    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
      Telefisch last edited by
      …doppelpost gelöscht
        Ach verdammt,
        irgendwie läuft das noch immer nicht richtig.
        Der Homekit-Adapter läuft zwar aber vom iOS aus finde ich keine HomeKit Bridge.
        Dann habe ich ein Backup zurückgespielt um nicht alles neu installieren zu müssen aber jetzt kann ich den Zwave-Adapter wieder nicht installieren:
        ! ` > $ ./iobroker add zwave
        npm install iobroker.zwave –unsafe-perm --production --prefix "/opt/iobroker" (System call)
        module.js:471 throw err;
        Error: Cannot find module '../'
        at Function.Module._resolveFilename (module.js:469:15)
        at Function.Module._load (module.js:417:25)
        at Module.require (module.js:497:17)
        at require (internal/module.js:20:19)
        at Object. <anonymous>(/opt/iobroker/node_modules/.bin/which:2:13)
        at Module._compile (module.js:570:32)
        at Object.Module._extensions..js (module.js:579:10)
        at Module.load (module.js:487:32)
        at tryModuleLoad (module.js:446:12)
        at Function.Module._load (module.js:438:3)
        module.js:471
        throw err;
        gyp: Call to 'which nodejs || which node' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        gyp
        ERR! configure error
        gyp ERR! stack Error: gyp failed with exit code: 1gyp
        ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16)gyp ERR! stack at emitTwo (events.js:106:13)
        gyp ERR! stack at ChildProcess.emit (events.js:191:7)
        gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
        gyp ERR! System Linux 3.10.102gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
        gyp ERR! node -v v6.12.2
        gyp ERR! node-gyp -v v3.4.0
        gyp ERR! not ok
        npm
        ERR! Linux 3.10.102npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"
        npm ERR! node v6.12.2
        npm ERR! npm v3.10.10
        npm ERR! code ELIFECYCLE
        npm ERR! openzwave-shared@1.4.0 install: node-gyp rebuildnpm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the openzwave-shared@1.4.0 install script 'node-gyp rebuild'.
        npm ERR! Make sure you have the latest version of node.js and npm installed.
        npm ERR! If you do, this is most likely a problem with the openzwave-shared package,npm ERR! not with npm itself.
        npm ERR! Tell the author that this fails on your system:
        npm ERR! node-gyp rebuild
        npm ERR! You can get information on how to open an issue for this project with:
        npm ERR! npm bugs openzwave-shared
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR! npm owner ls openzwave-shared
        npm ERR! There is likely additional logging output above.
        npm
        ERR! Please include the following file with any support request:npm ERR! /opt/iobroker/npm-debug.log
        host.iobroker install adapter zwave
        npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call)</anonymous></anonymous> `
        So langsam verliere ich ernsthaft den Spass am ioBroker 😞
        • andre
          andre Developer last edited by
          @Telefisch:
          Ach verdammt,
          module.js:471
          throw err;
          gyp
          gyp ERR! not ok
          npm
          npm ERR!
          npm
          So langsam verliere ich ernsthaft den Spass am ioBroker 😞 `
          Hallo Carsten,
          sorry dass es bei dir immernoch nicht richtig rund läuft. Ich bin gerne bereit wo es geht zu unterstützen und falls nötig auch das Image anzupassen, aber was homekit und zwave angeht, da stochere ich, mangels passender Hardware, echt im Nebel…
          Was ich halt nur machen kann, sind die Informationen über die Adapter (von git) nehmen und das ganze in meinem Image bestmöglich vorbereiten.
          Wenn ich jetzt (so teste ich) ein frisches Image nehme, einen Container starte und ausschließlich die Option "mit erhöhten Rechten ausführen" und eine Portweiterleitung 9091 -> 8081 konfiguriere, startet ioBroker normal und die Weboberfläche ist über Port 9091 erreichbar. Anschließend kann ich sowohl zwave (dauert recht lange) als auch homekit installieren. Homekit wird auch grün, zwave ja nicht, weil ich ja keinen Stick dran habe. Auswählen könnte ich die verschiedenen Usb Ports aber.
          An dem Punkt ist in Sache testen der Funktion bei mir leider Schluss.
          Was deinen aktuellen Fehler bei der Installation des Zwave angeht, könntest du es nochmal so versuchen:
          Manchmal hilft das…
          Beim homekit könnte noch ein Port fehlen... Eventuell braucht es da noch ein Forwarding für den avahi?
          Im Falle des zwave Adapters und der Netztwerkproblematik im Docker habe ich mich auch schon bei den Entwicklern zu Wort gemeldet. Leider lässt sich die Installationsroutine nicht so ohne Weiteres anpassen. Wenn ich Zeit finde, werde ich mal den Adapter forken und versuchen eine Docker-taugliche Version zu zaubern...
          MfG,
          Andre
          PS: Vielleicht wäre es ja für dich denkbar für die problematischen Adapter mit einem Satelliten zu arbeiten (Stichwort Multihost). Ich habe zum Beispiel für alles was Hardware braucht (bei mir sind das Bluetooth Scanner und rflink) einen separaten Host laufen. Ist bei mir ein Cubietruck, könnte aber auch ein raspberry pi sein.
          Grund: Ich wollte keine USB-Devices an der DS und (da meine DS nicht zentral steht) eine optimale Sende und Empfangsposition für Bluetooth und rflink.
          Gesendet von meinem Smartphone mit Tapatalk
            Guten Morgen Andre,
            erstmal riesen Dankeschön für Deine Hilfe.
            Leider funktioniert die ZWave Installation noch immer nicht.
            Ich hatte gehofft, dass Du mit den Meldungen was anfangen kannst.
            Die Installation des ZWave läuft bei Dir ja offensichtlich auch durch, also habe ich anscheinend (wiedermal) ne Ausnahmesituation. Schade ist das Ganze, weil es vor dem letzten Update (bis auf ZWave) monatelang lief.
            Nunja, was auch immer Docker oder Synology geändert haben, wir werden es nicht beeinflussen.
            Ich habe schon in Erwägung gezogen die Synology gänzlich vom iobroker zu befreien und auf eine eigene Plattform, nur für den Broker umzusteigen.
            Mit den RPIs habe ich allerdings nur schlechte Erfahrungen. Hatte da ne Homebridge installiert die immer stabil lief, bis man mal wieder nach Wochen ne neue Karte installieren durfte. Das ist alles nur so halbgar.
            Womit betreibst Du den Cubitruck? mit Festplatte oder SD-Karte?
            Ich hatte auch schon nen NUC in Erwägung gezogen, bin mir nur noch nicht sicher welche Leistungsklasse da Sinnvoll ist.
            Gruß Carsten
            • andre
              @Telefisch:
              Ich hatte auch schon nen NUC in Erwägung gezogen, bin mir nur noch nicht sicher welche Leistungsklasse da Sinnvoll ist. ` Ich habe im Cubie eine SSD Festplatte drin. Die SD steckt nurnoch drin damit das Ding von Festplatte booten kann. Läuft jetzt sein nem Jahr ohne Probleme, sind aber auch nur 5 Adapter drauf installiert.
              Intel NUC hatte ich auch schon mal auf dem Einkaufszettel. Allerdings würde ich da einen recht leistungsfähigen nehmen um genug Leistung für ein paar virtuelle Maschinen zu haben. 🙂
              MfG,
              André
                @andre:
                Allerdings würde ich da einen recht leistungsfähigen nehmen um genug Leistung für ein paar virtuelle Maschinen zu haben. `
                Wie man hier sieht ist die Nutzung in virtuellen maschinen nicht immer ganz einfach. Ich habe eine Installation auf einem NUC5PPYH laufen, selbst der ist für iobroker allein völlig unterfordert.
                @andre:
                Ich habe im Cubie eine SSD Festplatte drin. `
                Ich hatte da seit Jahren eine 500gb hdd drin, die natürlich nicht für 5 Jahre 24/7 ausgelegt war und irgendwann mit Lagerschaden ausgefallen war. Jetzt ist auch eine SSD drin. Der cubie ist mit seinem DualCore natürlich nicht mit einem Nuc zu vergleichen. Bei mir läuft noch ein MySQL server drauf.
                Gruß Rainer
                Der abgetrennte Teil zum Thema Virtualisierung - und evtl. Probleme dazu befindet sich jetzt hier:
                http://forum.iobroker.net/viewtopic.php?f=34&t=10159
                • andre
                  @Homoran:
                  Gruß Rainer
                  http://forum.iobroker.net/viewtopic.php?f=34&t=10159 `
                  Danke! 🙂
                    dtp last edited by
                    Kurze Frage.
                    Ich habe das ioBroker-Abbild auf meiner DS718+ installiert, als ich noch 2 GB RAM hatte. Später habe ich dann auf 6 GB aufgerüstet. Dies hat der Docker auch direkt erkannt. Mir scheint nur, dass der ioBroker irgendwie immer noch von 2 GB RAM ausgeht. Oder täusche ich mich da?
                    Falls nein, wie bringe ich dem ioBroker bei, dass insgesamt 6 GB zur Verfügung stehen? Oder muss ich das Abbild dazu neu installieren?
                    Gruß,
                    Thorsten
                    PS.: Bei mir läuft der ioBroker mit sämtlichen Adaptern übrigens einwandfrei.
                    PPS.: Frohes Neues natürlich.
                      Es gibt einen unterschied zwischen FREI und Available.
                      Verbraucht + Frei != Gesamt.
                      Werbraucht + Frei + Cached = Gesamt.
                      Dann hat dein Docker wohl einen großen Cache
                      Rainer
                        dtp last edited by
                        Hi Rainer,
                        heißt dann also, dass soweit alles in Ordnung ist, oder?
                        Gruß,
                        Thorsten
                          Ich denke schon.
                          Habe aber mit VMs keine Erfahrung
                          Rainer
                            dtp last edited by
                            Hi Rainer,
                            kein Problem. Ich lasse es erst mal so.
                            Falls mir jemand der Docker-Experten noch einen Hinweis geben könnte, wäre ich aber trotzdem dankbar.
                            Gruß,
                            Thorsten
                            • andre
                              @dtp:
                              Kurze Frage.
                              Gruß,
                              Thorsten
                              PPS.: Frohes Neues natürlich. `
                              Ich würde mir da keine großen Gedanken machen. Denke dass der Container schlicht die RAM Änderung der DS nicht mit bekommt/ bekommen kann. Vermutlich würde es reichen den Container zu löschen und neu an zu legen (sofern der ioBroker-Ordner auf die DS ausgelagert wurde).
                              MfG,
                              André
                                ask last edited by
                                Hallo André,
                                erstmal vielen Dank für Deine Einsatz, damit war ein ein leichtes ioBroker in Docker auf der DiskStation zu installieren.
                                Ich habe aber auch das Problem mit dem HomeKit Adapter, dieser startet sich nicht - Fehlermeldung:
                                ! host.ioBroker 2018-01-02 18:29:24.013 error instance system.adapter.yahka.0 terminated with code 1 ()
                                ! Caught 2018-01-02 18:29:24.013 error by controller[0]: at Object.Module._extensions..js (module.js:579:10)
                                ! Caught 2018-01-02 18:29:24.013 error by controller[0]: at Module._compile (module.js:570:32)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:24:20)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: at require (internal/module.js:20:19)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: at Module.require (module.js:497:17)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: at Function.Module._load (module.js:438:3)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: at tryModuleLoad (module.js:446:12)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: at Module.load (module.js:487:32)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: at Object.Module._extensions..node (module.js:597:18)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: at Error (native)
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: Error: /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns/build/Release/dns_sd_bindings.node: wrong ELF class: ELFCLASS32
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: ^
                                ! Caught 2018-01-02 18:29:24.012 error by controller[0]: throw ex;
                                ! Caught 2018-01-02 18:29:24.011 error by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:35
                                Die Prozesse "dbus-daemon –system", avahi-daemon laufen. Bonjour hatte ich auch schon abgeschaltet aber mit dem selben Ergebnis.
                                Was kann ich noch tun? Wenn du irgendetwas benötigst, Logs oder etwas anderes lass es mich wissen.
                                Danke!
                                Alex
                                  dtp last edited by
                                  @andre:
                                  Ich würde mir da keine großen Gedanken machen. Denke dass der Container schlicht die RAM Änderung der DS nicht mit bekommt/ bekommen kann. Vermutlich würde es reichen den Container zu löschen und neu an zu legen (sofern der ioBroker-Ordner auf die DS ausgelagert wurde). `
                                  Hi André,
                                  danke für Deine Info. Hab mal eben einfach ein neues ioBroker-Abbild erzeugt und vorher das alte umbenannt. War kein Problem und lief innerhalb von Sekunden. Allerdings wurde mir exakt die gleiche Speicherauslastung vom ioBroker angezeigt. Zudem ergab eine Abfrage mit
                                  vmstat -s
                                  im alten Abbild, dass die 6 GB wohl korrekt erkannt wurden. Hab dann das neue Abbild wieder gelöscht und bin zum alten zurück. Alles gut.
                                  Gruß,
                                  Thorsten
                                    dtp last edited by
                                    @ask:
                                    Ich habe aber auch das Problem mit dem HomeKit Adapter, dieser startet sich nicht - Fehlermeldung: `
                                    Kurze Frage. Hast Du die Homebridge im Docker-Abbild des ioBroker installiert? Das würde ich ehrlich gesagt nicht machen, sondern ein neues Abbild erzeugen, das unabhängig vom ioBroker-Abbild ist.
                                    Bei mir startet die Homebridge dann zwar korrekt, nur leider kann die Home App sie nicht finden. Aber das ist kein Problem des ioBroker-Abbilds.
                                    Gruß,
                                    Thorsten
                                      @dtp:
                                      @ask:
                                      Gruß,
                                      Thorsten `
                                      Homebridge?
                                      Sinn des Homekit-Adapters im ioBroker ist, die Homebridge nicht mehr zu benötigen.
                                      Bis zum letzten Docker-Update (vermute ich) hat der Adapter einwandfrei im Docker funktioniert.
                                      Ob es nun am Docker oder am Image liegt kann ich allerdings nicht genau sagen. Wie gesagt, hat es schon reibungslos funktioniert.
                                      Gruß Carsten
                                        ask last edited by
                                        Wie Carsten geschrieben hat, Homebridge benutze ich nicht sondern den HomeKit-Adapter im ioBroker.
                                        Alex
                                          Da der HK-Adapter ja früher funktionierte habe ich mal bei Synology nachgefragt, um herauszufinden was die geändert haben.
                                          Das ist die Antwort:
                                          ! ` > Sehr geehrter Kunde,
                                          vielen Dank für Ihre Anfrage.
                                          Mit dem letzten Update haben wir lediglich einen Fehler mit bestimmten Containern behoben: https://www.synology.com/en-us/releaseNote/Docker
                                          Wenn der Container gestartet werden kann, aber nicht mit Ihrem Apple Home Kit kommuniziert, dann müssten Sie sich zwecks support bitte an den Maintainer des jeweiligen Containers zu wenden (http://forum.iobroker.net/), da wir leider mit der Konfiguration der Container nicht behilflich sein dürfen und können. `
                                          Mit mehr habe ich auch nicht wirklich gerechnet.
                                          • andre
                                            @Telefisch:
                                            Mit mehr habe ich auch nicht wirklich gerechnet. `
                                            Hast du mal eine Version früher geschaut… am 15.11. gab es ja ein größeres Update des Docker Pakets (Update Docker Daemnon usw...). Das hat mir z.B. die Problematik mit dem Hostname eingebracht...
                                            Wie auch immer... ich würde gerne was zum Homekit-Problem tun, weiß aber nicht was... Wie bereits geschrieben kann ich installieren und er wird grün. Die Funktion kann ich nicht prüfen, weil mein altes iPad keine iOS Updates mehr bekommt und ich somit kein Device besitze welches mit dem Adapter kommunizieren könnte... Falls es eine andere Möglichkeit gibt, lasst es mich wissen.
                                            MfG,
                                            André
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1528052
