    4. [Javascript] Midas (Aquatemp) Poolheizung
      sunnylaila @Michael Roling last edited by
      @michael-roling
      ich habe eine Poolsana Promo Next 5 Wärmepumpe mit dem Wlan Modul von Poolsana..
      Habe es jetzt auch nochmal neu installiert und hier der neue Log
      	2024-07-16 07:43:36.428	error	Response: {"sessionid":null,"error_code":"0","error_msg":"Success","error_msg_code":"","totalSize":null,"totalPage":null,"nextPage":null,"objectResult":[],"isReusltSuc":true}
      midas-aquatemp.0
      2024-07-16 07:43:36.427	error	Error in updateDeviceID(): No device code found
      midas-aquatemp.0
      2024-07-16 07:43:36.359	info	Login ok! Token: 5CqvwvNH0tQ85m8hk0DATZHOTOEsF1K/kDQSTpKjxWRFYbVNJboSqmZwqSFBt3sbXPFacEkw0HogOrNnmbsXTw==
      midas-aquatemp.0
      2024-07-16 07:43:35.921	info	Request token
      midas-aquatemp.0
      2024-07-16 07:43:35.919	info	Objects created
      midas-aquatemp.0
      2024-07-16 07:43:35.916	info	Create object: midas-aquatemp.0.rawJSON
      midas-aquatemp.0
      2024-07-16 07:43:35.913	info	Create object: midas-aquatemp.0.DeviceCode
      midas-aquatemp.0
      2024-07-16 07:43:35.911	info	Create object: midas-aquatemp.0.ProductCode
      midas-aquatemp.0
      2024-07-16 07:43:35.908	info	Create object: midas-aquatemp.0.exhaust
      midas-aquatemp.0
      2024-07-16 07:43:35.905	info	Create object: midas-aquatemp.0.coilTemp
      midas-aquatemp.0
      2024-07-16 07:43:35.903	info	Create object: midas-aquatemp.0.suctionTemp
      midas-aquatemp.0
      2024-07-16 07:43:35.900	info	Create object: midas-aquatemp.0.tempSet
      midas-aquatemp.0
      2024-07-16 07:43:35.897	info	Create object: midas-aquatemp.0.tempOut
      midas-aquatemp.0
      2024-07-16 07:43:35.894	info	Create object: midas-aquatemp.0.tempIn
      midas-aquatemp.0
      2024-07-16 07:43:35.891	info	Create object: midas-aquatemp.0.state
      midas-aquatemp.0
      2024-07-16 07:43:35.888	info	Create object: midas-aquatemp.0.silent
      midas-aquatemp.0
      2024-07-16 07:43:35.885	info	Create object: midas-aquatemp.0.rotor
      midas-aquatemp.0
      2024-07-16 07:43:35.882	info	Create object: midas-aquatemp.0.mode
      midas-aquatemp.0
      2024-07-16 07:43:35.879	info	Create object: midas-aquatemp.0.errorMessage
      midas-aquatemp.0
      2024-07-16 07:43:35.876	info	Create object: midas-aquatemp.0.errorLevel
      midas-aquatemp.0
      2024-07-16 07:43:35.873	info	Create object: midas-aquatemp.0.errorCode
      midas-aquatemp.0
      2024-07-16 07:43:35.868	info	Create object: midas-aquatemp.0.error
      midas-aquatemp.0
      2024-07-16 07:43:35.859	info	Create object: midas-aquatemp.0.consumption
      midas-aquatemp.0
      2024-07-16 07:43:35.851	info	Create object: midas-aquatemp.0.info.connection
      midas-aquatemp.0
      2024-07-16 07:43:35.814	info	Create object: midas-aquatemp.0.ambient
      midas-aquatemp.0
      2024-07-16 07:43:35.777	info	starting. Version 0.0.1 (non-npm: MiRo1310/ioBroker.midas-aquatemp#1eafbd195d1db6ca646dbdda7f8dced23b9ab2fd) in /opt/iobroker/node_modules/iobroker.midas-aquatemp, node: v20.15.1, js-controller: 5.0.19
      midas-aquatemp.0
      2024-07-16 07:43:30.008	info	terminating
      midas-aquatemp.0
      2024-07-16 07:43:29.507	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      midas-aquatemp.0
      2024-07-16 07:43:29.505	info	terminating
      midas-aquatemp.0
      2024-07-16 07:43:29.503	info	Got terminate signal TERMINATE_YOURSELF
      midas-aquatemp.0
      2024-07-16 07:43:09.289	error	Error in getToken(): {"message":"","name":"AggregateError","stack":"AggregateError\n at AxiosError.from (/opt/iobroker/node_modules/iobroker.midas-aquatemp/node_modules/axios/dist/node/axios.cjs:841:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.midas-aquatemp/node_modules/axios/dist/node/axios.cjs:3106:25)\n at RedirectableRequest.emit (node:events:519:28)\n at eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)\n at ClientRequest.emit (node:events:519:28)\n at Socket.socketErrorListener (node:_http_client:500:9)\n at Socket.emit (node:events:519:28)\n at emitErrorNT (node:internal/streams/destroy:169:8)\n at emitErrorCloseNT (node:internal/streams/destroy:128:3)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/opt/iobroker/node_modules/iobroker.midas-aquatemp/node_modules/axios/dist/node/axios.cjs:4224:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async getToken (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/lib/token.js:48:24)\n at async updateToken (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/lib/token.js:73:5)\n at async MidasAquatemp.onReady (/opt/iobroker/node_modules/iobroker.midas-aquatemp/build/main.js:76:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/json","User-Agent":"axios/1.7.2","Content-Length":"72","Accept-Encoding":"gzip, compress, deflate, br"},"method":"post","url":"/app/user/login","data":"{\"userName\":\"\",\"password\":\"d41d8cd98f00b204e9800998ecf8427e\",\"type\":\"2\"}"},"code":"ECONNREFUSED","status":null}
      midas-aquatemp.0
      2024-07-16 07:43:09.207	info	Request token
      Leider geht es noch nicht
      • Michael Roling
        Michael Roling Developer @sunnylaila last edited by
        @sunnylaila Es ist so das der Adapter das Device nicht erkennt. Das was im log kommt sind von mir die erwarteten Logs. Jetzt müssen wir als nächstes schauen warum das Gerät nicht erkannt wird. Evtl hat @oxident da eine Idee zu. Ich bin aber dran
          @michael-roling
          ich hatte ganz am Anfang auch Probleme mit dem Javascript da hat der User znyde
          der die gleiche Pumpe hat wie ich eine Änderung im Javascript gepostet mit der es dann
          auch bei mir ging.
          Ich glaube es war Post 77 oder 78
          Vielleicht hilft es dir ja bei der Fehlersuche.
          Ich bin leider nur User und kenne mich damit null aus.
          Danke dir
          • Michael Roling
            @sunnylaila wenn du Zeit hast kannst du ja mal den Post raus suchen.
              sunnylaila @znyde last edited by
              @znyde said in [Javascript] Midas (Aquatemp) Poolheizung:
              @sunnylaila
              hiermit ignorierst du die SSL Zertifkats meldung
              Copy to Clipboard function updateToken() { if(token=="") { log("Token Neuanforderung"); var request = require('request'); var options = { url: cloudURL + '/app/user/login.json', method: 'POST', json: { "user_name": username, "password": password, "type": "2" }, rejectUnauthorized: false }; request(options,function (error, response, body){ console.log(error); console.log(JSON.stringify(response)); if(parseInt(body.error_code)==0) { token = body.object_result["x-token"]; log("Login ok! Token " + token); updateDeviceID(); } else { // Login-Fehler log("Login-Fehler in updateToken(): " + response.body, "warn"); token = ""; } }); } else { updateDeviceID(); } }
              einmal der Post
                @sunnylaila
                Bei mir ist das Modul an eine Promo Next 5 angeschlossen, das Mapping mit den Temperaturen habe ich geändert... übrigens kannst Du das in deiner App abfragen Burgermenü oben rechts -> Parametereinstellungen -> Kennwort: 022 (so war es bei mir)
                // Midas Poolheizung
                // v0.0.5
                // Changelog:
                // 0.0.5: weitere Abfragewerte hinzugefügt (Kompressor- und Ansaugtemperatur)
                // 0.0.4: Tokenverfall jetzt 60min nach Skriptstart und nicht zu jeder vollen Stunde (Dank an dering)
                // 0.0.3: Datenpunkte beim Start automatisch anlegen (Dank an Andy200877)
                // 0.0.2: Token bei jedem Set-Vorgang prüfen und ggf. neu anfordern (Dank an dering)
                const username = "xxx@xxxx.com";
                const password = "xxxxxx";
                const interval = 30;
                const cloudURL = "https://cloud.linked-go.com/cloudservice/api";
                const dpRoot = "0_userdata.0.Poolheizung";
                var token = "";
                var tokenRefreshTimer;
                var device = "";
                var reachable = false;
                function clearValues() {
                    saveValue("error", true, "boolean");
                    saveValue("consumption", 0, "number");
                    saveValue("state", false, "boolean");
                function saveValue(key, value, sType) {
                    var dp = dpRoot + "." + key;
                    if ( !existsState(dp )) {
                        createState(dp,value,{name: key,  type: 'number', role: 'value'}, function () {});
                    } else {
                        setState(dp,value,true);
                function findCodeVal(result, code) {
                    //log(code);
                    for(var i=0; i<result.length; i++) {
                        //log(result[i].code);
                        if(result[i].code.indexOf(code) >= 0) {
                            return result[i].value;
                    return "";
                function createobjects() {
                    log ("erstelle Objekte");
                    createState(dpRoot + '.ambient', {read: true, write: false,  type: "number", unit:"°C", name: "Umgebungstemperatur"});
                    createState(dpRoot + '.connection', {read: true, write: false,  type: "boolean", role: "state", name: "Verbindung", def: "false"});
                    createState(dpRoot + '.consumption', {read: true, write: false,  type: "number", unit:"W", name: "Stromverbrauch", def: 0});
                    createState(dpRoot + '.error', {read: true, write: false,  type: "boolean", role: "state", name: "Fehler", def: "false"});
                    createState(dpRoot + '.errorCode', {read: true, write: false,  type: "string", name: "Fehlercode", def: ""});
                    createState(dpRoot + '.errorLevel', {read: true, write: false,  type: "number", name: "Fehlerlevel"});
                    createState(dpRoot + '.errorMessage', {read: true, write: false,  type: "string", name: "Fehlermeldung", def: ""});
                    createState(dpRoot + '.mode', {read: true, write: true,  type: "string", states: "-1:off;0:cool;1:heat;2:auto", name: "Modus", def: ""});
                    createState(dpRoot + '.silent', {read: true, write: true,  type: "boolean", role: "state", name: "Silent", def: "false"});
                    createState(dpRoot + '.state', {read: true, write: false,  type: "boolean", role: "state", name: "Status", def: "false"});
                    createState(dpRoot + '.tempIn', {read: true, write: false,  type: "number", unit:"°C", name: "Eingangstemperatur"});
                    createState(dpRoot + '.tempOut', {read: true, write: false,  type: "number", unit:"°C", name: "Ausgangstemperatur"});
                    createState(dpRoot + '.tempSet', {read: true, write: true,  type: "number", unit:"°C", name: "Solltemperatur"});
                    createState(dpRoot + '.suctionTemp', {read: true, write: false,  type: "number", unit:"°C", name: "Luftansaugtemperatur"});
                    createState(dpRoot + '.coilTemp', {read: true, write: false,  type: "number", unit:"°C", name: "Kompressortemperatur"});
                    createState(dpRoot + '.rawJSON', {read: true, write: false,  type: "array", name: "komplette Rückgabe"});
                    if(token=="") {
                        var options = {
                            method: 'POST',
                         console.log(error);
                                updateDeviceID();
                            } else {
                                // Login-Fehler
                                token = "";
                    } else {
                        updateDeviceID();
                function updateDeviceID() {
                    if(token!="") {
                        var optionsDev = {
                            url: cloudURL + '/app/device/deviceList.json',
                            headers: { "x-token": token},
                            body: {product_ids: ["1442284873216843776"]},
                            method: 'POST',
                            json: true,
                        request(optionsDev,function (error, response, body1){
                  //  console.log(parseInt(body1.error_code));
                  //         console.log(JSON.stringify(response));
                   //         log(JSON.stringify(body1.object_result));
                            if(parseInt(body1.error_code)==0) {
                                //token = body.object_result["x-token"];
                               device = body1.object_result[0].device_code;
                               // device=1;
                                console.log(device);
                                reachable = (body1.object_result[0].device_status=="ONLINE");
                                if(reachable) {
                                    saveValue("connection", true, "boolean");
                                    if(device!="") updateDeviceStatus(device);
                                } else {
                                    // offline
                                    device = "";
                                    saveValue("connection", false, "boolean");
                            } else {
                                // Login-Fehler
                                //log("Fehler in updateDeviceID(): " + response.body);
                                token = "";
                                device = "";
                                reachable = false;
                function updateDeviceStatus(devicecode) {
                    if(token!="") {
                        var optionsDev = {
                            url: cloudURL + '/app/device/getDeviceStatus.json',
                            headers: { "x-token": token },
                            json: { "device_code": devicecode },
                            method: 'POST',
                        request(optionsDev,function (error, response, body){
                            //log(JSON.stringify(response));
                            //log(JSON.stringify(body.object_result));
                                if(body.object_result["is_fault"]==true) {
                                    // TODO: Fehlerbeschreibung abrufen
                                     //clearValues();
                                    updateDeviceDetails(devicecode);
                                    updateDeviceErrorMsg(devicecode);
                                } else {
                                    // kein Fehler
                                    saveValue("error", false, "boolean");
                                    saveValue("errorMessage", "", "string");
                                    saveValue("errorCode", "", "string");
                                    saveValue("errorLevel", 0, "number");
                                //log("Login ok! Token " + token);
                            } else {
                                // Login-Fehler
                                log("Fehler in updateDeviceStatus(): " + response.body);
                                token = "";
                                device = "";
                function updateDeviceErrorMsg(devicecode) {
                    if(token!="") {
                        var optionsDev = {
                            url: cloudURL + '/app/device/getFaultDataByDeviceCode.json',
                            method: 'POST',
                            //headers: {"content-type": "application/json"},
                            //charset: 'utf8',
                            //json: true
                                saveValue("errorMessage", body.object_result[0].description, "string");
                                saveValue("errorCode", body.object_result[0].fault_code, "string");
                                saveValue("errorLevel", body.object_result[0].error_level, "string");
                            } else {
                                // Login-Fehler
                                log("Fehler in updateDeviceErrorMsg(): " + response.body);
                                token = "";
                                device = "";
                function updateDeviceDetails(devicecode) {
                    if(token!="") {
                        var optionsDev = {
                            url: cloudURL + '/app/device/getDataByCode.json',
                          //  json: { "device_code": devicecode },
                          // R02=Heatin-Set Point,T2=inlet Water Temp, T3=Outlet Water Temp,T5=Ambient-Temp,
                          json: { "device_code": devicecode, "protocal_codes":["R02","T1","T2","T3","T5","P01","P02","Power","Mode"] },
                           // json: { "device_code": devicecode, "protocal_codes":["Power","Mode","Manual-mute","T01","T02","2074","2075","2076","2077","H03","Set-Temp","R08","R09","R10","R11","R01","R02","R03","T03","1158","1159","F17","H02","T04","T05","T07","T14","T17"] },
                            // "protocal_codes":["Power","Mode","Manual-mute","T01","T02","2074","2075","2076","2077","H03","Set_Temp","R08","R09","R10","R11","R01","R02","R03","T03","1158","1159","F17","H02","T04","T05"]
                            method: 'POST',
                  console.log("update detail" + JSON.stringify(response));
                                saveValue("rawJSON", body.object_result, "string");
                                if(findCodeVal(body.object_result, "Power")=="1") {
                                    // Stromverbrauch T07 x T14 in Watt
                                    saveValue("consumption", parseFloat(findCodeVal(body.object_result, "T07")) * parseFloat(findCodeVal(body.object_result, "T14")), "number");
                                    // Lüfter-Drehzahl T17
                                    saveValue("rotor", parseInt(findCodeVal(body.object_result, "T17")), "number");
                                    // Luftansaug-Temperatur T01
                                    saveValue("suctionTemp", parseFloat(findCodeVal(body.object_result, "T1")), "number");
                                    // Inlet-Temperatur T02
                                    saveValue("tempIn", parseFloat(findCodeVal(body.object_result, "T2")), "number");
                                    // outlet-Temperatur T03
                                    saveValue("tempOut", parseFloat(findCodeVal(body.object_result, "T3")), "number");
                                    // Coil-Temperatur T04
                                    saveValue("coilTemp", parseFloat(findCodeVal(body.object_result, "T04")), "number");
                                } else {
                                    saveValue("rotor", 0, "number");
                                // Ziel-Temperatur Set_Temp
                                saveValue("tempSet", parseFloat(findCodeVal(body.object_result, "Set_Temp")), "number");
                                // Umgebungs-Temperatur T05
                                saveValue("ambient", parseFloat(findCodeVal(body.object_result, "T5")), "number");
                                // Flüstermodus Manual-mute
                                if(findCodeVal(body.object_result, "Manual-mute")=="1") {
                                    saveValue("silent", true, "boolean");
                                } else {
                                    saveValue("silent", false, "boolean");
                                // Zustand Power
                                    saveValue("state", true, "boolean");
                                    saveValue("mode", findCodeVal(body.object_result,"Mode"), "string");
                                } else {
                                    saveValue("mode", "-1", "string");
                                //log(findCodeVal(body.object_result, "T07"));
                            } else {
                                // Login-Fehler
                                log("Fehler in updateDeviceDetails(): " + response.body);
                                token = "";
                                device = "";
                function updateDevicePower(devicecode, power) {
                    var powerOpt;
                    var powerMode = 2;
                    if(power==-1) {
                        // aus
                        powerOpt = 0;
                        powerMode = -1;
                    } else if(power==0) {
                        // an und kühlen
                        powerOpt = 1;
                        powerMode = 0;
                    } else if(power==1) {
                        // an und heizen
                        powerOpt = 1;
                        powerMode = 1;
                    } else if(power==2) {
                        // an und auto
                        powerOpt = 1;
                        powerMode = 2;
                    } else {
                        log("ungülter Zustand!");
                        return;
                    if(token!="") {
                        var optionsDev = {
                            url: cloudURL + '/app/device/control.json',
                            json: {"param":[{ "device_code": devicecode, "protocol_code": "Power","value": powerOpt }]},
                            method: 'POST',
                            //log(devicecode);
                                saveValue("mode", power, "string");
                                if(power>=0) updateDeviceMode(device, power);
                            } else {
                                log("Zustandsänderung fehlgeschlagen!");
                function updateDeviceMode(devicecode, mode) {
                    if(token!="") {
                        var optionsDev = {
                            json: {"param":[{ "device_code": devicecode, "protocol_code": "mode","value": mode }]},
                            method: 'POST',
                            //charset: 'utf8',
                            //json: true
                            //log(devicecode);
                                saveValue("mode", mode, "string");
                            } else {
                function updateDeviceSilent(devicecode, silent) {
                    var silentMode;
                    if(silent) {
                        silentMode = "1";
                    } else {
                        silentMode = "0";
                    if(token!="") {
                        var optionsDev = {
                            json: {"param":[{ "device_code": devicecode, "protocol_code": "Manual-mute","value": silentMode }]},
                            method: 'POST',
                            //charset: 'utf8',
                            //json: true
                            //log(devicecode);
                                saveValue("silent", silent, "boolean");
                            } else {
                function updateDeviceSetTemp(devicecode, temperature) {
                    var sTemperature = temperature.toString().replace(",", ".");
                    var sMode = getState(dpRoot + ".mode").val;
                    if(sMode=="-1") {
                        //log("Gerät einschalten um Temperatur zu ändern!", 'warn');
                        return;
                    } else if(sMode=="0") {
                        sMode = "R01"; // Kühlen
                    } else if(sMode=="1") {
                        sMode = "R02"; // Heizen
                    } else if(sMode=="2") {
                        sMode = "R03"; // Auto
                    if(token!="") {
                        var optionsDev = {
                            json: {"param":[{ "device_code": devicecode, "protocol_code": "R01","value": sTemperature },{ "device_code": devicecode, "protocol_code": "R02","value": sTemperature },{ "device_code": devicecode, "protocol_code": "R03","value": sTemperature },{ "device_code": devicecode, "protocol_code": "Set_Temp","value": sTemperature }]},
                            method: 'POST',
                            //charset: 'utf8',
                            //json: true
                            //log(devicecode);
                                saveValue("tempSet", temperature, "number");
                            } else {
                // Beginn des Skripts
                createobjects(); // DPs anlegen
                updateToken(); // Zugriffstoken erfragen und aktuelle Werte lesen
                schedule('*/' + interval + ' * * * * *', function () {
                    // regelmäßig Token und Zustand abfragen
                    updateToken();
                    // gewünschte Änderungen ausführen
                    if(!getState(dpRoot + ".mode").ack) {
                        updateDevicePower(device, getState(dpRoot + ".mode").val);
                    if(!getState(dpRoot + ".silent").ack) {
                        updateDevicePower(device, getState(dpRoot + ".silent").val);
                tokenRefreshTimer = setInterval(async function () {
                    // Token verfällt nach 60min
                    token = "";
                    //log("Token nach Intervall verworfen.")
                    updateToken();
                }, 3600000);
                on({id: dpRoot + ".mode", change: "ne", ack: false}, async function (obj) {
                    updateToken();
                on({id: dpRoot + ".silent", change: "ne", ack: false}, async function (obj) {
                    updateToken();
                    updateDeviceSilent(device, getState(dpRoot + ".silent").val);
                on({id: dpRoot + ".tempSet", change: "ne", ack: false}, async function (obj) {
                    updateToken();
                    updateDeviceSetTemp(device, getState(dpRoot + ".tempSet").val);
                und einmal hier das komplette Javascript
                was dann funktioniert hat
                • Michael Roling
                  @sunnylaila Ich habe das jetzt für 2 Funktionen eingebaut, wahrscheinlich muss das für alle anderen Funktionen auch noch implementiert werden. Wenn das dann alles funktioniert wird man dieses speziell im Adapter unchecken müssen das man die ssl zertifikat meldungen ignorieren möchte, was ein Sicherheitsrisiko ist. Aber erstmal testen ob es wie gesagt jetzt anders wird.
                    @michael-roling
                    habe es gerade neu installiert aber leider noch kein erfolg siehe log
                    midas-aquatemp.0
                    2024-07-17 18:38:47.258	error	Response: {"sessionid":null,"error_code":"0","error_msg":"Success","error_msg_code":"","totalSize":null,"totalPage":null,"nextPage":null,"objectResult":[],"isReusltSuc":true}
                    midas-aquatemp.0
                    2024-07-17 18:38:47.258	error	Error in updateDeviceID(): No device code found
                    midas-aquatemp.0
                    2024-07-17 18:38:47.092	info	Login ok! Token: TVhfM4yFTdnqTRMIchl7Rt+ILOZsLixeSOXBNvoowdNppxVNabU6Mj1mYkyWloTMXPFacEkw0HogOrNnmbsXTw==
                    midas-aquatemp.0
                    2024-07-17 18:38:46.550	info	Request token
                    midas-aquatemp.0
                    2024-07-17 18:38:46.546	info	Objects created
                    midas-aquatemp.0
                    2024-07-17 18:38:46.539	info	Create object: midas-aquatemp.0.rawJSON
                    midas-aquatemp.0
                    2024-07-17 18:38:46.521	info	Create object: midas-aquatemp.0.DeviceCode
                    midas-aquatemp.0
                    2024-07-17 18:38:46.514	info	Create object: midas-aquatemp.0.ProductCode
                    midas-aquatemp.0
                    2024-07-17 18:38:46.506	info	Create object: midas-aquatemp.0.exhaust
                    midas-aquatemp.0
                    2024-07-17 18:38:46.501	info	Create object: midas-aquatemp.0.coilTemp
                    midas-aquatemp.0
                    2024-07-17 18:38:46.497	info	Create object: midas-aquatemp.0.suctionTemp
                    midas-aquatemp.0
                    2024-07-17 18:38:46.493	info	Create object: midas-aquatemp.0.tempSet
                    midas-aquatemp.0
                    2024-07-17 18:38:46.488	info	Create object: midas-aquatemp.0.tempOut
                    midas-aquatemp.0
                    2024-07-17 18:38:46.483	info	Create object: midas-aquatemp.0.tempIn
                    midas-aquatemp.0
                    2024-07-17 18:38:46.478	info	Create object: midas-aquatemp.0.state
                    midas-aquatemp.0
                    2024-07-17 18:38:46.473	info	Create object: midas-aquatemp.0.silent
                    midas-aquatemp.0
                    2024-07-17 18:38:46.468	info	Create object: midas-aquatemp.0.rotor
                    midas-aquatemp.0
                    2024-07-17 18:38:46.463	info	Create object: midas-aquatemp.0.mode
                    midas-aquatemp.0
                    2024-07-17 18:38:46.459	info	Create object: midas-aquatemp.0.errorMessage
                    midas-aquatemp.0
                    2024-07-17 18:38:46.454	info	Create object: midas-aquatemp.0.errorLevel
                    midas-aquatemp.0
                    2024-07-17 18:38:46.447	info	Create object: midas-aquatemp.0.errorCode
                    midas-aquatemp.0
                    2024-07-17 18:38:46.438	info	Create object: midas-aquatemp.0.error
                    midas-aquatemp.0
                    2024-07-17 18:38:46.423	info	Create object: midas-aquatemp.0.consumption
                    midas-aquatemp.0
                    2024-07-17 18:38:46.415	info	Create object: midas-aquatemp.0.info.connection
                    midas-aquatemp.0
                    2024-07-17 18:38:46.358	info	Create object: midas-aquatemp.0.ambient
                    midas-aquatemp.0
                    2024-07-17 18:38:46.312	info	starting. Version 0.0.1 (non-npm: MiRo1310/ioBroker.midas-aquatemp#fe2980f6c63f14269805862155e182f5f2bed22b) in /opt/iobroker/node_modules/iobroker.midas-aquatemp, node: v20.15.1, js-controller: 5.0.19
                    Michael Roling O 2 Replies Last reply Reply Quote 0
                    • Michael Roling
                      @sunnylaila sorry. Ich muss dann noch mal schauen.
                      • O
                        oxident @sunnylaila last edited by
                        @sunnylaila Das ist echt tricky ... hat aber mit den SSL-Sachen nix zu tun. Ich schaue parallel auch nochmal!
                        • Michael Roling
                          Michael Roling Developer @oxident last edited by Michael Roling
                          @oxident Hast du schon was in Erfahrung bringen können? Mir scheint es so als ob er das Device nicht erkennt, und daher kann der ganze Code nicht laufen. Der Error der kommt, ist von mir so eingebaut. Das Login klappt ja, nur halt bekommt er keine weiteren Daten.
                          Dann ist die Frage von wo kommt der ProduktId? In meiner App steht eine ganz andere Id als wie im Adapter ausgelesen.
                          Ich nehme das mit dem ssl zertifikat erstmal wieder raus, denn das ist ja sonst eine mögliche Sicherheitslücke.
                          Kann das was mit dem Api-Level zu tun haben?
                          @sunnylaila Hast du das mal versucht ob es mit einem anderen geht?
                            @michael-roling
                            Was meinst du mit einem anderen?
                            Kann ich eventuell euch aus der App etwas auslesen in den Parameter Einstellung ?
                            • Michael Roling
                              @sunnylaila ich meinte anderen api Level in den settings
                                sorry für den Spam,
                                hier eine Lösung die bei mir geholfen hat
                                einfach diese Abfrage hinzufügen:
                                    if(token!="") {
                                        var optionsDev = {
                                            method: 'POST',
                                            json: true,
                                hier hat zynde noch etwas im Javascript hinzugefügt für die product id
                                " body: {product_ids: ["1442284873216843776"]}, "
                                vielleicht hilft das ja etwas
                                  @michael-roling
                                  api level hatte ich alle drei ausprobiert hat aber nichts geändert
                                  • Michael Roling
                                    @sunnylaila die productId ist bereits enthalten
                                    • Michael Roling
                                      @oxident Sag mal hatte das einen Grund warum man die Werte nur ändern darf wenn die Wärmepumpe an ist? Ich habe das mal raus genommen, es sei denn du hast da noch einen Einwand zu.
                                      • Michael Roling
                                        @sunnylaila Ich habe noch mal ein paar kleine Änderungen vor genommen. Also noch einmal bitte testen
                                        • O
                                          oxident @Michael Roling last edited by
                                          @michael-roling Also früher hat der Server sämtliche Änderungen (bis auf on/off) mit einem Fehler quittiert wenn die WP aus war. Ist das jetzt nicht mehr so?
                                          Also bei @sunnylaila stehe ich auch gerade auf dem Schlauch. Eine Paketmitschnitt aus der App wäre cool, aber das ist ja sicherlich nicht ganz so leicht...
                                          Eventuell könnte es an der ProductID liegen. Die habe ich vom Github-Projekt übernommen.
                                          • Michael Roling
                                            @oxident ja das geht jetzt.
                                            359
                                            70534
