    4. Nach Node JS updat kein Login mehr
      Thomas Braun Most Active @mike-eg6 last edited by
      @mike-eg6 sagte in Nach Node JS updat kein Login mehr:
      was soll ich jetzt machen?
      Regelmäßiger updaten...
      Zeig die Langfassung von
      iob diag
        mike-eg6 @Thomas Braun last edited by
        @thomas-braun said in Nach Node JS updat kein Login mehr:
        iob diag
        Copy text starting here:
                                v.2024-05-22
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               32 bit
        Timezone:               Europe/Vienna (CEST, +0200)
        User-ID:                1000
        Display-Server:         false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    20
        Nodejs-Installation:
        /usr/bin/nodejs         v22.4.1
        /usr/bin/node           v22.4.1
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.2
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:            7.8G         80M        7.2G        0.0K        490M        7.6G
        Swap:            99M          0B         99M
        Total:          7.9G         80M        7.3G
        Active iob-Instances:   1
        Active repo(s): stable
        ioBroker Core:          js-controller           5.0.19
                                admin                   6.2.22
        ioBroker Status:        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
          system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                2121
        States:                 1725
        Size of iob-Database:
        12M     /opt/iobroker/iobroker-data/objects.jsonl
        4.2M    /opt/iobroker/iobroker-data/objects.json.migrated
        4.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        0       /opt/iobroker/iobroker-data/objects.json.broken
        1.7M    /opt/iobroker/iobroker-data/states.jsonl
        292K    /opt/iobroker/iobroker-data/states.json.bak.migrated
        288K    /opt/iobroker/iobroker-data/states.json.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
        === Mark text until here for copying ===
        pi@raspberrypi:/opt/iobroker $ pt/iobroker Static hostname: raspberrypi
        Icon name: computer
        Architecture: arm64
        Kernel: aarch64
        Userland: 32 bit
        User-ID: 1000
        /usr/bin/npm 10.8.1
        /usr/bin/npx 10.8.1
        MEMORY:
        total used free shared buff/cache available
        Swap: 99M 0B 99M
        admin 6.2.22
        Objects type: jsonl
        States type: jsonl
        Objects: 2121
        States: 1725
          Kernel: aarch64
          Userland: 32 bit
          Bei Gelegenheit mal komplett NEUINSTALLIEREN.
          Diesmal als reine 64Bit-Version.
          iob nodejs-update 20
          ausführen.
            @mike-eg6
            Wenn nodejs@20 installiert ist, nochmal
            iob diag
            aber diesmal die Langfassung.
              iob diag
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 32 bit
              Systemuptime and Load:
               20:56:11 up  1:32,  1 user,  load average: 0.21, 0.36, 1.20
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Sun 2024-07-14 20:56:11 CEST
                         Universal time: Sun 2024-07-14 18:56:11 UTC
                               RTC time: n/a
                              Time zone: Europe/Vienna (CEST, +0200)
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
              *** Display-Server-Setup ***
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            7.8G        440M        6.5G        0.0K        875M        7.2G
              Swap:            99M          0B         99M
              Total:          7.9G        440M        6.6G
              Active iob-Instances:   9
                       7812 M total memory
                        440 M used memory
                        473 M active memory
                        669 M inactive memory
                       6496 M free memory
                        148 M buffer memory
                        726 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              top - 20:56:11 up  1:32,  1 user,  load average: 0.21, 0.36, 1.20
              Tasks: 164 total,   1 running, 163 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 26.1 us,  4.3 sy,  0.0 ni, 68.1 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
              MiB Mem :   7812.3 total,   6495.4 free,    441.3 used,    875.6 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7248.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       29G  4.5G   23G  17% /
              devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs     1.6G  840K  1.6G   1% /run
              /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
              /dev/sda1      fuseblk   7.5G   24M  7.5G   1% /media/usbstick
              tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
              [Sun Jul 14 19:23:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D5:EA:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bd5a9205-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sun Jul 14 19:23:35 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sun Jul 14 19:23:35 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sun Jul 14 19:23:38 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              Show mounted filesystems:
              TARGET                       SOURCE         FSTYPE     OPTIONS
              /                            /dev/mmcblk0p2 ext4       rw,noatime
              |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=3735680k,nr_inodes=933920,mode=755
              | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
              | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
              | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
              |-/proc                      proc           proc       rw,relatime
              | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
              |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
              | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
              | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
              | `-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
              |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755
              | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
              | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
              | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000
              |-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              `-/media/usbstick            /dev/sda1      fuseblk    rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
              /var:
              1.5G    /var/
              1.2G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
              1.2G    /var/log
              153M    /var/cache
              Archived and active journals take up 1.1G in the file system.
              /opt/iobroker/backups:
              39M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              213M    /opt/iobroker/iobroker-data/
              119M    /opt/iobroker/iobroker-data/files
              71M     /opt/iobroker/iobroker-data/backup-objects
              48M     /opt/iobroker/iobroker-data/files/javascript.admin
              32M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              13M     /opt/iobroker/iobroker-data/objects.jsonl
              12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
              4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.15.1
              /usr/bin/node           v20.15.1
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              /usr/bin/corepack       0.28.1
              nodejs:
                Installed: 20.15.1-1nodesource1
                Candidate: 20.15.1-1nodesource1
                Version table:
               *** 20.15.1-1nodesource1 600
                      500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                      100 /var/lib/dpkg/status
                   20.15.0-1nodesource1 600
                   20.14.0-1nodesource1 600
                   20.13.1-1nodesource1 600
                   20.13.0-1nodesource1 600
                   20.12.2-1nodesource1 600
                   20.12.1-1nodesource1 600
                   20.12.0-1nodesource1 600
                   20.11.1-1nodesource1 600
                   20.11.0-1nodesource1 600
                   20.10.0-1nodesource1 600
                   20.9.0-1nodesource1 600
                   20.8.1-1nodesource1 600
                   20.8.0-1nodesource1 600
                   20.7.0-1nodesource1 600
                   20.6.1-1nodesource1 600
                   20.6.0-1nodesource1 600
                   20.5.1-1nodesource1 600
                   20.5.0-1nodesource1 600
                   20.4.0-1nodesource1 600
                   20.3.1-1nodesource1 600
                   20.3.0-1nodesource1 600
                   20.2.0-1nodesource1 600
                   20.1.0-1nodesource1 600
                   20.0.0-1nodesource1 600
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          6.2.22
              javascript:     6.0.3
              nodejs modules from github:     0
              Adapter State
              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
              + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
              + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
              + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
              + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
              + instance is alive
              ioBroker-Repositories
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.17.14  , installed 6.2.22 [Updatable]
              Adapter    "backitup"     : 2.11.0   , installed 2.4.10 [Updatable]
              Adapter    "daikin"       : 1.4.2    , installed 1.4.2
              Adapter    "daswetter"    : 3.1.15   , installed 3.1.3  [Updatable]
              Adapter    "discovery"    : 4.5.0    , installed 3.0.5  [Updatable]
              Adapter    "hm-rega"      : 4.0.0    , installed 3.0.40 [Updatable]
              Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.12 [Updatable]
              Adapter    "hmip"         : 1.23.3   , installed 1.18.0 [Updatable]
              Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
              Adapter    "javascript"   : 8.3.1    , installed 6.0.3  [Updatable]
              Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
              Adapter    "socketio"     : 6.7.0    , installed 4.2.0  [Updatable]
              Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
              Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
              Adapter    "vis-map"      : 1.0.5    , installed 1.0.4  [Updatable]
              Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
              Adapter    "weatherunderground": 3.7.0, installed 3.4.2 [Updatable]
              Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
              Adapter    "wled"         : 0.7.2    , installed 0.6.7  [Updatable]
              Adapter    "ws"           : 2.6.1    , installed 1.3.0  [Updatable]
              Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
              Objects and States
              Objects:        2121
              States:         1796
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32622      4352/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32617      4352/iobroker.js-co
              tcp        0      0 127.0.0.1:39021         0.0.0.0:*               LISTEN      1001       35385      4730/io.yahka.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12213      540/sshd: /usr/sbin
              tcp6       0      0 :::38887                :::*                    LISTEN      1001       35194      4730/io.yahka.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          12215      540/sshd: /usr/sbin
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15378      669/dhcpcd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       35195      4730/io.yahka.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       35957      4671/io.wled.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12144      401/avahi-daemon: r
              udp        0      0 0.0.0.0:34991           0.0.0.0:*                           108        12146      401/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        12145      401/avahi-daemon: r
              udp6       0      0 :::51278                :::*                                108        12147      401/avahi-daemon: r
              2024-07-14 20:55:39.030  - info: hm-rpc.0 (5519) Terminated (NO_ERROR): Without reason
              2024-07-14 20:55:39.657  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
              2024-07-14 20:55:39.658  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
              2024-07-14 20:56:06.044  - error: hm-rega.0 (4410) CCU 10.0.0.3 unreachable
              2024-07-14 20:56:09.786  - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 5537
              2024-07-14 20:56:12.537  - info: hm-rpc.0 (5537) starting. Version 1.15.12 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.15.1, js-controller: 5.0.19
              2024-07-14 20:56:12.682  - info: hm-rpc.0 (5537) xmlrpc server is trying to listen on 10.0.0.10:2001
              2024-07-14 20:56:12.683  - info: hm-rpc.0 (5537) xmlrpc client is trying to connect to 10.0.0.3:2001/ with ["http://10.0.0.10:2001","raspberrypi:hm-rpc.0:055bf09dd9b483c029ffa58fca3d6c16"]
              2024-07-14 20:56:12.714  - error: hm-rpc.0 (5537) Init not possible, going to stop: connect ECONNREFUSED 10.0.0.3:2001
              2024-07-14 20:56:36.049  - error: hm-rega.0 (4410) CCU 10.0.0.3 unreachable
              2024-07-14 20:56:36.278  - info: daikin.0 (4409) Daikin Device initialized with Error :Cannot parse response: <html>
              <body>
              <h1>File is not found.</h1>
              please enter correct url.
              </body>
              </html>
              2024-07-14 20:56:36.278  - info: daikin.0 (4409) Retry init in 60 seconds
              2024-07-14 20:56:42.711  - error: hm-rpc.0 (5537) Init not possible, going to stop: connect ECONNREFUSED 10.0.0.3:2001
              2024-07-14 20:56:42.717  - info: hm-rpc.0 (5537) xmlrpc -> 10.0.0.3:2001/ init ["http://10.0.0.10:2001",""]
              2024-07-14 20:56:42.723  - error: hm-rpc.0 (5537) Cannot call init: [http://10.0.0.10:2001, ""] connect ECONNREFUSED 10.0.0.3:2001
              2024-07-14 20:56:42.729  - info: hm-rpc.0 (5537) terminating
              2024-07-14 20:56:42.730  - info: hm-rpc.0 (5537) Terminated (NO_ERROR): Without reason
              2024-07-14 20:56:43.288  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
              2024-07-14 20:56:43.289  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
              iob diag has finished.
              Press any key for a summary
              die V20 ist oben danke schonmal für eure hilfe
              M Homoran 2 Replies Last reply Reply Quote 0
                mike-eg6 @mike-eg6 last edited by
                aber login geht noch nicht
                  Homoran Global Moderator Administrators @mike-eg6 last edited by
                  der läuft auch nicht
                  versuch mal iob start admin.0
                    Thomas Braun Most Active @mike-eg6 last edited by Thomas Braun
                    @mike-eg6
                    sudo systemctl set-default multi-user.target
                    Dann ein
                    iob start admin
                    Und dann den ganzen Stau bei den updates auflösen...
                    iob update
                    iob upgrade all -y
                      @thomas-braun puhh gerettet
                      1000 Dank jetzt läuft er wieder danke vielmals
                      lg mike
                        @mike-eg6
                        Hast du die Updates eingespielt? Sonst kippt dir das früher oder später wieder weg.
                          ja hab ich gemacht dank dir
                          lg mike
                            @mike-eg6 hab schon wieder ein problem jetzt komm ich schon wieder nicht rein das komische ist wenn ich den Befehl ausführe passiert nix
                            iob diag
                            lg mike
                              @mike-eg6
                              systemctl status iobroker.service
                              sagt?
                                nach langer Zeit ein Update
                                ist vielleicht die Karte mittlerweile in die Knie gegangen?
                                  @mike-eg6
                                  curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                                  sagt?
                                    mike-eg6 @Thomas Braun last edited by Homoran
                                    pi@raspberrypi:~ $ systemctl status iobroker.service
                                    ● iobroker.service - ioBroker Server
                                         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
                                         Active: inactive (dead) (Result: exit-code) since Tue 2024-07-23 17:46:53 >
                                           Docs: http://iobroker.net
                                       Main PID: 5849 (code=exited, status=1/FAILURE)
                                            CPU: 2.279s
                                    Jul 23 17:46:53 raspberrypi systemd[1]: Stopped ioBroker Server.
                                    Jul 23 17:46:53 raspberrypi systemd[1]: iobroker.service: Consumed 2.279s CPU t>
                                    ...skipping...
                                            CPU: 2.279s
                                    ...skipping...
                                            CPU: 2.279s
                                    ...skipping...
                                            CPU: 2.279s
                                    ...skipping...
                                            CPU: 2.279s
                                    set mark: ...skipping...
                                            CPU: 2.279s
                                    ...skipping...
                                            CPU: 2.279s
                                    ...skipping...
                                            CPU: 2.279s
                                    Log file is already in use  (press RETURN)
                                      Da läuft halt nix.
                                      sudo systemctl start iobroker.service
                                      oder mal ordentlich neustarten.
                                        pi@raspberrypi:~ $ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                                          % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                        100   169  100   169    0     0    366      0 --:--:-- --:--:-- --:--:--   366
                                         69 23302   69 16126    0     0  10859      0  0:00:02  0:00:01  0:00:01  174k
                                        curl: (23) Failure writing output to destination
                                        pi@raspberrypi:~ $
                                          der Befehl ändert nix
                                            @mike-eg6 dann nochmal die Frage
                                            @homoran sagte in Nach Node JS updat kein Login mehr:
                                            2654
