    4. Hoymiles hms-800w-2t
      Michael 6 @kla960 last edited by Michael 6
      @hosssa Dem schließe ich mich auch an als neuer User einer HMS-800W-2T. Ich bekomme die WEB-API leider nicht zum Laufen.
      Daher bitte auch ichj um ein Docker-Image für den RaspberryPi.
      Update:
      Error:
      pi@rpi:/media/nas $ cat /etc/debian_version
      11.9
      sudo pip install -r req.txt
      Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
      Requirement already satisfied: Flask[async] in /usr/lib/python3/dist-packages (from -r req.txt (line 1)) (1.1.2)
      Collecting hoymiles-wifi
        Downloading https://www.piwheels.org/simple/hoymiles-wifi/hoymiles_wifi-0.2.2-py3-none-any.whl (33 kB)
      WARNING: flask 1.1.2 does not provide the extra 'async'
      Collecting protobuf
        Downloading https://www.piwheels.org/simple/protobuf/protobuf-5.27.2-cp39-cp39-linux_armv7l.whl (981 kB)
           |████████████████████████████████| 981 kB 966 kB/s
      Collecting crcmod
        Downloading https://www.piwheels.org/simple/crcmod/crcmod-1.7-cp39-cp39-linux_armv7l.whl (30 kB)
      Installing collected packages: protobuf, crcmod, hoymiles-wifi
      Successfully installed crcmod-1.7 hoymiles-wifi-0.2.2 protobuf-5.27.2
      pi@rpi:/media/nas $ python3 app.py
      Traceback (most recent call last):
        File "/media/nas/app.py", line 93, in <module>
          @app.post("/restartDtu/<hostname>")
      AttributeError: 'Flask' object has no attribute 'post'
      pi@rpi:/media/nas $ sudo docker build --tag hoymiles-web-api .
      [+] Building 0.5s (1/1) FINISHED        docker:default
       => [internal] load build definition from Dockerfile        0.3s
       => => transferring dockerfile: 2B        0.0s
      ERROR: failed to solve: failed to read dockerfile: open Dockerfile: no such file or directory
      pi@rpi:/media/nas $ sudo docker run -d -p 5000:5000 --name hoymiles-web-api hoymiles-web-api
      Unable to find image 'hoymiles-web-api:latest' locally
      docker: Error response from daemon: pull access denied for hoymiles-web-api, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
        Thomas Braun Most Active @Michael 6 last edited by
        @michael-6 sagte in Hoymiles hms-800w-2t:
        Bitte pip nie mittels sudo aufrufen.
          Michael 6 @Thomas Braun last edited by
          Klar, hast ja recht.
            Beowolf last edited by
            HMS-800W-2T
            Ich sehe das doch jetzt richitg, der HMS-800-2T wird doch jetzt unterstützt, richtig?
            Hier ist er doch aufgeführt.
            https://github.com/tbnobody/OpenDTU
            Manfred
            • Samson71
              Samson71 Global Moderator @Beowolf last edited by
              @beowolf sagte in Hoymiles hms-800w-2t:
              HMS-800W-2T
              VS
              Der HMS-800-2T ja, aber nicht der HMS-800W-2T
              Das "W" macht den Unterschied.
              • Dicken
                Dicken last edited by
                Hab ebenfalls den HMS-800W-2T und hab mir einfach ne Strommesssteckdose dazwischen gesetzt. So bin ich auch nicht von der Cloud abhängig und bekomm Live-Werte.
                  Michael 6 @Dicken last edited by
                  @dicken Das war auch mein erster Ansatz. Nur hat der Shelly IN der Garage schlechtes WLAN (50%) bricht weg. Alternativ müsste ich per PowerLine LAN in die Garage verlegen oder funktechnisch auf andere Produkte ausweichen wie FRITZ!DECT 210 oder Homematic HmIP-PSM-2 oder Powerline.
                  https://github.com/suaveolent/hoymiles-wifi läuft bei mir, zu EDA-Kosten. Also dachte ich am WE könnte ich über MQTT Datenpunkte schnell in den ioBroker bekommen - und später bei Bedarf neue Plugs nachrüsten...
                  Dicken bilberry 2 Replies Last reply Reply Quote 0
                  • Dicken
                    Dicken @Michael 6 last edited by
                    @michael-6 also ich hab ne HmIP-PSM-2 dazwischen.
                    • bilberry
                      bilberry @Michael 6 last edited by
                      @michael-6 , @hosssa
                      Ich finde Euren Weg über eine API deutlich eleganter als noch ein Gerät dazwischen zu schalten (auch wenn das derzeit die pragmatische und unkomplizierteste Lösung ist).
                      Mir (und vielen ander Usern vielleicht auch) ist aber noch nicht ganz klar, wie ihr vorgegangnen seid. Könnt ihr das hier mal bitte mit ein paar Stichpunkten skizzieren? Welches Setup ist erforderlich? Welche speziellen Voraussetzungen müssen ggf. geschaffen werden? Über welchen Weg wird mit der HMS kommuniziert (WLAN, Cloud, DTU-AP?) Wie kommen die Daten am einfachsten in den iobroker?
                        Michael 6 @bilberry last edited by Michael 6
                        @bilberry per LAN und Kommandozeile bisher (https://github.com/suaveolent/hoymiles-wifi).
                        Da siehst du sogar im Klartext die Passwörter von WLAN und AccessPoint.
                        Ich will etwas basteln um die Textausgabe in Datenpunkte zu bekommen, vielleicht hilt ChatGPT dabei...
                          Der hier folgende Teil zum Adapter wurde nach https://forum.iobroker.net/post/1182973 verschoben.
                          Bitte dort weitermachen
                          balkonkraftwerk hoymiles
                          14
                          27
                          19821
