    4. Backitup kein JavaScript Restore möglich!
      BenjaminCz @Thomas Braun last edited by
      @thomas-braun weil jetzt sieht es so aus:
      pi@raspberrypi:~ $ mount | sort
      bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
      cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
      configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
      debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
      /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
      /dev/mmcblk0p2 on / type ext4 (rw,noatime)
      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
      devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
      fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
      mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
      proc on /proc type proc (rw,relatime)
      securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
      sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
      systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
      tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
      tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
      tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
      tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
      tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
      pi@raspberrypi:~ $
      Ist Sauber oder ?
        Thomas Braun Most Active @BenjaminCz last edited by
        @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
        Nach dem Backup tut Backitup automatisch unmount machen
        Ja, deswegen muss der mountpunkt /opt/iobroker/backups auch leer sein, wenn die Freigabe nicht gemountet ist.
        oder woher kamen die vielen Mounts
        Keine Ahnung was da eingestellt war. Vermutlich alles unvollständige Backitup-Vorgänge und der mount ist stehen geblieben.
          @thomas-braun ok dann sage ich 1000 mal dank und Schönen abend ! Jetzt eine "sauber" funktionierendes Backup & Restore
            legro @simatec last edited by legro
            @simatec said in Backitup kein JavaScript Restore möglich!:
            @legro mach beibder Fritzbox das, was @Thomas-Braun gesagt hat. Noserverino aktivieren und smb 3.1.1
            Habe ich doch oben geschrieben, dass ich das alles im Vorfeld schon gemacht habe. Sonst hätte doch auch schon das Backup des ioBrokers nicht funktioniert.
              @benjamincz
              ls -lA /opt/iobroker/backups
              zeigt?
                Thomas Braun Most Active @legro last edited by
                @legro sagte in Backitup kein JavaScript Restore möglich!:
                Mach es bitte in einem separaten Thread...
                Hier geht es um NFS.
                  axel last edited by
                  Ich stehe auch vor dem selben Problem. Bei mir hat sich eine VM auf meiner QNAP während eines Versionsupgrade Ubuntu auf 24.04. verabschiedet. Das Imagee Festplatte war nicht mehr einbindbar, vorhandene Snapshots damit unbrauchbar. Das Image ließ sich auch in keine andere VM einbinden.
                  Da ich tägliche Backups mache, habe ich mir gedacht: kein Problem. Ein sauberes Ubuntu 24.o4. Installationsimage gezogen und auf einer neuen VM installiert. Basisinstallation ioBroker drauf, sollte ja mit Restore überschrieben werden. Gesagt getan. Erstes Problem war, dass das ioBroker-Backup von einem Share meiner QNAP nicht einspielbar war. Also, Samba installiert und das Backup nach /opt/iobroker/backups kopiert. Ließ sich dann von lokal einwandfrei und fehlerfrei zurückladen. Noch ein iob fix für alle Fälle.
                  Jetzt das Problem. Bei dem JS Backup das gleiche vorgehen. Leider funktioniert das nicht. Ich bekomme den oben beschriebenen Fehler
                  Error: {"errno":-2,"code":"ENOENT","syscall":"open","path":"/opt/iobroker/backups/tmpScripts/script.json"}
                  bei Restore-Versuch von der NAS und bei lokalen Restore keine verfügbare Datei angezeigt. Muss ein Rechteproblem sein.
                  Wie genau müssen die Dateirechte aussehen? Kann ich mögliche Einschränkungen mit "777" überbügeln und lösen?
                  In der JS-Backupdatei sind alle meine Programme drin. Könnte ich einzel rauskopieren und in JS einfügen. Ist aber eine große Tüftelei, da ich eine recht umfangreiche Installation habe.
                  Über jeden Tipp bin ich Dankbar.
                  Grüße Axel
                    Thomas Braun Most Active @axel last edited by Thomas Braun
                    @axel sagte in Backitup kein JavaScript Restore möglich!:
                    Ein sauberes Ubuntu
                    Ein Widerspruch in sich...
                    Wie und was mountest du denn da genau? Die Mountoptionen für cifs von backitup bringen eigentlich die richtigen Rechte mit.
                    Edit: Gerade spaßeshalber ein JS-Backup per Backitup eingespielt. Funktioniert hier einwandfrei.
                    2024-07-14 12:07:41.437  - info: backitup.0 (15420) DATA: {"type":"nas / copy","fileName":"/opt/iobroker/backups/javascripts_2024_07_14-03_42_38_chet_backupiobroker.tar.gz","currentTheme":"react-dark","currentProtocol":"http:","stopIOB":false}
                    2024-07-14 12:07:41.677  - info: javascript.0 (15361) Got terminate signal TERMINATE_YOURSELF
                    2024-07-14 12:07:41.692  - info: javascript.0 (15361) Stopping script script.js.common.awtrix
                    2024-07-14 12:07:41.694  - info: javascript.0 (15361) Stopping script script.js.common.frostwarner
                    2024-07-14 12:07:41.695  - info: javascript.0 (15361) Stopping script script.js.common.lautstaerke_bad
                    2024-07-14 12:07:41.697  - info: javascript.0 (15361) Stopping script script.js.common.lautstaerke_kueche
                    2024-07-14 12:07:41.697  - info: javascript.0 (15361) Stopping script script.js.common.nuki_ext_wohnungstuer_entriegelt
                    2024-07-14 12:07:41.698  - info: javascript.0 (15361) Stopping script script.js.common.paketlieferungen
                    2024-07-14 12:07:41.700  - info: javascript.0 (15361) Stopping script script.js.common.pakettruhe_offen
                    2024-07-14 12:07:41.700  - info: javascript.0 (15361) Stopping script script.js.common.ps4_waker
                    2024-07-14 12:07:41.701  - info: javascript.0 (15361) Stopping script script.js.common.sonnenaufgang
                    2024-07-14 12:07:41.701  - info: javascript.0 (15361) Stopping script script.js.common.sonnenuntergang
                    2024-07-14 12:07:41.702  - info: javascript.0 (15361) Stopping script script.js.common.speedtest
                    2024-07-14 12:07:41.702  - info: javascript.0 (15361) Stopping script script.js.common.telefon_klingelt
                    2024-07-14 12:07:41.702  - info: javascript.0 (15361) Stopping script script.js.common.treppenhaus_licht_hub
                    2024-07-14 12:07:41.703  - info: javascript.0 (15361) Stopping script script.js.common.tuerklingel_laeutet
                    2024-07-14 12:07:41.703  - info: javascript.0 (15361) Stopping script script.js.common.usv_warner
                    2024-07-14 12:07:41.704  - info: javascript.0 (15361) Stopping script script.js.common.wohnung_verlassen
                    2024-07-14 12:07:41.704  - info: javascript.0 (15361) Stopping script script.js.common.zuhause_verlassen
                    2024-07-14 12:07:41.705  - info: javascript.0 (15361) Stopping script script.js.nuki_extended_restart_fix
                    2024-07-14 12:07:41.705  - info: javascript.0 (15361) Stopping script script.js.solix2mqtt
                    2024-07-14 12:07:41.706  - info: javascript.0 (15361) Stopping script script.js.stromzaehler2
                    2024-07-14 12:07:41.718  - info: javascript.0 (15361) terminating
                    2024-07-14 12:07:41.721  - info: javascript.0 (15361) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2024-07-14 12:07:42.189  - info: javascript.0 (15361) terminating
                    2024-07-14 12:07:49.679  - info: javascript.0 (75561) starting. Version 8.6.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v22.4.1, js-controller: 6.0.8
                    2024-07-14 12:07:50.520  - info: javascript.0 (75561) requesting all states
                    2024-07-14 12:07:50.523  - info: javascript.0 (75561) requesting all objects
                    2024-07-14 12:07:53.191  - info: javascript.0 (75561) received all objects
                    2024-07-14 12:07:53.650  - info: javascript.0 (75561) received all states
                    2024-07-14 12:07:53.825  - info: javascript.0 (75561) Start JavaScript script.js.common.awtrix (Blockly)
                    2024-07-14 12:07:53.897  - info: javascript.0 (75561) script.js.common.awtrix: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:53.905  - info: javascript.0 (75561) Start JavaScript script.js.common.frostwarner (Blockly)
                    2024-07-14 12:07:53.913  - info: javascript.0 (75561) script.js.common.frostwarner: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:53.915  - info: javascript.0 (75561) Start JavaScript script.js.common.lautstaerke_bad (Blockly)
                    2024-07-14 12:07:53.922  - info: javascript.0 (75561) script.js.common.lautstaerke_bad: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:53.923  - info: javascript.0 (75561) Start JavaScript script.js.common.lautstaerke_kueche (Blockly)
                    2024-07-14 12:07:53.929  - info: javascript.0 (75561) script.js.common.lautstaerke_kueche: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:53.930  - info: javascript.0 (75561) Start JavaScript script.js.common.nuki_ext_wohnungstuer_entriegelt (Blockly)
                    2024-07-14 12:07:53.938  - info: javascript.0 (75561) script.js.common.nuki_ext_wohnungstuer_entriegelt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:53.939  - info: javascript.0 (75561) Start JavaScript script.js.common.paketlieferungen (Blockly)
                    2024-07-14 12:07:54.018  - info: javascript.0 (75561) script.js.common.paketlieferungen: registered 1 subscription, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.018  - info: javascript.0 (75561) Start JavaScript script.js.common.pakettruhe_offen (Blockly)
                    2024-07-14 12:07:54.026  - info: javascript.0 (75561) script.js.common.pakettruhe_offen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.027  - info: javascript.0 (75561) Start JavaScript script.js.common.ps4_waker (Blockly)
                    2024-07-14 12:07:54.033  - info: javascript.0 (75561) script.js.common.ps4_waker: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.034  - info: javascript.0 (75561) Start JavaScript script.js.common.sonnenaufgang (Blockly)
                    2024-07-14 12:07:54.041  - info: javascript.0 (75561) script.js.common.sonnenaufgang: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.042  - info: javascript.0 (75561) Start JavaScript script.js.common.sonnenuntergang (Blockly)
                    2024-07-14 12:07:54.049  - info: javascript.0 (75561) script.js.common.sonnenuntergang: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.049  - info: javascript.0 (75561) Start JavaScript script.js.common.speedtest (Javascript/js)
                    2024-07-14 12:07:54.055  - info: javascript.0 (75561) script.js.common.speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
                    2024-07-14 12:07:54.059  - info: javascript.0 (75561) script.js.common.speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 180 Sekunden ausgeführt!
                    2024-07-14 12:07:54.064  - info: javascript.0 (75561) script.js.common.speedtest: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.064  - info: javascript.0 (75561) Start JavaScript script.js.common.telefon_klingelt (Blockly)
                    2024-07-14 12:07:54.072  - info: javascript.0 (75561) script.js.common.telefon_klingelt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.073  - info: javascript.0 (75561) Start JavaScript script.js.common.treppenhaus_licht_hub (Blockly)
                    2024-07-14 12:07:54.079  - info: javascript.0 (75561) script.js.common.treppenhaus_licht_hub: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.079  - info: javascript.0 (75561) Start JavaScript script.js.common.tuerklingel_laeutet (Blockly)
                    2024-07-14 12:07:54.085  - info: javascript.0 (75561) script.js.common.tuerklingel_laeutet: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.086  - info: javascript.0 (75561) Start JavaScript script.js.common.usv_warner (Blockly)
                    2024-07-14 12:07:54.092  - info: javascript.0 (75561) script.js.common.usv_warner: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.092  - info: javascript.0 (75561) Start JavaScript script.js.common.wohnung_verlassen (Blockly)
                    2024-07-14 12:07:54.099  - info: javascript.0 (75561) script.js.common.wohnung_verlassen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.099  - info: javascript.0 (75561) Start JavaScript script.js.common.zuhause_verlassen (Blockly)
                    2024-07-14 12:07:54.105  - info: javascript.0 (75561) script.js.common.zuhause_verlassen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.106  - info: javascript.0 (75561) Start JavaScript script.js.nuki_extended_restart_fix (Javascript/js)
                    2024-07-14 12:07:54.112  - info: javascript.0 (75561) script.js.nuki_extended_restart_fix: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.113  - info: javascript.0 (75561) Start JavaScript script.js.solix2mqtt (Javascript/js)
                    2024-07-14 12:07:54.119  - info: javascript.0 (75561) script.js.solix2mqtt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.120  - info: javascript.0 (75561) Start JavaScript script.js.stromzaehler2 (Javascript/js)
                    2024-07-14 12:07:54.126  - info: javascript.0 (75561) script.js.stromzaehler2: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-07-14 12:07:54.197  - info: javascript.0 (75561) Watch /home/iobroker/skripte/common/
                    2024-07-14 12:07:54.200  - info: javascript.0 (75561) Watch /home/iobroker/skripte/global/
                    2024-07-14 12:07:54.201  - info: javascript.0 (75561) Watch /home/iobroker/skripte/
                    Edit2:
                    Mountoptionen wie folgt:
                    //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                    forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770 sorgt also schon für ausreichende Rechte für den user iobroker.
                      axel @Thomas Braun last edited by
                      Restore
                      User: iobroker auf QNAP
                      Ergebnis:
                      Fehler:
                        axel last edited by
                        und neu:
                        Error: {"errno":-3,"code":"Z_DATA_ERROR"}
                          @axel
                          invalid stored block lengths
                          deutet auf ein korruptes File hin.
                            @axel
                            Könnte das sein:
                            https://github.com/cthackers/adm-zip/issues/473
                            Was liefert
                            cd /opt/iobroker/ && npm ls adm-zip
                            Wobei backitup adm-zip gar nicht verwendet...
                            agubskyy created this issue in cthackers/adm-zip
                            closed Error: invalid stored block lengths. Library can't extract archive after your today's release #473
                              axel last edited by
                              Danke für die Antworten. Aus irgend einem Grund wurden die Scripts restored, trotz Fehlermeldungen. Ist schon komisch, aber mein Problem ist gelöst...
                              Zur Frage:
                              axel@sh:~$ cd /opt/iobroker/ && npm ls adm-zip
                              [sudo] password for axel:
                              iobroker.inst@3.0.0 /opt/iobroker
                              └── (empty)
                              axel@sh:/opt/iobroker$
                              3948
