    4. Adapter Update nicht möglich --> gelöst
      Thomas Braun Most Active @K_o_bold last edited by
      @k_o_bold
      Komplette Ein- wie Ausgaben zeigen.
      iob update
      iob upgrade all
        K_o_bold @Thomas Braun last edited by
        @thomas-braun sagte in Adapter Update nicht möglich:
        iob update
        root@uwe-nuc7i3bnh:/opt/iobroker# iob update
        Used repository: stable
        Adapter    "admin"        : 6.17.14  , installed 6.17.14
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "daikin-cloud" : 0.4.6    , installed 0.3.0  [Updatable]
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "doorbird"     : 1.6.0    , installed 1.5.0  [Updatable]
        Adapter    "easee"        : 1.0.10   , installed 1.0.10
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "evcc"         : 0.1.1    , installed 0.1.1
        Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
        Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.3.1    , installed 8.3.1
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "panasonic-viera": 2.1.0  , installed 1.0.2  [Updatable]
        Adapter    "rflink"       : 2.1.6    , installed 2.1.6
        Adapter    "scenes"       : 3.0.4    , installed 3.0.4
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smart-eq"     : 0.0.4    , installed 0.0.4
        Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sonnen"       : 1.18.1   , installed 1.18.1
        Adapter    "tado"         : 0.5.5    , installed 0.5.4  [Updatable]
        Adapter    "telegram"     : 3.3.2    , installed 3.3.2
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
        Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
        Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
        Adapter    "vis-2-widgets-inventwo": 0.1.5, installed 0.1.5
        Adapter    "vis-2-widgets-jaeger-design": 1.1.19, installed 1.1.19
        Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        iob upgrade all
        root@uwe-nuc7i3bnh:/opt/iobroker# iob upgrade all
        This upgrade of "tado" will introduce the following changes:
        -> 0.5.5:
        Bump axios to 1.7.2
        Would you like to upgrade tado from @0.5.4 to @0.5.5 now? [(y)es, (n)o]: y
        Update tado from @0.5.4 to @0.5.5
        NPM version: 10.7.0
        Installing iobroker.tado@0.5.5... (System call)
        upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
        upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/jsonConfig.json jsonConfig.json application/json
        upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
        This upgrade of "panasonic-viera" will introduce the following changes:
        -> 2.1.0:
        Adapter requires node.js >= 18 and js-controller >= 5 now
        Dependencies have been updated
        -> 2.0.0:
        added support to set Application and Encryption Key in adapter admin
        changed adapter to use node-panasonic-viera to support modern TV models
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade panasonic-viera from @1.0.2 to @2.1.0 now? [(y)es, (n)o]: n
        No upgrade of "panasonic-viera" desired.
        This upgrade of "doorbird" will introduce the following changes:
        -> 1.6.0:
        Adapter requires node.js >= 18 and Admin >=6 now
        Would you like to upgrade doorbird from @1.5.0 to @1.6.0 now? [(y)es, (n)o]: y
        Update doorbird from @1.5.0 to @1.6.0
        NPM version: 10.7.0
        Installing iobroker.doorbird@1.6.0... (System call)
        Update "system.adapter.doorbird.0"
        upload [14] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/doorbird.png doorbird.png image/png
        upload [13] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [12] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [11] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [10] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [9] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [8] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [7] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [6] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [5] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [4] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [3] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [2] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/index.html index.html text/html
        upload [1] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/index_m.html index_m.html text/html
        upload [0] doorbird.admin /opt/iobroker/node_modules/iobroker.doorbird/admin/words.js words.js application/javascript
        This upgrade of "daikin-cloud" will introduce the following changes:
        -> 0.4.6:
        Update dependencies with optimizations and second blocking layer for rate limiting
        -> 0.4.5:
        Block communication when rate limited according to Daikin response
        -> 0.4.4:
        Fix initialization retry schedule
        -> 0.4.3:
        IMPORTANT: Minimum Node.js version is 18.2
        BREAKING: Adjusted to new Daiking Cloud API - You need to reauthenticate!
        BREAKING: New rate limit of new API is 200 requests per day!! Adjust your usage!
        Added option to set "slow polling" interval
        Make electrical data available as states (arrays for now)
        Restore last data updated timestamp
        Make sure cloudConnection always contains a boolean
        Refresh token also when error is "Refresh Token has expired"
        Would you like to upgrade daikin-cloud from @0.3.0 to @0.4.6 now? [(y)es, (n)o]: y
        Update daikin-cloud from @0.3.0 to @0.4.6
        NPM version: 10.7.0
        Installing iobroker.daikin-cloud@0.4.6... (System call)
        Update "system.adapter.daikin-cloud.1"
        upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
        upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
        upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
        upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/index_m.html index_m.html text/html
        upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/style.css style.css text/css
        upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
        upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
          Thomas Braun Most Active @K_o_bold last edited by Thomas Braun
          @k_o_bold
          Bring mal dein nodejs auf Stand. Am besten auf die aktuelle 20er-Version.
          iob update
          sagt nun?
          • Armilar
            Armilar Most Active Forum Testing last edited by Armilar
            @k_o_bold
            hmm... dein daikin-cloud war in der Version 0.3.0 ... und dürfte aufgrund der Breaking-Changes bei Daikin schon etliche Tage nicht mehr arbeiten...
            Da musst du sowieso ran.
            https://forum.iobroker.net/topic/75670/test-adapter-daikin-cloud-0-4-0?page=1
            Besser gleich in latest (0.4.8) - die hat schon ein paar Pflaster mehr und erspart etwas Ärger
            mcm1957 K 2 Replies Last reply Reply Quote 0
            • mcm1957
              mcm1957 @Armilar last edited by
              Daikin-cloud ist zwischenzeitlich auch auf stable im Lettstand verfügbar
                K_o_bold @Thomas Braun last edited by K_o_bold
                @thomas-braun ,
                nodejs ist bei mir die aktuellste 18 Version --> Node.js: v18.20.4
                Ich denke daran kann es nicht liegen, oder? Die Adapter benötigen v20.x noch nicht.
                Da ich den Docker Container von Buanet nutze, mache ich jetzt ungern innerhalb des Containers ein update, sondern warte auf eine neue Version von ihm
                  K_o_bold @Armilar last edited by
                  @armilar ,
                  ja das versuche ich ja... Aber der Adapter und alle anderen lassen sich plötzlich nicht mehr updaten
                    Homoran Global Moderator Administrators @K_o_bold last edited by
                    @k_o_bold dann mach mal ein iob upgrade daikin-cloud --debug und poste das Ergebnis
                      K_o_bold @Homoran last edited by
                      @homoran sagte in Adapter Update nicht möglich:
                      root@uwe-nuc7i3bnh:/opt/iobroker# iob upgrade daikin-cloud --debug
                      -> 0.4.6:
                      -> 0.4.5:
                      -> 0.4.4:
                      -> 0.4.3:
                      NPM version: 10.8.1
                      npm error code EHOSTUNREACH
                      npm error syscall connect
                      npm error errno EHOSTUNREACH
                      npm error request to https://registry.npmjs.org/iobroker.daikin-cloud failed, reason: connect EHOSTUNREACH 2606:4700::6810:323:443
                      npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-07-16T19_41_55_122Z-debug-0.log
                        @k_o_bold sagte in Adapter Update nicht möglich:
                        du erreichst den npm Server nicht!
                        hast du Probleme mit dem Netzwerk, wahrscheinlich mit IPv6?
                          @homoran ,
                          mein Netzwerk sollte ok, sein. Zumindest habe ich nichts geändert.
                          Der Server ist per LAN mit der Fritzbox verbunden...IPv4 soweit ich das beurteilen kann...
                          Wie könnte ich den Prüfen ob es an meinem Netzwerk liegt?
                          Sorry ich bin da noch nicht so fit
                            nix gut!
                            der server wird per ipv6 aufgerufen!
                            teste mal https://internet.nl/connection/
                              @homoran ,
                              Ok, ich denke dann kommen wir der Sachen näher...
                              Ich frage mich nur, warum das bisher funktioniert hat...
                              Ich denke, das kann ich in der Fritzbox einstellen, oder?
                                ich denke auch. weiss aber nicht wo
                                  @homoran ,
                                  scheint aber bei mir aktiv zu sein...
                                    Homoran Global Moderator Administrators @K_o_bold last edited by Homoran
                                    dann klemmt's irgendwo beim Provider wenn's draußen ist oder irgendwo drinnen bei dir.
                                    ggf. kannst du auch ipv6 via ipv4 tunneln.
                                      @k_o_bold
                                      Was ist denn das da für ein Zugang?
                                        @homoran ,
                                        oder einfach mal die Fritzbox neustarten 😬 hilft auch manchmal....
                                        Oh Mann...
                                        Vielen, Vielen Dank für deine und eure Hilfe und Geduld....
                                          @thomas-braun ,
                                          was meinst du?
                                            @k_o_bold
                                            Ich meinte, über welchen Internetprovider bzw. über welche Technik du ins Netz gehst.
                                            Ich vermute, dein ISP hat dich auf IPv6 gehievt.
                                            2117
