    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      micha2020 @Thomas Braun last edited by micha2020
      @thomas-braun Ok, bekommst du. Dachte das wäre zu viel...
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: IO-Broker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.2.16-19-pve
          Architecture: x86-64
      model name      : Intel(R) N97
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       22:12:36 up 67 days,  2:45,  2 users,  load average: 0.53, 0.63, 0.55
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Thu 2024-07-04 22:12:36 CEST
                 Universal time: Thu 2024-07-04 20:12:36 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      micha
      HOME=/home/micha
      GROUPS=micha sudo users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            8.6G        5.0G        656M         98K        2.9G        3.6G
      Swap:           1.1G        1.1G         18M
      Total:          9.7G        6.1G        674M
      Active iob-Instances:   33
               8192 M total memory
               4795 M used memory
               2661 M active memory
               4612 M inactive memory
                625 M free memory
                  0 M buffer memory
               2771 M swap cache
               1024 M total swap
               1006 M used swap
                 17 M free swap
      top - 22:12:36 up 67 days,  2:45,  2 users,  load average: 0.65, 0.65, 0.56
      Tasks:  57 total,   1 running,  56 sleeping,   0 stopped,   0 zombie
      %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,    623.7 free,   4797.0 used,   2771.3 buff/cache
      MiB Swap:   1024.0 total,     17.3 free,   1006.7 used.   3395.0 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--112--disk--0 ext4       79G  9.9G   65G  14% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
      tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
      tmpfs                            tmpfs     3.1G  108K  3.1G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                                  SOURCE                           FSTYPE     OPTIONS
      /                                                       /dev/mapper/pve-vm--112--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3228332k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      | |-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
      | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8036616k,nr_inodes=2009154,mode=755,inode64
      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8036616k,nr_inodes=2009154,mode=755,inode64
      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8036616k,nr_inodes=2009154,mode=755,inode64
      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8036616k,nr_inodes=2009154,mode=755,inode64
      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8036616k,nr_inodes=2009154,mode=755,inode64
      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8036616k,nr_inodes=2009154,mode=755,inode64
      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      585M    /var/
      302M    /var/cache
      298M    /var/cache/apt
      223M    /var/cache/apt/archives
      146M    /var/lib
      Archived and active journals take up 15.4M in the file system.
      /opt/iobroker/backups:
      114M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      5.9G    /opt/iobroker/iobroker-data/
      5.3G    /opt/iobroker/iobroker-data/history
      482M    /opt/iobroker/iobroker-data/files
      169M    /opt/iobroker/iobroker-data/history/20240624
      169M    /opt/iobroker/iobroker-data/history/20240623
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.3-1nodesource1
        Version table:
           18.20.3-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
       *** 18.20.2-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.17.14
      javascript:     8.3.1
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : IO-Broker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : IO-Broker                                -  enabled
      + system.adapter.backitup.0               : backitup              : IO-Broker                                -  enabled
      + system.adapter.discovery.0              : discovery             : IO-Broker                                -  enabled
        system.adapter.feiertage.0              : feiertage             : IO-Broker                                -  enabled
        system.adapter.flot.0                   : flot                  : IO-Broker                                - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : IO-Broker                                -  enabled
      + system.adapter.history.0                : history               : IO-Broker                                -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : IO-Broker                                -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : IO-Broker                                -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: IO-Broker                                - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : IO-Broker                                - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IO-Broker                                - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IO-Broker                                - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: IO-Broker                                - disabled
      + system.adapter.info.0                   : info                  : IO-Broker                                -  enabled
      + system.adapter.iot.0                    : iot                   : IO-Broker                                -  enabled
        system.adapter.jarvis.0                 : jarvis                : IO-Broker                                - disabled
      + system.adapter.javascript.0             : javascript            : IO-Broker                                -  enabled
      + system.adapter.kecontact.0              : kecontact             : IO-Broker                                -  enabled
      + system.adapter.kecontact.1              : kecontact             : IO-Broker                                -  enabled
      + system.adapter.linux-control.0          : linux-control         : IO-Broker                                -  enabled
      + system.adapter.modbus.0                 : modbus                : IO-Broker                                -  enabled
      + system.adapter.modbus.1                 : modbus                : IO-Broker                                -  enabled
        system.adapter.mqtt.0                   : mqtt                  : IO-Broker                                - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : IO-Broker                                -  enabled
      + system.adapter.proxmox.0                : proxmox               : IO-Broker                                -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : IO-Broker                                -  enabled
      + system.adapter.pushover.1               : pushover              : IO-Broker                                -  enabled
      + system.adapter.pushover.2               : pushover              : IO-Broker                                -  enabled
        system.adapter.schoolfree.0             : schoolfree            : IO-Broker                                -  enabled
      + system.adapter.shelly.0                 : shelly                : IO-Broker                                -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : IO-Broker                                -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : IO-Broker                                -  enabled, port: 5000
      + system.adapter.telegram.0               : telegram              : IO-Broker                                -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : IO-Broker                                -  enabled
      + system.adapter.tr-064.0                 : tr-064                : IO-Broker                                -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : IO-Broker                                -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IO-Broker                                - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IO-Broker                                - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : IO-Broker                                - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IO-Broker                                - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : IO-Broker                                - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IO-Broker                                - disabled
        system.adapter.vis.0                    : vis                   : IO-Broker                                -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : IO-Broker                                -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : IO-Broker                                -  enabled
      + system.adapter.web.0                    : web                   : IO-Broker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                   : worx                  : IO-Broker                                -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.17.14  , installed 6.17.14
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fullybrowser" : 3.0.12   , installed 2.2.0  [Updatable]
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
      Adapter    "kecontact"    : 2.2.0    , installed 2.2.0
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "worx"         : 3.0.2    , installed 3.0.2
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Objects and States
      Objects:        14295
      States:         12073
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 53
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       432606154  522420/io.sonoff.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       422972176  491803/io.shelly.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       297327225  124/iobroker.js-con
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       297328287  124/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          297326981  1/init
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          297329108  292/master
      tcp        0      0 192.168.2.12:2010       0.0.0.0:*               LISTEN      1001       422971676  491552/io.hm-rpc.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       457459003  635596/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       422972346  492014/io.web.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          297329109  292/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          297326983  1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          297329776  1/init
      udp        0      0 0.0.0.0:40906           0.0.0.0:*                           1001       474364544  700090/io.kecontact
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          297326982  1/init
      udp        0      0 0.0.0.0:36320           0.0.0.0:*                           1001       474367334  700097/io.kecontact
      udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       474367327  700097/io.kecontact
      udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       474364534  700090/io.kecontact
      udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       474367328  700097/io.kecontact
      udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       474364535  700090/io.kecontact
      udp6       0      0 :::111                  :::*                                0          297326984  1/init
      2024-07-04 21:50:09.213  - info: host.IO-Broker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2024-07-04 21:54:50.705  - info: web.0 (492014) <== Disconnect system.user.admin from ::ffff:192.168.2.99 vis.0
      2024-07-04 22:00:00.127  - info: host.IO-Broker instance system.adapter.weatherunderground.0 started with pid 719075
      2024-07-04 22:00:01.303  - info: weatherunderground.0 (719075) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v18.20.2, js-controller: 5.0.19
      2024-07-04 22:00:04.194  - info: host.IO-Broker instance system.adapter.ical.0 started with pid 719090
      2024-07-04 22:00:05.423  - info: ical.0 (719090) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
      2024-07-04 22:00:05.848  - info: weatherunderground.0 (719075) Terminated (NO_ERROR): Without reason
      2024-07-04 22:00:05.920  - info: ical.0 (719090) processing URL:  https://.ics
      2024-07-04 22:00:05.951  - info: ical.0 (719090) processing URL: Feiertage https://.ics
      2024-07-04 22:00:06.027  - info: ical.0 (719090) processing URL: Müllkalender https://.ics
      2024-07-04 22:00:06.153  - info: ical.0 (719090) processing URL: Geburtstagskalender https://.ics
      2024-07-04 22:00:06.399  - warn: weatherunderground.0 (719075) get state error: Connection is closed.
      2024-07-04 22:00:06.448  - info: host.IO-Broker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2024-07-04 22:00:06.881  - info: ical.0 (719090) processing URL: Familienkalender https://.ics
      2024-07-04 22:00:12.484  - info: ical.0 (719090) Terminated (NO_ERROR): Without reason
      2024-07-04 22:00:12.997  - info: host.IO-Broker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-07-04 22:02:58.039  - info: web.0 (492014) ==> Connected system.user.admin from ::ffff:192.168.2.106
      2024-07-04 22:03:21.160  - info: web.0 (492014) ==> Connected system.user.admin from ::ffff:192.168.2.106
      2024-07-04 22:03:49.775  - info: web.0 (492014) <== Disconnect system.user.admin from ::ffff:192.168.2.106 flot
      2024-07-04 22:03:49.799  - info: web.0 (492014) <== Disconnect system.user.admin from ::ffff:192.168.2.106 vis.0
      2024-07-04 22:03:50.235  - info: web.0 (492014) ==> Connected system.user.admin from ::ffff:192.168.2.106
      2024-07-04 22:10:00.063  - info: host.IO-Broker instance system.adapter.weatherunderground.0 started with pid 720278
      2024-07-04 22:10:01.267  - info: weatherunderground.0 (720278) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v18.20.2, js-controller: 5.0.19
      2024-07-04 22:10:13.375  - info: weatherunderground.0 (720278) Terminated (NO_ERROR): Without reason
      2024-07-04 22:10:13.884  - info: host.IO-Broker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      iob diag has finished.
      Press any key for a summary
      Ist das denn jetzt richtig eigebettet?
      Ich verstehe hier leider nur Bahnhof erlich gesagt...
        Thomas Braun Most Active @micha2020 last edited by
        @micha2020 sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
        Pending Updates: 53
        Systempflege betreiben.
        Und du bist im Stable-Zweig unterwegs, den Adapter gibt es aber nur im Beta-Repo:
        vw-connect
        latest:	0.6.0 for 84 days
        stable:	-.-.-
          @thomas-braun Ich dacht ich pflege es indem ich ab und zu apt update und apt upgrade ausführe sowie Adapter aktualisiere wenn verfügbar...
          Das mit dem Stable und Beta hatte ich ja schon gepostet...
          Bei Stable bekomme ich gar nichts neues zu sehen und bei Beta nur Version 0.2.0...
          Wie komme ich denn an die Version 0.6.0 ran?
          Sorry, ich kann dir nicht wirklich folgen da ich mich nicht wirklich gut auskenne...
            Thomas Braun Most Active @micha2020 last edited by Thomas Braun
            Dann solltest du das wesentlich häufiger machen.
            iob repo unset stable
            iob repo set beta
            iob update
            iob upgrade vw-connect@0.6.0
            iob repo unset beta
            iob repo set stable
            iob update
              @thomas-braun Hammer! Vielen vielen Dank! Hat alles geklappt. Daten kommen wieder an. Sind zwar teilweise andere Datenpunkte und ich muss die VIS anpassen, aber das ist kein Problem. Dann hab ich am WE was schönes zu tun 😉
              Ich danke nochmal allen die mir geholfen oder mitgelesen haben, besonders @Thomas-Braun
              Ich werde künftig dann den Standard-User nutzen, noch öfter Update/Upgrade ausführen (gerade noch mal nachgeholt) und bei Problemen gerne wieder dieses Forum durchforsten und /oder nachfragen.
              Vielen Dank nochmal und eine gute Nacht an alle 👋
                pingo @micha2020 last edited by pingo
                Ich habe Version 0.6.0 laufen, aber seit einiger Zeit werden die Datenpunkte nicht mehr durchgängig upgedated. Z.B. als SOC meines Id.Buzz wird 70 % angezeigt, aber im Auto sind es 75%.
                Hat VW ein Serverproblem oder stimmt etwas mit meiner Instanz nicht?
                • BananaJoe
                  BananaJoe Most Active @pingo last edited by
                  @pingo sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                  Jupp. Hab heut den Tag über diverse Fehlermeldungen dazu im Log gehabt (bei mir ist auf einem 2. Bildschirm eigentlich immer eine puTTY-Sitzung offen in der das ioBroker-Log durchscrollt)
                  G 1 Reply Last reply Reply Quote 2
                    guitardoc @BananaJoe last edited by guitardoc
                    @bananajoe Gabs auch schon Tage, wo VW kein Serverproblem hatte? Bei mir ist das Log ständig mit Fehlermeldungen vom VW-Adapter voll. Letztens konnte ich mich nicht mal mehr an meinem eigenen Auto anmelden und musste als Gast fahren - erst komplettes Zurücksetzen und neu Einrichten meines Profils hat es mir erlaubt, mein eigenes Fahrzeug mit meinen eigenen Einstellungen zu nutzen... Vielleicht sollte VW die Daten per Fax schicken, geht bestimmt schneller und zuverlässiger... 🙂
                      headder9999 last edited by
                      ich hoffe ich platziere meine Frage hier richtig:
                      Ich möchte mich gerne benachrichtigen (per Telegram), wenn a) mein Auto geladen wird und b) ein PV Akku eine Schwelle von x% (in meinem Fall 20%) unterschreitet.
                      Das Blockly hierzu habe ich auch erfolgreich geschrieben bis auf die Bedingung a) wenn mein Auto geladen wird.
                      Weiß jemand wo man im "we Connect" auslesen kann, ob gerade geladen wird oder nicht?
                      LIeben Dank & viele Grüße
                        micha2020 @headder9999 last edited by micha2020
                        @headder9999 der Datenpunkt --> vw-connect.0.[Fahrgestellnummer].status.services.charging.status sollte gehen denke ich...
                        oder sonst der Datenpunkt --> vw-connect.0.[Fahrgestellnummer].status.services.charging.remainingTime da hier auch nur eine Restladezeit angegeben ist, wenn er lädt. Sonst steht dort 0 soweit ich weiß...
                        • amg_666
                          amg_666 @micha2020 last edited by amg_666
                          Hallo, ich hab seit heute einen neuen skoda Octavia, da will der Adapter nicht so richtig.
                          Hauptuser ist im Fzg eingerichtet und in der Skoda App, funktioniert alles.
                          Adapter bleibt gelb und im Log steht
                          vw-connect.0
                          	2024-07-22 21:37:50.975	error	No Token received. Please try to logout and login in the VW app or select type VWv2 in the settings
                          vw-connect.0
                          	2024-07-22 21:37:50.874	info	https://identity.vwgroup.io/signin-service/v1/consent/users/xxxxxxx@apps_vw-dilab_com?scopes=openid%20mbb%20profile&relayState=axxxxxxx&callback=https://identity.vwgroup.io/oidc/v1/oauth/client/callback&hmac=xxxxxxx
                          vw-connect.0
                          	2024-07-22 21:37:50.873	warn	No Token received visiting url and accept the permissions or login and accept
                          vw-connect.0
                          	2024-07-22 21:37:49.840	info	Login in with skoda
                          vw-connect.0
                          	2024-07-22 21:37:49.799	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v20.15.1, js-controller: 6.0.9
                          Ich hab mich in der App mal aus-/eingeloggt, das hat aber nix gebracht. Diesen Fehler wurde in diesem Thread auch weiter oben schon öfter gemeldet, ich hab da aber keine Lösung gesehen. Ist das ggf. ein temporäres Problem?
                          • O
                            oxident @amg_666 last edited by
                            @amg_666 Ist bei mir seit vorhin auch so ... habe aber nichts am Fzg oder dergleichen geändert.
                            • amg_666
                              amg_666 @oxident last edited by
                              @oxident Du kannst mal folgendes versuchen (hats bei mir gebracht:
                              Kopiere die URL aus dem logfile
                              und geb die in einem Browserfenster ein. Bei mir kam dann von Skoda die Aufforderung Datenzugriff freizugeben. Das hab ich gemacht, Adapter neu gestartet und es lief.
                              amg_666 R A 3 Replies Last reply Reply Quote 0
                              • amg_666
                                amg_666 @amg_666 last edited by
                                @tombox Gibt es irgendeine Übersicht, was der Adapter (bzw. das Fahrzeug) an Daten liefert?
                                Bei meinem BMW sehe ich für jede Tür/jedes Fenster, den Tankinhalt etc einen Datenpunkt. ei meinem neuen Skoda sehe ich grade mal, dass das Fzg abgeschlossen ist und Längen/Breitengrad wo es sich befindet.
                                Da sind zwar noch jede Menge andere DP, aber die sagen mir alle nix...
                                  TT-Tom @amg_666 last edited by
                                  @amg_666
                                  bei meinem Kodiaq gibt es auch für jede Tür / Fenster usw. einen DP.
                                  ist zwar kryptisch, lässt sich aber durch Probieren ermitteln.
                                    MN78 last edited by MN78
                                    seit 5 Tagen werden die Datenpunkte bei mir nicht mehr aktualisiert. Im Log erscheint error 503. Wo kann der Fehler liegen?
                                    Danke!
                                    vw-connect.0
                                    	2024-07-27 15:25:28.981	info	Minimum update interval is 15min for Wallcharging data, to prevent blocking
                                    vw-connect.0
                                    	2024-07-27 15:25:28.981	info	Wallcharging login was successfull
                                    vw-connect.0
                                    	2024-07-27 15:25:28.539	error	Get Vehicles Failed
                                    vw-connect.0
                                    	2024-07-27 15:25:28.539	error	503
                                    vw-connect.0
                                    	2024-07-27 15:25:28.538	error	"<html>\r\n<head><title>503 Service Temporarily Unavailable</title></head>\r\n<body>\r\n<center><h1>503 Service Temporarily Unavailable</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n"
                                    vw-connect.0
                                    	2024-07-27 15:25:28.371	info	Login successful
                                    vw-connect.0
                                    	2024-07-27 15:25:28.369	info	Login in with id
                                    vw-connect.0
                                    	2024-07-27 15:25:28.369	info	Start Wallcharging login
                                    vw-connect.0
                                    	2024-07-27 15:25:28.369	info	History limit: 100, set to -1 to disable wallcharging login
                                    vw-connect.0
                                    	2024-07-27 15:25:28.368	info	ID login successfull
                                    vw-connect.0
                                    	2024-07-27 15:25:28.079	debug	Error: Invalid protocol: weconnect:
                                    vw-connect.0
                                    	2024-07-27 15:25:27.446	debug	{"date":"Sat, 27 Jul 2024 13:25:27 GMT","content-length":"0","connection":"close",---*gelöscht*---
                                    vw-connect.0
                                    	2024-07-27 15:25:27.446	debug	""
                                    vw-connect.0
                                    	2024-07-27 15:25:27.102	debug	emailPasswordForm2
                                    vw-connect.0
                                    	2024-07-27 15:25:26.740	debug	parseEmailForm
                                    vw-connect.0
                                    	2024-07-27 15:25:25.762	info	Login in with id
                                    vw-connect.0
                                    	2024-07-27 15:25:25.733	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.19
                                      TT-Tom @MN78 last edited by
                                      @mn78 sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                      503
                                      Webservice nicht verfügbar.
                                      dein Login klappt, aber es kommen keine Daten vom Server, vermutlich basteln die wieder.
                                        MN78 @TT-Tom last edited by
                                        @tt-tom App und Web funktioniert einwandfrei. ✌
                                          LiJuDa last edited by
                                          ich besitze seit Anfang Mai einen Skoda Enyaq und habe auch die App (MySkoda) dafür erfolgreich einrichten können. Im ioBroker habe mir nun die Instanz vw-connect mit dem Typ ""Skoda Enyq" eingerichtet. Laut Protokoll funktioniert der Login nun auch aber leider findet er kein Fahrzeug. Könnt ihr mir da weiterhelfen?
                                            astrakid @LiJuDa last edited by
                                            @lijuda https://github.com/TA2k/ioBroker.vw-connect/issues/329
                                            an der schnittstelle hat sich etwas mehr geändert, so dass TA2k das nicht mal eben anpassen konnte. wenn du login daten für ihn hast, freut er sich bestimmt. meine hatte er, aber die zeit reichte nicht, und ich wollte über meinen urlaub den account wieder "sauber" haben.
                                            astrakid created this issue in TA2k/ioBroker.vw-connect
                                            open Skoda Enyaq connect not possible after API change on VW's side #329
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3099
                                            1609578
