    4. [Javascript] Midas (Aquatemp) Poolheizung
      sunnylaila @Michael Roling last edited by
      @michael-roling
      Habe den Adapter gerade nochmal neu gestartet hier der log
      2024-07-13 22:38:08.380	error	Error in updateToken(): "TypeError: Cannot read properties of undefined (reading 'deviceCode')\n at updateDeviceID (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/lib/updateDeviceId.js:87:56)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async updateToken (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/lib/token.js:72:7)\n at async MidasAquatemp.onReady (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/main.js:74:5)"
      midas-aquatemp.0
      2024-07-13 22:38:08.377 error Error in updateToken(): {}
      midas-aquatemp.0
      2024-07-13 22:38:08.325 info Token: DUEH/4eWeBmqKXli/ow4n8RmDGpRTbM8dFrxwTfV1m8Q2iKxnMJQJZvmJf7GEPVzfkZ5ZX3FuvyvU2l6xWgJxQ==
      midas-aquatemp.0
      2024-07-13 22:38:08.323 info Login ok! Token:
      midas-aquatemp.0
      2024-07-13 22:38:07.842 info Request token
      midas-aquatemp.0
      2024-07-13 22:38:07.739 info starting. Version 0.0.1 (non-npm: MiRo1310/ioBroker.midas-aquatemp#a9191e54de055a8df15987a6cd243a8f3f50331c) in /opt/iobroker/node_modules/iobroker.midas-aquatemp, node: v20.15.1, js-controller: 5.0.19
      • Michael Roling
        Michael Roling Developer @sunnylaila last edited by
        @sunnylaila Nicht neu starten, sondern einmal von Github installieren
          @michael-roling
          habe ihn jetzt deinstalliert und neu installiert aber immer noch kein login siehe log
          2024-07-13 22:51:55.950	error	Error in updateDeviceID(): "TypeError: Cannot read properties of undefined (reading 'deviceCode')\n at updateDeviceID (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/src/lib/updateDeviceId.js:46:58)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async updateToken (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/src/lib/token.js:44:13)\n at async MidasAquatemp.onReady (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/src/main.js:75:9)"
          midas-aquatemp.0
          2024-07-13 22:51:55.948 error Error in updateDeviceID(): {}
          midas-aquatemp.0
          2024-07-13 22:51:55.902 info Login ok! Token: TE4egOhJDnfr1iSnp1IiHvEcRDOVwSPL9u4rn/V0M6aMyfjLQmc7xJCjKSML+114fkZ5ZX3FuvyvU2l6xWgJxQ==
          midas-aquatemp.0
          2024-07-13 22:51:55.343 info Request token
          midas-aquatemp.0
          2024-07-13 22:51:55.288 info starting. Version 0.0.1 (non-npm: MiRo1310/ioBroker.midas-aquatemp#354ac4bcb4b693502de3c03a627303b1ced29cb1) in /opt/iobroker/node_modules/iobroker.midas-aquatemp, node: v20.15.1, js-controller: 5.0.19
          midas-aquatemp.0
          2024-07-13 22:51:52.483 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          midas-aquatemp.0
          2024-07-13 22:51:52.479 error midas-aquatemp.0 invalid process id scenario 21674 vs. own ID 21622. Stopping
          midas-aquatemp.0
          2024-07-13 22:51:49.106 info terminating
          midas-aquatemp.0
          2024-07-13 22:51:48.634 warn Got terminate signal. Checking desired PID: 21622 vs own PID 18866
          midas-aquatemp.0
          2024-07-13 22:51:48.604 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          midas-aquatemp.0
          2024-07-13 22:51:48.602 info terminating
          midas-aquatemp.0
          2024-07-13 22:51:48.600 warn Got terminate signal. Checking desired PID: 0 vs own PID 18866
          • Michael Roling
            @sunnylaila Wie hast du denn neu installiert? Du musst einfach über die Katze mit der Url https://github.com/MiRo1310/ioBroker.midas-aquatemp.git instalieren
              @michael-roling
              genau so habe ich es installiert.
              er logt sich ja auch ein und bekommt einen Token aber hat den Fehler
              vielleicht ist da das Problem?
              • O
                oxident last edited by
                Also ich für meinen Teil kann zumindest sagen, dass die Abfrage bestens funktioniert (habe aber auch exakt das gleiche Modell wie MIchael) und der Adapter sehr schnell auf "grün" wechselt.
                Derzeit ist zwar noch alles schreibgeschützt, aber das liegt daran, dass bestimmt in dieser Minute dran gearbeitet wird 😉
                S Michael Roling 2 Replies Last reply Reply Quote 0
                  sunnylaila @oxident last edited by
                  @oxident
                  hallo Oxident vielleicht hilft das ja bei der Fehlersuche bei deinem Javascript v0.12
                  bekomme ich die gleiche Fehlermeldung
                  javascript.0 09:20:02.428 info Start JavaScript script.js.Poolheizung_neu (Javascript/js)
                  javascript.0 09:20:02.436 info script.js.Poolheizung_neu: erstelle Objekte
                  javascript.0 09:20:02.612 info script.js.Poolheizung_neu: registered 3 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                  javascript.0 09:20:02.910 error script.js.Poolheizung_neu: Fehler in updateDeviceID(): TypeError: Cannot read properties of undefined (reading 'deviceCode')
                  Gruß Sunnylaila
                  • Michael Roling
                    @sunnylaila wichtig ist es nicht das Skript und den Adapter gleichzeitig laufen zu lassen
                    • Michael Roling
                      Michael Roling Developer @oxident last edited by Michael Roling
                      @oxident was ist noch schreibgeschützt?
                      Ohh das war ein Fehler im Code. Habe das gefixt. Ich bekomme aber einfach den Iobroker Integration test nicht grün. 😡
                      Evtl einmal die states löschen und neu erstellen lassen vom adapter
                        @michael-roling , ich habe sie einzeln getestet aber halt mit dem gleichen Ergebnis.
                        • Michael Roling
                          @sunnylaila Hat das denn schon mal bei dir funktioniert
                            @michael-roling , ja das hat es musste aber 2 neue Accounts anlegen in der Aqua Temp App da ich nur noch mit dem iobroker und nicht mehr mit der App reingekommen bin in der App hies es immer Falsches Passwort habe dann 2 neue Accounts angelegt. jetzt komme ich mit der App wieder rein und im iobroker halt die updateDevice Fehlermeldung.
                            • O
                              oxident @Michael Roling last edited by
                              @michael-roling Hatte ich eigentlich schon. Probiere aber nochmal. Mir war im Code auf die Schnelle aufgefallen, dass alle States als write: false angelegt werden. Oder hab ich das falsch gelesen?
                              @sunnylaila Um mögliche Fehler auszuschließen: Hast Du mal die Aquatemp-App mit dem iob-Account probiert? Der Hersteller hat da echt fiese Stolperfallen eingebaut, das nervt wirklich, daher muss man sich da immer langsam herantasten. Für mich sieht es jetzt so aus, als wären bei dem Account keine Geräte hinterlegt.
                              Michael Roling S 2 Replies Last reply Reply Quote 0
                              • Michael Roling
                                @oxident du musst aber auch vorher von github neu
                                installieren
                                  @oxident
                                  Hallo, habe ich auch probiert das sehe ich die Anlage und kann sie auch steuern, hatte
                                  sogar zum Testen noch eine dritte Mail hinzugefügt auf einem dritten Gerät auch das geht in der App und im iobroker immer der gleiche Fehler mit dem updatedevice
                                  Michael Roling O 2 Replies Last reply Reply Quote 0
                                  • Michael Roling
                                    @sunnylaila Ich habe noch mal was geändert. Kannste noch mal von Github laden und testen. Ich bin erstmal raus.
                                    • O
                                      @michael-roling Jepp, hatte ich vorhin gemacht, aber ich glaube, das war zwischen zwei Commits 😉
                                      Checke ich später nochmal.
                                      Danke auch für die Einladung.
                                      • Michael Roling
                                        @oxident gerne. Lass uns aber vorher sprechen bevor du etwas anpassen möchtest. Damit wir uns nicht gegenseitig überschreiben.
                                        • O
                                          @michael-roling Na klar 😉
                                          • O
                                            oxident @sunnylaila last edited by
                                            @sunnylaila Habe zwar noch keine Lösung, aber schreibe hier mal als "Referenz", dass der Fehler
                                            Fehler in updateDeviceID(): {"error_msg":"请重新登录","error_msg_code":"","isReusltSuc":false,"objectResult":null,"error_code":"-100"}
                                            auf eine Doppelnutzung des Accounts (z. B. gleichzeitig mit der Aquatemp-App) hindeutet.
                                            Ich weiß, bei Dir ist der Fehler anders, daher können wir den Grund schonmal ausschließen 😄
                                            359
                                            70580
