    4. Zigbee iobroker Error while opening serialport
      Thomas Braun Most Active @stauber last edited by
      @stauber sagte in Zigbee iobroker Error while opening serialport:
      node -v
      sagt?
        stauber @Thomas Braun last edited by
        auch 22
          @stauber
          Bitte keine Bildchen von Text.
          sudo apt update
          sudo apt install nodejs=20.15.1-1nodesource1
            ok das hat funktioniert vielen Dank!
            jetzt mit
            iob diag
            Kannst du mir sagen wo ungefähr die by id steht?
              @stauber
              Poste die Langfassung in Gänze.
                stauber @Thomas Braun last edited by stauber
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                  Operating System: Raspbian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Model           : Raspberry Pi 4 Model B Rev 1.2
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 32 bit
                Systemuptime and Load:
                 19:48:08 up 23:11,  1 user,  load average: 0.64, 0.87, 0.91
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Sun 2024-07-14 19:48:08 CEST
                           Universal time: Sun 2024-07-14 17:48:08 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                *** Display-Server-Setup ***
                Display-Server: false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            3.8G        1.0G        1.5G        0.0K        1.2G        2.7G
                Swap:            99M          0B         99M
                Total:          3.9G        1.0G        1.6G
                Active iob-Instances:   22
                         3793 M total memory
                         1018 M used memory
                         1067 M active memory
                          957 M inactive memory
                         1540 M free memory
                          251 M buffer memory
                          981 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                top - 19:48:09 up 23:11,  1 user,  load average: 0.67, 0.87, 0.91
                Tasks: 174 total,   1 running, 173 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3793.3 total,   1540.2 free,   1019.4 used,   1233.7 buff/cache
                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2697.6 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4      220G  8.2G  203G   4% /
                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                tmpfs          tmpfs     759M  892K  758M   1% /run
                /dev/sda1      vfat      253M   51M  202M  20% /boot
                tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                [Sat Jul 13 20:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:D6:24 vc_mem.mem_base        =0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=61bf9d36-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): write access will be enabled during recovery
                [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): recovery complete
                [Sat Jul 13 20:36:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sat Jul 13 20:36:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Sat Jul 13 20:36:30 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                Show mounted filesystems:
                TARGET                       SOURCE     FSTYPE     OPTIONS
                /                            /dev/sda2  ext4       rw,noatime
                |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
                | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
                | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
                |-/proc                      proc       proc       rw,relatime
                | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
                | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
                |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
                | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
                | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
                `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                /var:
                2.6G    /var/
                1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                1.3G    /var/log
                1.2G    /var/cache/apt
                Archived and active journals take up 1.2G in the file system.
                /opt/iobroker/backups:
                121M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                604M    /opt/iobroker/iobroker-data/
                439M    /opt/iobroker/iobroker-data/files
                138M    /opt/iobroker/iobroker-data/files/javascript.admin
                136M    /opt/iobroker/iobroker-data/backup-objects
                118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if03
                /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100PJ1-if00
                HINT:
                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                /dev/ttyACM0
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.15.1
                /usr/bin/node           v20.15.1
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                /usr/bin/corepack       0.28.1
                nodejs:
                  Installed: 20.15.1-1nodesource1
                  Candidate: 20.15.1-1nodesource1
                  Version table:
                 *** 20.15.1-1nodesource1 600
                        500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                        100 /var/lib/dpkg/status
                     20.15.0-1nodesource1 600
                     20.14.0-1nodesource1 600
                     20.13.1-1nodesource1 600
                     20.13.0-1nodesource1 600
                     20.12.2-1nodesource1 600
                     20.12.1-1nodesource1 600
                     20.12.0-1nodesource1 600
                     20.11.1-1nodesource1 600
                     20.11.0-1nodesource1 600
                     20.10.0-1nodesource1 600
                     20.9.0-1nodesource1 600
                     20.8.1-1nodesource1 600
                     20.8.0-1nodesource1 600
                     20.7.0-1nodesource1 600
                     20.6.1-1nodesource1 600
                     20.6.0-1nodesource1 600
                     20.5.1-1nodesource1 600
                     20.5.0-1nodesource1 600
                     20.4.0-1nodesource1 600
                     20.3.1-1nodesource1 600
                     20.3.0-1nodesource1 600
                     20.2.0-1nodesource1 600
                     20.1.0-1nodesource1 600
                     20.0.0-1nodesource1 600
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.19
                admin:          6.17.14
                javascript:     8.3.1
                nodejs modules from github:     0
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
                + system.adapter.awtrix-light.1           : awtrix-light          : raspberrypi                              -  enabled
                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                  system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                  system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                  system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
                + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
                  system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
                + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                  system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
                  system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
                  system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
                  system.adapter.places.0                 : places                : raspberrypi                              - disabled
                + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                  system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.17.14  , installed 6.17.14
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "birthdays"    : 3.0.0    , installed 3.0.0
                Adapter    "denon"        : 1.15.5   , installed 1.15.5
                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
                Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
                Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
                Adapter    "heos"         : 2.2.1    , installed 2.2.1
                Adapter    "hmip"         : 1.23.3   , installed 1.23.3
                Adapter    "ical"         : 1.15.0   , installed 1.15.0
                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                Adapter    "klf200"       : 1.2.0    , installed 1.2.0
                Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                Adapter    "places"       : 1.2.0    , installed 1.2.0
                Adapter    "rest-api"     : 2.0.1    , installed 2.0.1
                Adapter    "scenes"       : 3.0.4    , installed 3.0.4
                Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                Adapter    "ws"           : 2.6.1    , installed 2.6.1
                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                Objects and States
                Objects:        9591
                States:         7847
                Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      109        14805      522/mosquitto
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       703780     4069/io.shelly.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12860      524/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       702593     3884/iobroker.js-co
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       702596     3884/iobroker.js-co
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       701671     3902/io.admin.0
                tcp6       0      0 :::1883                 :::*                    LISTEN      109        14806      522/mosquitto
                tcp6       0      0 :::22                   :::*                    LISTEN      0          12862      524/sshd: /usr/sbin
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15505      394/avahi-daemon: r
                udp        0      0 127.0.0.1:4002          0.0.0.0:*                           1001       705775     4736/io.govee-local
                udp        0      0 0.0.0.0:34863           0.0.0.0:*                           108        15507      394/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14846      734/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        15506      394/avahi-daemon: r
                udp6       0      0 :::50567                :::*                                108        15508      394/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          15746      734/dhcpcd
                2024-07-14 19:46:11.260  - info: zigbee.0 (4000) Got terminate signal TERMINATE_YOURSELF
                2024-07-14 19:46:11.381  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                2024-07-14 19:46:11.263  - info: zigbee.0 (4000) cleaned everything up...
                2024-07-14 19:46:11.285  - info: zigbee.0 (4000) Zigbee: disabling joining new devices.
                2024-07-14 19:46:11.529  - warn: zigbee.0 (4000) Failed to stop zigbee during startup
                2024-07-14 19:46:11.530  - info: zigbee.0 (4000) terminating
                2024-07-14 19:46:11.531  - info: zigbee.0 (4000) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-07-14 19:46:11.601  - info: zigbee.0 (4000) debug devices set to []
                2024-07-14 19:46:11.765  - info: zigbee.0 (4000) terminating
                2024-07-14 19:46:12.143  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-07-14 19:46:12.272  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                2024-07-14 19:46:12.522  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 5046
                2024-07-14 19:46:18.289  - info: zigbee.0 (5046) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.1, js-controller: 5.0.19
                2024-07-14 19:46:18.399  - info: zigbee.0 (5046) delete old Backup files. keep only last 10
                2024-07-14 19:46:18.402  - info: zigbee.0 (5046) Starting Zigbee  npm ...
                2024-07-14 19:46:18.831  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
                2024-07-14 19:46:39.534  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                2024-07-14 19:46:39.535  - error: zigbee.0 (5046) Failed to start Zigbee
                2024-07-14 19:46:39.536  - error: zigbee.0 (5046) Error herdsman start
                2024-07-14 19:46:49.540  - info: zigbee.0 (5046) Try to reconnect. 1 attempts left
                2024-07-14 19:46:49.541  - info: zigbee.0 (5046) Starting Zigbee  npm ...
                2024-07-14 19:46:49.555  - info: zigbee.0 (5046) Installed Version: iobroker.zigbee@1.10.3
                2024-07-14 19:46:49.827  - error: zigbee.0 (5046) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                2024-07-14 19:46:49.828  - error: zigbee.0 (5046) Failed to start Zigbee
                2024-07-14 19:46:49.829  - error: zigbee.0 (5046) Error herdsman start
                  Userland : 32 bit
                  Beizeiten mal komplett neuaufsetzen, dann in einer reinen 64Bit-Version.
                  Boot Target: graphical.target
                  sudo systemctl set-default multi-user.target
                  Dein Dateisystem hat Einschläge.
                  by-id:
                  einer der beiden Einträge muss in den Einstellungen eingetragen werden. Musst du mal ausprobieren, ob if03 oder if00 passt.
                  Schmeiß die Quelle
                  raus.
                  S arteck 2 Replies Last reply Reply Quote 0
                    by-id:
                    Nein bleibt Orange bei beiden Einträgen
                    kann es sein das die Erweiterte Pan falsch ist? Hab ein Backupgeladen das vor 2 Tagen da ist alles noch gelaufen.
                    Schmeiß die Quelle
                    raus.
                    Wie mach ich das?
                    Vielen Dank für deine Unterstützung und deine Mühen
                      Wie mach ich das?
                      Lösch die entsprechende Zeile in der Datei /etc/apt/sources.list raus.
                        @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
                        pi@raspberrypi:~ $ /etc/apt/sources.list
                        -bash: /etc/apt/sources.list: Keine Berechtigung
                        pi@raspberrypi:~ $
                        er sagt ich habe keine Berechtigung
                          Du verwendest ja auch kein Kommando...
                          sudo nano /etc/apt/sources.list
                          Speichern mit Strg-O, nano verlassen mit Strg-X
                            arteck Developer Most Active @Thomas Braun last edited by arteck
                            -if00
                            ist es immer
                              tut mir leid das ich mich jetzt erst melde hatte viel zu tun in der Arbeit.
                              Heute hab ich einen Stick von Sonoff ausprobiert und siehe das es läuft wieder ich vermute das das Board einfach defekt ist.
                              Danke nochmal für eure Hilfe
                                searcher57 @Thomas Braun last edited by
                                @thomas-braun said in Zigbee iobroker Error while opening serialport:
                                Hallo Thomas,
                                jetzt bin ich am Ende! Nachdem ich Probleme mit dem Smartmeter-Adapter (Stromwerte), RPI2 Adapter (Gaswerte) kommt jetzt auch noch der Zigbee Adapter hinzu. Ich habe alles rauf und runter mit einem Raspi 5 8GB probiert. Danach habe ich den Raspi 4 8GB getestet. Auch da bekomme ich den Adapter nicht ans laufen.
                                Hier das Log des Raspi 5:
                                zigbee.0
                                	2024-09-26 15:45:02.137	error	Error herdsman start
                                zigbee.0
                                	2024-09-26 15:45:02.137	error	Failed to start Zigbee
                                zigbee.0
                                	2024-09-26 15:45:02.136	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                                zigbee.0
                                	2024-09-26 15:45:02.061	info	Installed Version: iobroker.zigbee@1.10.3
                                zigbee.0
                                	2024-09-26 15:45:02.054	info	Starting Zigbee npm ...
                                zigbee.0
                                	2024-09-26 15:45:02.053	info	Try to reconnect. 1 attempts left
                                zigbee.0
                                	2024-09-26 15:44:52.052	error	Error herdsman start
                                zigbee.0
                                	2024-09-26 15:44:52.052	error	Failed to start Zigbee
                                zigbee.0
                                	2024-09-26 15:44:52.051	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                zigbee.0
                                	2024-09-26 15:44:51.664	info	Installed Version: iobroker.zigbee@1.10.3
                                zigbee.0
                                	2024-09-26 15:44:51.465	info	Starting Zigbee npm ...
                                zigbee.0
                                	2024-09-26 15:44:51.464	info	delete old Backup files. keep only last 10
                                zigbee.0
                                	2024-09-26 15:44:51.433	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                                zigbee.0
                                	2024-09-26 15:43:06.087	info	terminating
                                zigbee.0
                                	2024-09-26 15:43:05.820	info	Terminated (NO_ERROR): Without reason
                                zigbee.0
                                	2024-09-26 15:43:05.819	info	terminating
                                zigbee.0
                                	2024-09-26 15:43:05.818	info	debug devices set to []
                                zigbee.0
                                	2024-09-26 15:43:05.815	info	Got terminate signal TERMINATE_YOURSELF
                                zigbee.0
                                	2024-09-26 15:43:05.808	warn	Failed to stop zigbee during startup
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                iob diag:
                                Skript v.2024-05-22
                                *** BASE SYSTEM ***
                                 Static hostname: Raspi58GB
                                       Icon name: computer
                                          Kernel: Linux 6.6.47+rpt-rpi-2712
                                    Architecture: arm64
                                Model           : Raspberry Pi 5 Model B Rev 1.0
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                 15:47:28 up 4 min,  2 users,  load average: 0.37, 0.65, 0.33
                                CPU threads: 4
                                Current issues:
                                               Local time: Thu 2024-09-26 15:47:28 CEST
                                           Universal time: Thu 2024-09-26 13:47:28 UTC
                                                 RTC time: Thu 2024-09-26 13:47:28
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                Boot Target:    multi-user.target
                                *** MEMORY ***
                                Mem:            8.4G        2.1G        5.6G        5.6M        792M        6.3G
                                Swap:           209M          0B        209M
                                Total:          8.7G        2.1G        5.8G
                                Active iob-Instances:   25
                                         8052 M total memory
                                         2020 M used memory
                                         2032 M active memory
                                          401 M inactive memory
                                         5370 M free memory
                                           61 M buffer memory
                                          693 M swap cache
                                          199 M total swap
                                            0 M used swap
                                          199 M free swap
                                top - 15:47:28 up 4 min,  2 users,  load average: 0.37, 0.65, 0.33
                                Tasks: 197 total,   2 running, 195 sleeping,   0 stopped,   0 zombie
                                %Cpu(s): 40.0 us,  0.0 sy,  0.0 ni, 40.0 id, 20.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   8052.3 total,   5367.8 free,   2023.6 used,    755.4 buff/cache
                                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6028.8 avail Mem
                                *** FILESYSTEM ***
                                udev           devtmpfs  3.8G     0  3.8G   0% /dev
                                tmpfs          tmpfs     806M  5.3M  800M   1% /run
                                /dev/mmcblk0p2 ext4       59G   14G   42G  25% /
                                tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                /dev/sda1      exfat      29G  379M   29G   2% /mnt/usb0
                                /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                                tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                                [Thu Sep 26 15:43:19 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:2F:A6:31 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4e8600df-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Thu Sep 26 15:43:20 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                                [Thu Sep 26 15:43:22 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                                /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                                | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                                | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4766
                                |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                                |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=3950672k,nr_inodes=246917,mode=755
                                |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755
                                | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mode=700,uid=1000,gid=1000
                                |-/mnt/usb0                                             /dev/sda1      exfat       rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
                                `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                6.4G    /var/
                                5.3G    /var/lib
                                5.1G    /var/lib/influxdb/engine/data
                                Archived and active journals take up 634.8M in the file system.
                                45M     /opt/iobroker/backups/
                                1.2G    /opt/iobroker/iobroker-data/
                                1.1G    /opt/iobroker/iobroker-data/files
                                441M    /opt/iobroker/iobroker-data/files/javascript.admin
                                409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                                Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                /usr/bin/nodejs         v20.17.0
                                /usr/bin/node           v20.17.0
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                /usr/bin/corepack       0.29.3
                                nodejs:
                                  Installed: 20.17.0-1nodesource1
                                  Candidate: 20.17.0-1nodesource1
                                  Version table:
                                 *** 20.17.0-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                     20.16.0-1nodesource1 1001
                                     20.15.1-1nodesource1 1001
                                     20.15.0-1nodesource1 1001
                                     20.14.0-1nodesource1 1001
                                     20.13.1-1nodesource1 1001
                                     20.13.0-1nodesource1 1001
                                     20.12.2-1nodesource1 1001
                                     20.12.1-1nodesource1 1001
                                     20.12.0-1nodesource1 1001
                                     20.11.1-1nodesource1 1001
                                     20.11.0-1nodesource1 1001
                                     20.10.0-1nodesource1 1001
                                     20.9.0-1nodesource1 1001
                                     20.8.1-1nodesource1 1001
                                     20.8.0-1nodesource1 1001
                                     20.7.0-1nodesource1 1001
                                     20.6.1-1nodesource1 1001
                                     20.6.0-1nodesource1 1001
                                     20.5.1-1nodesource1 1001
                                     20.5.0-1nodesource1 1001
                                     20.4.0-1nodesource1 1001
                                     20.3.1-1nodesource1 1001
                                     20.3.0-1nodesource1 1001
                                     20.2.0-1nodesource1 1001
                                     20.1.0-1nodesource1 1001
                                     20.0.0-1nodesource1 1001
                                     18.19.0+dfsg-6~deb12u2 500
                                     18.19.0+dfsg-6~deb12u1 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          7.1.2
                                javascript:     8.7.6
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : Raspi58GB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.0                 : alexa2                : Raspi58GB                                -  enabled
                                  system.adapter.alias-manager.0          : alias-manager         : Raspi58GB                                - disabled
                                + system.adapter.awtrix-light.0           : awtrix-light          : Raspi58GB                                -  enabled
                                + system.adapter.backitup.0               : backitup              : Raspi58GB                                -  enabled
                                + system.adapter.broadlink2.0             : broadlink2            : Raspi58GB                                -  enabled
                                  system.adapter.devices.0                : devices               : Raspi58GB                                - disabled
                                  system.adapter.discovery.0              : discovery             : Raspi58GB                                - disabled
                                + system.adapter.doorbird.0               : doorbird              : Raspi58GB                                -  enabled
                                + system.adapter.echarts.0                : echarts               : Raspi58GB                                -  enabled
                                + system.adapter.followthesun.0           : followthesun          : Raspi58GB                                -  enabled
                                + system.adapter.frontier_silicon.0       : frontier_silicon      : Raspi58GB                                -  enabled
                                  system.adapter.frontier_silicon.1       : frontier_silicon      : Raspi58GB                                - disabled
                                  system.adapter.frontier_silicon.2       : frontier_silicon      : Raspi58GB                                - disabled
                                  system.adapter.frontier_silicon.3       : frontier_silicon      : Raspi58GB                                - disabled
                                + system.adapter.hm-rega.0                : hm-rega               : Raspi58GB                                -  enabled
                                + system.adapter.hm-rpc.0                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                                + system.adapter.hm-rpc.1                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                                + system.adapter.influxdb.0               : influxdb              : Raspi58GB                                -  enabled, port: 8086
                                + system.adapter.iot.0                    : iot                   : Raspi58GB                                -  enabled
                                + system.adapter.javascript.0             : javascript            : Raspi58GB                                -  enabled
                                + system.adapter.mqtt.0                   : mqtt                  : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.rpi2.0                   : rpi2                  : Raspi58GB                                -  enabled
                                + system.adapter.shelly.0                 : shelly                : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : Raspi58GB                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  system.adapter.smartmeter.0             : smartmeter            : Raspi58GB                                - disabled
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : Raspi58GB                                -  enabled
                                + system.adapter.telegram.0               : telegram              : Raspi58GB                                -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.vis-2.0                  : vis-2                 : Raspi58GB                                -  enabled
                                  system.adapter.vis.0                    : vis                   : Raspi58GB                                -  enabled
                                + system.adapter.web.0                    : web                   : Raspi58GB                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  system.adapter.yr.0                     : yr                    : Raspi58GB                                -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : Raspi58GB                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                                + instance is alive
                                Upgrade policy: none
                                Adapter    "admin"        : 7.1.2    , installed 7.1.2
                                Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                                Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                                Adapter    "doorbird"     : 1.7.0    , installed 1.7.0
                                Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                                Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
                                Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                                Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                                Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                Controller "js-controller": 6.0.11   , installed 6.0.11
                                Adapter    "rpi2"         : 1.3.2    , installed 2.0.0
                                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                Objects and States
                                Objects:        11825
                                States:         9324
                                Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                Hit:2 http://deb.debian.org/debian bookworm InRelease
                                Hit:5 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                                Hit:6 https://repos.influxdata.com/debian stable InRelease
                                Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Pending Updates: 0
                                tcp        0      0 192.168.178.57:2001     0.0.0.0:*               LISTEN      1001       6795       1179/io.hm-rpc.1
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        7371       814/mosquitto
                                tcp        0      0 192.168.178.57:42010    0.0.0.0:*               LISTEN      1001       6776       1164/io.hm-rpc.0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5765       829/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       7487       946/iobroker.js-con
                                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       7492       946/iobroker.js-con
                                tcp        0      0 192.168.178.57:8100     0.0.0.0:*               LISTEN      1001       8840       1313/io.doorbird.0
                                tcp6       0      0 :::1883                 :::*                    LISTEN      106        7372       814/mosquitto
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          5767       829/sshd: /usr/sbin
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9544       1359/io.simple-api.
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        8359       884/influxd
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9610       1421/io.web.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7530       965/io.admin.0
                                udp        0      0 0.0.0.0:37934           0.0.0.0:*                           1001       6727       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:50257           0.0.0.0:*                           1001       7729       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5702       671/avahi-daemon: r
                                udp        0      0 0.0.0.0:38186           0.0.0.0:*                           1001       6721       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:46537           0.0.0.0:*                           1001       6726       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7818       1252/io.shelly.0
                                udp        0      0 0.0.0.0:55117           0.0.0.0:*                           1001       6723       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:39374           0.0.0.0:*                           104        5704       671/avahi-daemon: r
                                udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       6717       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:39813           0.0.0.0:*                           1001       6722       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:44924           0.0.0.0:*                           1001       6725       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:57524           0.0.0.0:*                           1001       6720       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:53786           0.0.0.0:*                           1001       6724       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:58130           0.0.0.0:*                           1001       6729       1119/io.broadlink2.
                                udp        0      0 0.0.0.0:45874           0.0.0.0:*                           1001       6728       1119/io.broadlink2.
                                udp6       0      0 :::5353                 :::*                                104        5703       671/avahi-daemon: r
                                udp6       0      0 :::59656                :::*                                104        5705       671/avahi-daemon: r
                                2024-09-26 15:45:09.621  - info: simple-api.0 (1359) Allow states only when user is owner: false
                                2024-09-26 15:45:09.628  - info: simple-api.0 (1359) http server listening on port 8087
                                2024-09-26 15:45:12.658  - info: host.Raspi58GB instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 1374
                                2024-09-26 15:45:13.651  - info: tankerkoenig.0 (1374) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.17.0, js-controller: 6.0.11
                                2024-09-26 15:45:13.670  - info: tankerkoenig.0 (1374) Adapter is already in daemon mode
                                2024-09-26 15:45:13.671  - info: tankerkoenig.0 (1374) Sync time set to 30 minutes or 1800000 ms
                                2024-09-26 15:45:16.680  - info: host.Raspi58GB instance system.adapter.vis-2.0 in version "2.9.32" started with pid 1389
                                2024-09-26 15:45:17.906  - info: vis-2.0 (1389) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.17.0, js-controller: 6.0.11
                                2024-09-26 15:45:18.068  - error: vis-2.0 (1389) License is invalid! Nothing updated. Error: serial number (UUID) in license is for other device
                                2024-09-26 15:45:18.153  - info: tankerkoenig.0 (1374) Start first request
                                2024-09-26 15:45:21.336  - info: yr.0 (1267) Data updated.
                                2024-09-26 15:45:21.337  - info: yr.0 (1267) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-09-26 15:45:21.523  - info: vis.0 (1405) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.11
                                2024-09-26 15:45:21.906  - info: host.Raspi58GB instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-09-26 15:45:22.663  - info: vis.0 (1405) Terminated (NO_ERROR): Without reason
                                2024-09-26 15:45:23.198  - info: host.Raspi58GB instance system.adapter.vis.0 terminated while should be started once
                                2024-09-26 15:45:24.723  - info: host.Raspi58GB instance system.adapter.web.0 in version "6.2.5" started with pid 1421
                                2024-09-26 15:45:25.655  - info: web.0 (1421) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
                                2024-09-26 15:45:25.777  - info: web.0 (1421) socket.io server listening on port 8082
                                2024-09-26 15:45:25.779  - info: web.0 (1421) http server listening on port 8082
                                2024-09-26 15:45:28.675  - info: host.Raspi58GB instance system.adapter.followthesun.0 in version "0.5.1" started with pid 1436
                                2024-09-26 15:45:29.606  - info: followthesun.0 (1436) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.followthesun, node: v20.17.0, js-controller: 6.0.11
                                2024-09-26 15:45:29.615  - info: followthesun.0 (1436) Started with JSON-Explorer version 0.1.16
                                2024-09-26 15:45:29.615  - info: followthesun.0 (1436) Sun position calculation will be done every 60 seconds
                                2024-09-26 15:45:29.616  - info: followthesun.0 (1436) Daily sun parameter calculation scheduled for 00:00:39
                                die Einstellungen des Adapters:
                                Erkennst Du einen Fehler? Ich möchte doch wenigstens die Zigbee-Aktoren wieder nutzen.
                                Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
                                • Meister Mopper
                                  Meister Mopper @searcher57 last edited by
                                  @searcher57
                                  Läuft da vielleicht ein ModemManager? Der hat hier auch schon den Start verhindert.
                                  systemctl status ModemManager.service
                                    searcher57 @Meister Mopper last edited by
                                    @meister-mopper said in Zigbee iobroker Error while opening serialport:
                                    @searcher57
                                    Was ist das? Und wie kann ich den deaktivieren?
                                      Thomas Braun Most Active @searcher57 last edited by
                                      @searcher57
                                      Die extended PAN-ID ist mit Sicherheit falsch, zumindest ist DDDDDDDDDDDDDDDDDDD ungünstig.
                                        @searcher57
                                        Es kann sein, dass ich bei der Ersteinrichtung da etwas verändert habe. Kannst Du mir sagen, wie ich die abfrage?
                                          @searcher57
                                          Ich habe sie jetzt in DDADDDDDDD2DFDDD geändert.
                                            @searcher57 sagte in Zigbee iobroker Error while opening serialport:
                                            Im nv_backup stehen die alten Werte drin, soweit ich weiß.
                                            231
                                            42336
