls sqlite3
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     C:\ioBroker\node_modules\iobroker\npm-debug.log
      host.iobroker install adapter sbfspot
      gyp
      gyp ERR! stack
      gyp ERR! not ok
      node-pre-gyp
       ERR! build error
      node-pre-gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\ioBroker\\node_modules\\iobroker.sbfspot\\node_modules\\sqlite3\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
      npm
      npm ERR! npm ERR! Failed at the sqlite3@3.1.13 install script 'node-pre-gyp install --fallback-to-build'.
      npm
      npm ERR!
      npm ERR!
       Please include the following file with any support request:npm ERR!     C:\ioBroker\node_modules\iobroker\npm-debug.log
      gyp
      gyp ERR! not ok
      node-pre-gyp
      ERR!
       build error
      npm
      npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.sbfspot" "--production" "--prefix" "C:/ioBroker"npm ERR! node v4.5.0
      npm ERR! npm ERR!
       Failed at the sqlite3@3.1.13 install script 'node-pre-gyp install --fallback-to-build'.npm ERR! This is most likely a problem with the sqlite3 package,
      npm
       ERR! Or if that isn't available, you can get their info via:npm ERR!
      npm ERR! Please include the following file with any support request:npm ERR!     C:\ioBroker\node_modules\iobroker\npm-debug.log
      ERROR: host.iobroker Cannot install sbfspot
      ERROR: process exited with code 13</anonymous></anonymous></anonymous>
      Tut wohl nicht so mit sqlite oder gibts hier ein anderes Problem ?
      Beste Grüße
      • Rene_HM
        Rene_HM Developer last edited by
        Der continous integration mit AppVeyor und travis sagt etwas ähnliches:
        auf x86-Systemen mit nodejs 4 kann anscheinend sqlite3 3.1.8 oder höher nicht gebaut werden.
        Auf Linux-Systemen scheint das kein Problem zu sein…
        Wenn man auf eine 2.0.14 von sqlite3 zurückspringt, funktioniert Windows, aber dann Linux nicht mehr 😢
        AppVeyor sagt aber auch, dass das Ganze mit nodejs 6 oder 8 funktionieren sollte...
        • Rene_HM
          Jetzt ist endlich continous integration mit AppVeyor und travis grün.
          Ich habe die sqlite3 Version auf 3.1.7 zurück gesetzt, das ist die gleiche, die auch ioBroker.sql nutzt.
          Damit habe ich nun die Version 1.0.0 auf github und npm released.
            philipp485 last edited by
            Hallo Rene,
            erstmal vielen Dank, dass du einen Adapter für sbfspot geschrieben hast. Ich nutze sbfspot schon länger, um mir per Node-RED die aktuellen Werte live in der Vis anzeigen zu lassen.
            Ich habe deinen Adapter gerade installiert, bekomme aber bei dem regelmäßigen Task, der sich die Variablen aus der SQLite holt folgenden Fehler:
            host.iobroker	2017-12-26 16:55:00.269	info	instance system.adapter.sbfspot.0 terminated with code 0 (OK)
            sbfspot.0	2017-12-26 16:55:00.261	info	terminating
            sbfspot.0	2017-12-26 16:55:00.252	debug	cleaned everything up...
            sbfspot.0	2017-12-26 16:55:00.252	error	at Statement. (/opt/iobroker/node_modules/iobroker.sbfspot/sbfspot.js:430:13)
            sbfspot.0	2017-12-26 16:55:00.252	error	at GetInverter (/opt/iobroker/node_modules/iobroker.sbfspot/sbfspot.js:457:13)
            sbfspot.0	2017-12-26 16:55:00.252	error	at DB_GetInvertersData (/opt/iobroker/node_modules/iobroker.sbfspot/sbfspot.js:480:19)
            sbfspot.0	2017-12-26 16:55:00.252	error	--> in Database#all('SELECT * from SpotData where Serial =xxxxxxxxxx ORDER BY TimeStamp DESC LIMIT 1', [Function])
            sbfspot.0	2017-12-26 16:55:00.252	error	at Statement. (/opt/iobroker/node_modules/iobroker.sbfspot/sbfspot.js:481:13)
            sbfspot.0	2017-12-26 16:55:00.252	error	ReferenceError: GetInverterterData is not defined
            sbfspot.0	2017-12-26 16:55:00.252	error	uncaught exception: GetInverterterData is not defined
            sbfspot.0	2017-12-26 16:55:00.247	debug	SELECT * from SpotData where Serial =xxxxxxxxxx ORDER BY TimeStamp DESC LIMIT 1
            sbfspot.0	2017-12-26 16:55:00.244	info	got data from SB 5000TL-21 with ID xxxxxxxxxx
            sbfspot.0	2017-12-26 16:55:00.244	debug	rows [{"Serial":xxxxxxxxxx,"Name":"SN: xxxxxxxxxx","Type":"SB 5000TL-21","SW_Version":"02.81.01.R","TimeStamp":1514303685,"TotalPac":0,"EToday":5.179,"ETotal":8576.84,"OperatingTime":5729.71,"FeedInT
            sbfspot.0	2017-12-26 16:55:00.238	debug	SELECT * from Inverters
            sbfspot.0	2017-12-26 16:55:00.238	debug	sqlite Database is connected ...
            sbfspot.0	2017-12-26 16:55:00.237	debug	--- connecting to /usr/share/solar/sbfspot.3/SBFspot.db
            sbfspot.0	2017-12-26 16:55:00.204	info	start with mySQL
            sbfspot.0	2017-12-26 16:55:00.203	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v8.9.3
            sbfspot.0	2017-12-26 16:55:00.194	debug	statesDB connected
            sbfspot.0	2017-12-26 16:55:00.187	debug	objectDB connected
            host.iobroker	2017-12-26 16:55:00.010	info	instance system.adapter.sbfspot.0 started with pid 22775
            Hast du eine Idee, woran das liegen könnte?
            Viele Grüße
            Philipp
            • Rene_HM
              @philipp485:
              Hast du eine Idee, woran das liegen könnte? `
              Ich habe den Fehler gefunden und behoben. Im github liegt die Version 1.0.1. Diese Version behebt den typo wie oben beschrieben und enthält noch einen bug fix für die Abfrage der historischen Daten bei Verwendung von sqlite. mySQL betrifft die beiden Änderungen nicht…
              Grüße René
                @Rene_HM:
                @philipp485:
                Grüße René `
                Perfekt, schaut erstmal gut aus. Werte sind nun gefüllt. Danke! 🙂
                Allerdings sieht das Widget seeeeeehr komisch aus bei mir … muss ich mir mal die Tage genauer anschauen, was da wieder falsch ist. 😄
                • Rene_HM
                  so komisch ist das gar nicht. Hier werden mehrere Graphen parallel dargestellt und auf die Zeichenfläche formatiert.
                  Die schmalen Balken sind die letzten 30 Tage, die breiten blauen sind wahrscheinlich die Daten vom aktuellen Tag (wenn wenige Daten vorliegen) und die breiten gelben könnten die letzen beiden Jahre darstellen…
                  Ich würde dazu raten, jeweils ein separates widget für Tag, letzte 30 Tage, letzte 12 Monate und Jahre zu verwenden. Dann sieht das auch besser aus. Siehe auch ein paar posts weiter oben...
                    @Rene_HM:
                    Ich würde dazu raten, jeweils ein separates widget für Tag, letzte 30 Tage, letzte 12 Monate und Jahre zu verwenden. Dann sieht das auch besser aus. Siehe auch ein paar posts weiter oben... `
                    Ah ok, das macht Sinn. 😄 Nun siehts schon besser aus, allerdings zeigt er mir die X-Achsen-Beschriftung nicht an. Gibts da noch etwas, was ich irgendwo einstellen muss?
                    • Rene_HM
                      In den settings im widget unter Allgemein gibt es die Option "Zeige X-Achse" …
                        @Rene_HM:
                        In den settings im widget unter Allgemein gibt es die Option "Zeige X-Achse" … `
                        Die hatte ich natürlich aktiviert … macht aber keinen Unterschied ob deaktiviert oder aktiviert - X-Achsen-Beschriftung fehlt :?
                        • Rene_HM
                          Kannst du von der console vom browser das log schicken? (gern auch per PN)
                          Im chrome unter "weitere Tools" und dann "Entwicklertools" aktivieren. Dann vis evtl. im edit-Mode neu laden. Evtl. reichen die logs schon zur Fehleranalyse, falls nicht, baue ich noch ein paar schnell ein…
                          • Rene_HM
                            Ich habe in der Zwischenzeit das widget komplett überarbeitet.
                            Es gibt nun nur noch einen Graph pro widget, da man sowieso immer nur einen vernünftig darstellen kann. In den Einstellungen kann man einstellen, was man darstellen will. Damit werden ein paar Grundeinstellungen automatisch angepasst (OID und Zeit/Datumsformat).
                            Außerdem wird die OID auch nach Änderung der WR-Seriennummer neu erstellt, vorher war das nur bei Änderung der Instanz der Fall.
                            Falls die Einstellung im widget sich nach dem update nicht ändert, hilft ein````
                            iobroker upload vis
                            Der Adapter ist nun auch für admin3 nutzbar…
                              A Former User last edited by
                              Kann mir einer erklären was die Auswahl bei "Zeitinterval" bewirkt?
                                Heilu last edited by
                                Hallo, super Adapter. Endlich vernünftig Daten auswerten. 😉
                                Aber mit der Darstellung des Widget gibt es bei mir Probleme. Leider finde ich den Fehler nicht. Alle Json in den Objekt History enthalten Werte. Für die 30-Tage sind der Juni, Juli und August enthalten. Im Widget wird aber bei 5 Labels 3x Juli und 3x August dargestellt?! Dazu kommt, dass die Darstellung auf Mobilgeräten gar nicht da ist, sondern nur über dem Browser des PC. Weiß leider überhaupt nicht, wo ich da ansetzen soll.
                                Falls einer eine Idee hat…
                                Heiko
                                Noch etwas aufgefallen: Ich habe die Daten in eine Tabelle übernommen. Dabei werden die Werte der einzelnen Jahre jedes mal summiert, sodass für 2018 jetzt die Gesamtleistung meiner Anlage angezeigt wird. Ähnlich ist es für die Monate, wobei in der Grafik die Werte richtig sind. :roll:
                                Hier noch ein Auszug aus der Log
                                2018-08-01 15:40:01.339 - debug: sbfspot.0 objectDB connected
                                2018-08-01 15:40:01.426 - debug: sbfspot.0 statesDB connected
                                2018-08-01 15:40:01.554 - info: sbfspot.0 starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v8.11.3
                                2018-08-01 15:40:01.797 - info: sbfspot.0 start with sqlite
                                2018-08-01 15:40:01.798 - debug: sbfspot.0 --- connecting to /home/pi/smadata/SBFspot.db
                                2018-08-01 15:40:01.799 - debug: sbfspot.0 sqlite Database is connected ...
                                2018-08-01 15:40:01.800 - debug: sbfspot.0 SELECT * from Inverters
                                2018-08-01 15:40:01.831 - debug: sbfspot.0 rows [{"Serial":2100138924,"Name":"SN: 2100138924","Type":"SB 4000TL-20","SW_Version":"02.07.00.R","TimeStamp":1533130564,"TotalPac":2485,"EToday":18.797,"ETotal":37093.8,"OperatingTime":36300.3,"FeedInTime":35006.2,"Status":"OK","GridRelay":"Closed","Temperature":62.73}]
                                2018-08-01 15:40:01.832 - info: sbfspot.0 got data from SB 4000TL-20 with ID 2100138924
                                2018-08-01 15:40:01.847 - debug: sbfspot.0 SELECT * from SpotData where Serial =2100138924 ORDER BY TimeStamp DESC LIMIT 1
                                2018-08-01 15:40:01.865 - debug: sbfspot.0 rows [{"TimeStamp":1533130564,"Serial":2100138924,"Pdc1":1647,"Pdc2":872,"Idc1":6.606,"Idc2":3.145,"Udc1":249.41,"Udc2":277.5,"Pac1":2485,"Pac2":0,"Pac3":0,"Iac1":10.776,"Iac2":0,"Iac3":0,"Uac1":230.6,"Uac2":0,"Uac3":0,"EToday":18797,"ETotal":37093775,"Frequency":50,"OperatingTime":36300.3,"FeedInTime":35006.2,"BT_Signal":81.9608,"Status":"OK","GridRelay":"Closed","Temperature":62.73}]
                                2018-08-01 15:40:01.869 - debug: sbfspot.0 SELECT strftime('%Y-%m-%d', datetime(TimeStamp, 'unixepoch')) as date, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100138924' AND TimeStamp>= 1530538801.869 AND TimeStamp<= 1533130801.869 Group By strftime('%Y-%m-%d', datetime(TimeStamp, 'unixepoch'))
                                2018-08-01 15:40:02.077 - debug: sbfspot.0 rows [{"date":"2018-07-02","ertrag":27161},{"date":"2018-07-03","ertrag":24967},{"date":"2018-07-04","ertrag":24397},{"date":"2018-07-05","ertrag":24304},{"date":"2018-07-06","ertrag":14496},{"date":"2018-07-07","ertrag":25048},{"date":"2018-07-08","ertrag":24221},{"date":"2018-07-09","ertrag":13764},{"date":"2018-07-10","ertrag":7438},{"date":"2018-07-11","ertrag":4915},{"date":"2018-07-12","ertrag":17338},{"date":"2018-07-13","ertrag":13165},{"date":"2018-07-14","ertrag":24257},{"date":"2018-07-15","ertrag":26095},{"date":"2018-07-16","ertrag":25615},{"date":"2018-07-17","ertrag":24028},{"date":"2018-07-18","ertrag":23337},{"date":"2018-07-19","ertrag":25005},{"date":"2018-07-20","ertrag":20363},{"date":"2018-07-21","ertrag":9957},{"date":"2018-07-22","ertrag":19872},{"date":"2018-07-23","ertrag":23823},{"date":"2018-07-24","ertrag":23948},{"date":"2018-07-25","ertrag":20011},{"date":"2018-07-26","ertrag":24071},{"date":"2018-07-27","ertrag":23244},{"date":"2018-07-28","ertrag":10078},{"date":"2018-07-29","ertrag":18836},{"date":"2018-07-30","ertrag":20182},{"date":"2018-07-31","ertrag":22392},{"date":"2018-08-01","ertrag":18797}]
                                2018-08-01 15:40:02.094 - debug: sbfspot.0 SELECT strftime('%Y-%m-%d', datetime(TimeStamp, 'unixepoch')) as date, ETotal FROM `SpotData` WHERE `Serial` = '2100138924' ORDER by `TimeStamp` ASC LIMIT 1
                                2018-08-01 15:40:02.105 - debug: sbfspot.0 prepare: rows [{"date":"2018-06-26","ETotal":36329858}]
                                2018-08-01 15:40:02.106 - debug: sbfspot.0 2018-06-26 36329858
                                2018-08-01 15:40:02.109 - debug: sbfspot.0 SELECT strftime('%H-%i', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100138924' AND TimeStamp>= 1533074402.109 AND TimeStamp<= 1533130802.109 Group By strftime('%H-%i', datetime(TimeStamp, 'unixepoch'))
                                2018-08-01 15:40:02.149 - debug: sbfspot.0 rows [{"time":null,"ertrag":18797}]
                                2018-08-01 15:40:02.154 - debug: sbfspot.0 SELECT strftime('%Y', datetime(TimeStamp, 'unixepoch')) as date, Max(`ETotal`) as ertrag, Min(`ETotal`) as startertrag FROM `SpotData` WHERE `Serial` = '2100138924' Group By strftime('%Y', datetime(TimeStamp, 'unixepoch'))
                                2018-08-01 15:40:02.246 - debug: sbfspot.0 rows [{"date":"2018","ertrag":37093775,"startertrag":0}]
                                2018-08-01 15:40:02.246 - debug: sbfspot.0 2009 705434.1359223301
                                2018-08-01 15:40:02.247 - debug: sbfspot.0 2010 4938038.951456311
                                2018-08-01 15:40:02.247 - debug: sbfspot.0 2011 9170643.766990293
                                2018-08-01 15:40:02.247 - debug: sbfspot.0 2012 13403248.582524274
                                2018-08-01 15:40:02.247 - debug: sbfspot.0 2013 17635853.398058254
                                2018-08-01 15:40:02.248 - debug: sbfspot.0 2014 21868458.213592235
                                2018-08-01 15:40:02.248 - debug: sbfspot.0 2015 26101063.029126216
                                2018-08-01 15:40:02.248 - debug: sbfspot.0 2016 30333667.844660196
                                2018-08-01 15:40:02.248 - debug: sbfspot.0 2017 34566272.66019417
                                2018-08-01 15:40:02.248 - debug: sbfspot.0 2018 73423633
                                2018-08-01 15:40:02.249 - debug: sbfspot.0 [{"year":2009,"value":705434},{"year":2010,"value":4938038},{"year":2011,"value":9170643},{"year":2012,"value":13403248},{"year":2013,"value":17635853},{"year":2014,"value":21868458},{"year":2015,"value":26101063},{"year":2016,"value":30333667},{"year":2017,"value":34566272},{"year":2018,"value":73423633}]
                                2018-08-01 15:40:02.250 - debug: sbfspot.0 SELECT strftime('%Y-%m', datetime(TimeStamp, 'unixepoch')) as date, Max(`ETotal`) as ertrag FROM `SpotData` WHERE `Serial` = '2100138924' AND TimeStamp>= 1501538402.25 AND TimeStamp<= 1533130802.25 Group By strftime('%Y-%m', datetime(TimeStamp, 'unixepoch'))
                                2018-08-01 15:40:02.375 - debug: sbfspot.0 rows [{"date":"2018-06","ertrag":36441049},{"date":"2018-07","ertrag":37074975},{"date":"2018-08","ertrag":37093775}]
                                • Rene_HM
                                  @Heilu:
                                  Dazu kommt, dass die Darstellung auf Mobilgeräten gar nicht da ist, sondern nur über dem Browser des PC. `
                                  Du meinst die ioBroker.vis Android App? Das ist klar, da dort die widgets in die app "hineinkompiliert" werden müssen. Dieser pull request ist noch offen…
                                  Ich nutze die App nicht mehr. Stattdessen nutze ich meine eigene (siehe [viewtopic.php?f=35&t=9716]. Die kann auch die vis anzeigen, braucht aber kein update, wenn mal ein widget neu ist…
                                  @Heilu:
                                  Im Widget wird aber bei 5 Labels 3x Juli und 3x August dargestellt?! `
                                  Kannst du davon mal einen screen shoot posten?
                                  @Heilu:
                                  Dabei werden die Werte der einzelnen Jahre jedes mal summiert, sodass für 2018 jetzt die Gesamtleistung meiner Anlage angezeigt wird. Ähnlich ist es für die Monate, wobei in der Grafik die Werte richtig sind. `
                                  sbfspot speichert die Werte in dieser Art. Für die Grafik berechne ich die Differenz…
                                    In der json wird Juni, Juli und August angezeigt. Ok, das mit der app werde ich mir mal genauer anschauen. Hast du für die Berechnung der Differenz ein Script was du mir zur Verfügung stellen könntest ?
                                    Danke schon mal
                                    • Rene_HM
                                      Das Problem mit den "doppelten" Datumswerten liegt daran, dass nicht genügend Datenpunkte zur Darstellung verfügbar sind. In den Graph-Einstellungen kann man angeben, wieviele Ticks auf der X-Achse dargestellt werden sollen. Wenn dieser Wert größer ist, als die zur Verfügung stehenden Daten, erzeugt flot solche "doppelten" Werte.
                                      Als Lösung sehe ich drei Möglichkeiten:
                                      1. warten, bis genügend Werte in der Datenbank vorhanden sind
                                      2. manuell Daten für die Vergangenheit in die Datenbank eintragen
                                      3. update der Adapter-Version: in Adapter - Version 2.2.4 (derzeit nur auf github) habe ich die Anpassung eingebaut (d.h. ich reduziere die Ticks)
                                        > 2) update der Adapter-Version: in Adapter - Version 2.2.4 (derzeit nur auf github) habe ich die Anpassung eingebaut (d.h. ich reduziere die Ticks)
                                        Getestet, das sieht schon besser aus.
                                        Welche Möglichkeit gibt es das im vis darzustellen? Die Widgets werden ja nur auf dem PC dargestellt und nicht auf Tablets. Wäre das ein großer Aufwand das in einer nächsten Version einzubinden?
                                        Ansonsten läuft alles super.
                                        Danke dafür
                                        • Rene_HM
                                          im browser werden die widgets auch auf einem tablet angezeigt. Wie gesagt, Ich verwende dafür meine app
                                          https://play.google.com/store/apps/details?id=eu.rg_engineering.hometabremote. Im Prinzip nutze ich auch da auch einen browser…
                                          Den pull request für die vis app mache ich noch...
                                            Super,
                                            vielen Dank für deine Mühe
                                            248
                                            40873
